    4. [Adapter] cloudfreie Auslesung von Deye-Invertern
      Thomas Braun Most Active @Buster last edited by
      @buster
      Bitte zieh das Fenster deines Terminals breiter, damit die Zeilenumbrüche nicht kaputt gehen. Oder verwende gleich ein besseres Terminal.
        Buster @Thomas Braun last edited by
        so besser 😉
        habe den adapter neu gestartet ......
        2024-05-31 14:08:16.859  - info: host.iobroker instance system.adapter.deyeidc.0 started with pid 17583
        2024-05-31 14:08:18.734  - debug: deyeidc.0 (17583) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-05-31 14:08:18.791  - debug: deyeidc.0 (17583) Objects client ready ... initialize now
        2024-05-31 14:08:18.794  - debug: deyeidc.0 (17583) Objects create System PubSub Client
        2024-05-31 14:08:18.796  - debug: deyeidc.0 (17583) Objects create User PubSub Client
        2024-05-31 14:08:18.863  - debug: deyeidc.0 (17583) Objects client initialize lua scripts
        2024-05-31 14:08:18.874  - debug: deyeidc.0 (17583) Objects connected to redis: 127.0.0.1:9001
        2024-05-31 14:08:18.879  - silly: deyeidc.0 (17583) redis psubscribe cfg.o.system.user.*
        2024-05-31 14:08:18.920  - silly: deyeidc.0 (17583) redis psubscribe cfg.o.enum.*
        2024-05-31 14:08:18.923  - silly: deyeidc.0 (17583) objectDB connected
        2024-05-31 14:08:18.927  - debug: deyeidc.0 (17583) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-05-31 14:08:18.953  - debug: deyeidc.0 (17583) States create System PubSub Client
        2024-05-31 14:08:18.955  - debug: deyeidc.0 (17583) States create User PubSub Client
        2024-05-31 14:08:19.039  - debug: deyeidc.0 (17583) States connected to redis: 127.0.0.1:9000
        2024-05-31 14:08:19.040  - silly: deyeidc.0 (17583) statesDB connected
        2024-05-31 14:08:19.283  - info: deyeidc.0 (17583) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.deyeidc, node: v18.19.0, js-controller: 5.0.17
        2024-05-31 14:08:19.317  - debug: deyeidc.0 (17583) IP address [192.168.0.44] seems to be valid.
        2024-05-31 14:08:19.318  - info: deyeidc.0 (17583) Retrieving data from the inverter will be done every 60 seconds
        2024-05-31 14:08:19.319  - debug: deyeidc.0 (17583) checkUserData is ready
        2024-05-31 14:08:19.320  - debug: deyeidc.0 (17583) try to connect . . .
        2024-05-31 14:08:19.355  - debug: deyeidc.0 (17583) Connected to server
        2024-05-31 14:08:19.361  - silly: deyeidc.0 (17583) States system redis pmessage system.adapter.deyeidc.0.logLevel/system.adapter.deyeidc.0.logLevel:{"val":"silly","ack":true,"ts":1717157299326,"q":0,"from":"system.adapter.deyeidc.0","lc":1717149942276}
        2024-05-31 14:08:29.516  - debug: deyeidc.0 (17583) Connection timeout
        2024-05-31 14:08:29.517  - debug: deyeidc.0 (17583) Connection closed/destroyed
        2024-05-31 14:08:29.519  - debug: deyeidc.0 (17583) Connection closed
        2024-05
          Thomas Braun Most Active @Buster last edited by Thomas Braun
          @buster
          iob nodejs-update 20
          Und der Wechselrichter wohnt unter 192.168.0.44?
          Irgendwie scheint der Adapter da nicht an Land zu kommen.
          Edit: Typos
            jepp der wohnt da ..... kann auch darauf zugreifen und die Konfigoberfläche aufrufen
            ich mach mal das update.....
              Update gemacht.... verhält sich aber immer noch gleich ...
