    4. Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      anno171986 @Thomas Braun last edited by
      @thomas-braun Konnte jetzt den Updateprozess starten, aber das gab auch Fehler.
      anno171986@raspberrypi:~ $ iobroker stop
      anno171986@raspberrypi:~ $ iobroker update | grep Updatable
      Adapter    "ems-esp"      : 3.5.0    , installed 3.0.3  [Updatable]
      Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
      Adapter    "iot"          : 3.2.2    , installed 2.0.11 [Updatable]
      Adapter    "javascript"   : 8.3.1    , installed 7.8.0  [Updatable]
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.1  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
      Adapter    "telegram"     : 3.3.2    , installed 3.2.1  [Updatable]
      Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.25 [Updatable]
      Adapter    "worx"         : 3.0.2    , installed 2.3.4  [Updatable]
      anno171986@raspberrypi:~ $ iobroker upgrade self
      Host    "raspberrypi"    is up to date.
      anno171986@raspberrypi:~ $ iobroker upgrade -yes
      Update worx from @2.3.4 to @3.0.2
      NPM version: 10.7.0
      Installing iobroker.worx@3.0.2... (System call)
      Try to solve ENOTEMPTY error automatically
      Could not handle ENOTEMPTY, because no deletable files were found
      npm error code ENOTEMPTY
      npm error syscall rename
      npm error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv
      npm error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164
      npm error errno -39
      npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164'
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-04T18_47_41_533Z-debug-0.log
      host.raspberrypi Cannot install iobroker.worx@3.0.2: 217
        Thomas Braun Most Active @anno171986 last edited by
        @anno171986
        Das ist das Ding:
        Temp directories causing npm8 problem: 108
        Some problems detected, please run iob fix
        In dieser Reihenfolge:
        iob stop
        iob fix
        iob nodejs-update
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Wenn der Server dann wieder läuft schauen wir weiter.
          anno171986 last edited by anno171986
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v20.14.0. Do you want to install recommended version 18.20.3?
          Press <y> to continue or any other key to quit
          We are not fixing your installation. Exiting.
          anno171986@raspberrypi:~ $ iob stop
          anno171986@raspberrypi:~ $ sudo apt update
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          anno171986@raspberrypi:~ $ sudo apt full-upgrade
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            linux-headers-6.6.20+rpt-common-rpi linux-kbuild-6.6.20+rpt
          Use 'sudo apt autoremove' to remove them.
          The following packages will be REMOVED:
            linux-headers-6.6.20+rpt-rpi-2712 linux-headers-6.6.20+rpt-rpi-v8 linux-image-6.6.20+rpt-rpi-2712 linux-image-6.6.20+rpt-rpi-v8
          0 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
          After this operation, 70.9 MB disk space will be freed.
          Do you want to continue? [Y/n] y
          (Reading database ... 111073 files and directories currently installed.)
          Removing linux-headers-6.6.20+rpt-rpi-2712 (1:6.6.20-1+rpt1) ...
          Removing linux-headers-6.6.20+rpt-rpi-v8 (1:6.6.20-1+rpt1) ...
          Removing linux-image-6.6.20+rpt-rpi-2712 (1:6.6.20-1+rpt1) ...
          /etc/kernel/postrm.d/initramfs-tools:
          update-initramfs: Deleting /boot/initrd.img-6.6.20+rpt-rpi-2712
          Removing linux-image-6.6.20+rpt-rpi-v8 (1:6.6.20-1+rpt1) ...
          update-initramfs: Deleting /boot/initrd.img-6.6.20+rpt-rpi-v8
          anno171986@raspberrypi:~ $ sudo reboot
          Ich bin mal bei Version 20 geblieben
          Nach dem Neustart konnte ich das update starten
            @anno171986
            Und ein erneutes
            iob diag
            spuckt nun was aus?
            A 2 Replies Last reply Reply Quote 0
              @thomas-braun Habe ich gerade gestartet, poste ich gleich.
              Was im iob Protokoll steht z.b. das Problem mit SQL
              sql.0
              	2024-06-04 21:21:37.894	error	Error: connect ECONNREFUSED 192.168.178.12:3306
                @anno171986 sagte in Objects database error: connect ECONNREFUSED 127.0.0.1:9001:
                Der lässt dich nicht ran. Warum auch immer. Von msql hab ich aber keine Ahnung. Muss dir wwer anders weiterhelfen.
