    4. jarvis v3.2.x - just another remarkable vis
      hotspot_2 @MCU last edited by
      @mcu Danke! Funktioniert wieder.
        hvb @Zefau last edited by hvb
        Hi, Ich hab in machen widgets, z.b. JsonTable, JavaScript zur Formatierung der Werte.
            "field": "updated",
            "label": "Updated",
            "format": "val => {try{formatTimeStamp(val)}catch(err){console.log(err.message)}finally{}}"
        formatTimeStamp ist in Scripts definiert.
        function formatTimeStamp (val) {
             return (val === undefined ? '' : new Date(Number(val)).toLocaleString('de-DE'));    // Timestamp in UNIX format
        In version 3.2.x Beta 10 wird die Formatierung nicht ausgeführt, da die function formatTimeStamp nicht verfügbar ist. Hier noch das Browser Log
        App Time - Processed Users and Groups: 21.00ms
        index-bd3a13be.js:69 Pro Valid Pro User:
        index-bd3a13be.js:131 App Time - Validated pro: 42.00ms
        index-bd3a13be.js:131 settings Loaded from cache.
        index-bd3a13be.js:127 Apply settings...
        index-bd3a13be.js:131 layout Loaded from cache.
        index-bd3a13be.js:131 devices Loaded from cache.
        index-bd3a13be.js:131 widgets Loaded from cache.
        index-bd3a13be.js:131 styles Loaded from cache.
        index-bd3a13be.js:131 scripts Loaded from cache.
        index-bd3a13be.js:131 App Time - Cache loaded: 48.00ms
        6[Violation] Added non-passive event listener to a scroll-blocking <some> event. Consider marking event handler as 'passive' to make the page more responsive. See <URL>
        index-bd3a13be.js:127 settings Received payload and signature has CHANGED!
        index-bd3a13be.js:127 devices Received payload, but signature is unchanged. Do nothing.
        index-bd3a13be.js:131 App Time - Processed Devices: 558.00ms
        VM578:1 formatTimeStamp is not defined
        10VM578:1 formatTimeStamp is not defined
        index-bd3a13be.js:127 widgets Received payload, but signature is unchanged. Do nothing.
        index-bd3a13be.js:127 layout Received payload, but signature is unchanged. Do nothing.
        index-bd3a13be.js:127 styles Received payload, but signature is unchanged. Do nothing.
        index-bd3a13be.js:127 scripts Received payload, but signature is unchanged. Do nothing.
        index-bd3a13be.js:131 App Time - Processed Widgets, Layout, Styles and Scripts: 692.00ms
        index-bd3a13be.js:131 App Sentry is turned on. You may deactivate it in the adapter settings.
        index-bd3a13be.js:24 App Time - Processed Config and Adapter-Instances: 727.00ms
        index-bd3a13be.js:24 App Last Verification:  1717656450757
        index-bd3a13be.js:24 App Development Mode:  false
        index-bd3a13be.js:24 App Time - Verified installation: 729.00ms
        index-bd3a13be.js:24 App Time - Processed Icons: 809.00ms
          MCU @hvb last edited by
          @hvb ab v3.2.0 wurde date() in jDate() umbenannt. Eigene Funktionen gehen nicht.
            hvb @MCU last edited by
            @mcu Das Problem ist nicht der Date() call innerhalb von formatTimeStamp. Gleiches Ergebnis nach Anpassung auf jDate().
            Ich hab noch andere Widgets mit JsonTable die die gleiche Mimik verwenden um values zu formatieren aber kein Date().
            Beim neu laden der Seite werfen alle Aufrufe die auf eine function in Scripts zugreifen einen Error, da die aufgerufene function nicht definiert ist. Vermutlich weil Scripts noch nicht geladen ist zu diesem Zeitpunkt. Wechselt man dann zu einem anderen Tab im Layout und wieder zurück, funktioniert alles.
            Hier mal noch ein paar screen shots und das log:
            Neu laden der Page:
            Log nach neu laden:
            Die Fehler werden geworfen bevor Widgets, Layout, Style und Scripts geladen sind
            Wechsel zu einem anderen tab und wieder zurück -> alles wird so formatiert wie gewünscht. Keine Fehler mehr im Log, da Scripts verfügbar.
              @hvb
              Dann evtl mit
              if (typeof myFunction === 'function') {
              vorher überprüfen, würde aber nur die Fehler verhindern, die Anzeige wäre trotzdem leer.
