    4. Wir Empfehlen: Node.js 20.x :-)
      Thomas Braun Most Active @hansmeier last edited by Thomas Braun
      @hansmeier
      Versuch mal:
      iob repo add beta http://download.iobroker.net/sources-dist-latest.json
      iob repo add live-stable http://iobroker.live/repo/sources-dist.json
      iob repo add live-beta http://iobroker.live/repo/sources-dist-latest.json
      iob repo add stable http://download.iobroker.net/sources-dist.json
      iob repo set stable
      iob repo list
        hansmeier @Thomas Braun last edited by
        @thomas-braun sagte in Wir Empfehlen: Node.js 20.x 🙂:
        das widerspricht sich irgendwie:
        $ iob repo add stable http://download.iobroker.net/sources-dist.json
        Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
        $ iob repo list
        List is empty
          @hansmeier
          Keine Ahnung was du da veranstaltest hast. Im Zweifel führe ich es auf die Verwendung des 'root' zurück. Wie immer, wenn ein verrootetes System plötzlich merkwürdige Dinge tut.
          iob repo unset stable
          iob repo del stable
            $ iob repo unset stable
            Repository "stable" deactivated.
            List is empty
            $ iob repo del stable
            Repository "stable" deleted.
            List is empty
            $ iob repo set stable
            Repository "stable" set as active.
            List is empty
            $ iob repo list
            List is empty
              @hansmeier
              Fällt mir nix mehr zu ein.
              • MartinP
                MartinP @Thomas Braun last edited by MartinP
                @thomas-braun Mein Senf:
                hauptseite und forum funktionieren, Repository Down?
                martin@iobroker-test-sicher:/var$ ping iobroker.net
                PING iobroker.net (82.165.135.239) 56(84) bytes of data.
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=55 time=22.0 ms
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=55 time=19.3 ms
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=55 time=17.6 ms
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=55 time=17.9 ms
                ^C
                --- iobroker.net ping statistics ---
                4 packets transmitted, 4 received, 0% packet loss, time 3007ms
                rtt min/avg/max/mdev = 17.605/19.196/21.973/1.721 ms
                martin@iobroker-test-sicher:/var$ ping forum.iobroker.net
                PING forum.iobroker.net (213.136.68.177) 56(84) bytes of data.
                64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=1 ttl=57 time=26.0 ms
                64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=2 ttl=57 time=24.0 ms
                64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=3 ttl=57 time=21.9 ms
                ^C
                --- forum.iobroker.net ping statistics ---
                3 packets transmitted, 3 received, 0% packet loss, time 2003ms
                rtt min/avg/max/mdev = 21.918/23.954/25.978/1.657 ms
                martin@iobroker-test-sicher:/var$ ping download.iobroker.net
                PING download.iobroker.net (93.90.206.45) 56(84) bytes of data.
                ^C
                --- download.iobroker.net ping statistics ---
                3 packets transmitted, 0 received, 100% packet loss, time 2042ms
                  Thomas Braun Most Active @MartinP last edited by Thomas Braun
                  @martinp
                  Der antwortet nicht auf pings.
                  Der host iobroker.net selber antwortet nämlich.
                  MartinP H 2 Replies Last reply Reply Quote 0
                  • MartinP
                    @thomas-braun Das Problem von Gestern sollte behoben sein?
                    forum, Hauptseite und repositories scheinen unterschiedliche IP-Adressen zu haben
                      @martinp sagte in Wir Empfehlen: Node.js 20.x 🙂:
                      Ja, soweit ich weiß läuft wieder alles.
                        @thomas-braun Das heisst dann wohl für mich: ioBroker neu installieren und dann das letzte Backup per Backitup Adapter einspielen ?
                        Proxmox Backup ist zu jung. Da dürfte der Fehler schon enthalten sein.
                        • MartinP
                          @thomas-braun stimmt, aber mit Merkwürdigkeiten gibt einen Redirect auf repo.iobroker.live, ab da geht es per IPv6 weiter:
                          martin@iobroker-test-sicher:~$ wget http://download.iobroker.net/sources-dist.json
                          --2024-06-07 15:31:32--  http://download.iobroker.net/sources-dist.json
                          Resolving download.iobroker.net (download.iobroker.net)... 93.90.206.45
                          Connecting to download.iobroker.net (download.iobroker.net)|93.90.206.45|:80... connected.
                          HTTP request sent, awaiting response... 301 Moved Permanently
                          Location: http://repo.iobroker.live/sources-dist.json [following]
                          --2024-06-07 15:31:32--  http://repo.iobroker.live/sources-dist.json
                          Resolving repo.iobroker.live (repo.iobroker.live)... 2606:4700:3030::ac43:de66, 2606:4700:3035::6815:56aa, 104.21.86.170, ...
                          Connecting to repo.iobroker.live (repo.iobroker.live)|2606:4700:3030::ac43:de66|:80... connected.
