    4. Dieser Adapter benötigt den vis- oder vis-2-Adapter
      PPB1308 @Homoran last edited by
      ja
        Homoran Global Moderator Administrators @PPB1308 last edited by
        @ppb1308 dann versuch es erst mal mit iob upload all
          @homoran said in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
          ok, das hat nun fast alles upgedatet, aber das eine Vis Widget bleibt ohne Update und zeigt immer noch die Meldung im Debug "INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-justgage/www" was not found! Nothing was uploaded or deleted.":
          das Log zum Update Versuch:
          $ iobroker upgrade vis-justgage@2.1.7 --debug
          Update vis-justgage from @1.0.2 to @2.1.7
          NPM version: 10.7.0
          Installing iobroker.vis-justgage@2.1.7... (System call)
          npm warn ERESOLVE overriding peer dependencynpm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
          npm warn deprecated left-pad@1.3.0: use String.prototype.padStart()
          npm warn deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
          npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
          removed 2 packages, and changed 1 package in 11s
          Adapter "system.adapter.vis.0" restarted.
          Adapter "system.adapter.vis-2.0" restarted.
          Update "system.adapter.vis-justgage.0"
          upload [2] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
          upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index_m.html index_m.html text/html
          upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
          Process exited with code 0
          Das Verzeichnis gibts auch nicht:
          peter@briioBrProx:/opt/iobroker$ ls -lah /opt/iobroker/node_modules/iobroker.vis-justgage
          total 124K
          drwxrwxr-x+    5 iobroker iobroker 4.0K May 31 10:54 .
          drwxrwxr-x+ 1215 iobroker iobroker  68K May 31 10:54 ..
          -rw-rw-r--+    1 iobroker iobroker 1.2K May 31 10:54 LICENSE
          -rw-rw-r--+    1 iobroker iobroker 5.9K May 31 10:54 README.md
          drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 10:54 admin
          drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 10:54 img
          -rw-rw-r--+    1 iobroker iobroker  14K May 31 10:54 io-package.json
          -rw-rw-r--+    1 iobroker iobroker    1 May 31 10:54 iob_npm.done
          -rw-rw-r--+    1 iobroker iobroker 2.5K May 31 10:54 package.json
          drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 10:54 widgets
          Qix- created this issue in visionmedia/debug
          closed ReDos Vulnerability Regression Visibility Notice #797
          Homoran P 2 Replies Last reply Reply Quote 0
            @ppb1308 sagte in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
            wR das die defekte Version?
              PPB1308 @PPB1308 last edited by
              Update scheint aber nun geklappt zu haben, das Widget wird nicht mehr als ncht aktuell gelistet.
              Hm, sehr merkwürdig.
                PPB1308 @Homoran last edited by PPB1308
                Hm, kann ich nicht sagen, den Core Adapter hab ich gar nicht im Visier gehabt, nur die Vis Widgets, die sich nicht updaten ließen.
                Das scheint ja nach dem update all wohl behoben.
                Muss ich mir um das vermeintlich fehlende Verzeichnis Sorgen machen?
                Danke für die Hilfe!
                  den Core Adapter
                  das ist kein Adapter, aber die defekte Version war es anscheinend nicht
                  Vielleicht weiss @Thomas-Braun das noch besser
                    @homoran @PPB1308
                    Keine Ahnung.
                    Aber bring alle Adapter auf Stand oder geh auf das Stable-Repository.
                      PPB1308 @Thomas Braun last edited by
                      ja, hab ich ja jetzt gemacht.
                      Danke.
                      • mcm1957
                        mcm1957 last edited by
                        @ppb1308
                        Sodala
                        adapter-core 3.1.4 ist die aktuellste und empfohlene Version
                        vis-justgage hat kein www Verzeichnis. Keine Ahnung woher die Fehlermeldung kommt. vis-justgage ist m.W. nach nicht mit vis-2 kompatibel
                        vis-map gibt diese Meldung via admin news aus. Die Funktion ist durch diese Meldung in keiner Weise beeinflusst. Wenn das Widget funktioniert sollte also alles OK sein. Bitte eröffne ggF ein Issue im adapter repo.
                        1318