                  @thomas-braun Hier der iob diag Auszug, auch dort steht was zu SQL
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.6.31+rpt-rpi-v8
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   21:23:04 up 4 min,  2 users,  load average: 2.57, 2.25, 1.04
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Tue 2024-06-04 21:23:04 CEST
                             Universal time: Tue 2024-06-04 19:23:04 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  anno171986
                  HOME=/home/anno171986
                  GROUPS=anno171986 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  *** Display-Server-Setup ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            8.2G        3.8G        3.7G        1.3M        835M        4.4G
                  Swap:           209M          0B        209M
                  Total:          8.4G        3.8G        3.9G
                  Active iob-Instances:   22
                           7809 M total memory
                           3601 M used memory
                           3561 M active memory
                            570 M inactive memory
                           3533 M free memory
                             59 M buffer memory
                            736 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  top - 21:23:04 up 4 min,  2 users,  load average: 2.57, 2.25, 1.04
                  Tasks: 206 total,   1 running, 205 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 12.5 us, 25.0 sy,  0.0 ni, 50.0 id, 12.5 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7809.0 total,   3532.5 free,   3602.2 used,    796.8 buff/cache
                  MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4206.9 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  3.6G     0  3.6G   0% /dev
                  tmpfs          tmpfs     781M  1.3M  780M   1% /run
                  /dev/sda2      ext4      117G  7.1G  104G   7% /
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                  /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                  tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
                  [Tue Jun  4 21:18:30 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:47:26:6F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a36b2e0a-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
                  [Tue Jun  4 21:18:36 2024] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                  [Tue Jun  4 21:18:38 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                  Show mounted filesystems:
                  TARGET                                                  SOURCE      FSTYPE      OPTIONS
                  /                                                       /dev/sda2   ext4        rw,noatime
                  |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                  | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                  | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                  | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                  |-/proc                                                 proc        proc        rw,relatime
                  | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2361
                  |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                  |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3728000k,nr_inodes=932000,mode=755
                  | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                  | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
                  | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                  |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=799648k,mode=755
                  | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                  | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                  | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799644k,nr_inodes=199911,mode=700,uid=1000,gid=1000
                  `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.7G    /var/
                  936M    /var/log/journal/9735987036244807bbcd08440a9098fe
                  936M    /var/log
                  292M    /var/lib
                  Archived and active journals take up 935.5M in the file system.
                  /opt/iobroker/backups:
                  37M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  859M    /opt/iobroker/iobroker-data/
                  525M    /opt/iobroker/iobroker-data/files
                  138M    /opt/iobroker/iobroker-data/files/javascript.admin
                  128M    /opt/iobroker/iobroker-data/backup-objects
                  118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  186M    /opt/iobroker/iobroker-data/states.jsonl
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyACM0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.14.0
                  /usr/bin/node           v20.14.0
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  /usr/bin/corepack       0.28.1
                  nodejs:
                    Installed: 20.14.0-1nodesource1
                    Candidate: 20.14.0-1nodesource1
                    Version table:
                   *** 20.14.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u1 500
                       18.13.0+dfsg1-1 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.13.16
                  javascript:     8.3.1
                  nodejs modules from github:     1
                  +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                  + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
                    system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                  + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                  + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                  + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                  + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                  + system.adapter.lupusec.0                : lupusec               : raspberrypi                              -  enabled
                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                    system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
                    system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              - disabled
                  + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.178.12, run as: admin
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                  + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              - disabled
                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                    system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                  + system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                  + instance is alive
                  ioBroker-Repositories
                  Stable (default): http://download.iobroker.net/sources-dist.json
                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                  Active repo(s): Stable (default)
                  Installed ioBroker-Instances
                  Used repository: Stable (default)
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                  Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
                  Adapter    "harmony"      : 1.4.0    , installed 1.4.0
                  Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                  Adapter    "iot"          : 3.2.2    , installed 3.2.2
                  Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                  Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                  Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                  Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                  Adapter    "sql"          : 2.2.0    , installed 2.2.0
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                  Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
                  Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
                  Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
                  Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                  Adapter    "worx"         : 3.0.2    , installed 3.0.2
                  Adapter    "ws"           : 2.6.1    , installed 2.6.1
                  Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Objects and States
                  Objects:        9822
                  States:         7204
                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        4056       780/mariadbd
                  tcp        0      0 192.168.178.12:8087     0.0.0.0:*               LISTEN      1001       6933       1491/io.simple-api.
