    4. JavaScript
    5. Plötzlich ReferenceError: request is not defined
      TT-Tom @kptkip last edited by
      @kptkip
      Wenn jetzt kein anderer User schneller ist, sehe ich mir das heute Abend an.
        @kptkip
        hier mal zum Testen und bitte ggf bei Fehler das Log posten.
        //Get Token from Tibber
        const LoginUri = 'https://app.tibber.com/login.credentials';
        const uri = 'https://app.tibber.com/v4/gql?query={me{homes{electricVehicles{lastSeen%0A%20 battery{percent}}}}}';
        let output = '1';
        let TokenFromLogin = '';
        const params = {
            '@type': 'login',
            email: [EMAIL],
            password: [PASSWD],
        //Using the request.post function to send a POST request with JSON data
        httpPost(LoginUri, { params }, (error, response) => {
            if (error) {
                log(error, 'error');
            } else {
                log(response.statusCode);
                log(response.data);
                TokenFromLogin = response.data;
                //Request Battery Status
                //Using the request.post function to send a POST request with a Bearer token
                httpPost(uri, { headers: { Authorization: 'Bearer ' + TokenFromLogin } }, (error, response) => {
                    if (!error) {
                        log(response.data);
                        log(response.headers);
                        output = response.data;
                        setState('0_userdata.0.Polestar.Tibber_Response', output);
                    } else {
        K 1 Reply Last reply Reply Quote 2
          kptkip @TT-Tom last edited by kptkip
          Hey @tt-tom !
          Sorry, Update, es klappt doch nicht. war zu schnell.
          Hier das log:
          script.js.Strom_und_PV.Tibber_Polestar_SOC: 400
          javascript.0	20:16:00.186	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"error":"To login you need to type in both your email and your password."}
          javascript.0	20:16:00.359	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: 400
          javascript.0	20:16:00.359	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"errors":[{"message":"GraphQL operations must contain a non-empty `query` or a `persistedQuery` extension.","extensions":{"code":"INTERNAL_SERVER_ERROR","exception":{"stacktrace":["GraphQLError: GraphQL operations must contain a non-empty `query` or a `persistedQuery` extension."," at processGraphQLRequest (/app/node_modules/apollo-server-core/dist/requestPipeline.js:73:40)"," at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"," at async processHTTPRequest (/app/node_modules/apollo-server-core/dist/runHttpQuery.js:222:30)"]}}}]}
          javascript.0	20:16:00.360	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: Object [AxiosHeaders] { date: 'Sat, 01 Jun 2024 18:16:09 GMT', 'content-type': 'application/json; charset=utf-8', 'content-length': '573', connection: 'close', 'x-powered-by': 'Express', 'access-control-allow-origin': '*', etag: 'W/"23d-S8aiZRFOGuFbW0vwnvg3M2ft9pA"', vary: 'Accept-Encoding' }
          Kann es sein, dass der Aufruf hier:
          das JSON-Objekt nicht kenntlich macht. Also, dass die API das nicht auseinander sortiert?
          Im Originalscript wird das mit json: params angegeben. Oder sollen die geschweiften Klammern das machen?
          • haus-automatisierung
            haus-automatisierung Developer Most Active @kptkip last edited by
            @kptkip Params ist schon ein Objekt. Also nicht nochmal in ein Objekt wrappen:
            // Get Token from Tibber
            const loginUri = 'https://app.tibber.com/login.credentials';
            let output = '1';
            let tokenFromLogin = '';
            const postData = {
                '@type': 'login',
                email: [EMAIL],
                password: [PASSWD],
            // Using the request.post function to send a POST request with JSON data
            httpPost(loginUri, postData, (error, response) => {
                if (error) {
                } else {
                    log(response.data);
                    tokenFromLogin = response.data;
                    // Request Battery Status
                    // Using the request.post function to send a POST request with a Bearer token
                    httpPost(uri, { bearerAuth: tokenFromLogin }, (error, response) => {
                        if (!error) {
                            log(response.data);
                        } else {
            T K 2 Replies Last reply Reply Quote 2
              TT-Tom @haus-automatisierung last edited by
              ja, da war ich etwas überfragt, ob mit Klammern oder ohne. Danke für die Hilfe. 👍
                kptkip @haus-automatisierung last edited by kptkip
                Der erste call klappt nun. Danke! 🙂
                Ich denke beim zweiten, bei dem die Daten abgeholt werden gibts noch ein Problem:
                javascript.0	09:02:00.246	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: 200
                javascript.0	09:02:00.246	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"token":"SuperToken"}
                javascript.0	09:02:00.477	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: 400