              Bleibt nur Funktionen zu verwenden, die verfügbar sind, wie jDate().
              Oder direkt die Funktion (new Date(Number(val)).toLocaleString('de-DE')) in format verwenden.
                @MCU Verstehe ich Deine Antwort richtig, dass eigene Funktionen im Moment nicht mehr gehen?
                Kommt das wieder oder wird das künftig nicht mehr unterstützt? Wäre schade, hab das ziemlich oft verwendet.
                  MCU @hvb last edited by MCU
                  @hvb Nein ich wusste es gar nicht, dass sie funktionieren. Habe es nie getestet und gebraucht.
                  Du kannst ja auch ein Issue dafür anlegen, wenn es so in v3.1.8 funktioniert hat.
                  Vielleicht muss man für "eigene Funktionen", die man in jarvis für Module nutzen möchte, ein "Preload"-scripts definieren?
                    @mcu OK, mach ich. Würde sehr bei komplexeren Aktivitäten helfen. Das wird sonst schnell unübersichtlich und nicht mehr wartbar, wenn man alles ins widget packen muss.
                      @hvb Die Frage ist warum du für eine solch große Tabelle nicht ein eigenes javascript nutzt?
                      Dort kannst du dann die Formate vorgeben, auch mit eigenen Funktionen.
                        @mcu Das würde natürlich funktionieren. Da das JSON die Rohdaten enthält und ich es eh per server script erzeuge, könnte ich natürlich auf ein formatierte Version erzeugen für das widget. Das mach Sinn.
                        Ich hab noch einen anderen Anwendungsfall. Ich erzeuge mit styles und client seitigem script aus einer ButtonGroupAction eine ToggelButtonListe die mir auch noch anzeigt, was gerade aktiv ist.
                        Im obigen Fall ein Umschalten zwischen Automatik, Manuell AN, Manuell AUS
                        Das geht nur durch direkte DOM manipulation also nicht serverseitig lösbar.
                          @hvb Zeig mal bitte das Script dazu.
                            @mcu
                            Algemeine function um das richtige Element zu finden und eine Klasse "button-pressed" zu setzen oder wieder zu entfernen:
                            Wird mit der Value des Button, der deviceId und einem Device spezifischen Mapping aufgerufen.
                            function styleButtonGroup(val, deviceId, mapping){
                                //console.log(`val: ${val} deviceId: ${deviceId}`)
                                var buttons = null
                                var button = null
                                var icons = null
                                // see whether there is a widget containing a listItem with a ButtonGroupAction that has a listItemBody containing a hidden label that matches our deviceId
                                var listItems = document.querySelectorAll('.jarvis-StateListItem:has(.jarvis-ButtonGroupAction)')
                                //console.log(listItems)
                                listItems?.forEach((listItem) => {
                                    //console.log(listItem)
                                    var label = listItem.querySelector('.jarvis-StateListItem-Body .q-item__label.q-item__label--caption')
                                    console.log(label)
                                    if(label?.textContent === deviceId) {
                                        buttons = listItem.querySelectorAll('.jarvis-ButtonGroupAction button')
                                        //console.log(buttons)
                                        buttons?.forEach((button) => {
                                            //console.log(button)
                                            if(button.classList.contains('jarvis-ButtonGroupAction-' + mapping[val])) {
                                                button.classList.add('button-pressed')
                                            else{
                                                button.classList.remove('button-pressed')
                                        icons = listItem.querySelectorAll('.jarvis-ButtonGroupAction .icon')
                                        //console.log(icon)
                                        icons?.forEach((icon) => {
                                            //console.log(icon)
                                            for (const scene in mapping) {
                                                const sceneName = mapping[scene]
                                                //console.log(sceneName)
                                                if(icon.classList.contains('jarvis-ButtonGroupAction-' + sceneName)) {
                                                    icon.classList.add(sceneName)
                            // AutoMation Mapping
                            const autoOnOffMapping = {
                              "AUTO":"AUTO",
                              "ON":"ON",
                              "OFF":"OFF"