                          HTTP request sent, awaiting response... 200 OK
                          Length: 4600604 (4.4M) [application/json]
                          Saving to: 'sources-dist.json'
                          sources-dist.json              100%[====================================================>]   4.39M  --.-KB/s    in 0.1s
                          2024-06-07 15:31:33 (36.9 MB/s) - 'sources-dist.json' saved [4600604/4600604]
                          EDIT: Gibt ja auch eine IPv4 Adresse, und die lässt sich auch anpingen....
                            hansmeier last edited by hansmeier
                            IPv6 habe ich in meinem Router ungefähr zum gleichen Zeitpunkt wo ich keine Updates mehr angezeigt bekam, deaktiviert.
                            Der Grund waren Probleme mit WireGuard.
                            Es könnte also ein Zusammenhang bestehen.
                            Hab jetzt mal IPv6 wieder freigegeben.
                            Bringt aber leider keine Änderung
                              @hansmeier sagte in Wir Empfehlen: Node.js 20.x 🙂:
                              Schlechte Idee.
                              Versuch es mal mit
                              iob setup first
                                iob setup first
                                Cool ! Das hat es gebracht. Die Repositories sind wieder da. Und gleich kamen 11 Adapter Updates hoch.
                                Danke, du hast meinen Tag gerettet.
                                Ich muss mal Proxmox unbedingt so einstellen, dass die Backups länger zurückreichen als eine Woche. 🙄
                                                        v.2024-05-22
                                 Static hostname: ioBrokerUbuntu2204
                                       Icon name: computer-container
                                         Chassis: container
                                  Virtualization: lxc
                                Operating System: Ubuntu 22.04.4 LTS
                                          Kernel: Linux 6.8.4-3-pve
                                    Architecture: x86-64
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1001
                                Display-Server:         false
                                Boot Target:            graphical.target
                                Pending OS-Updates:     0
                                Pending iob updates:    11
                                Nodejs-Installation:
                                /usr/bin/nodejs         v20.14.0
                                /usr/bin/node           v20.14.0
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                /usr/bin/corepack       0.28.1
                                Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                MEMORY:
                                Mem:            6.1G        2.2G        3.1G        0.0K        811M        3.9G
                                Swap:           2.0G          0B        2.0G
                                Total:          8.2G        2.2G        5.2G
                                Active iob-Instances:   39
                                Active repo(s): stable
                                ioBroker Core:          js-controller           5.0.19
                                                        admin                   6.13.16
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : ioBrokerUbuntu2204                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : ioBrokerUbuntu2204                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                17559
                                States:                 15478
                                Size of iob-Database:
                                17M     /opt/iobroker/iobroker-data/objects.jsonl
                                12M     /opt/iobroker/iobroker-data/objects.json.migrated
                                12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                9.4M    /opt/iobroker/iobroker-data/states.jsonl
                                2.3M    /opt/iobroker/iobroker-data/states.json.migrated
                                2.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                • mcm1957
                                  mcm1957 @hansmeier last edited by
                                  Die Repositories kann man übrigends auch via Browser checken:
                                  https://repo.iobroker.live/sources-dist-latest.json
                                  https://repo.iobroker.live/sources-dist.json
                                  sollten ein größeres json liefern. In edge ist es bei mir auch bracuhbar formatiert, in chrome nicht.
                                    Homoran Global Moderator Administrators @mcm1957 last edited by
                                    @mcm1957 sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                    leider klappt das oft 8bw8hl der ioBroker Probleme hat.
                                    • mcm1957
                                      mcm1957 @Homoran last edited by
                                      Ja - aber da ihr oben gemutmaßt habt dass der Server weg ist wäre das in dem Fall eine Testmöglichkeit. Wenn das nicht geht ists klar dass was am Server klemmt ...
                                      • MartinP
                                        MartinP @DJMarc75 last edited by MartinP
                                        @djmarc75 said in Wir Empfehlen: Node.js 20.x 🙂:
                                        @myssv sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                        folgende Fehler
                                        Du wohnst in einer Zone wo es diese beiden Astros im Moment nicht gibt.
                                        Kann man ignorieren und ist in der neuen Version 8.4.2 vom JavaSkriptAdapter behoben.
                                        Hmm, in wohne in Dortmund, ist eigentlich nicht nahe genug am Polarkreis um dieses Meldungen zu triggern - oder muss man da irgendwo seinen Geo-Position eintragen?
                                        In den Basiseinstellungen ist das erfolgt..
                                        Homoran Marc Berg 2 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @MartinP last edited by
                                          Hmm, in wohne in NRW, ist eigentlich nicht nahe genug am Polarkreis um dieses Meldungen zu triggern -
                                          aber sicher doch!
                                          sieh mal bei sonnenverlauf.de nach ob bei dir die Sonne unter -18° Elevation kommt.
                                          Würde mich sehr wundern.
                                          • Marc Berg
                                            Marc Berg Most Active @MartinP last edited by
                                            Alles ca. nördlich des 49. Breitengrades ist davon "betroffen", also auch NRW.
                                            MartinP 1 Reply Last reply Reply Quote 1
                                            1.3k
                                            237
                                            71247