                javascript.0	09:02:00.477	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"errors":[{"message":"GraphQL operations must contain a non-empty `query` or a `persistedQuery` extension.","extensions":{"code":"INTERNAL_SERVER_ERROR","exception":{"stacktrace":["GraphQLError: GraphQL operations must contain a non-empty `query` or a `persistedQuery` extension."," at processGraphQLRequest (/app/node_modules/apollo-server-core/dist/requestPipeline.js:73:40)"," at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"," at async processHTTPRequest (/app/node_modules/apollo-server-core/dist/runHttpQuery.js:222:30)"]}}}]}
                javascript.0	09:02:00.477	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: Object [AxiosHeaders] { date: 'Sun, 02 Jun 2024 07:02:10 GMT', 'content-type': 'application/json; charset=utf-8', 'content-length': '573', connection: 'close', 'x-powered-by': 'Express', 'access-control-allow-origin': '*', etag: 'W/"23d-S8aiZRFOGuFbW0vwnvg3M2ft9pA"', vary: 'Accept-Encoding' }
                Es scheinen noch nicht alle Daten übermittelt zu werden, wenn ich das richtig verstehe:
                "must contain a non-empty 'query'"
                  @kptkip
                  im Original steht
                  headers: {
                                'Authorization': 'Bearer ' + Token
                  da wird das Wort Bearer vor den Token gesetzt mit einem Leerzeichen.
                  ändere mal diese Zeile
                  in diese um
                  tokenFromLogin = 'Bearer ' + response.data;
                  Wenn dies auch wieder zu Fehler führt wäre das nochmal ein Versuch
                              if (!error) {
                                  log(response.data);
                              } else {
                  dann bin ich aber auch mit mein Latein am Ende.
                    kptkip last edited by kptkip
                    Klappt auch nicht.
                    Nachdem ich trotz Google nichts passendes gefunden habe, gehe ich als Hypothese davon aus, dass:
                    genau den Authentifizierungs-Mechanismus per "Bearer" auslösen soll.
                    Was mich bei der Fehlermeldung irritiert, ist die Meldung, dass Inhalte leer wären. Im Prinzip muss die URL (habs im Browser getestet - im eingeloggten Zustand) nur abgesetzt werden und im Header der Token mitgegeben werden. Frage mich, wo er noch Inhalte haben möchte?
                    BTW: Wenn ich nach "Javascript" und "httpPost()" google, finde ich keine vernünftige Erläuterung oder Doku. Zumindest nicht, wie das hier verwendet wird.
                    Das Einzige als Treffer sind dann Anleitungen und Dokus zum Befehl "fetch()" (klappt hier auch nur mit explizitem require('fetch') und nicht freiweg ) oder zu axios. Vlt. bin ich aber auch nicht schlau genug, zum Suchen.
                    haus-automatisierung T 2 Replies Last reply Reply Quote 0
                      haus-automatisierung Developer Most Active @kptkip last edited by haus-automatisierung
                      @kptkip sagte in Plötzlich ReferenceError: request is not defined:
                      Das ist ja auch ioBroker spezifisch und ein Wrapper für axios in der JavaScript-Sandbox. Damit wir in Zukunft die darunter liegende Library austauschen können, und trotzdem alles weiter funktioniert. Demnach auch nur hier dokumentiert:
                      https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#httpget
                      EDIT: Ich sehe gerade, dass der zweite Aufruf ja auch ein httpPost ist. Dann müssen natürlich die Daten mitgegeben werden. Sicher, dass das ein Post-Request sein muss (wozu? Da werden ja Get-Parameter genutzt für den Query). Teste mal so:
                      let output = '1';
                      const postData = {
                          '@type': 'login',
                          email: [EMAIL],
                          password: [PASSWD],
                          if (error) {
                          } else {
                              log(response.data);
                              httpPost(uri, {}, { bearerAuth: tokenFromLogin }, (error, response) => {
                                  if (!error) {
                                      log(response.data);
                                  } else {
                      Alternativ den Query per Post senden:
                      const uri = 'https://app.tibber.com/v4/gql';
                      let output = '1';
                      const postData = {
                          '@type': 'login',
                          email: [EMAIL],
                          password: [PASSWD],
                          if (error) {
                          } else {
                              log(response.data);
                              httpPost(uri, { query: '{me{homes{electricVehicles{lastSeen%0A%20 battery{percent}}}}}' }, { bearerAuth: tokenFromLogin }, (error, response) => {
                                  if (!error) {
                                      log(response.data);
                                  } else {
                        TT-Tom @kptkip last edited by TT-Tom
                        Das habe ich in der Doku auch so gefunden, was mir nicht klar ist/war, das Wort Bearer wird das jetzt automatisch vor den Token gesetzt? @haus-automatisierung Denn in deinem Original-Script war es zusätzlich zum Token angehängt.
