    5. Formatierung Pushover
      liv-in-sky @stenmic last edited by
      @stenmic
      sendTo('pushover', {
          message: 'This message includes <b>bold</b>, <i>italic</i> and <u>underlined</u> text <font color=green>in</font> <font color=#ffa500>different</font> <font color=red>colors</font>.',
          html: 1
      so funktioniert es - mit blockly habe ich es auch nicht geschafft
      Quarkmax 1 Reply Last reply Reply Quote 0
        @stenmic
        evtl hier ein issue aufmachen https://github.com/ioBroker/ioBroker.pushover
          @stenmic
          hier ist auch eine lösung für blockly https://forum.iobroker.net/post/1166622
            @stenmic
            warum ein doppel-post ?????
            • Quarkmax
              Quarkmax @liv-in-sky last edited by
              @liv-in-sky sagte in Formatierung Pushover:
              sendTo("pushover.0", "send", {
                  message: messageIn,
                  title: titleIn,
                  sound: soundIn,
                  priority: priorityIn,
                  device: deviceIn,
                  html: 1
              sendTo("pushover", {
                 message:  'Test text', // mandatory - your text message
                 title:    'SweetHome', // optional  - your message's title, otherwise your app's name is used
                 sound:    'magic',     // optional  - the name of one of the sounds supported by device clients to override the user's default sound choice
                                        //    pushover, bike, bugle, cashregister, classical, cosmic, falling,
                                        //    gamelan, incoming, intermission, magic, mechanical, pianobar, siren,
                                        //    spacealarm, tugboat, alien, climb, persistent, echo, updown, none
                 priority: -1,          // optional
                                        //    -1 to always send as a quiet notification,
                                        //    1 to display as high-priority and bypass the user's quiet hours, or
                                        //    2 to also require confirmation from the user
                 token: 'API/KEY token' // optional
                                        // add other than configurated token to the call
                 url,                   // optional  - a supplementary URL to show with your message
                 url_title,             // optional  - a title for your supplementary URL, otherwise just the URL is shown
                 device,                // optional  - your user's device name to send the message directly to that device, rather than all of the user's devices
                 timestamp              // optional  - a Unix timestamp of your message's date and time to display to the user, rather than the time your message is received by our API
                 html                   // optional  - 1 to enable parsing of HTML formating for bold, italic, underlined and font color
                 monospace              // optional  - 1 to display the message in monospace font
                                        //    either html or monospace is allowed
              liv-in-sky 1 Reply Last reply Reply Quote 1
                liv-in-sky @Quarkmax last edited by
                @quarkmax
                es geht wie im link beschrieben - man darf nicht den pushover block nehmn, sondern den sendTo block (erster block ganz oben
                dann pushover auswählen und im zahnrad die parameter message und html einrichten - html fehlt im orginal pushover block - daher geht es nicht damit
                  stenmic @liv-in-sky last edited by
                  @liv-in-sky
                  hab den anderen Post erst gefunden nachdem ich diesen hier gepostet habe
                  S liv-in-sky 2 Replies Last reply Reply Quote 0
                    stenmic @stenmic last edited by
                    danke für die Vorschläge
                      @stenmic
                      probier mal das beschrieben in meinen letzten post mit dem sendTo block
                        @liv-in-sky
                        schon getestet… funktioniert
                        521
