    4. Gelöst Sonoff T1 TX 2CH als Rollladensteuerung
      Einstein2002 @Dieter_P last edited by
      @dieter_p
      dann macht er das:
      14:21:57.102 CMD: ShutterPosition1 50
      14:21:57.112 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER2":"ON"}
      14:21:57.117 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER2 = ON
      14:21:57.124 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":100,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:57.145 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":100}'
      14:21:57.228 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":100}
      14:21:57.242 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":99,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:57.263 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":99}'
      14:21:57.293 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":99}
      14:21:58.278 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":93,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:58.300 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":93}'
      14:21:58.326 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":93}
      14:21:59.259 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":86,"Direction":-1,"Target":50,"Tilt":0}}
      14:21:59.281 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":86}'
      14:21:59.308 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":86}
      14:22:00.273 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":79,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:00.296 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":79}'
      14:22:00.321 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":79}
      14:22:01.277 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":73,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:01.299 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":73}'
      14:22:01.327 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":73}
      14:22:02.307 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":66,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:02.328 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":66}'
      14:22:02.341 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":66}
      14:22:03.273 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":59,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:03.295 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":59}'
      14:22:03.322 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":59}
      14:22:04.246 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":53,"Direction":-1,"Target":50,"Tilt":0}}
      14:22:04.269 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":53}'
      14:22:04.296 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":53}
      14:22:04.697 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER2":"ON"}
      14:22:04.702 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER2 = ON
      14:22:04.707 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/SHUTTER1 = 50
      14:22:04.712 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:04.733 RUL: SHUTTER1#POSITION performs 'backlog publish stat/Fit_Rollo/RESULT {"ShutterPosition1":50}'
      14:22:04.830 MQT: stat/Fit_Rollo/RESULT = {"ShutterPosition1":50}
      14:22:06.247 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:22:06","Uptime":"0T00:54:10","UptimeSec":3250,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":26,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}
      14:22:06.258 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:22:06","Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:16.250 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:22:16","Uptime":"0T00:54:20","UptimeSec":3260,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":36,"Signal":-82,"LinkCount":1,"Downtime":"0T00:00:04"}}
      14:22:16.258 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:22:16","Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:26.243 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/STATE = {"Time":"2024-05-28T14:22:26","Uptime":"0T00:54:30","UptimeSec":3270,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":25,"MqttCount":1,"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"IoT","BSSId":"F4:92:BF:AA:EC:39","Channel":3,"Mode":"11n","RSSI":36,"Signal":-82,"LinkCount":1,"Downtime":"0T00:00:04"}}
      14:22:26.255 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/tele/SENSOR = {"Time":"2024-05-28T14:22:26","Shutter1":{"Position":50,"Direction":0,"Target":50,"Tilt":0}}
      14:22:34.717 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"POWER2":"OFF"}
      14:22:34.722 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/POWER2 = OFF
      Es wird die 50 angefahren, bleibt aber nicht stehen und wie man erkennen kann kommt der Power2 OFF Befehl erst viel später. 😞
        @dieter_p
        Auch der Schieber erkennt das, blöde ist nur der Rollo ist ganz zu...😁
          Dieter_P @Einstein2002 last edited by
          @einstein2002
          Wenn er die Laufzeiten nicht nimmt, würde ich versuchen über
          ShutterSetClose<x>
          ShutterSetOpen<x>
          und ggf über ShutterCalibration<x> zu ergänzen.
          Klappt das alles nicht wirklich, hängt ggf. irgendwo was und ein Factory Reset mit anschließendem Neuversuch nach Kalibrierungsanleitung funtzt dann.
          E 2 Replies Last reply Reply Quote 0
            Einstein2002 @Dieter_P last edited by Einstein2002
            @dieter_p sagte in Sonoff T1 TX 2CH als Rollladensteuerung:
            @einstein2002
            ShutterSetClose<x>
            ShutterSetOpen<x>
            Das X ShutterSetClose<x> bleibt oder soll ich es so verändern ShutterSetClose<1> ??
