Zigbee, mein Sorgenkind - geht wieder nicht
@brokeling sagte in Zigbee, mein Sorgenkind - geht wieder nicht:
Was kann ich machen?
mehr Informationen liefern
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: raspi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : armv7l Userland : 32 bit Systemuptime and Load: 22:41:56 up 7:55, 1 user, load average: 1.48, 1.17, 1.04 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2024-06-04 22:41:57 CEST Universal time: Tue 2024-06-04 20:41:57 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video bluetooth redis gpio i2c *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.9G 933M 0.0K 994M 1.8G Swap: 99M 0B 99M Total: 3.9G 1.9G 1.0G Active iob-Instances: 31 3786 M total memory 1858 M used memory 242 M active memory 2494 M inactive memory 933 M free memory 120 M buffer memory 873 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 22:41:57 up 7:55, 1 user, load average: 1.84, 1.25, 1.07 Tasks: 179 total, 1 running, 178 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 2.9 sy, 0.0 ni, 95.7 id, 0.0 wa, 0.0 hi, 1.4 si, 0.0 st MiB Mem : 3786.2 total, 934.2 free, 1857.7 used, 994.3 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 1794.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 117G 22G 90G 20% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 758M 828K 757M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sdb1 ext4 113G 79G 29G 74% /backup /dev/sda1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 379M 16K 379M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Jun 4 14:46:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Tue Jun 4 14:46:37 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [Tue Jun 4 14:46:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Tue Jun 4 14:46:39 2024] EXT4-fs (sda2): re-mounted. Opts: (null) [Tue Jun 4 14:46:40 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null) Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime,stripe=8191 |-/dev devtmpfs devtmpfs rw,relatime,size=1773668k,nr_inodes=84274,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot | |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime | `-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=775416k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=387704k,nr_inodes=96926,mode=700,uid=1000,gid=1000 |-/backup /dev/sdb1 ext4 ro,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 7.8G /var/ 3.4G /var/cache/apt 3.4G /var/cache 3.3G /var/lib 3.3G /var/cache/apt/archives Archived and active journals take up 976.2M in the file system. /opt/iobroker/backups: 4.1G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 556M /opt/iobroker/iobroker-data/backup-objects 434M /opt/iobroker/iobroker-data/files 139M /opt/iobroker/iobroker-data/files/javascript.admin 118M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 41M /opt/iobroker/iobroker-data/states.json.old 41M /opt/iobroker/iobroker-data/states.json.bak 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 19M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map 17M /opt/iobroker/iobroker-data/objects.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f0aafe52a4ed11a13181582981d5c7-if00-port0 Your zigbee.0 COM-Port is matching 'by-id'. Very good! *** NodeJS-Installation *** /usr/bin/nodejs v18.20.3 /usr/bin/node v18.20.3 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.3-1nodesource1 Candidate: 18.20.3-1nodesource1 Version table: *** 18.20.3-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.19 admin: 6.13.16 javascript: 8.3.1 nodejs modules from github: 0 Adapter State + system.adapter.admin.1 : admin : raspi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspi - enabled + system.adapter.backitup.0 : backitup : raspi - enabled + system.adapter.chromecast.0 : chromecast : raspi - enabled + system.adapter.cloud.0 : cloud : raspi - enabled system.adapter.feiertage.0 : feiertage : raspi - enabled system.adapter.flot.0 : flot : raspi - enabled system.adapter.hue.0 : hue : raspi - disabled, port: 443 system.adapter.ical.0 : ical : raspi - enabled system.adapter.icons-icons8.0 : icons-icons8 : raspi - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspi - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi - enabled + system.adapter.javascript.0 : javascript : raspi - enabled system.adapter.luftdaten.0 : luftdaten : raspi - enabled system.adapter.luftdaten.1 : luftdaten : raspi - enabled system.adapter.mqtt.0 : mqtt : raspi - disabled, port: 1884, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : raspi - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : raspi - enabled + system.adapter.nuki.0 : nuki : raspi - enabled + system.adapter.ping.0 : ping : raspi - enabled + system.adapter.pushover.0 : pushover : raspi - enabled + system.adapter.reolink.0 : reolink : raspi - enabled + system.adapter.reolink.1 : reolink : raspi - enabled + system.adapter.reolink.2 : reolink : raspi - enabled + system.adapter.reolink.3 : reolink : raspi - enabled + system.adapter.reolink.4 : reolink : raspi - enabled + system.adapter.samsung_tizen.0 : samsung_tizen : raspi - enabled, port: 8002 + system.adapter.sayit.0 : sayit : raspi - enabled + system.adapter.sayit.1 : sayit : raspi - enabled + system.adapter.sayit.2 : sayit : raspi - enabled + system.adapter.sayit.3 : sayit : raspi - enabled + system.adapter.sayit.4 : sayit : raspi - enabled + system.adapter.sayit.5 : sayit : raspi - enabled + system.adapter.shelly.0 : shelly : raspi - enabled, port: 1885, bind: 0.0.0.0 system.adapter.shelly.1 : shelly : raspi - disabled, port: 1882, bind: 0.0.0.0 + system.adapter.signal-cmb.0 : signal-cmb : raspi - enabled + system.adapter.simple-api.0 : simple-api : raspi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.2 : sourceanalytix : raspi - enabled + system.adapter.sql.0 : sql : raspi - enabled, port: 0 + system.adapter.statistics.0 : statistics : raspi - enabled + system.adapter.telegram.0 : telegram : raspi - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : raspi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspi - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : raspi - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : raspi - enabled system.adapter.vis-history.0 : vis-history : raspi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspi - enabled system.adapter.vis-justgage.0 : vis-justgage : raspi - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspi - enabled system.adapter.vis-metro.0 : vis-metro : raspi - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspi - enabled system.adapter.vis.0 : vis : raspi - enabled + system.adapter.web.0 : web : raspi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f0aafe52a4ed11a13181582981d5c7-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : raspi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.samsung_tizen.0 : samsung_tizen : raspi - enabled, port: 8002 + system.adapter.shelly.0 : shelly : raspi - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sql.0 : sql : raspi - enabled, port: 0 + system.adapter.telegram.0 : telegram : raspi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f0aafe52a4ed11a13181582981d5c7-if00-port0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "chromecast" : 3.4.0 , installed 3.4.0 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "deconz" : 1.4.1 , installed 1.4.1 Adapter "discovery" : 4.4.0 , installed 4.4.0 Adapter "fb-checkpresence": 1.2.4 , installed 1.2.4 Adapter "feiertage" : 1.2.0 , installed 1.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fullybrowser" : 3.0.12 , installed 3.0.12 Adapter "hue" : 3.11.0 , installed 3.11.0 Adapter "ical" : 1.15.0 , installed 1.15.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "iqontrol" : 2.3.0 , installed 2.3.0 Adapter "javascript" : 8.3.1 , installed 8.3.1 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "luftdaten" : 3.1.0 , installed 3.1.0 Adapter "moma" : 1.2.9 , installed 1.2.9 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "net-tools" : 1.0.11 , installed 1.0.11 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "nuki" : 1.6.0 , installed 1.6.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "owntracks" : 1.0.5 , installed 1.0.5 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 3.0.6 , installed 3.0.6 Adapter "reolink" : 1.1.0 , installed 1.1.0 Adapter "samsung_tizen": 1.1.0 , installed 1.1.0 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "shelly" : 6.9.0 , installed 6.9.0 Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.0 , installed 6.7.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "spotify-premium": 1.5.0 , installed 1.5.0 Adapter "sql" : 2.2.0 , installed 2.2.0 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "telegram" : 3.3.2 , installed 3.3.2 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "wiobrowser" : 2.0.2 , installed 2.0.2 Adapter "ws" : 2.6.1 , installed 2.6.1 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Objects and States Please stand by - This may take a while Objects: 7425 States: 5825 *** OS-Repositories and Updates *** Hit:1 http://phoscon.de/apt/deconz bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 11933 361/deCONZ tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 11907 527/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 11991 487/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 20548 1956/io.sonoff.0 tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14727 361/deCONZ tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 18115 2313/io.shelly.0 tcp 0 0 192.168.178.53:9092 0.0.0.0:* LISTEN 1001 21329 2492/io.nuki.