    4. Wir Empfehlen: Node.js 20.x :-)
      hansmeier @Thomas Braun last edited by
      @thomas-braun sagte in Wir Empfehlen: Node.js 20.x 🙂:
      iob repo add stable http://download.iobroker.net/sources-dist.json
      das widerspricht sich irgendwie:
      $ iob repo add stable http://download.iobroker.net/sources-dist.json
      Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
      $ iob repo list
      List is empty
        Thomas Braun Most Active @hansmeier last edited by Thomas Braun
        @hansmeier
        Keine Ahnung was du da veranstaltest hast. Im Zweifel führe ich es auf die Verwendung des 'root' zurück. Wie immer, wenn ein verrootetes System plötzlich merkwürdige Dinge tut.
        iob repo unset stable
        iob repo del stable
          $ iob repo unset stable
          Repository "stable" deactivated.
          List is empty
          $ iob repo del stable
          Repository "stable" deleted.
          List is empty
          $ iob repo set stable
          Repository "stable" set as active.
          List is empty
          $ iob repo list
          List is empty
            @hansmeier
            Fällt mir nix mehr zu ein.
            • MartinP
              MartinP @Thomas Braun last edited by MartinP
              @thomas-braun Mein Senf:
              hauptseite und forum funktionieren, Repository Down?
              martin@iobroker-test-sicher:/var$ ping iobroker.net
              PING iobroker.net (82.165.135.239) 56(84) bytes of data.
              64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=55 time=22.0 ms
              64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=55 time=19.3 ms
              64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=55 time=17.6 ms
              64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=55 time=17.9 ms
              ^C
              --- iobroker.net ping statistics ---
              4 packets transmitted, 4 received, 0% packet loss, time 3007ms
              rtt min/avg/max/mdev = 17.605/19.196/21.973/1.721 ms
              martin@iobroker-test-sicher:/var$ ping forum.iobroker.net
              PING forum.iobroker.net (213.136.68.177) 56(84) bytes of data.
              64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=1 ttl=57 time=26.0 ms
              64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=2 ttl=57 time=24.0 ms
              64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=3 ttl=57 time=21.9 ms
              ^C
              --- forum.iobroker.net ping statistics ---
              3 packets transmitted, 3 received, 0% packet loss, time 2003ms
              rtt min/avg/max/mdev = 21.918/23.954/25.978/1.657 ms
              martin@iobroker-test-sicher:/var$ ping download.iobroker.net
              PING download.iobroker.net (93.90.206.45) 56(84) bytes of data.
              ^C
              --- download.iobroker.net ping statistics ---
              3 packets transmitted, 0 received, 100% packet loss, time 2042ms
                Thomas Braun Most Active @MartinP last edited by Thomas Braun
                @martinp
                Der antwortet nicht auf pings.
                Der host iobroker.net selber antwortet nämlich.
                MartinP H 2 Replies Last reply Reply Quote 0
                • MartinP
                  @thomas-braun Das Problem von Gestern sollte behoben sein?
                  forum, Hauptseite und repositories scheinen unterschiedliche IP-Adressen zu haben
                    @martinp sagte in Wir Empfehlen: Node.js 20.x 🙂:
                    Ja, soweit ich weiß läuft wieder alles.
                      @thomas-braun Das heisst dann wohl für mich: ioBroker neu installieren und dann das letzte Backup per Backitup Adapter einspielen ?
                      Proxmox Backup ist zu jung. Da dürfte der Fehler schon enthalten sein.
                      • MartinP
                        @thomas-braun stimmt, aber mit Merkwürdigkeiten gibt einen Redirect auf repo.iobroker.live, ab da geht es per IPv6 weiter:
                        martin@iobroker-test-sicher:~$ wget http://download.iobroker.net/sources-dist.json
                        --2024-06-07 15:31:32--  http://download.iobroker.net/sources-dist.json
                        Resolving download.iobroker.net (download.iobroker.net)... 93.90.206.45
                        Connecting to download.iobroker.net (download.iobroker.net)|93.90.206.45|:80... connected.
                        HTTP request sent, awaiting response... 301 Moved Permanently
                        Location: http://repo.iobroker.live/sources-dist.json [following]
                        --2024-06-07 15:31:32--  http://repo.iobroker.live/sources-dist.json
                        Resolving repo.iobroker.live (repo.iobroker.live)... 2606:4700:3030::ac43:de66, 2606:4700:3035::6815:56aa, 104.21.86.170, ...
                        Connecting to repo.iobroker.live (repo.iobroker.live)|2606:4700:3030::ac43:de66|:80... connected.
                        HTTP request sent, awaiting response... 200 OK
                        Length: 4600604 (4.4M) [application/json]
                        Saving to: 'sources-dist.json'
                        sources-dist.json              100%[====================================================>]   4.39M  --.-KB/s    in 0.1s
                        2024-06-07 15:31:33 (36.9 MB/s) - 'sources-dist.json' saved [4600604/4600604]
                        EDIT: Gibt ja auch eine IPv4 Adresse, und die lässt sich auch anpingen....
                          hansmeier last edited by hansmeier
                          IPv6 habe ich in meinem Router ungefähr zum gleichen Zeitpunkt wo ich keine Updates mehr angezeigt bekam, deaktiviert.
