    • amg_666
      amg_666 @simatec last edited by amg_666
      @simatec sagte in Test Adapter ioBroker.backitup v3.0.x:
      @amg_666 Wird gefixt
      Mit der 3.0.1 sieht das gut aus, er zeigt jetzt alle gesicherten Skripte im Log an. Danke!
        fastfoot last edited by
        @simatec tolle Arbeit, ist absolut gelungen!
        • O
          oFbEQnpoLKKl6mbY5e13 last edited by
          @simatec
          2024-05-29 20:26:47.224  - info: backitup.0 (1159) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.3, js-controller: 5.0.19
          2024-05-29 20:26:47.723  - info: backitup.0 (1159) [iobroker] backup will be activated at 01:30 every 1 day(s)
          2024-05-29 20:26:47.952  - info: backitup.0 (1159) [ccu] backup will be activated at 01:20 every 3 day(s)
          2024-05-29 20:26:54.225  - warn: admin.0 (15872) backitup has an invalid jsonConfig: [{"instancePath":"/items/_options","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/required","keyword":"required","params":{"missingProperty":"items"},"message":"must have required property 'items'"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
            Shadowhunter23 @oFbEQnpoLKKl6mbY5e13 last edited by
            @ofbeqnpolkkl6mby5e13
            Bzgl. der Warnung: https://forum.iobroker.net/topic/27267/test-adapter-iobroker-backitup-v3-0-x/2635?_=1717006698974
            • O
              oFbEQnpoLKKl6mbY5e13 @Shadowhunter23 last edited by oFbEQnpoLKKl6mbY5e13
              @shadowhunter23
              Ah, okay, danke.
              Edit:
              Vielleicht sollte man mal einen neuen Thread erstellen. Fast 3000 Beiträge machen die Sache nicht gerade übersichtlich...
              • mcm1957
                mcm1957 last edited by
                @simatec said in Test Adapter ioBroker.backitup v3.0.x:
                @amg_666 Die Beta Repo wird meist zwischen 14 - 15 Uhr aktualisiert... Ist also gerade am bauen
                14:00 UTC == 16:00 MEZ Sommerzeit 🙂
                • mcm1957
                  mcm1957 @Homoran last edited by
                  @homoran said in Test Adapter ioBroker.backitup v3.0.x:
                  @shadowhunter23 sagte in Test Adapter ioBroker.backitup v3.0.x:
                  Bin aber nicht sicher ob das immer noch das offene, bekannte Issue ist.
                  welche Version des admin?
                  der wirft die Warnung
                  invalid json Config Warnings sind von der Admin Version unabhängig. Die Prüfung erfolgt immer gegen die online Version des Schemas.
                  • Marc Berg
                    Marc Berg Most Active @simatec last edited by
                    @simatec
                    Gibt es einen Grund, warum das Backup der States/Objects DB um rund ein Drittel anwächst, wenn die 3.0.x installiert ist?
                    • simatec
                      simatec Developer Most Active @Marc Berg last edited by
                      @marc-berg Aktuell würde mir jetzt kein Grund einfallen. Gut Backitup selber ist ab v3.0.x aufgrund der React Komponenten etwas größer und benötigt mehr Platz auf der Platte. Aber auf States und Objects sollte es sich nicht auswirken
                      Marc Berg 2 Replies Last reply Reply Quote 0
                      • Marc Berg
                        Hm, tut es aber leider bei mir. Habe das jetzt ein paar Mal durchgespielt. Es ist nicht nur das Backup, welches viel größer wird, auch die eigentliche Datenbank:
                        Ist jetzt nicht so dramatisch, aber falls da ein Fehler hintersteckt, wäre es vielleicht gut, den zu finden.
                        • Marc Berg
                          Marc Berg Most Active @simatec last edited by Marc Berg
                          Habe noch ein wenig gegraben, mit der Version 3.0.x wird ein Schlüssel
                          cfg.f.backitup.admin$%$static/js/main.7253116f.js.map$%$data
                          in der Datenbank angelegt, dessen Inhalt allein 33MB groß ist.
                          außerdem noch (10 MB):
                          cfg.f.backitup.admin$%$static/js/main.7253116f.js$%$data
                          und (jeweils 7MB)
                          cfg.f.backitup.admin$%$custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.ebe43e81.chunk.js.map$%$data
                          cfg.f.backitup.admin$%$custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.baf6e6c7.chunk.js.map$%$data
                          • simatec
                            @marc-berg ja das sind alles react relevante Dateien. Diese Schlüssel solltest du ebenfalls für andere react Adapter wie iot, javascript, admin etc. finden.
                            • Marc Berg
                              Ja, da hast du recht, wobei unter den Top 10 vier Mal Backitup auftaucht. Mir erschließt sich nicht wirklich, wieso Dateien in der Datenbank abgelegt werden. Aber wenn das die schöne neue React Welt ist, 🤷‍♂️
                              Kann mir nur nicht vorstellen, dass dies in Hinblick auf Arbeitsspeicherverbrauch und Performance eine gute Idee sein könnte, vor allem wenn jetzt noch mehr React-basierte Adapter hinzu kommen.