                          @haus-automatisierung said in Plötzlich ReferenceError: request is not defined:
                          Danke für den hint mit dem Wrapper und den Link 😉
                          Das mit dem Hinweis auf GET ist ein guter, da tatsächlich keine Daten (abgesehen vom Header) übermittelt werden. Das macht Sinn.
                          Allerdings klappt es noch nicht. Hier mal die Ergebnisse (POST und GET):
                          Mit POST:
                          ergibt folgende Fehler:
                          javascript.0	11:37:00.464	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: 401
                          javascript.0	11:37:00.465	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"errors":"Not authenticated. Login at: https://app.tibber.com/login"}
                          javascript.0	11:37:00.465	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: Object [AxiosHeaders] { date: 'Sun, 02 Jun 2024 09:37:10 GMT', 'content-type': 'application/json; charset=utf-8', 'content-length': '71', connection: 'close', 'x-powered-by': 'Express', 'access-control-allow-origin': '*', etag: 'W/"47-pLydXmqqqWtGzFFyAjprzeLl/Aw"', vary: 'Accept-Encoding' }
                          Per GET mit:
                          httpGet(uri, { bearerAuth: tokenFromLogin }, (error, response) => {
                          oder:
                          httpGet(uri, { headers: { Authorization: 'Bearer ' + tokenFromLogin } }, (error, response) => {
                          liefert er:
                          javascript.0	11:34:00.343	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: 401
                          javascript.0	11:34:00.343	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"errors":"Not authenticated. Login at: https://app.tibber.com/login"}
                          javascript.0	11:34:00.343	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: Object [AxiosHeaders] { date: 'Sun, 02 Jun 2024 09:34:10 GMT', 'content-type': 'application/json; charset=utf-8', 'content-length': '71', connection: 'close', 'x-powered-by': 'Express', 'access-control-allow-origin': '*', etag: 'W/"47-pLydXmqqqWtGzFFyAjprzeLl/Aw"', vary: 'Accept-Encoding' }
                          Die zusätzliche Query-Variante ist ganz wuschig:
                          Das ergibt folgende Fehler:
                          javascript.0	11:30:00.403	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: 400
                          javascript.0	11:30:00.403	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"errors":[{"message":"Syntax Error: Unexpected character: \"%\".","extensions":{"code":"GRAPHQL_PARSE_FAILED","exception":{"stacktrace":["GraphQLError: Syntax Error: Unexpected character: \"%\"."," at syntaxError (/app/node_modules/graphql/error/syntaxError.js:15:10)"," at readNextToken (/app/node_modules/graphql/language/lexer.js:420:40)"," at Lexer.lookahead (/app/node_modules/graphql/language/lexer.js:84:29)"," at Lexer.advance (/app/node_modules/graphql/language/lexer.js:67:38)"," at Parser.advanceLexer (/app/node_modules/graphql/language/parser.js:1536:31)"," at Parser.expectToken (/app/node_modules/graphql/language/parser.js:1393:12)"," at Parser.parseName (/app/node_modules/graphql/language/parser.js:108:24)"," at Parser.parseField (/app/node_modules/graphql/language/parser.js:347:30)"," at Parser.parseSelection (/app/node_modules/graphql/language/parser.js:337:14)"," at Parser.many (/app/node_modules/graphql/language/parser.js:1511:26)"," at Parser.parseSelectionSet (/app/node_modules/graphql/language/parser.js:320:24)"," at Parser.parseField (/app/node_modules/graphql/language/parser.js:365:16)"," at Parser.parseSelection (/app/node_modules/graphql/language/parser.js:337:14)"," at Parser.many (/app/node_modules/graphql/language/parser.js:1511:26)"," at Parser.parseSelectionSet (/app/node_modules/graphql/language/parser.js:320:24)"," at Parser.parseField (/app/node_modules/graphql/language/parser.js:365:16)"," at Parser.parseSelection (/app/node_modules/graphql/language/parser.js:337:14)"," at Parser.many (/app/node_modules/graphql/language/parser.js:1511:26)"," at Parser.parseSelectionSet (/app/node_modules/graphql/language/parser.js:320:24)"," at Parser.parseField (/app/node_modules/graphql/language/parser.js:365:16)"," at Parser.parseSelection (/app/node_modules/graphql/language/parser.js:337:14)"," at Parser.many (/app/node_modules/graphql/language/parser.js:1511:26)"," at Parser.parseSelectionSet (/app/node_modules/graphql/language/parser.js:320:24)"," at Parser.parseOperationDefinition (/app/node_modules/graphql/language/parser.js:231:28)"," at Parser.parseDefinition (/app/node_modules/graphql/language/parser.js:155:19)"," at Parser.many (/app/node_modules/graphql/language/parser.js:1511:26)"," at Parser.parseDocument (/app/node_modules/graphql/language/parser.js:122:25)"," at parse (/app/node_modules/graphql/language/parser.js:32:17)"," at parse (/app/node_modules/apollo-server-core/dist/requestPipeline.js:181:36)"," at processGraphQLRequest (/app/node_modules/apollo-server-core/dist/requestPipeline.js:90:39)"," at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"," at async processHTTPRequest (/app/node_modules/apollo-server-core/dist/runHttpQuery.js:222:30)"]}}}]}
                          In allen Fällen klappt es mit der Authentifizierung per Bearer-Header nicht wie gewünscht.
