    4. Test eCharts Adapter
      Maas-Meister last edited by
      Brauche dringend Hilfe: (schon super viel Zeit verbrannt)
      Ich möchte meinen Stromverbrauch + Stromkosten nebeneinander in ein Balken-Diagramm anzeigen lassen.
      Als Quelle habe ich ein json-string
      [{"from":"2023-03-01T00:00:00.000+01:00","to":"2023-04-01T00:00:00.000+02:00","cost":137.372376561,"unitPrice":0.25357,"unitPriceVAT":0.040486,"consumption":541.754,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-04-01T00:00:00.000+02:00","to":"2023-05-01T00:00:00.000+02:00","cost":90.7700860794,"unitPrice":0.243949,"unitPriceVAT":0.03895,"consumption":372.087,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-05-01T00:00:00.000+02:00","to":"2023-06-01T00:00:00.000+02:00","cost":45.3044254425,"unitPrice":0.219539,"unitPriceVAT":0.035052,"consumption":206.362,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-06-01T00:00:00.000+02:00","to":"2023-07-01T00:00:00.000+02:00","cost":41.3673965509,"unitPrice":0.234526,"unitPriceVAT":0.037445,"consumption":176.387,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-07-01T00:00:00.000+02:00","to":"2023-08-01T00:00:00.000+02:00","cost":44.7069721861,"unitPrice":0.225864,"unitPriceVAT":0.036062,"consumption":197.938,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-08-01T00:00:00.000+02:00","to":"2023-09-01T00:00:00.000+02:00","cost":58.4057955355,"unitPrice":0.247937,"unitPriceVAT":0.039587,"consumption":235.567,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-09-01T00:00:00.000+02:00","to":"2023-10-01T00:00:00.000+02:00","cost":62.7189878063,"unitPrice":0.257247,"unitPriceVAT":0.041073,"consumption":243.808,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-10-01T00:00:00.000+02:00","to":"2023-11-01T00:00:00.000+01:00","cost":113.0440595319,"unitPrice":0.243011,"unitPriceVAT":0.0388,"consumption":465.18,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-11-01T00:00:00.000+01:00","to":"2023-12-01T00:00:00.000+01:00","cost":165.1500357416,"unitPrice":0.24995,"unitPriceVAT":0.039908,"consumption":660.731,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-12-01T00:00:00.000+01:00","to":"2024-01-01T00:00:00.000+01:00","cost":218.4211066317,"unitPrice":0.21144,"unitPriceVAT":0.033759,"consumption":1033.019,"consumptionUnit":"kWh","currency":"EUR"}]
      Dieses formatiere ich in ein E-Charts taugliches JSON um und logge dies mit History:
          "ts": 1677625200000,
          "val": 541.754
          "ts": 1680300000000,
          "val": 372.087
          "ts": 1682892000000,
          "val": 206.362
          "ts": 1685570400000,
          "val": 176.387
          "ts": 1688162400000,
          "val": 197.938
          "ts": 1690840800000,
          "val": 235.567
          "ts": 1693519200000,
          "val": 243.808
          "ts": 1696111200000,
          "val": 465.18
          "ts": 1698793200000,
          "val": 660.731
          "ts": 1701385200000,
          "val": 1033.019
      Wenn ich dieses in E-Charts bringen will, werden mir die Monate angezeigt, aber keine Werte.
      Hab es schon aus der History Datenbank + direkt als json - beides ohne Erfolg.
      Wie muss das json aussehen damit ich Balken sehen kann?
        Sombornus @Maas-Meister last edited by
        Servus @maas-meister,
        ich habe folgendes festgestellt: Wieso auch immer funktioniert die Darstellung von Bar-Charts auf Basis von JSON Daten nur mit dem Firefox Browser!
        Aus meiner Sicht sieht das JSON Beispiel von Dir gut aus. Probiere einfach mal den Firefox aus.
        So sieht jedenfalls Dein Beispiel bei mir aus:
          Maas-Meister @Sombornus last edited by
          @sombornus sagte in Test eCharts Adapter:
          MEGA, danke für den Tipp!
          Werde ich später testen - auch ob der Fully Browser dies richtig wieder gibt.
          Wenn ich "Line" einstellen, wird mir was angezeigt. Sobald ich auf "Bar" stelle sehe ich gar nichts mehr.
          Was hast du unten noch eingestellt?
          • U
            user12 last edited by user12
            Guten Tag, hat jemand zufällig eine Idee.
            Ich habe mit einigen Videoanleitungen mein ersten Versuche geschafft und habe einen Sensor in IOBroker integriert und möchte diese Daten per Telegram an mich senden.
            Der Export und und das dazugehörige Kommando klappt gut.
            Ich möchte gerne die Bildgröße, die mir mein Telegrambot anzeigt ändern. Im Moment hat es folgende Auflösungen: 1024x300.
            Kann man das irgendwie ändern?
            Danke für die Tipps
            Hier das zugehörige Blockly
            • David G.
              David G. @user12 last edited by
              @user12
              Ich mache es so
              U 1 Reply Last reply Reply Quote 1
              • U
                user12 @David G. last edited by
                @david-g
                Danke, hat super geklappt)
                • Latzi
                  Latzi last edited by
                  Gibt es eine Möglichkeit, bei mehrfachen y-Achsenskalen die Werte zu versetzen, damit sie nicht übereinander erscheinen?
                  • Steffe.S.