                              • simatec
                                @marc-berg Ich nehme das mal mit fürs nächste Dev Meeting mit
                                B O 2 Replies Last reply Reply Quote 1
                                  bommel_030 @simatec last edited by
                                  @simatec
                                  Hi, ich habe mit der backitup >v3 Probleme beim sichern mein influxdb v2.
                                  2024-06-10 01:00:10.031	debug	Backup has started ...
                                  2024-06-10 01:00:20.033	debug	[iobroker/mount] nfs-mount command: "sudo mount 192.168.10.25:/volume1/backup/iobroker /opt/iobroker/backups"
                                  2024-06-10 01:00:20.099	debug	[iobroker/mount] mount successfully completed
                                  2024-06-10 01:00:20.100	debug	[iobroker/mount] done
                                  2024-06-10 01:00:25.722	debug	[iobroker/iobroker] host.iobroker-master 81154 states saved
                                  2024-06-10 01:00:27.018	debug	[iobroker/iobroker] host.iobroker-master 96012 objects saved
                                  2024-06-10 01:00:30.322	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_06_10-01_00_20_standard_vm_backupiobroker.tar.gz
                                  2024-06-10 01:00:30.322	debug	[iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
                                  2024-06-10 01:00:31.363	debug	[iobroker/iobroker] done
                                  2024-06-10 01:00:31.515	debug	[iobroker/influxDB] InfluxDB-Backup for influx_dauer is started ...
                                  2024-06-10 01:00:31.516	debug	[iobroker/influxDB] Start InfluxDB Backup ...
                                  2024-06-10 01:00:31.521	debug	[iobroker/influxDB] InfluxDB Backup tmp directory created
                                  2024-06-10 01:00:31.524	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2024-06-10 01:00:31.525	error	unhandled promise rejection: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x...
                                  2024-06-10 01:00:31.529	error	TypeError: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x... at validateArgumentNullCheck (node:child_process:973:11) at normalizeExecArgs (node:child_process:191:3) at Object.exec (node:child_process:233:16) at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/12-influxDB.js:79:17
                                  2024-06-10 01:00:31.530	error	Exception-Code: ERR_INVALID_ARG_VALUE: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x...
                                  2024-06-10 01:00:31.551	info	cleaned everything up...
                                  2024-06-10 01:00:31.552	info	terminating
                                  2024-06-10 01:00:31.552	debug	Plugin sentry destroyed
                                  2024-06-10 01:00:31.553	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2024-06-10 01:00:32.054	info	terminating
                                  2024-06-10 01:00:32.220	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2024-06-10 01:00:32.223	error	Caught by controller[1]: TypeError: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x...
                                  2024-06-10 01:00:32.223	error	Caught by controller[1]: at validateArgumentNullCheck (node:child_process:973:11)
                                  2024-06-10 01:00:32.223	error	Caught by controller[1]: at normalizeExecArgs (node:child_process:191:3)
                                  2024-06-10 01:00:32.223	error	Caught by controller[1]: at Object.exec (node:child_process:233:16)
                                  2024-06-10 01:00:32.223	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/12-influxDB.js:79:17
                                  2024-06-10 01:00:32.223	error	instance system.adapter. terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  Vorher läuft das Backup vom ioBroker problemlos durch, bei influx stürzt er scheinbar ab (Bekomme auch keine Benachrichtigung über einen Fehler) und führt danach problemlos das CCU Backup durch. Falls ich ein issue erstellen soll mache ich das gerne.
                                  • simatec
                                    simatec Developer Most Active @bommel_030 last edited by
                                    @bommel_030 Welche Version von Backitup ist installiert? Bitte poste mal deine Backitup Config als JSON
                                      bommel_030 @simatec last edited by bommel_030
                                      @simatec
                                      Installiert ist v3.0.2. Im JSON habe ich PW und Token unkenntlich gemacht.
                                      Dabei ist mir aufgefallen, die beiden Token unter "influxDBEvents" sehen "komisch" aus.
                                      Der unter "influxDBToken""normal":
                                      Wobei ich nicht weiß ob das ein Anzeigeeffekt von Notepad++ ist.
                                      • simatec
                                        @bommel_030 Bitte trage deine Token erneut in der Config ein und speichere sie.
                                        Danach sollte es funktionieren. In Version 3.0.1 gab es da eine Änderung.
                                          @simatec
                                          Danke, hätte ich auch selber drauf kommen können.... Mal schauen ob der Durchlauf heute Nacht noch mal meckert.
                                          • simatec
                                            @bommel_030 Kannst ja auch mit einem manuellen Backup testen
                                            170
                                            2780
                                            2372828