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 15823 583/iobroker.js-con tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 110 11996 597/mariadbd tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 118 11918 498/redis-server 12 tcp6 0 0 :::8081 :::* LISTEN 1001 15966 1018/io.admin.1 tcp6 0 0 :::8082 :::* LISTEN 1001 22573 2404/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 11909 527/sshd: /usr/sbin tcp6 0 0 :::8087 :::* LISTEN 1001 23713 2606/io.simple-api. tcp6 0 0 ::1:631 :::* LISTEN 0 11990 487/cupsd tcp6 0 0 ::1:6379 :::* LISTEN 118 11919 498/redis-server 12 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 11964 814/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 15581 614/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 39705 4963/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11782 355/avahi-daemon: r udp 0 0 0.0.0.0:54036 0.0.0.0:* 108 11784 355/avahi-daemon: r udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 14732 361/deCONZ udp6 0 0 :::546 :::* 0 15706 814/dhcpcd udp6 0 0 :::47317 :::* 108 11785 355/avahi-daemon: r udp6 0 0 :::5353 :::* 108 11783 355/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-06-04 22:43:09.144 - debug: statistics.0 (5421) [EXECUTING] avg call 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus 2024-06-04 22:43:09.144 - debug: statistics.0 (5421) [STATE CHANGE] new last for "temp.avg.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.last: 0 2024-06-04 22:43:09.898 - debug: statistics.0 (5421) [STATE CHANGE] ======================= 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus ======================= 2024-06-04 22:43:09.898 - debug: statistics.0 (5421) [STATE CHANGE] stateChange => 545 2024-06-04 22:43:09.898 - debug: statistics.0 (5421) [STATE CHANGE] schedule onStateChangeSumDeltaValue for 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus 2024-06-04 22:43:09.899 - debug: statistics.0 (5421) [STATE CHANGE] schedule onStateChangeMinMaxValue for 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus 2024-06-04 22:43:09.900 - debug: statistics.0 (5421) [EXECUTING] sum delta 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus 2024-06-04 22:43:09.939 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.15Min on 0 to -22 2024-06-04 22:43:09.953 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.hour on 0 to -1907 2024-06-04 22:43:09.963 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.day on 0 to 15685368 2024-06-04 22:43:09.973 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.week on 0 to 15685368 2024-06-04 22:43:09.981 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.month on 0 to 42266073 2024-06-04 22:43:09.991 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.quarter on 0 to 42266073 2024-06-04 22:43:09.996 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumDelta.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.year on 0 to 809795257 2024-06-04 22:43:10.001 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.15Min on NaN to NaN 2024-06-04 22:43:10.007 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.hour on NaN to NaN 2024-06-04 22:43:10.012 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.day on NaN to NaN 2024-06-04 22:43:10.017 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.week on NaN to NaN 2024-06-04 22:43:10.021 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.month on NaN to NaN 2024-06-04 22:43:10.026 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.quarter on NaN to NaN 2024-06-04 22:43:10.030 - debug: statistics.0 (5421) [STATE CHANGE] Increase temp.sumGroup.Strombezug.year on NaN to NaN 2024-06-04 22:43:10.035 - debug: statistics.0 (5421) [EXECUTING] minmax 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus 2024-06-04 22:43:10.035 - debug: statistics.0 (5421) [STATE CHANGE] new last for "temp.minmax.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.last: 545 2024-06-04 22:43:10.041 - debug: statistics.0 (5421) [EXECUTING] avg call 0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus 2024-06-04 22:43:10.041 - debug: statistics.0 (5421) [STATE CHANGE] new last for "temp.avg.0_userdata.0.Holger2.Energie_Haus.Gesamtverbrauch_Haus.last: 0
Was soll ich noch liefern?
Evtl. Adpater neu starten und Fehlermeldungen? -
Kann es sein, das dir der mitlaufende deCONZ da noch irgendwie reinspukt?
Wenn der nicht mehr gebraucht wird: Schmeiß ihn raus. -
debug: statistics.0
Und stell den auf ein anderes LogLevel ein. Oder debuggst du den gerade?
Den Adapter habe ich gelöscht.
Das Programm ist noch auf dem raspi drauf.
