    • Michael Roling
      Michael Roling Developer @Willi-Wunder last edited by
      @willi-wunder Installiere jetzt noch mal
        Willi-Wunder @Michael Roling last edited by
        @michael-roling
        Fehler kommt noch, vielleicht jetzt mehr Infos hier...
        telegram-menu.0
        	2024-05-31 22:17:54.904	debug	RequestMessageIds: {"6xxxxxxxxx2":[{"id":25219,"time":1717160557964},{"id":25220,"time":1717160924613},{"id":25221,"time":1717161019094},{"id":25222,"time":1717161019188},{"id":25223,"time":1717161024744},{"id":25224,"time":1717161024772},{"id":25225,"time":1717161028058},{"id":25226,"time":1717161028384},{"id":25227,"time":1717161040382},{"id":25228,"time":1717161040591},{"id":25229,"time":1717161052048},{"id":25230,"time":1717161052307},{"id":25231,"time":1717161058782},{"id":25232,"time":1717161058978},{"id":25232,"time":1717161062592},{"id":25233,"time":1717161062807},{"id":25234,"time":1717161118384},{"id":25235,"time":1717161122118},{"id":25236,"time":1717161122200},{"id":25236,"time":1717161127543},{"id":25237,"time":1717161131844},{"id":25238,"time":1717161190844},{"id":25239,"time":1717161190951},{"id":25239,"time":1717161207885},{"id":25240,"time":1717161208060},{"id":25241,"time":1717161212815},{"id":25242,"time":1717161226567},{"id":25243,"time":1717161226674},{"id":25243,"time":1717161234869},{"id":25244,"time":1717161239816},{"id":25243,"time":1717161250052},{"id":25245,"time":1717161254827},{"id":25246,"time":1717161535225},{"id":25247,"time":1717161535238},{"id":25248,"time":1717161537581},{"id":25249,"time":1717161537718},{"id":25250,"time":1717164793978},{"id":25251,"time":1717164812392},{"id":25252,"time":1717164812452},{"id":25253,"time":1717164818177},{"id":25254,"time":1717164818284},{"id":25255,"time":1717164820104},{"id":25256,"time":1717164820244},{"id":25257,"time":1717164823704},{"id":25258,"time":1717164823926},{"id":25258,"time":1717164827143},{"id":25259,"time":1717164831849},{"id":25260,"time":1717164838301},{"id":25261,"time":1717164838359},{"id":25261,"time":1717164841677},{"id":25262,"time":1717164841854},{"id":25263,"time":1717164871523},{"id":25264,"time":1717164871614},{"id":25264,"time":1717164876254},{"id":25265,"time":1717164904534},{"id":25266,"time":1717164909052},{"id":25267,"time":1717164909254},{"id":25267,"time":1717164910937},{"id":25268,"time":1717164934325},{"id":25269,"time":1717164934410},{"id":25269,"time":1717164938598},{"id":25270,"time":1717164938824},{"id":25269,"time":1717164983161},{"id":25271,"time":1717164983496},{"id":25272,"time":1717165530466},{"id":25273,"time":1717185769310},{"id":25274,"time":1717185769493},{"id":25274,"time":1717185773500},{"id":25275,"time":1717185773666},{"id":25276,"time":1717185777929},{"id":25277,"time":1717185788408},{"id":25278,"time":1717185788505},{"id":25279,"time":1717185796109},{"id":25280,"time":1717185796209},{"id":25280,"time":1717185798472},{"id":25281,"time":1717185798657},{"id":25282,"time":1717185830388},{"id":25283,"time":1717185830656},{"id":25283,"time":1717185833540},{"id":25284,"time":1717185872745},{"id":25285,"time":1717186661475},{"id":25286,"time":1717186661591},{"id":25286,"time":1717186670443},{"id":25287,"time":1717186674904}],"1570135773":[{"id":24733,"time":1713536422019},{"id":24735,"time":1713536422315},{"id":24736,"time":1713536422381}]}
        telegram-menu.0
        	2024-05-31 22:17:54.903	debug	Save Message ID
        telegram-menu.0
        	2024-05-31 22:17:54.895	debug	Sent Value to ["{\"6xxxxxxxx2\":25287}"] users!