                          T haus-automatisierung 2 Replies Last reply Reply Quote 0
                            %0A
                            bedeutet LF -> LineFeed
                            %20 ist das Leerzeichen
                            was ist wenn du die weg lässt
                              @kptkip Sorry, ist recht schwer ohne einen Link auf die API-Doku alles zu raten 🙂 @TT-Tom hat Recht, würde das auch einfach entfernen und testen.
                                Nur zur Vollständigkeit - die Tibber-API ist hier:
                                https://developer.tibber.com/docs/overview
                                Mit der URL hab ich auch schon rumgespielt. Das ändert nichts. Würde mich ehrlich gesagt auch wundern. Die URL hat im Script mit request.post() wunderbar funktioniert. Sogar mit nicht-URL-encodetem Leerzeichen.
                                [EDIT:]
                                Ich habe immer noch die Vermutung, dass die neuen Functions httpPost() und httpGet() im JS-Wrapper die Header-Parameter nicht korrekt durchreichen.
                                Wenn ich mir das hier durchlese:
                                https://developer.salesforce.com/docs/marketing/marketing-cloud-ampscript/references/mc-ampscript-http/mc-ampscript-reference-http-post.html
                                Komm ich zur Überlegung, ob das hier (oder axios) korrekt bedient wird:
                                HttpPost(urlEndpoint,
                                         contentTypeHeader,
                                         contentToPost,
                                         response,
                                         headerName1, headerValue1,
                                         [headerName2, headerValue2...] )
                                Nur mal so als Double-Check: @haus-automatisierung Kannst Du das ausschließen?
                                  Ich glaube, ich habe eine andere Vermutung:
                                  Der Rückgabewert des ersten Befehls ist ein JSON-Objekt
                                  javascript.0	13:37:00.168	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"token":"SuperToken"}
                                  Der zweite Befehl will aber als Auth-Token einen String. Da aber ein JSON-Objekt ankommt, schlägt die Authentifizierung fehl.
                                  Ich hab das Rauslösen des Wertes aus dem Object aber nicht hinbekommen (wurde im alten Script mit var TokenFromLogin = body.token;erledigt).
                                  Vielleicht kann mir da jemand mit mehr JS-Erfahrung auf die Sprünge helfen? 🙂
                                  mcm1957 T 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    mcm1957 @kptkip last edited by Homoran
                                    @kptkip said in Plötzlich ReferenceError: request is not defined:
                                    javascript.0	13:37:00.168	info	script.js.Strom_und_PV.Tibber_Polestar_SOC: {"token":"gibbetnichmehr"}
                                    @kptkip
                                    Falls das Token nicht nur kurzzeitig gültig ist solltest du es hier löschen um Missbrauch zu minimieren.
                                    T K 2 Replies Last reply Reply Quote 0
                                      TT-Tom @mcm1957 last edited by
                                      @mcm1957 dann lösche ihn auch in deinem Zitat 😉
                                        @kptkip
                                        versuche mal das hier
                                        tokenFromLogin = getAttr (response.data, 'token')
                                        log(tokenFromLogin)
                                          kptkip @mcm1957 last edited by
                                          @mcm1957
                                          Danke für den Hinweis. 🙏 Die Tokens sind in meinen Posts gelöscht.
                                            Homoran Global Moderator Administrators @TT-Tom last edited by
                                            @tt-tom sagte in Plötzlich ReferenceError: request is not defined:
                                            erledigt
                                            mcm1957 1 Reply Last reply Reply Quote 2
                                            10499
