    4. Unifi Steuern ohne Adapter (Script,SSH)
      liv-in-sky @kmxak last edited by liv-in-sky
      @kmxak
      bei mir sieht der teil jetzt so aus - oben das setting habe ich weggelassen
      //const unifi = new Unifi.Controller({ hostname: config.hostname, port: config.port, sslverify: config.sslverify });
      // Erstelle die benötigten Datenpunkte für die Voucher-Konfiguration
      createState("0_userdata.0.Unifi.Voucher.config.minutes", 123, { type: 'number', name: 'minutes', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.config.count", 1, { type: 'number', name: 'count', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.config.quota", 0, { type: 'number', name: 'quota', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.config.note", "testthis", { type: 'string', name: 'note', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.config.up", null, { type: 'number', name: 'up', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.config.down", null, { type: 'number', name: 'down', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.config.megabytes", null, { type: 'number', name: 'megabytes', read: true, write: true });
      // Erstelle die benötigten Datenpunkte für die Voucher-Daten
      createState("0_userdata.0.Unifi.Voucher.data.latestJson", "{}", { type: 'string', name: 'latestJson', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.code", "", { type: 'string', name: 'code', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.duration", 0, { type: 'number', name: 'duration', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.qos_overwrite", false, { type: 'boolean', name: 'qos_overwrite', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.note", "", { type: 'string', name: 'note', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.for_hotspot", false, { type: 'boolean', name: 'for_hotspot', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.create_time", 0, { type: 'number', name: 'create_time', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.quota", 0, { type: 'number', name: 'quota', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.site_id", "", { type: 'string', name: 'site_id', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.admin_name", "", { type: 'string', name: 'admin_name', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.used", 0, { type: 'number', name: 'used', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.status", "", { type: 'string', name: 'status', read: true, write: true });
      createState("0_userdata.0.Unifi.Voucher.data.status_expires", 0, { type: 'number', name: 'status_expires', read: true, write: true });
      // Erstelle den Datenpunkt für den Trigger
      createState("0_userdata.0.Unifi.Voucher.trigger", false, { type: 'boolean', name: 'trigger', read: true, write: true });
      let lastVoucherCreateTime = 0; // Speichert die create_time des letzten erstellten Vouchers
      // Reagiere auf Änderungen des Datenpunkts "trigger"
      on({ id: '0_userdata.0.Unifi.Voucher.trigger', change: 'ne', val: true }, async (obj) => {
          console.log('Trigger-Datenpunkt geändert: ' + obj.state.val);
       console.log('Versuche, mich bei UniFi anzumelden...');
      await unifi.login(config.username, config.password)
          .then(loginData => {
              console.log('Login erfolgreich: ' + JSON.stringify(loginData));
          .catch(error => {
              console.log('ERROR: ' + error);
          try {
              // Lese die Konfigurationswerte aus den Datenpunkten
              const minutes = 12223//getState("0_userdata.0.Unifi.Voucher.config.minutes").val;
              const count = 1//getState("0_userdata.0.Unifi.Voucher.config.count").val;
              const quota = null//getState("0_userdata.0.Unifi.Voucher.config.quota").val;
              const note = "newnewnew"// getState("0_userdata.0.Unifi.Voucher.config.note").val;
              const up = null//getState("0_userdata.0.Unifi.Voucher.config.up").val;
              const down = null//getState("0_userdata.0.Unifi.Voucher.config.down").val;
              const megabytes = null //getState("0_userdata.0.Unifi.Voucher.config.megabytes").val;
              // Erzeuge einen neuen Voucher
              console.log('Trigger aktiviert, erstelle neuen Voucher...');