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4008       703/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4084       673/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7184       673/iobroker.js-con
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       7709       1237/io.mqtt.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7256       902/io.admin.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          4010       703/sshd: /usr/sbin
                  tcp6       0      0 :::61991                :::*                    LISTEN      1001       9485       1163/io.harmony.0
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       9486       1163/io.harmony.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        960        550/avahi-daemon: r
                  udp        0      0 0.0.0.0:52195           0.0.0.0:*                           104        962        550/avahi-daemon: r
                  udp6       0      0 fe80::b1a2:bab:8ce2:546 :::*                                0          7363       592/NetworkManager
                  udp6       0      0 fe80::378e:5998:7a1:546 :::*                                0          6419       592/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        961        550/avahi-daemon: r
                  udp6       0      0 :::34631                :::*                                104        963        550/avahi-daemon: r
                  2024-06-04 21:22:01.836  - warn: sql.0 (964) No Connection to database
                  2024-06-04 21:22:01.838  - warn: sql.0 (964) No Connection to database
                  2024-06-04 21:22:01.846  - warn: sql.0 (964) storeState executed with 40 errors: Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717459200000,"val":97,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717470000000,"val":98,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717480800000,"val":89,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717491600000,"val":77,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717502400000,"val":66,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717513200000,"val":79,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717524000000,"val":85,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717534800000,"val":90,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717545600000,"val":81,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717556400000,"val":92,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717567200000,"val":85,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717578000000,"val":57,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717588800000,"val":50,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717599600000,"val":51,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717610400000,"val":62,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717621200000,"val":78,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717632000000,"val":82,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717642800000,"val":81,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717653600000,"val":77,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717664400000,"val":61,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717675200000,"val":59,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717686000000,"val":72,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717696800000,"val":75,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717707600000,"val":87,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717718400000,"val":90,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717729200000,"val":92,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717740000000,"val":83,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717750800000,"val":59,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717761600000,"val":55,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717772400000,"val":66,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717783200000,"val":65,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717794000000,"val":82,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717804800000,"val":91,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717815600000,"val":93,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717826400000,"val":76,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717837200000,"val":73,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717848000000,"val":77,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717858800000,"val":66,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717869600000,"val":69,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureHumidity: undefined, Data: {"ts":1717880400000,"val":75,"ack":false,"from":"mcuScript"}
                  2024-06-04 21:22:01.852  - warn: sql.0 (964) storeState executed with 40 errors: Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717459200000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717470000000,"val":1015,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717480800000,"val":1014,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717491600000,"val":1013,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717502400000,"val":1011,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717513200000,"val":1010,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717524000000,"val":1008,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717534800000,"val":1007,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717545600000,"val":1005,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717556400000,"val":1004,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717567200000,"val":1007,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717578000000,"val":1009,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717588800000,"val":1010,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717599600000,"val":1012,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717610400000,"val":1012,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717621200000,"val":1013,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717632000000,"val":1014,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717642800000,"val":1014,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717653600000,"val":1015,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717664400000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717675200000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717686000000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717696800000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717707600000,"val":1017,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717718400000,"val":1017,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717729200000,"val":1017,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717740000000,"val":1017,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717750800000,"val":1017,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717761600000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717772400000,"val":1016,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717783200000,"val":1015,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717794000000,"val":1015,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717804800000,"val":1014,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717815600000,"val":1012,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717826400000,"val":1011,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717837200000,"val":1010,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717848000000,"val":1010,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717858800000,"val":1009,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717869600000,"val":1009,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futurePressure: undefined, Data: {"ts":1717880400000,"val":1009,"ack":false,"from":"mcuScript"}
                  2024-06-04 21:22:01.854  - warn: sql.0 (964) storeState executed with 40 errors: Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717459200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717470000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717480800000,"val":0.3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717491600000,"val":0.7,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717502400000,"val":0.5,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717513200000,"val":0.1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717524000000,"val":0.3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717534800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717545600000,"val":0.9,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717556400000,"val":3.2,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717567200000,"val":1.3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717578000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717588800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717599600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717610400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717621200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717632000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717642800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717653600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717664400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717675200000,"val":0.2,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717686000000,"val":0.2,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717696800000,"val":0.1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717707600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717718400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717729200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717740000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717750800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717761600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717772400000,"val":0.3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717783200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717794000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717804800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717815600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717826400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717837200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717848000000,"val":0.8,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717858800000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717869600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureRain: undefined, Data: {"ts":1717880400000,"val":0,"ack":false,"from":"mcuScript"}