                          Der Grund waren Probleme mit WireGuard.
                          Es könnte also ein Zusammenhang bestehen.
                          Hab jetzt mal IPv6 wieder freigegeben.
                          Bringt aber leider keine Änderung
                            @hansmeier sagte in Wir Empfehlen: Node.js 20.x 🙂:
                            Schlechte Idee.
                            Versuch es mal mit
                            iob setup first
                              iob setup first
                              Cool ! Das hat es gebracht. Die Repositories sind wieder da. Und gleich kamen 11 Adapter Updates hoch.
                              Danke, du hast meinen Tag gerettet.
                              Ich muss mal Proxmox unbedingt so einstellen, dass die Backups länger zurückreichen als eine Woche. 🙄
                                                      v.2024-05-22
                               Static hostname: ioBrokerUbuntu2204
                                     Icon name: computer-container
                                       Chassis: container
                                Virtualization: lxc
                              Operating System: Ubuntu 22.04.4 LTS
                                        Kernel: Linux 6.8.4-3-pve
                                  Architecture: x86-64
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              Timezone:               Europe/Berlin (CEST, +0200)
                              User-ID:                1001
                              Display-Server:         false
                              Boot Target:            graphical.target
                              Pending OS-Updates:     0
                              Pending iob updates:    11
                              Nodejs-Installation:
                              /usr/bin/nodejs         v20.14.0
                              /usr/bin/node           v20.14.0
                              /usr/bin/npm            10.7.0
                              /usr/bin/npx            10.7.0
                              /usr/bin/corepack       0.28.1
                              Recommended versions are nodejs 18.20.3 and npm 10.7.0
                              MEMORY:
                              Mem:            6.1G        2.2G        3.1G        0.0K        811M        3.9G
                              Swap:           2.0G          0B        2.0G
                              Total:          8.2G        2.2G        5.2G
                              Active iob-Instances:   39
                              Active repo(s): stable
                              ioBroker Core:          js-controller           5.0.19
                                                      admin                   6.13.16
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : ioBrokerUbuntu2204                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : ioBrokerUbuntu2204                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                17559
                              States:                 15478
                              Size of iob-Database:
                              17M     /opt/iobroker/iobroker-data/objects.jsonl
                              12M     /opt/iobroker/iobroker-data/objects.json.migrated
                              12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              9.4M    /opt/iobroker/iobroker-data/states.jsonl
                              2.3M    /opt/iobroker/iobroker-data/states.json.migrated
                              2.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              • mcm1957
                                mcm1957 @hansmeier last edited by
                                Die Repositories kann man übrigends auch via Browser checken:
                                https://repo.iobroker.live/sources-dist-latest.json
                                https://repo.iobroker.live/sources-dist.json
                                sollten ein größeres json liefern. In edge ist es bei mir auch bracuhbar formatiert, in chrome nicht.
                                  Homoran Global Moderator Administrators @mcm1957 last edited by
                                  @mcm1957 sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                  leider klappt das oft 8bw8hl der ioBroker Probleme hat.
                                  • mcm1957
                                    mcm1957 @Homoran last edited by
                                    Ja - aber da ihr oben gemutmaßt habt dass der Server weg ist wäre das in dem Fall eine Testmöglichkeit. Wenn das nicht geht ists klar dass was am Server klemmt ...
                                    • MartinP
                                      MartinP @DJMarc75 last edited by MartinP
                                      @djmarc75 said in Wir Empfehlen: Node.js 20.x 🙂:
                                      @myssv sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                      folgende Fehler
                                      Du wohnst in einer Zone wo es diese beiden Astros im Moment nicht gibt.
                                      Kann man ignorieren und ist in der neuen Version 8.4.2 vom JavaSkriptAdapter behoben.
                                      Hmm, in wohne in Dortmund, ist eigentlich nicht nahe genug am Polarkreis um dieses Meldungen zu triggern - oder muss man da irgendwo seinen Geo-Position eintragen?
                                      In den Basiseinstellungen ist das erfolgt..
                                      Homoran Marc Berg 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @MartinP last edited by
                                        Hmm, in wohne in NRW, ist eigentlich nicht nahe genug am Polarkreis um dieses Meldungen zu triggern -
                                        aber sicher doch!
                                        sieh mal bei sonnenverlauf.de nach ob bei dir die Sonne unter -18° Elevation kommt.
                                        Würde mich sehr wundern.
                                        • Marc Berg
                                          Marc Berg Most Active @MartinP last edited by
                                          Alles ca. nördlich des 49. Breitengrades ist davon "betroffen", also auch NRW.
                                          MartinP 1 Reply Last reply Reply Quote 1
                                          • MartinP
                                            MartinP @Marc Berg last edited by
                                            @marc-berg said in Wir Empfehlen: Node.js 20.x 🙂:
                                            Irritierend, aber wenn, wie @homoran schrieb die "Nacht" erst beginnt, wenn die Sonne 18° unter dem Horizont steht ist das wahrscheinlich unter dem Gesichtspunkt, dass es selbst bei Neumond nie GANZ dunkel wird eine schlüssige Definition.
                                            1.2k
                                            237
                                            71247
