    4. Ecovacs-Debot Adapter - bestimmten Raum reinigen
      Thomas Braun Most Active @surfer09 last edited by
      @surfer09
      Ist die Version denn überhaupt im npm vorhanden?
      Zieh die halt direkt aus dem GitHub.
      • surfer09
        surfer09 @Thomas Braun last edited by surfer09
        @thomas-braun Das hatte ich bereits versucht
        2024-06-02T14_06_49_122Z-debug-0.log
          @surfer09
          Text gehört in CodeTags, nicht in bunte Bildchen. Oder Dateianhänge.
          • surfer09
            host.IOBroker-Master
            	2024-06-02 16:06:51.592	info	iobroker exit 25
            	2024-06-02 16:06:50.564	error	iobroker host.IOBroker-Master Cannot install mrbungle64/ioBroker.ecovacs-deebot: 4294963238
            	2024-06-02 16:06:50.564	error	iobroker npm error code ENOENTnpm error syscall spawn gitnpm error path gitnpm error errno -4058npm error enoent An unknown git error occurrednpm error enoent This is related to npm not being able to find a file.npm error enoentnpm error A complete log of this run can be found in: C:\Windows\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-02T14_06_49_122Z-debug-0.log
            	2024-06-02 16:06:50.546	info	iobroker npm error A complete log of this run can be found in: C:\Windows\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-02T14_06_49_122Z-debug-0.log
            	2024-06-02 16:06:50.545	info	iobroker npm error enoent This is related to npm not being able to find a file. npm error enoent
            	2024-06-02 16:06:50.545	info	iobroker npm error enoent An unknown git error occurred
            	2024-06-02 16:06:50.544	info	iobroker npm error syscall spawn git npm error path git npm error errno -4058
            	2024-06-02 16:06:50.543	info	iobroker npm error code ENOENT
            	2024-06-02 16:06:48.857	info	iobroker Installing mrbungle64/ioBroker.ecovacs-deebot... (System call)
            	2024-06-02 16:06:48.857	info	iobroker NPM version: 10.7.0
            	2024-06-02 16:06:48.533	info	iobroker install mrbungle64/ioBroker.ecovacs-deebot
            	2024-06-02 16:06:47.661	info	iobroker url mrbungle64/ioBroker.ecovacs-deebot --host IOBroker-Master --debug
            Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @surfer09 last edited by Thomas Braun
              @surfer09
              Da ist git wohl nicht richtig aufgesetzt. Oder die BuildChain.
              Unter Linux läuft es sofort:
              $ iobroker url mrbungle64/ioBroker.ecovacs-deebot --host chet --debug
              npm warn node_modules/iobroker.admin
              npm warn deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
              npm warn deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
              npm warn deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
              190 packages are looking for funding run `npm fund` for details
              upload [1] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/style.css style.css text/css
              upload [0] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/words.js words.js application/javascript
              Process exited with code 0
              surfer09 1 Reply Last reply Reply Quote 1
              • surfer09
                @thomas-braun Git habe ich gestern in der Version 2.45.1 nachinstalliert, das würde ich jetzt mal ausschließen, weil ich damit gestern auch erst einen Fehler hatte. Nach der Installation funktionierte das dann aber.
                  @surfer09
                  Von Windows hab ich keine Ahnung. Wäre mir auch für solche Server-Dienste auch viel zu umständlich und frickelig.
                  • mcm1957
                    mcm1957 @surfer09 last edited by
                    @surfer09 said in Ecovacs-Debot Adapter - bestimmten Raum reinigen:
                    Bitte poste das idente Problem noch noch 3 mal. Uns ist fad 😞
                    https://forum.iobroker.net/topic/75073/fehlermeldung-bei-adapterinstallation-fehlende-komponente
                    WENN schon ein Doppelpost im Einzelfall sinnvoll erscheint, dann bite EINDEUTIG kennzeichnen und gegenseitig verlinken.
                    • surfer09
                      surfer09 @mcm1957 last edited by
                      @mcm1957 Ich dachte mir, dass das Problem mit der fehlenden Komponente nicht wirklich etwas mit dem Ecovacs Adapter zu tun hat. Daher der Post im Error Forum.
                      • mcm1957
                        @surfer09
                        Der Gedanke ist nicht abwegig. Aber Doppelposts bitte das nächste Mal trotzdem eindeutig kennzeichnen
                        • surfer09
                          surfer09 @mcm1957 last edited by surfer09
                          @mrbungle64 : Ich konnte die Version 1.14.16 Alpha 2 jetzt von GitHub installieren, aber einen Map-Ordner habe ich weiterhin nicht.
                          • surfer09
                            surfer09 @surfer09 last edited by surfer09
                            @mrbungle64: Danke, mit der Version 1.4.16 Alpha3 von GitHub gibt es jetzt unterhalb des Punktes "control" die einzelnen Räume:
                            Wenn ich die Küche saugen möchte, setze ich den Datenpunkt einfach auf "true"?
                              sigi234 Forum Testing Most Active @surfer09 last edited by
                              @surfer09
                              Ja
                              1823