              Schließt die Verbindung nach timeout.....
              ? Rene55 2 Replies Last reply Reply Quote 0
                A Former User @Buster last edited by
                @buster
                hast du auch die richtige Seriennummer ( des Datenloggers, nicht vom Wechselrichter! ) eingetragen, und den richtigen Port ? (8899 wenn unveraendert)
                  Buster @Guest last edited by
                  @ilovegym
                  danke für den Hinweis ...... kaum macht man es richtig....schon geht's .
                  War natürlich die falsche SN Nummer 😉
                  Danke für Eure Hilfe !!!!
                  LG Buster
                  • Rene55
                    Rene55 @Buster last edited by
                    @buster Danke an @ilovegym und @Thomas-Braun, ich hätte das mit der Seriennummer auch stark vermutet.
                    Übrigens, dass die Verbindung nach dem Abrufen der Datenblöcke wieder geschlossen wird ist so richtig - außer, du hast ein externes Relais angeschlossen. Dann bleibt die Verbindung offen, weil das Relais soviel quasselt.
                    Chenda 1 Reply Last reply Reply Quote -1
                    • Chenda
                      Chenda @Rene55 last edited by
                      @rene55
                      Ich konnte IP und SN von einem deye WR eingeben und die Verbindung klappte auf Anhieb. kann ich mehrere deye Wechselrichter auslesen und wenn ja wie funktioniert das? Ich sehe nur Felder für ein Gerät.
                        A Former User @Chenda last edited by
                        @chenda
                        fuer jeden Wechselrichter eine Instanz anlegen, und dort die IP des Wechselrichters und die Seriennummers des Datenloggers eintragen.
                        Funktioniert hier mit 5 Wechselrichtern einwandfrei.
                        Chenda 1 Reply Last reply Reply Quote 1
                        • Chenda
                          Chenda @Guest last edited by
                          @ilovegym
                          Danke für die schnelle Antwort.
                          Wie lege ich eine zweite Instanz an?
                            @chenda
                            Im Tab Adapter bei demjenigen auf das + klicken..
                            Chenda 1 Reply Last reply Reply Quote 0
                            • Chenda
                              @ilovegym
                                kptkip last edited by
                                Gibt es eine Möglichkeit, in der admin-Oberfläche die jeweiligen json-Dateien von github zu importieren? Oder müssen die von Hand eingepflegt werden?
                                • Rene55
                                  Rene55 @kptkip last edited by
                                  @kptkip Dazu kann man die gewünschte .json über den linken Pfeil importieren. Danach natürlich IP-Adresse und Seriennummer neu eintragen._Einstellungen_importieren.png
                                  • Nashra
                                    Hey @Rene55 , wollte die json exportieren, aber das geht nicht d.h. ich klick auf den Button aber nichts passiert.
                                    Wo wird diese Datei abgelegt?
                                    • Rene55
                                      Rene55 @Nashra last edited by
                                      @nashra Von woher wolltest du was exportieren?
                                      Aus dem Adapter? Dann liegt das .json so wie es im Browser eingestellt ist - meist unter 'Downloads'.
                                      • Nashra
                                        Nashra Most Active Forum Testing @Rene55 last edited by
                                        @rene55 sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                                        @Rene55 das ist schon klar, aber es passiert nichts wenn ich auf den Button klicke.
                                        Habe es jetzt bei einigen anderen Adaptern versucht, klappt nicht. Hat also nichts mit
                                        deinem zu tun, sondern scheint ein generelles Problem zu sein.
                                          Homoran Global Moderator Administrators @Nashra last edited by
                                          @nashra sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                                          welche Versionen Controller und admin?
                                          • Nashra
                                            Nashra Most Active Forum Testing @Homoran last edited by Nashra
                                            ups verklickt..
                                            admin 6.13.16
                                            controller 5.0.19
                                            1158
                                            367566
