    4. Beta Test Simulation auf der Basis von fullcalendar
      MDorf @arteck last edited by
      @arteck
      Wäre Klasse wenn du was fixen könntest! Der Adapter wäre sonst sehr genial...:-)
        Thomas Braun Most Active @MDorf last edited by
        @mdorf sagte in Beta Test Simulation auf dem Basis von fullcalendar:
        node: v18.17.1
        Offenbar hängst du noch auf dem obsoleten Repo. Stell das um:
        iob stop
        iob fix
        iob nodejs-update
          MDorf @Thomas Braun last edited by
          Versuch war's wert...es wurde auch aktualisiert, allerdings besteht das Problem noch:
          2024-02-11 23:18:33.749 - info: admin.0 (121751) ==> Connected system.user.admin from 2a00:6020:43cd:bd00:5d21:966e:d2b2:80a9
          2024-02-11 23:19:06.642 - info: admin.0 (121751) <== Disconnect system.user.admin from 2a00:6020:43cd:bd00:5d21:966e:d2b2:80a9 fullcalendar
          2024-02-11 23:19:12.677 - error: fullcalendar.0 (122758) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-02-11 23:19:12.678 - error: fullcalendar.0 (122758) unhandled promise rejection: Cannot read properties of null (reading '_id')
          2024-02-11 23:19:12.684 - error: fullcalendar.0 (122758) TypeError: Cannot read properties of null (reading '_id')
          at getImage (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:200:29)
          at AdapterClass. (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:412:36)
          2024-02-11 23:19:12.685 - error: fullcalendar.0 (122758) Cannot read properties of null (reading '_id')
          2024-02-11 23:19:12.711 - info: fullcalendar.0 (122758) terminating
          2024-02-11 23:19:12.713 - warn: fullcalendar.0 (122758) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-02-11 23:19:13.215 - info: fullcalendar.0 (122758) terminating
          2024-02-11 23:19:13.307 - error: host.smarthomepi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2024-02-11 23:19:13.308 - error: host.smarthomepi Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
          2024-02-11 23:19:13.308 - error: host.smarthomepi Caught by controller[1]: at getImage (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:200:29)
          2024-02-11 23:19:13.308 - error: host.smarthomepi Caught by controller[1]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:412:36)
          2024-02-11 23:19:13.309 - error: host.smarthomepi instance system.adapter.fullcalendar.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2024-02-11 23:19:13.309 - info: host.smarthomepi Restart adapter system.adapter.fullcalendar.0 because enabled
            RandyAndy @MDorf last edited by
            @andreas-k-0 said in Beta Test Simulation auf dem Basis von fullcalendar:
            Sekundenbruchteil "rot"
            Das kann ich nur bestätigen.
              RandyAndy @Andreas K 0 last edited by RandyAndy
              Es gibt zwar in der beta eine neue Version, aber die Simulations-Aufzeichnung lässt sich leider immer noch nicht starten.
              Diese Funktion wäre aber eigentlich der Schritt zu einer realistischen Simulation.
              Andreas
                RandyAndy @Bluefox last edited by
                @bluefox
                Es scheint so, dass die Simulation immer noch nicht richtig gestartet werden kann.
                Allerdings habe ich es nun mit einem Workaround hingebracht.
                Erst den Adapter stoppen, dann Simulation aufzeichenen starten und dann den Adpater wieder starten. Dann scheint er aufzuzeichnen.
                Ich beobachte das mal.
                O 123brokerei 2 Replies Last reply Reply Quote 0
                • O
                  oFbEQnpoLKKl6mbY5e13 @RandyAndy last edited by
                  Erstellt doch bitte ein Issue dazu im Adapter-Repo:
                  https://github.com/ioBroker/ioBroker.fullcalendar/issues
                    RandyAndy @oFbEQnpoLKKl6mbY5e13 last edited by
                    @ofbeqnpolkkl6mby5e13
                    Habe ich soeben gemacht. Und es scheint so, dass Event aufgezeichent werden die gar nicht vorhanden sind auch an Tagen die noch gar nicht erreicht sind. So habe ich am Montag den 15. April plötzlich auch events für Dienstag den 16. April.
                    Da stimmt noch etwas in der Summe nicht.
                      @bluefox
                      Und noch ein Frage. Wie kann ich eigentlich einzelne Simulationen oder Kalender deaktivieren bzw. wieder aktivieren.
                      Derzeit kann ich eigentlich nur immer den gesamten Adapter an und ausschalten, das ist aber nicht wirklich zielführend.
                      Vielleicht sehe ich es nur nicht
                      Andreas
                      • 123brokerei
                        123brokerei @RandyAndy last edited by
                        @randyandy
                        @Bluefox
                        Bei mir leider auch genau das gleiche Verhalten. Habe die 2.3.17 installiert.
                        123brokerei Bluefox 2 Replies Last reply Reply Quote 0
                        • 123brokerei
                          123brokerei @123brokerei last edited by
                          Was mir noch aufgefallen ist... kann es sein, dass der Adapter einen String als true/false sendet?
                          Das macht die Interpretation etwas komplizierter bzw. verursacht in meinen blocklys Warnungen.
                          Bluefox 1 Reply Last reply Reply Quote 0
                          • Bluefox
                            Bluefox @123brokerei last edited by
                            @123brokerei Bitte hier kommentieren https://github.com/ioBroker/ioBroker.fullcalendar/issues/234
                            RandyAndy1 created this issue in ioBroker/ioBroker.fullcalendar
                            open Simulation scan can't be started #234
                            • Bluefox
                              @123brokerei Kannst du bitte ein issue öffnen. Es ist für mich nicht klar welche Zustände geschrieben werden
                                Alero @Bluefox last edited by
                                @bluefox
                                hi,
                                ich versuche den Full Kalender auch für eine Abwesenheitssimulation zu nutzen.
                                Ich kann sie anlegen, Bei Zustände bekomme ich die Möglichkeit diese auszuwählen. Nur bei den Kategorien bekomme ich, wenn ich drauf klicke, einen weißen Bildschirm anstatt die die Kategorien wie z.B. Beleuchtung wo ich alle meine Shellys reingepackt habe. Was mache ich falsch?
                                31.7k
                                79.8k
                                21
                                1772