        telegram-menu.0
        	2024-05-31 22:17:54.801	debug	ParseModeType "Markdown"
        telegram-menu.0
        	2024-05-31 22:17:54.801	debug	chatId : "6xxxxxxxxxx2"
        telegram-menu.0
        	2024-05-31 22:17:54.800	debug	parse_mode : undefined
        telegram-menu.0
        	2024-05-31 22:17:54.800	debug	userListWithChatID : [{"name":"Systemchef","chatID":"6xxxxxxxxx2"},{"name":"Britta","chatID":"1570135773"}]
        telegram-menu.0
        	2024-05-31 22:17:54.800	debug	Instance : "telegram.0"
        telegram-menu.0
        	2024-05-31 22:17:54.800	debug	Send this to : "Systemchef"
        telegram-menu.0
        	2024-05-31 22:17:54.800	debug	Send this Value : "Heizung neuer Zustand: AUS"
        • Michael Roling
          @willi-wunder kommt denn immer noch das -
          W 2 Replies Last reply Reply Quote 0
            @michael-roling
            Nein, das Zeichen kommt jetzt nicht mehr.
            Beim setzen der Heizkurve kommt nun dies.....
            luxtronik1.0
            	2024-05-31 22:21:39.263	info	ack is not set!
            telegram-menu.0
            	2024-05-31 22:21:39.262	debug	Send Value {"id":"luxtronik1.0.control.EndpunktHK","confirm":true,"returnText":"Neuer Endpunkt wurde auf && °C gesetzt","userToSend":"Systemchef"}
            telegram-menu.0
            	2024-05-31 22:21:39.262	debug	State, which is listen to was changed "luxtronik1.0.control.EndpunktHK"
            telegram-menu.0
            	2024-05-31 22:21:39.209	debug	Value to Set: 27
            telegram-menu.0
            	2024-05-31 22:21:39.209	debug	Change Valuetype from : number to number
            telegram-menu.0
            	2024-05-31 22:21:39.208	debug	Sent Value to ["{\"error\":{\"6xxxxxxxxxx2\":{\"code\":\"ETELEGRAM\",\"message\":\"ETELEGRAM: 400 Bad Request: text must be non-empty\"}}}"] users!
            telegram.0
            	2024-05-31 22:21:39.183	error	Failed sending [chatId - 6xxxxxxxx2]: Error: ETELEGRAM: 400 Bad Request: text must be non-empty
            telegram-menu.0
            	2024-05-31 22:21:39.183	debug	subscribe []
            telegram-menu.0
            	2024-05-31 22:21:39.150	debug	Data found: true
            telegram-menu.0
            	2024-05-31 22:21:39.149	debug	CalledText found
            telegram-menu.0
            	2024-05-31 22:21:39.148	debug	ID to subscribe "luxtronik1.0.control.EndpunktHK"
            telegram-menu.0
            	2024-05-31 22:21:39.148	debug	Element {"id":"luxtronik1.0.control.EndpunktHK","confirm":true,"returnText":"Neuer Endpunkt wurde auf && °C gesetzt","userToSend":"Systemchef"}
            telegram-menu.0
            	2024-05-31 22:21:39.147	debug	SubmenuData3[{"id":"luxtronik1.0.control.EndpunktHK","confirm":true,"returnText":"Neuer Endpunkt wurde auf && °C gesetzt","userToSend":"Systemchef"}]
            telegram-menu.0
            	2024-05-31 22:21:39.147	debug	Submenu data [null,null,null,[{"id":"luxtronik1.0.control.EndpunktHK","confirm":true,"returnText":"Neuer Endpunkt wurde auf && °C gesetzt","userToSend":"Systemchef"}]]
            telegram-menu.0
            	2024-05-31 22:21:39.143	debug	setStateIds[{"id":"luxtronik1.0.control.EndpunktHK","confirm":true,"returnText":"Neuer Endpunkt wurde auf && °C gesetzt","userToSend":"Systemchef"}]
            telegram-menu.0
            	2024-05-31 22:21:39.142	debug	JSON parse: {"id":"luxtronik1.0.control.EndpunktHK","text":"Neuer Endpunkt wurde auf && °C gesetzt"}
              @michael-roling
              Beim Aufruf "WW Spreizung" kam jetzt wieder "-". Creazy...... 🤡
              • Michael Roling
                Michael Roling Developer last edited by
                @willi-wunder Ich denke ich habe den Fehler gefunden. Aber da ich jetzt noch tiefer in Typescript eingestiegen bin könnte es sein das das eine oder andere nicht mehr funktioniert.