              const clientVoucher = await unifi.createVouchers(
                  minutes,
                  count,
                  quota,
                  note,
                  up,
                  down,
                  megabytes
              ).catch(error => {
                  console.log('Fehler beim Anlegen: ' + error);rausHier();setState('0_userdata.0.Unifi.Voucher.trigger', false);
              console.log('Voucher erstellt: ' + JSON.stringify(clientVoucher));
              // Erfasse die create_time des erstellten Vouchers
              const newVoucherCreateTime = clientVoucher[0].create_time;
              // Hole nur den neuesten Voucher basierend auf create_time
              console.log('Hole den neuesten Voucher...');
              const myVoucher = await unifi.getVouchers(newVoucherCreateTime);
              console.log("Neuester Voucher: " + JSON.stringify(myVoucher));
              rausHier();
              // Schreibe die Voucher-Daten in den Datenpunkt "latestJson"
              console.log('Schreibe Voucher-Daten in den Datenpunkt "latestJson"...');
              setState('0_userdata.0.Unifi.Voucher.data.latestJson', JSON.stringify(myVoucher));
              // Extrahiere die Werte aus dem Voucher-Objekt und setze die Datenpunkte
              const voucher = myVoucher[0];
              setState('0_userdata.0.Unifi.Voucher.data.code', voucher.code);
              setState('0_userdata.0.Unifi.Voucher.data.duration', voucher.duration);
              setState('0_userdata.0.Unifi.Voucher.data.qos_overwrite', voucher.qos_overwrite);
              setState('0_userdata.0.Unifi.Voucher.data.note', voucher.note);
              setState('0_userdata.0.Unifi.Voucher.data.for_hotspot', voucher.for_hotspot);
              setState('0_userdata.0.Unifi.Voucher.data.create_time', voucher.create_time);
              setState('0_userdata.0.Unifi.Voucher.data.quota', voucher.quota);
              setState('0_userdata.0.Unifi.Voucher.data.site_id', voucher.site_id);
              setState('0_userdata.0.Unifi.Voucher.data.admin_name', voucher.admin_name);
              setState('0_userdata.0.Unifi.Voucher.data.used', voucher.used);
              setState('0_userdata.0.Unifi.Voucher.data.status', voucher.status);
              setState('0_userdata.0.Unifi.Voucher.data.status_expires', voucher.status_expires);
              // Setze den Trigger wieder auf false
              console.log('Setze den Trigger wieder auf false...');
          } catch (error) {
      async function rausHier() {
          console.log('Logout bei UniFi...');
         await unifi.logout()
              .then(() => {
                  console.log('Logout erfolgreich.');
              .catch(error => {
                  console.log('Fehler beim Logout: ' + error);
      VORSICHT - habe Konfigurationswerte geändert - zeile 49 ff
      kmxak 1 Reply Last reply Reply Quote 0
        liv-in-sky @draexler last edited by
        @draexler
        genial 🙂
        habe diese teile auch schon mal angesehen - aber die gibt es doch momentan nicht günstig zu kaufen?
        wie @kmxak schon sagte - die id muss mit gespeichert werden- bei nur einem voucher ist das dann nicht so wild
        ich überlege mir was und poste dann
        draexler 1 Reply Last reply Reply Quote 0
        • draexler
          draexler @liv-in-sky last edited by
          @liv-in-sky Schön, wenns dir gefällt 😉 Die Dame des Hauses findet es übertrieben 😉
          Also von den Preisen geht es. Sind lauter Waveshare Komponenten. Das Universal e-Paper Raw Panel Driver Board aktuell 19 Euro und das Waveshare 2.13 Inch E-Paper Raw Display 18 Euro. Der Button ist ein ein ein euro Artikel und das Gehäuse mit dem 3D Drucker selbst gedruckt. Das wars schon.
          Das ganze läuft mit den ESPHOME Adapter auf dem ioBroker.
          Aber auf jeden Fall danke das du dir wegen dem löschen Gedanken machst. Habe gerade auch gesehen das die ID ja nicht gleich dem Voucher Code ist.
          ? liv-in-sky 2 Replies Last reply Reply Quote 0
            A Former User @draexler last edited by
            @draexler Find ich auch Klasse, was du da gemacht hast!
            Dachte du hast das mit openEpaper gemacht.. aber so gehts auch!
