    4. Wallbox, PV mit openWB in iobroker einbinden
      mading @Wolfirr last edited by
      @wolfirr unterhalb, leg‘ einfach deine eigene Ordnerstruktur an.
        Wolfirr @mading last edited by
        @mading endlich konnte ich bei Sonnenschein den Speicher mal wieder richtig betreiben und das Blockly nochmal laufen lassen und testen. Dabei ist mir folgender Debug ausgegeben worden und ich weiß nicht, wo der Fehler liegen kann?
        Danke im Voraus
        Debug Output:
        15.2.2024, 12:55:39.788	[info ]: javascript.0 (1832412) Start javascript script.js.Speicher.SN103
        15.2.2024, 12:55:39.871	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: schedule(cron=* * * * *)
        15.2.2024, 12:55:39.873	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1707994275680,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707994275680}
        15.2.2024, 12:55:39.874	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":1963,"ack":true,"ts":1707998056473,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707998056473}
        15.2.2024, 12:55:39.875	[error]: javascript.0 (1832412) script.js.Speicher.SN103 Error by subscription (trigger): Wrong ID of type boolean or number.
        15.2.2024, 12:55:39.875	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
        15.2.2024, 12:56:00.049	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getObject(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, enumName=undefined) => {"_id":"fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W","type":"state","common":{"name":"ESS_Minutenwerte 03_Battery_to_Household_in_W","type":"number","role":"value","read":true,"write":false,"custom":{"influxdb.0":{"enabled":true,"storageType":"Number","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000}}},"native":{"Name":"ESS_Minutenwerte","Attribute":"03_Battery_to_Household_in_W","Readings":true,"type":"number","role":"value"},"value":{"val":"0"},"from":"system.adapter.influxdb.0","user":"system.user.admin","ts":1704876495776}
        15.2.2024, 12:56:00.050	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":1963,"ack":true,"ts":1707998056473,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707998056473}
        15.2.2024, 12:56:00.051	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":1963,"ack":true,"ts":1707998056473,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707998056473}
        15.2.2024, 12:56:00.052	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: setForeignState(id=0_userdata.0.eigeneDatenpunkte.Caterva.SN103.LeistungSN103, state={"val":-1963,"ack":true,"ts":1707998160052,"q":0,"from":"system.adapter.javascript.0","lc":1707998160052,"c":"script.js.Speicher.SN103"})
        15.2.2024, 12:56:00.053	[warn ]: javascript.0 (1832412) script.js.Speicher.SN103: setForeignState(id=0_userdata.0.eigeneDatenpunkte.Caterva.SN103.LeistungSN103, state={"val":-1963,"ack":true,"ts":1707998160052,"q":0,"from":"system.adapter.javascript.0","lc":1707998160052,"c":"script.js.Speicher.SN103"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
        15.2.2024, 12:56:00.055	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
        15.2.2024, 12:56:00.058	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":70,"ack":true,"ts":1707997876082,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707997876082}
        15.2.2024, 12:56:00.059	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":70,"retain":true}, hasCallback=true)
        15.2.2024, 12:56:20.056	[error]: javascript.0 (1832412) script.js.Speicher.SN103: timeout
        15.2.2024, 12:56:20.058	[error]: javascript.0 (1832412) script.js.Speicher.SN103: timeout
        15.2.2024, 12:57:00.052	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getObject(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, enumName=undefined) => {"_id":"fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W","type":"state","common":{"name":"ESS_Minutenwerte 03_Battery_to_Household_in_W","type":"number","role":"value","read":true,"write":false,"custom":{"influxdb.0":{"enabled":true,"storageType":"Number","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000}}},"native":{"Name":"ESS_Minutenwerte","Attribute":"03_Battery_to_Household_in_W","Readings":true,"type":"number","role":"value"},"value":{"val":"0"},"from":"system.adapter.influxdb.0","user":"system.user.admin","ts":1704876495776}
          @wolfirr
          Es gibt wohl ein Problem mit 1832412) script.js.Speicher.SN103 Error by subscription (trigger): Wrong ID of type boolean or number.
          Was ist das für ein DP?
