      michael_4358 @TT-Tom last edited by
      @tt-tom
      die software..
      das panel zeigt nur noch den wait for content Kreisel... kann den Fehler arm nicht finden..
        TT-Tom @michael_4358 last edited by
        @michael_4358
        was kommt den auf der Tasmota Konsole so als Meldungen?
        deine MQTT einstellungen geprüft in Tasmota?
          @tt-tom said in SONOFF NSPanel mit Lovelace UI:
          @michael_4358
          script.js.NSPanel.panel_14: AxiosError: getaddrinfo EAI_AGAIN undefined at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:610:25) at RedirectableRequest.emit (node:events:514:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:526:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:514:28) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { hostname: 'undefined', syscall: 'getaddrinfo', code: 'EAI_AGAIN', errno: -3001, config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http', 'fetch' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://undefined/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: 'undefined', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: f46b7c2a61424bbb93184ac7b44ac888-bf1d9b097c857475\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.3.1,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=f46b7c2a61424bbb93184ac7b44ac888\r\n' + 'Host: undefined\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: 'undefined', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 16384, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://undefined/cm?cmnd=Status0', [Symbol(kCapture)]: false }, cause: Error: getaddrinfo EAI_AGAIN undefined at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:108:26) { errno: -3001, code: 'EAI_AGAIN', syscall: 'getaddrinfo', hostname: 'undefined' } }
          das schmeisst mir der Broker aus...
            michael_4358 @michael_4358 last edited by
            @TT-Tom
            das is auf der panel Konsole
            17:39:18.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:24.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:30.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:36.103 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:42.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:48.103 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:53.998 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:39:59.999 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:05.899 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:11.899 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:17.799 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:23.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:29.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:35.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:41.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:47.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:47.891 MQT: tele/tasmota_C6C160/STATE = {"Time":"2024-06-03T17:40:47","Uptime":"0T00:15:10","UptimeSec":910,"Heap":107,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":54,"Objects":660},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Datenbremse","BSSId":"68:D7:9A:14:06:1B","Channel":1,"Mode":"HT40","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:05"}}
            17:40:47.901 MQT: tele/tasmota_C6C160/SENSOR = {"Time":"2024-06-03T17:40:47","ANALOG":{"Temperature1":27.0},"TempUnit":"C"}
            17:40:53.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:40:59.497 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:05.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:11.398 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:17.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:23.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:29.298 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:35.197 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:41.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:47.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:53.098 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:41:58.999 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:05.002 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:10.898 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:16.898 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:22.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:28.798 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:34.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:40.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:46.698 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:52.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:42:58.598 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:04.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:10.498 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:16.399 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:22.400 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:28.302 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:34.304 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:40.197 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:46.198 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
            17:43:52.108 MQT: tele/tasmota_C6C160/RESULT = {"CustomRecv":"event,startup,53,eu"}
              @michael_4358 sagte in SONOFF NSPanel mit Lovelace UI:
              stimmt der Pfad vom MQTT noch mit dem Script überein?
                @tt-tom
                tatsächlich❗️
                aber costum send wird nicht erzeugt...
                  TT-Tom last edited by TT-Tom
                  @michael_4358
                  Stell in Tasmota die alte Verzeichnis Struktur wieder ein, dann sollte alles wieder funktionieren.
                  zeig mal deine alten Datenpunkte
                    @michael_4358
                    das ist zu spät ich hab die gelöscht da ich dachte dort kommt es zu Problemen,.
                      @michael_4358
                      Die steht doch noch im Script, oder? Ansonsten ist im Wiki eine Beschreibung.
                        @michael_4358
                        habe es wie im wiki gemacht aber der Datenpunkt fehlt..
                          @michael_4358
                          Zeige mal deine MQTT Einstellungen von Tasmota und die von mqtt.0
                            @tt-tom Bildschirmfoto 2024-06-03 um 19.53.56.png Bildschirmfoto 2024-06-03 um 19.54.34.png Bildschirmfoto 2024-06-03 um 19.54.41.png
                              @michael_4358
                              Vom objektbaum mqtt meinte ich.
                                  TT-Tom @michael_4358 last edited by TT-Tom
                                  @michael_4358
                                  da passt schon etwas nicht, dein Fulltopic in Tasmota fängt doch mit NSPanel14 an. hast du noch mehr Einträge unter mqtt.0
                                  EDIT: da ist ein Fehler in deiner Tasmota Config
                                  Dein Fulltopic fehlt ein / und du hast das %topic% auch NSPanel14 genannt
                                  Schreibe mal Smarthome/%topic%/%prefix% und poste dann die Ausgabe von der Tasmota Konsole und den Objektbaum von mqtt.0
                                    @tt-tom
                                    nach den ganzen neustarten zeigt das display nur noch "system data erorr"....
                                    alles auf anfang..
                                      @michael_4358
                                      Tasmota läuft noch? Dann solltest du die TFT Firmware nochmal neu installieren.
                                      Bin heute nur am Handy erreichbar und kann dir nur bedingt weiterhelfen. Ggf heute Abend über Discord.
                                        australien @TT-Tom last edited by
                                        @tt-tom gibt es dazu schon Neuigkeiten?
                                          Foradh 0 last edited by
                                          funktioniert bei euch eigentlich ein Tasmota-Update über die Bestätigung am Panel?
                                          Falls ich das Update über das Nspanel starte bleibt dieses im Safeboot stehen und führt das Update nicht durch.
                                          Problem tritt bei allen 4 Panels auf die ich aktuell betreibe. Gerade nochmal probiert für das Update von 14.0 auf 14.1.
                                          Im Iobroker wird unter Javascript log auch angezeigt dass er das Panel in den Safeboot wechselt, dann passiert allerdings nichts mehr.
                                          Ich habe die aktuelle tasmota32.bin dann heruntergeladen und unter dem Safeboot Webinterface die Panels damit manuell aktualisiert.
                                          Ist das bei euch auch so oder gibt es hier eine Lösung dass das Update von alleine druchläuft?
                                            @michael_4358
                                            habe den Treiber neu installiert bekomme aber keine Verbindung zum panel...
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6239943