                            // Wir vom Device aus aufgerufen
                            function styleMotionLightButtonGroup(val, deviceId){
                                styleButtonGroup(val, deviceId, autoOnOffMapping)
                            Und jetzt noch die zugehörigen styles:
                              ButtonGroupAction icon definitiions
                            .AUTO {
                            	--svg: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 24 24'%3E%3Cpath fill='%23000' d='M12.68 6h-1.36L7 16h2l.73-2h4.54l.73 2h2zm-2.38 6.5L12 8l1.7 4.5zm7.1 7.9L19 22h-5v-5l2 2c2.39-1.39 4-4.05 4-7c0-4.41-3.59-8-8-8s-8 3.59-8 8c0 2.95 1.61 5.53 4 6.92v2.24C4.47 19.61 2 16.1 2 12C2 6.5 6.5 2 12 2s10 4.5 10 10c0 3.53-1.83 6.62-4.6 8.4'/%3E%3C/svg%3E");
                            	-webkit-mask-image: var(--svg);
                            .ON {
                            	--svg: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 24 24'%3E%3Cpath fill='%23000' d='m16.56 5.44l-1.45 1.45A5.969 5.969 0 0 1 18 12a6 6 0 0 1-6 6a6 6 0 0 1-6-6c0-2.17 1.16-4.06 2.88-5.12L7.44 5.44A7.961 7.961 0 0 0 4 12a8 8 0 0 0 8 8a8 8 0 0 0 8-8c0-2.72-1.36-5.12-3.44-6.56M13 3h-2v10h2'/%3E%3C/svg%3E");
                            .OFF {
                            	--svg: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 24 24'%3E%3Cpath fill='%23000' d='M12 3a9 9 0 0 0-9 9a9 9 0 0 0 9 9a9 9 0 0 0 9-9a9 9 0 0 0-9-9m0 16a7 7 0 0 1-7-7a7 7 0 0 1 7-7a7 7 0 0 1 7 7a7 7 0 0 1-7 7'/%3E%3C/svg%3E");
                              handle ButtonGroupActions
                              Allow the Group to expand to max-content instead of the default 60%
                            .jarvis-StateListItem-Action:has(.jarvis-ButtonGroupAction) {
                            	/* Styles for ListAction when it contains GroupAction */
                            	max-width: 100% !important;
                            .jarvis-StateListItem:has(.jarvis-ButtonGroupAction) .jarvis-StateListItem-Body .q-item__label.q-item__label--caption {
                            	color: var(--q-primary);
                            	margin-top: -1px;
                            	height: 0px !important;
                            	visibility: hidden;
                              jarvis-ButtonGroupAction gets the class with the background icon via java script
                              and here we define the common styles for this
                            .jarvis-StateListItem:has(.jarvis-ButtonGroupAction) .q-btn__content .icon {
                            	background-color: white !important;
                            	display: inline-block;
                            	width: 16px;
                            	height: 16px;
                            	-webkit-mask-repeat: no-repeat;
                            	-webkit-mask-size: 100% 100%;
                              normally the content of the button is a text lablel, which we want to hide here
                            .jarvis-StateListItem:has(.jarvis-ButtonGroupAction) .q-btn__content:has(.icon)>:not(.icon) {
                            	display: none;
                              highlight the button representing the current state
                            :root {
                            	--q-primary: #1976d2;
                            	--q-primary-red: 25;
                            	--q-primary-green: 118;
                            	--q-primary-blue: 210;
                            .q-btn-group>.q-btn-item.button-pressed {
                            	background-color: rgba(var(--q-primary-red), var(--q-primary-green), var(--q-primary-blue), 0.5) !important;
                            	border: 1px solid grey;
                            Das Widget dazu sieht so aus:
                            Und das zugehörige Device so:
                            Der Trick ist, dass im CustomTextBody die deviceId steckt und das dadurch erzeugte Element hidden ist. Damit kann man das richtige device im Dom finden und dann modifizieren.
                            In den State Properties steht dann der Aufruf der function styleButtonGroup in Script.
                            Damit kann man auch Hue Scenen auf Buttons legen:
                              @hvb Ich probiere es aus und nehme es dann in die Doku, ok?
                                @mcu Gerne.
                                in der 3.1.8 funktioniert das ganz gut. in der 3.2.x ist auch hier das Problem, dass das Script nicht immer aufgerufen wird und die Button Icons dann nicht angezeigt werden. Z.B.
                                nach Seite neu laden:
                                nach klick auf einen Button:
                                beim ersten Popup aufruf:
                                beim nächsten Popup aufruf:
                                hinter dem control mode device liegt ein device in 0.userdata....