            @mading Hallo Mading, auf was referenziert die '1832412'? Finde dazu keinen Zusammenhang. Habe noch sehen, dass da ein verstecktes Blockly war, dass ich nicht gesehen hatte. Nachdem ich es entfernt habe, kommt nur noch der Timeout:
            21:49:00.568	info	javascript.0 (1832412) Start javascript script.js.Speicher.SN103
            21:49:00.783	info	javascript.0 (1832412) script.js.Speicher.SN103: schedule(cron=* * * * *)
            21:49:00.784	info	javascript.0 (1832412) script.js.Speicher.SN103: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
            21:50:00.056	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708103715789,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103715789}
            21:50:00.057	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708094176184,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708094176184}
            21:50:00.059	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
            21:50:00.061	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":13,"ack":true,"ts":1708103895547,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103895547}
            21:50:00.065	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":13,"retain":true}, hasCallback=true)
            21:50:20.060	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
            21:50:20.065	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
            21:51:00.044	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708103715789,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103715789}
            21:51:00.045	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708094176184,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708094176184}
            21:51:00.047	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
            21:51:00.048	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":13,"ack":true,"ts":1708103895547,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103895547}
            21:51:00.049	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":13,"retain":true}, hasCallback=true)
            21:51:20.047	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
            21:51:20.049	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
            21:52:00.040	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708103715789,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103715789}
            21:52:00.040	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708094176184,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708094176184}
            21:52:00.042	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
            21:52:00.043	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":13,"ack":true,"ts":1708103895547,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103895547}
            21:52:00.044	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":13,"retain":true}, hasCallback=true)
            Wolfirr
              @wolfirr schwer zu sagen. Wie oft schickst du Updates an den Speicher oder fragst ihn ab? Wie ist der Speicher angebunden (WLan/ LAN)?
                @mading Danke soweit, ich hab noch ein paar Änderungen und Tests durchgeführt, dann die openWB auf V2 upgedated. Jetzt kommen die Daten an der openWB an und werden auch richtig angezeigt. Hoffe, dass nun auch das PV-Überschussladen richtig funktioniert.
                In der V1.9 openWB war anscheinend ein Fehler mit MQTT, da ich immer Schwierigkeiten hatte den Topic richtig zu bezeichnen und die Schreibweise der houseBattery irgendwie nicht korrekt erkannt wurde.
                Die Gerätschaften sind alle per LAN angeschlossen, da bei mir das WLAN schwierig ist mit dauerhafter Verbindung in die verschiedenen Gebäude.
                Herzlichen Dank an eure Unterstützung!
                Wenn jemand Fragen hat, wie man iobroker mit openWB V2.0 anbindet, jetzt hab ich etwas Erfahrung sammel dürfen und kann vielleicht auch helfen.
                  Mar-Bus @Wolfirr last edited by
                  @wolfirr
                  Hallo wolfirr,
                  ich bin leider nicht sehr erfahren mit MQTT. Ich bin ebenfalls mit dem iobroker unterwegs und möchte Daten meiner openWB mit dem Softwarestand 2.1.4 auslesen.
                  Dazu habe ich den mqtt-client als Adapter heruntergeladen und die ip-Adresse der openWB eingetragen, siehe den Screenshot.
                  Leider bekomme ich aber keine Daten unter den Objekten eingelesen. Mir ist allerdings auch nicht klar, wer als MQTT-Broker agiert. Muss ich dazu erst noch einen MQTT-Broker installieren, oder übernimmt das bereits die openWB? Muss in der openWB die Brücke aktiviert werden? Welche Funktion hat diese Brücke?
                  Herzliche Dank im Voraus, vielleicht kannst Du mir dazu ein paar Infos geben?
                    ag @Mar-Bus last edited by
                    @mar-bus
                    Hallo.
                    Hier https://forum.iobroker.net/topic/43655/wallbox-pv-mit-openwb-in-iobroker-einbinden/64
                    habe ich beschrieben wie ich das bei mir gelöst habe.
                    Die openWB ist der Mqtt Broker.