            Da war ich mir nie sicher!
              @dieter_p
              14:41:12.387 CMD: ShutterSetClose<x>
              14:41:12.396 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"ShutterSetClose1":"Konfiguration zurücksetzen"}
              14:41:54.859 CMD: ShutterSetOpen<x>
              14:41:54.868 MQT: SmartHome/Haus/Obergeschoss/Fitness/Fit_Rollo/stat/RESULT = {"ShutterSetOpen1":"Konfiguration zurücksetzen"}
                Dieter_P @Einstein2002 last edited by Dieter_P
                @einstein2002 said in Sonoff T1 TX 2CH als Rollladensteuerung:
                @einstein2002
                ShutterSetClose<x>
                ShutterSetOpen<x>
                das <x> ist zu ersetzen durch den Shutter den Du zurück setzen möchtest also bei dir Nr1
                ShutterSetClose1
                  @dieter_p
                  was mir jetzt erst auffällt, ich kann den nicht mehr stoppen, soll heißen wenn ich power1 einmal drücke fährt er hoch, drücke ich noch einmal power1 bleibt er stehen. Das macht der hier nicht!
                  Warum?
                    @dieter_p
                    So ich habe den jetzt neu aufgebaut, hatte zum Glück eine Datensicherung von früher.
                    Jetzt gehen die Tasten wieder so wie sie sollen, dann versuche ich es mal erneut. Falls hier einer einen Tipp haben sollte, gerne her damit.
                    Dankeschön jetzt schon mal
                      Einstein2002 last edited by Einstein2002
                      Hallo Leute,
                      Problem gelöst.
                      Es lag an der Pulstime.
                      Diese muß!! Auf "0" gesetzt werden. Danach die Zeiten nochmals für eine Hoch und eine Runterfahrt mit der Stoppuhr ermittelt und eingegeben.
                      Dies habe ich bei Github gefunden dazu:
                      backlog SetOption80 1; SetOption13 1; ShutterRelay1 1; PulseTime1 0; PulseTime2 0; Pulsetime3 1; Interlock 1,2,3; Interlock ON; PowerRetain 1
                      Und was soll ich sagen... es läuft!!
                      Ich hoffe dies hilft einen von Euch weiter.
                      Grüße Michael
                      • Santos
                        Santos last edited by
                        Guten Morgen zusammen,
                        Ich wollte keinen separaten Thread aufmachen, deswegen frage einfach hier.
                        Bei mir zu Hause sind 7 Fenster mit dem 2Ch Sonoff Schalter installiert und mit Tasmota gefälscht. Bei zwei letzten Fenster habe ich bei der Installation etwas schief gemacht, kriege es nicht mehr logisch kalibriert. Programmiert sind sie so, dass sie morgens auf 100% Open fahren und abends auf 30% abdunkeln.
                        Ich schildere kurz das Problem.
                        Wenn ich das Fenster ganz aufmache (power1), ist die Rolllade ganz oben und das Fenster ist somit offen, steht auf 100% Open bei den Datenpunkten in ioBroker.
                        Nach ein paar Tagen merke ich, dass die Rollladen bei 100% immer mehr durchhängen, bis sie irgendwann nach einer Woche mit halb verdunkelten Fenster stehen, obwohl im Datenpunkt 100% Open steht. Ich weiß, dass ich sie falsch kalibriert habe, stehe aber auf dem Schlauch und bekomme es nicht mehr hin.
                        Abhilfe schafft es, wenn ich die Rolladen mit power2 ganz zu mache, dann mit power1 ganz auf, so steht Macher das Fenster offen. Das nervt aber natürlich, jede Woche das durchzuführen.
                        Vielleicht findet jemand Zeit und Lust mir den Fehler zu erklären.
                        Danke im Voraus
                        599