                  2024-06-04 21:22:01.873  - warn: sql.0 (964) storeState executed with 40 errors: Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717459200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717470000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717480800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717491600000,"val":3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717502400000,"val":3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717513200000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717524000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717534800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717545600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717556400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717567200000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717578000000,"val":4,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717588800000,"val":5,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717599600000,"val":2,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717610400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717621200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717632000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717642800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717653600000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717664400000,"val":2,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717675200000,"val":3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717686000000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717696800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717707600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717718400000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717729200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717740000000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717750800000,"val":3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717761600000,"val":4,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717772400000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717783200000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717794000000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717804800000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717815600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717826400000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717837200000,"val":3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717848000000,"val":4,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717858800000,"val":1,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717869600000,"val":0,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureUV_Index: undefined, Data: {"ts":1717880400000,"val":0,"ack":false,"from":"mcuScript"}
                  2024-06-04 21:22:01.875  - warn: sql.0 (964) storeState executed with 40 errors: Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717459200000,"val":6,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717470000000,"val":3,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717480800000,"val":8,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717491600000,"val":16,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717502400000,"val":16,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717513200000,"val":13,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717524000000,"val":12,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717534800000,"val":12,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717545600000,"val":18,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717556400000,"val":19,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717567200000,"val":14,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717578000000,"val":19,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717588800000,"val":20,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717599600000,"val":20,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717610400000,"val":13,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717621200000,"val":9,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717632000000,"val":7,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717642800000,"val":10,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717653600000,"val":11,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717664400000,"val":19,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717675200000,"val":19,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717686000000,"val":16,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717696800000,"val":11,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717707600000,"val":7,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717718400000,"val":8,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717729200000,"val":7,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717740000000,"val":9,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717750800000,"val":14,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717761600000,"val":17,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717772400000,"val":15,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717783200000,"val":11,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717794000000,"val":9,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717804800000,"val":11,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717815600000,"val":14,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717826400000,"val":17,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717837200000,"val":21,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717848000000,"val":20,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717858800000,"val":17,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717869600000,"val":12,"ack":false,"from":"mcuScript"}, Error writing state for 0_userdata.0.daswetter.futureWind: undefined, Data: {"ts":1717880400000,"val":11,"ack":false,"from":"mcuScript"}
                  2024-06-04 21:22:07.901  - error: sql.0 (964) Error: connect ECONNREFUSED 192.168.178.12:3306
                  2024-06-04 21:22:18.022  - error: telegram.0 (995) Failed sending [chatId - 1211163069]: Error: ETELEGRAM: 400 Bad Request: text is too long
                  2024-06-04 21:22:37.906  - error: sql.0 (964) Error: connect ECONNREFUSED 192.168.178.12:3306
                  2024-06-04 21:22:48.068  - info: zigbee.0 (1309) Send command to 0x0c4314fffe56b4df failed with: Code 9999 (No response)
                  2024-06-04 21:22:48.339  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xa4c138add3c0a8a7 TS011F
                  2024-06-04 21:22:48.850  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0x588e81fffee0ccc6 TS0502A
                  2024-06-04 21:23:07.911  - error: sql.0 (964) Error: connect ECONNREFUSED 192.168.178.12:3306
                  2024-06-04 21:23:10.230  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xf0d1b80000196d05 Gardenpole RGBW Z3
                  2024-06-04 21:23:10.847  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0x5c0272fffe802c81 TRADFRI control outlet
                  2024-06-04 21:23:10.976  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0x7cb03eaa0a00b70b CLA60 TW OSRAM
                  2024-06-04 21:23:11.498  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0x680ae2fffe3a4858 ZG9101SAC-HP
                  2024-06-04 21:23:11.758  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xa4c13801297e5e2b TS0001
                  2024-06-04 21:23:11.773  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xa4c138b3d7c14b87 TS011F
                  2024-06-04 21:23:11.799  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xa4c138bc4d1cdc90 TS011F
                  2024-06-04 21:23:12.178  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0x680ae2fffe3a482b ZG9101SAC-HP
                  2024-06-04 21:23:12.474  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xa4c138f12aac2718 TS011F
                  2024-06-04 21:23:12.673  - warn: zigbee.0 (1309) DeviceAvailability:Failed to ping 0xa4c13883d0135f67 TS011F
                  2024-06-04 21:23:37.922  - error: sql.0 (964) Error: connect ECONNREFUSED 192.168.178.12:3306
                    Im Zigbee-Adapter statt /dev/ttyACM0 besser
                    als COM-Port eintragen.
                    Fehlen beim sql vielleicht die Credentials?
                      @thomas-braun said in Objects database error: connect ECONNREFUSED 127.0.0.1:9001:
                      Ich bin gerade am Testen mit SQL
                        ENDLICH!
                        Es lag an den Credentials und an den Rechten für den User (Remote-Zugriff).
                        Jetzt, wo der SQl Adapter wieder grün wurde konnte ich auch das SQL Backup einspielen und die DB ist nun auch wieder da.
                        Vielen DAnk für deine Hilfe!
                        5491