              liv-in-sky @draexler last edited by liv-in-sky
              @draexler
              zum ersten test (von @kmxak geklaut 🙂 )
              const Unifi = require('node-unifi');
              let triggerDP="0_userdata.0.Unifi.Voucher.trigger";
              let deleteSchedule="0 6 * * *"
              // Konfiguration
              const config = {
                 hostname: "192.168.178.xx",
                 port: '8443', // 443 UDM Pro, 8443 für andere Controller
                 username: 'x',
                 password: 'xx',
                 sslverify: false
              createState("0_userdata.0.Unifi.Voucher.data._id", "", { type: 'string', name: 'code', read: true, write: true });
              on({ id: triggerDP, change: 'ne', val: true }, async (obj) => {
                 .catch(error => {
                 try {
                     const note = "newne222wnew"// getState("0_userdata.0.Unifi.Voucher.config.note").val;
                         minutes,
                         count,
                         quota,
                         note,
                         up,
                         down,
                         megabytes
                     ).catch(async error => {
                         console.log('Fehler beim Anlegen: ' + error);console.log('Logout bei UniFi...');
                          await unifi.logout().then(() => {console.log('Logout erfolgreich.');  }).catch(error => {console.log('Fehler beim Logout: ' + error); });
                         setState(triggerDP, false);
                    console.log('Logout bei UniFi...'); await unifi.logout().then(() => {console.log('Logout erfolgreich.');  }).catch(error => {console.log('Fehler beim Logout: ' + error); });
                     let val0=myVoucher[0].code;
                     setState("0_userdata.0.Unifi.Voucher.data.code",val0.slice(0,5)+"-"+val0.slice(5))
                     setState('0_userdata.0.Unifi.Voucher.data._id', myVoucher[0]._id);         // Extrahiere die Werte aus dem Voucher-Objekt und setze die Datenpunkte
                 } catch (error) {
              // LÖSCHEN MORGENS VOUCHER
              schedule(deleteSchedule, async () => {
              const unifi = new Unifi.Controller({hostname:"192.168.168.176",port:'8443', sslverify: false});
                 .catch(error => {
              //const clientVoucher = await unifi.createVouchers(800,1,5,"testthis");
              const clientDelVoucher = await unifi.revokeVoucher(getState("0_userdata.0.Unifi.Voucher.data._id").val);
              console.log("vouchers: "+ JSON.stringify(clientDelVoucher))
                // LOGOUT
              zu tun:
              • user, pass, port, ip eingeben
              • zeile 4: id deines trigger datenpunktes
              • zeile 5 dein schedule, wann gelöscht werden soll
              • ab zeile 36 deine voucherdaten definieren
              teste kannst man durch das schedule
              • kmxak
                kmxak Most Active @liv-in-sky last edited by kmxak
                @liv-in-sky sagte in Adapter: ioBroker.unifi:
                @kmxak
                    .catch(error => {
                    try {
                            minutes,
                            count,
                            quota,
                            note,
                            up,
                            down,
                            megabytes
                        ).catch(error => {
                        rausHier();
                    } catch (error) {
                        .then(() => {
                        .catch(error => {
                mh es klappt. was hast du denn nun geändert? das logout hatte ich auch schon mal extern ausgeführt allerdings ohne das const unifi....
                muss meins nochmal überarbeiten
                  @kmxak
                  denke das verschieben war es:
                  und das await vor login und logout sollte auch wichtig sein
                  • kmxak
                    @liv-in-sky
                    jo möglich. bei mir läuft es nun. habs mal auf github geladen: https://github.com/vr6syncro/ioBroker-Unifi-Voucher-Script
                      @kmxak
                      in diesem script habe ich noch was geändert https://forum.iobroker.net/post/1165701
                      das rausHier() habe ich wieder reingenommen - außerhalb von on(..) ist unifi.logout nicht wirklich definiert - funktioniert zwar - aber stimmt irgendwie nicht
                      vielleicht magst du es anpassen
                      kmxak 1 Reply Last reply Reply Quote 1
                      • kmxak
                        @liv-in-sky so ist aktualisiert
                        Feuersturm 1 Reply Last reply Reply Quote 2
                        • Feuersturm
                          Feuersturm @kmxak last edited by
                          @kmxak Ich versuche gerade dein Skript in Betrieb zu nehmen.
                          Das hier hab ich gemacht:
                          node-unifi Paket installiert im Javascript Adapter
                          Muss ich für diesen Schritt UniFi Controller mit API-Zugriff sowie ein Wifi Operator Account noch etwas im Unifi Controller aktivieren? Was ist der Wifi Operator Account?