Kann ich mit folgendem Kommando das Programm löschen (?):sudo apt remove deconz
@thomas-braun said in Zigbee, mein Sorgenkind - geht wieder nicht:
sudo systemctl stop deconz*
pi@raspi:~ $ sudo systemctl stop deconz* Failed to stop deconz-latest-beta.deb.service: Unit deconz-latest-beta.deb.service not loaded.
scheint nicht zu laufen.
Dann löschen mitsudo apt remove deconz
@brokeling Nee, du hast da irgendwelche deb-Files in dem Ordner liegen.
Man installiert Software NICHT so, wenn man die auch immer aus einem Repo ziehen kann.rm deconz* systemctl status deconz*
pi@raspi:~ $ rm deconz* pi@raspi:~ $ systemctl status deconz* ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2024-06-04 14:46:25 CEST; 8h ago Main PID: 360 (deCONZ-WIFI2.sh) Tasks: 2 (limit: 4915) CPU: 44min 39.474s CGroup: /system.slice/deconz-wifi.service ├─ 360 /bin/bash /usr/bin/deCONZ-WIFI2.sh └─21530 sleep 1 Jun 04 17:38:50 raspi deCONZ-WIFI2.sh[19381]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 18:13:24 raspi deCONZ-WIFI2.sh[3743]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 18:47:57 raspi deCONZ-WIFI2.sh[19944]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 19:22:30 raspi deCONZ-WIFI2.sh[4176]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 19:56:57 raspi deCONZ-WIFI2.sh[20590]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 20:31:26 raspi deCONZ-WIFI2.sh[4880]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 21:06:03 raspi deCONZ-WIFI2.sh[21260]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 21:40:53 raspi deCONZ-WIFI2.sh[5064]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 22:15:44 raspi deCONZ-WIFI2.sh[21225]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. Jun 04 22:50:29 raspi deCONZ-WIFI2.sh[6644]: /usr/bin/deCONZ-WIFI2.sh: Zeile 833: python: Kommando nicht gefunden. ● deconz.service - deCONZ: ZigBee gateway -- REST API Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2024-06-04 14:46:25 CEST; 8h ago Main PID: 361 (deCONZ) Tasks: 6 (limit: 4915) CPU: 5min 58.347s CGroup: /system.slice/deconz.service └─361 /usr/bin/deCONZ -platform minimal --http-port=80 lines 1-29
Zigbee geht übrigens gerade (wieder)...
Zigbee geht übrigens gerade...
Ich würde dennoch alles rauswerfen, was auf der Kiste nichts (mehr) zu suchen hat.
sudo systemctl stop deconz-wifi.service sudo systemctl stop deconz.service sudo apt purge deconz
ja, natürlich, danke!
pi@raspi:~ $ sudo systemctl stop deconz-wifi.service pi@raspi:~ $ sudo systemctl stop deconz.service pi@raspi:~ $ sudo apt purge deconz Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: enchant libenchant1c2a libicu63 libqt5qml5 libqt5serialport5 libqt5sql5 libqt5sql5-sqlite libqt5websockets5 sqlite3 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. Die folgenden Pakete werden ENTFERNT: deconz* 0 aktualisiert, 0 neu installiert, 1 zu entfernen und 2 nicht aktualisiert. Nach dieser Operation werden 38,5 MB Plattenplatz freigegeben. Möchten Sie fortfahren? [J/n] j (Lese Datenbank ... 110414 Dateien und Verzeichnisse sind derzeit installiert.) Entfernen von deconz (2.26.3) ... Trigger für mailcap (3.69) werden verarbeitet ... Trigger für desktop-file-utils (0.26-1) werden verarbeitet ...
Heute hatte ich schon ein paar Adapter runtergeschmissen bzw. deaktiviert.
Dazu noch den Raspi von flach liegend 90 Grad aufgestellt. Das brachte mit dem verbauten passiven Kühlgehäuse doch glatt ca. 8 °C Temperaturreduktion von 62 -> 54 °C. Warum der Adapter jetzt wieder angelaufen ist bzw. funktioniert, weiß ich nicht. Könnte sein dass er jetzt, nachdem ich mich ans Forum gewandt habe, doch klein beigegeben hat -
Stell das
Operating System: Raspbian GNU/Linux 11 (bullseye)beizeiten auf Debian 12 'Bookworm' und 64Bit in der Lite-Version um. Geht aber nur per Neuinstallation.