                                und im server seitigen script wird dann die MotionLightAutomation behandelt.
                                Zum testen sollten die styles, das script und das device in 0.userdata zum halten des button status aber reichen.
                                Wenn du mehr brauchst, dann kann ich dir nächste Woche noch was liefern oder Fragen beantworten.
                                  MCU last edited by MCU
                                  Neuerung in der Doku (KEIN Jarvis-Standard!)
                                  scripts widgetMinimize -> Widgets mit Header minimieren
                                    @hvb Also bei mir läuft es gar nicht.
                                    Selbst ein einfacher document.querySelektorAll('.jarvis-StateListItem') läuft nicht.
                                    Im ButtonGroup sind auch nur 2 Icons vordefiniert.
                                    Die "add"-Funktion für zusätzliche Buttons fehlt, oder?
                                    Ich muss es mal im v3.1.8 testen.
                                    Auch unter v3.1.8 keinen Erfolg, liegt aber an fehlenden Funktionen.
                                    Es fehlen
                                    • Funktion zum Hinzufügen / Ändern vom Button
                                    • Funktion Änderung / Hinzufügen der Klasse '.jarvis-ButtonGroupAction-' + mapping[val]
                                    In v31.8 werden die querySelektorAll Befehle korrekt ausgeführt.
                                    Habe 2 Issues angelegt
                                    https://github.com/Zefau/ioBroker.jarvis/issues/2651
                                    https://github.com/Zefau/ioBroker.jarvis/issues/2652
                                    In v3.1.8 wird die Funktion aus dem Gerät (Datenpunkt-Eigenschaften) 5x aufgerufen, nach einem Reload.
                                    mcuiobroker created this issue in Zefau/ioBroker.jarvis
                                    closed [v3.2.0-beta.10] scripts: querySelektorAll ohne Funktion #2651
                                    closed [v3.2.0-beta.10] scripts: eigene Funktionen, werden nicht schnell genug geladen -> evtl Preload scripts? #2652
                                      sigi234 Forum Testing Most Active last edited by sigi234
                                      bekomme nach einen Update vom Script Adapter folgende Fehler:
                                      host.SmartHome
                                      2024-06-08 07:05:46.558	error	instance system.adapter.jarvis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      jarvis.0
                                      2024-06-08 07:05:45.901	error	Cannot read properties of undefined (reading 'smartName')
                                      jarvis.0
                                      2024-06-08 07:05:45.901	error	TypeError: Cannot read properties of undefined (reading 'smartName') at AdapterClass.<anonymous> (C:\SmartHome\node_modules\iobroker.jarvis\lib\server.js:1:1621) at AdapterClass.emit (node:events:519:28) at Immediate.<anonymous> (C:\SmartHome\node_modules\@iobroker\js-controller-adapter\build\lib\adapter\adapter.js:8729:49) at process.processImmediate (node:internal/timers:478:21)
                                      jarvis.0
                                      2024-06-08 07:05:45.893	error	uncaught exception: Cannot read properties of undefined (reading 'smartName')
                                      Plattform: Windows
                                      RAM: 15.9 GB
                                      Admin: 6.17.14
                                      Node.js: v20.14.0
                                      NPM: 10.7.0
                                      JS: 5.0.19
                                      JavaScript: 8.5.0
                                      Jarvis: v3.2.0-alpha.7
                                        MCU @sigi234 last edited by MCU
                                        @sigi234 jarvis hat die Version?
                                        Du hast nur den javascript Adapter upgedatet?
                                        Sehe gerade die Signatur, v3.2.0-alpha.7. Immer noch?
                                          sigi234 Forum Testing Most Active @MCU last edited by sigi234
                                          @mcu sagte in jarvis v3.2.x - just another remarkable vis (alpha-testing):
                                          Bei mir ist alles auf Beta und aktuell, denke es war der javascript Adapter, kann aber auch der js-controller sein.
                                          Ja , welche ist die funktionierende Beta? Bin mal auf eine andere Alpha gegangen das ging nix mehr.
                                            @sigi234 Habe noch nicht die 8.5.0 von javascript.
                                            Jarvis läuft mit v3.2.0-beta.10.
                                            v3.2.0-beta.12 (letzte) läuft gar nicht..
                                            smartName sagt mir aber gar nix.
                                            Evtl muss man Deine DPs prüfen.
                                            893
                                            247320