                          Wenn ich das Skript starte kommt folgendes im Log:
                          javascript.0
                          	2024-06-01 22:52:52.807	error	script.js.Skripte.Netzwerk.Unifi_vouchers_generieren: ERROR: TypeError: Cannot read properties of undefined (reading '0')
                          javascript.0
                          	2024-06-01 22:52:52.803	error	script.js.Skripte.Netzwerk.Unifi_vouchers_generieren: Fehler beim Logout: Error: getaddrinfo ENOTFOUND unifi
                          javascript.0
                          	2024-06-01 22:52:52.689	error	script.js.Skripte.Netzwerk.Unifi_vouchers_generieren: ERROR: Error: getaddrinfo ENOTFOUND unifi
                          javascript.0
                          	2024-06-01 22:52:44.165	info	script.js.Skripte.Netzwerk.Unifi_vouchers_generieren: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          javascript.0
                          	2024-06-01 22:52:44.116	info	Start JavaScript script.js.Skripte.Netzwerk.Unifi_vouchers_generieren (Javascript/js)
                          A liv-in-sky 2 Replies Last reply Reply Quote 0
                            Adnim @Feuersturm last edited by Adnim
                            @feuersturm sagte in Adapter: ioBroker.unifi:
                            den kann man unter Administratoren anlegen im Unifi Portal .
                            Es kommt aber bei meinem Versuch hier die gleichen Fehlermeldungen wie bei dir.
                              liv-in-sky @Feuersturm last edited by
                              @feuersturm hast du dir die neuste version von github runtergeladen ?
                              • Feuersturm
                                Feuersturm @liv-in-sky last edited by
                                @liv-in-sky ja ich hab gestern Abend den v03 Stand von GitHub verwendet.
                                Den Hotspot Manager hatte ich auch noch gefunden und auch angelegt aber der Fehler bleibt.
                                  @feuersturm
                                  poste bitte das ganze log vom script - kopiert von der admin-log-seite
                                    Adnim @liv-in-sky last edited by
                                    @liv-in-sky
                                    mehr log gibt es bei mir da nicht
                                      liv-in-sky @Adnim last edited by
                                      @adnim
                                      bei mir sieht das so aus
                                      javascript.0
                                      2024-06-02 07:30:18.729	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Logout erfolgreich.
                                      javascript.0
                                      2024-06-02 07:30:18.680	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Logout bei UniFi...
                                      javascript.0
                                      2024-06-02 07:30:18.680	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Neuester Voucher: [{"duration":12223,"qos_overwrite":false,"note":"newne222wnew","code":"3709308106","for_hotspot":false,"create_time":1717306218,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"665c036aa29b27114a1acdf3","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":123,"qos_overwrite":false,"note":"testthis","code":"8764054636","for_hotspot":false,"create_time":1717306218,"quota":0,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"665c036aa29b27114a1acdf1","admin_name":"e","used":0,"status":"VALID_MULTI","status_expires":0}]
                                      javascript.0
                                      2024-06-02 07:30:18.652	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Hole den neuesten Voucher...
                                      javascript.0
                                      2024-06-02 07:30:18.652	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Voucher erstellt: [{"create_time":1717306218}]
                                      javascript.0
                                      2024-06-02 07:30:18.630	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Trigger aktiviert, erstelle neuen Voucher...
                                      javascript.0
                                      2024-06-02 07:30:18.630	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Login erfolgreich: true
                                      javascript.0
                                      2024-06-02 07:30:18.288	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Versuche, mich bei UniFi anzumelden...
                                      javascript.0
                                      2024-06-02 07:30:18.288	info	script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten-draexler: Trigger-Datenpunkt geändert: true
                                        @adnim schon mal die javascript instanz neugestartet
                                          Adnim @liv-in-sky last edited by Adnim
                                          @liv-in-sky
                                          ja habe ich und auch die info gesehen das "node-unifi" installiert wird.
                                          javascript.0
                                          2024-06-02 08:16:31.172	error	script.js.common.unifivoucher: ERROR: TypeError: Cannot read properties of undefined (reading '0')
                                          javascript.0
                                          2024-06-02 08:16:31.172	error	script.js.common.unifivoucher: Fehler beim Logout: Error: getaddrinfo ENOTFOUND unifi
                                          javascript.0
                                          2024-06-02 08:16:31.149	error	script.js.common.unifivoucher: ERROR: Error: getaddrinfo ENOTFOUND unifi
                                          admin.0
                                          2024-06-02 08:16:22.436	info	<== Disconnect system.user.admin from 192.165.175.19 javascript
                                          javascript.0
                                          2024-06-02 08:16:17.914	info	script.js.common.unifivoucher: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                            @adnim poste mal dein script
                                            152
                                            25068