                    Steffe.S. last edited by
                    Hallo, gibt es eine Möglichkeit, die Schrift oben links etwas weiter nach rechts zu rücken? Irgendwie hängt die Schrift immer über der Bezeichnung der Y Achse linksbündig (egal was ich im Adapter einstelle die Schrift ist immer oben links. Oben recht, unten recht / links wird nicht berücksichtigt)
                    BananaJoe Steffe.S. 2 Replies Last reply Reply Quote 0
                    • BananaJoe
                      BananaJoe Most Active @Steffe.S. last edited by
                      @steffe-s also bei mir ist diese zwar unten, wird aber immer innerhalb der Grafik angezeigt:
                      Oben auch:
                      Spiel mal weiter mit den Einstellungen
                      • Steffe.S.
                        Steffe.S. @Steffe.S. last edited by Steffe.S.
                        @steffe-s sagte in Test eCharts Adapter:
                        ... unter Optionen habe ich Auto-Abstand ausgeschaltet, dann passt es mit der Schrift. Wenn ich Auto-Abstand wieder einschalte ist der beschriebene Fehler wieder da, es liegt also definitiv an der Einstellung. Kann das Problem / die Lösung vielleicht jemand destätigen bzw. testen?
                        • BananaJoe
                          BananaJoe Most Active @Steffe.S. last edited by BananaJoe
                          @steffe-s Auto-Abstand kann in der Tat komische Effekte hervorrufen. Bei manchen meiner eCharts ist keine Änderungen zu erkennen, bei anderen verschiebt es sich dann wie bei dir ungünstig.
                          Kommt wohl auf die Kombination der Parameter an.
                          • spicer
                            spicer last edited by
                            Ist etwa auch das schuld, dass der negative X-Offset immer noch nicht funzt, obschon der Dev das eingebunden hat?
                              stenmic @Bluefox last edited by stenmic
                              @bluefox
                              Hi, zwei Fragen.
                              Sobald ich bei echart das Grid einfärbe wird es gestrichelt dargestellt. Ist das normal?
                              Schön wäre auch wenn man mehr Optionen aus Datenpunkten übernehmen könnte.
                              z.B. Farben und Zeitbereiche. Dann könnte man mehr über die VIS steuern.
                              Bei Farben meine ich, wenn der Wert für mich positiv ist möchte ich ne grüne Line, bei schlechten Werten eine Rote. Die Farbe steht in einem Datenpunkt, den ich je nach Situation flexibel anpasse.
                              Oder vielleicht könnte man Bindings analog vis nutzen. Dann wäre der Adapterfür mich der Killer für Grafana.
                                micklafisch last edited by
                                Der eChart Adapter flackert alle 10 Sekunden kurz auf und scheint sich zu aktualisieren (per HTML Widget mittels Binding als auch mit dem eChart Widget). Kann dies auch manuell angestoßen werden?
                                Grund ist, ich manipuliere mit JSON in einem Chart eine zweite Linie welchen einen Bereich im Chart markiert. Wenn ich jetzt das JSON ändere, wird erst mit der nächsten Aktualisierung dieses JSON verarbeitet und angezeigt-> im schlimmsten Fall 9,9 Sekunden. Hört sich trivial an, aber wenn nach dem auslösen nichts passiert, sind fast 10 Sekunden lange bis optisch sich was ändert.
                                Leider funktioniert das laut Github zum JSON erwähnte
                                 The chart will be automatically updated every time the value changes.
                                nicht, sondern lediglich nur alle 10 Sekunden.
                                  ergänzend kann ich berichten, dass bei einer Änderung der Daten im Datenpunkt die JSON Linie sofort ausgeblendet wird, aber die Anzeige der geänderten Daten erst nach der oben genannten Aktualisierung erfolgt. Dabei ist es auch egal ob die JSON Linie an erster Stelle oder an zweiter Stelle im Chart ist.
                                  • Gargano
                                    Gargano last edited by
                                    Wenn sich das Chart aktualisiert, wird oben ein laufender Balken eingeblendet. Dadurch verschiebt sich das Chart kurz ein Stück nach unten. Also ein Zucken nach unten.
                                    Kann ich diese Zucken unterbinden ?
                                    • D3ltoroxp
                                      D3ltoroxp last edited by
                                      Ich hänge mich hier mal mit an. Ich versuche mich gerade mit dem eChart Adapter. Nun würde ich gerne das Widget in der VIS nutzen, leider taucht es bei mir nicht auf. Habe schon upload vis und Strg+F5 probiert. Bekomme das Widget leider nicht angezeigt.
                                      -cs- sigi234 Bernd1967 3 Replies Last reply Reply Quote 0
                                      • -cs-
                                        -cs- @D3ltoroxp last edited by
                                        Hi, entweder hab ich was übersehen, auf alle fälle finde es nicht.
                                        Wenn ich in einem EChart, dargestellt in auf einem Mobilen Gerät, egal ob Fully Browser oder ioBroker- App, einzelne Charte ausblenden möchte funktioniert das nicht.
                                        Am PC kann man ja einzelne Charts aus und einblenden, aber auf mobilen Geräten scheint es mir so, als wie wenn es immer einen Doppelcklick ausführt. Sprich man kann keine einzelnen Charts ein-/ausblenden.
                                        Wie bringe ich es fertig an mobilen Geräten einzelne Charts aus- oder einzublenden?
                                        Schöne Grüße
                                        Christian
                                          sigi234 Forum Testing Most Active @D3ltoroxp last edited by
                                          @d3ltoroxp
                                          Lösche den Filter mal
                                          • D3ltoroxp
                                            D3ltoroxp @sigi234 last edited by
                                            @sigi234 Du meinst hier ?
                                            Hab ich raus und mal komplett durchgescrollt, aber ich sehe kein eCharts.
                                            echarts
                                            105
                                            652
                                            165683