                      Mar-Bus @ag last edited by
                      @ag
                      Danke für die Info, zwei kurze Fragen:
                      Wenn ich das richtige sehe, hast du sowohl den Broker als auch den Client in deinem iobroker eingerichtet. Werden beide Adapter gebraucht? Oder ist der Broker aus anderen Gründen installiert worden?
                      Die Brücke muss auch eingerichtet werden?
                      Herzliche Grüße
                        @ag
                        Noch eine weitere Frage:
                        ist die Bezeichnung der Brücke im mqtt-client als Class-ID einzutragen, in deinem Beispielen ist die Class-ID "iobr_openwb", während die Brücke in der openWB "ioBroker" lautet, oder sind die Bezeichnungen unabhängig von einander und können beliebig gewählt werden?
                        Danke und Grüße
                          @mar-bus
                          Ich habe auf der OpenWB keine Brücke eingerichtet.
                          Mit MQTT-Explorer kannst du die mal anschauen was die Box ohne Brücke so alles von sich gibt.
                          Den MQTT-Brocker Adapter hat bei mir keinen Bezug zur WB.
                          Die client-ID ist beliebig, muss aber in deinem Netz einmalig sein.
                            @ag
                            Mit welcher Intention hast Du denn dann die Konfiguration der Brücke geteilt. Nur zur Info?
                            Herzliche Grüße
                              @mar-bus
                              Du hats mich erwischt :-), da war was aus der alten WB Software mit reingerutscht.
                              Aktuell so eingestellt:
                                @ag
                                Ok, das macht dann Sinn. Ich habe mir jetzt den mqtt-explorer installiert, dort kann ich sehen, was die openwb published.
                                Leider klappt es mqtt-client-adapter im ioBroker nicht. Unter den Objekten des mqtt-clients werden keine Objekte angezeigt.
                                Irgendeine Idee?
                                  @mar-bus
                                  Die Objekte die du brauchst musst du selbst anlegen und konfigurieren.
                                  Beispiele hier:
                                    @ag
                                    Danke für die Hinweise, ich bin jetzt auf einem anderen Wege zum Erfolg gekommen.
                                    Ich habe den mqtt-Broker/Client-Adapter installiert. Dann habe ich die Verbindungsdaten zur openWB als Client eingepflegt.
                                    Im nächsten Schritt habe ich unter den Client Settings nur die Subscribe Pattern eingepflegt, die für mich interessant sind. Dabei hat der mqtt-explorer mir gute Dienste erwiesen.
                                    Im letzten Schritt habe ich dann unter MQTT Einstellungen die Maske zum Bekanntgeben eigener States geleert, damit wird anscheinend wohl ein Publishing in Richtung openWB vermieden. Ich hatte davor immer Fehlermeldungen im Protokoll, weil Fehler beim Subsriben und Publishen auftraten.
                                    Ein anderer Weg, aber dieser scheint jetzt zu funktionieren.
                                    Danke für die Hilfe.
                                      mading @Mar-Bus last edited by
                                      @mar-bus sagte in Wallbox, PV mit openWB in iobroker einbinden:
                                      @ag
                                      So funktioniert es auch problemlos mit owb 1.x. Hat jemand eine liste der wichtigsten topics zum lesen und setzen oder ggf. schon blockly gebaut? Bin noch auf 1.x und die läuft mit meinen Blockly gut. Im openwb Forum ist alles sehr stark verteilt und kaum/ nicht dokumentiert.
                                        MB11 last edited by
                                        @lesiflo hallo
                                        habe soeben eine Verbindung mit dem MQTT Adapter alles ist grün aber bekomme keine Objekte angezeigt was mache ich falsch ?
                                        bin neu hier und habe schon einiges gelesen und ausprobiert aber komme nicht weiter bin erst am Anfang mit allem 🙂
                                        habe auch schon openWB installiert der Ordner ist auf dem Pi aber wie nutze ich die Daten dann im IObroker ? habe kein plan ?
                                          lesiflo Most Active @mading last edited by lesiflo
                                          @mading Schau mal hier Link Text
                                            lesiflo Most Active @MB11 last edited by
                                            @mb11 Wie sind denn eine Einstellungen im mqtt Adapter?
                                            116
                                            27685