                liv-in-sky Rene55 2 Replies Last reply Reply Quote 0
                  liv-in-sky @Michael Roling last edited by liv-in-sky
                  @michael-roling sagte in Test Adapter telegram-menu v.1.6.x:
                  bitte nicht - wäre doof, wenn ich unterwegs bin und das ganze nicht funktioniert 🙂 🙂 hab mich schon sehr an deinen adapter gewöhnt 👍
                  • Michael Roling
                    Michael Roling Developer @liv-in-sky last edited by Michael Roling
                    @liv-in-sky Okay dann mache ich selbst erstmal den Probelauf.
                    Dann dauert es aber noch etwas , da ich noch einiges im Code optimieren muss.
                      @michael-roling
                      Super, bin gespannt. Beim ändern der Werte ist manchmal mein Luxtronik 1 Adapter abgeschmiert, Werte Abfragen war kein Problem. Könnte dies damit auch behoben sein? Wollte schon beim anderen Adapter nachfragen......
                      Hab die Tage gesehen, dass bei SetState bei Wert nun diese Auswahl möglich ist. Was genau kann ich damit machen? Hast du hier ein Beispiel oder kannst es erklären? Hab es leider nicht so verstanden, bei mir steht bisher immer der Wert "0" drin.
                      Vielen Dank.
                      Michael Roling W 2 Replies Last reply Reply Quote 0
                      • Rene55
                        Rene55 @Michael Roling last edited by
                        @michael-roling Frage am Rande: Ist denn Typescript wirklich so der Burner? Ich kann für mich nur ableiten, dass ich zwar die eigenen Variablen typisieren kann, aber wenn ich Daten von Extern hole, bin ich genau so 'untypisiert' wie in einfachem Javascript.
                        • Michael Roling
                          Michael Roling Developer @Rene55 last edited by
                          @rene55 ja alles was von extern kommt ist klar, aber auch nur wenn es sich um Objekte oder arrays handelt. Durch typescript werden aber viele Flüchtigkeitsfehler vermieden. Im Nachhinein umzustellen ist schon schwierig. Aber auch das geht.
                          • Michael Roling
                            @willi-wunder Mmmh. Eigentlich hatte der Telegram Adapter den Fehler ja geworfen und nichts gesendet. Aber ich weiß es nicht genau. We will see
                            • Rene55
                              @michael-roling Ja da magst du recht haben. Hatte mich auch mal an TS versucht, aber das code generieren mit dev-server gelang nicht so richtig. Aber ist nicht Thema für hier sondern mal (wenn du Zeit und Lust hast) mal woanders.
                              • Michael Roling
                                @rene55 kein Problem gerne.
                                • Rene55
                                  @michael-roling Ich brauche wahrscheinlich nur einen kleinen Schubs - bin aber gerade ein wenig eingeschränkt (Urlaub). Wie kommen wir zusammen? Discord?
                                  • Michael Roling
                                    @rene55 Ja Discord habe ich, aber noch nicht wirklich genutzt. Oder Teams
                                    • Rene55
                                      @michael-roling Ich will dich jetzt nicht drängen, möglich Donnerstag Abends oder später? Melde dich einfach, wenn es dir passt.
                                      • Michael Roling
                                        @rene55 Ich bin da relativ flexibel
                                        Michael Roling 1 Reply Last reply Reply Quote 1
                                        • Michael Roling
                                          Michael Roling Developer @Michael Roling last edited by
                                          @michael-roling lass uns einfach die Tage noch mal sprechen
                                          • Michael Roling
                                            Michael Roling Developer @Rene55 last edited by Michael Roling
                                            @rene55 wäre jetzt schon da
                                            1795
                                            789935
