    4. iobroker npm warn ERESOLVE overriding peer dependencynpm
      Thomas Braun Most Active @tomtaz last edited by
      @tomtaz
      cd /opt/iobroker && npm ls
      sagt?
        tomtaz @Thomas Braun last edited by
        tomtaz@ioBroker:/opt/iobroker$ cd /opt/iobroker && npm ls
        [sudo] Passwort für tomtaz:
        iobroker.inst@3.0.0 /opt/iobroker
        ├── @iobroker-javascript.0/axios@npm:axios@1.7.2
        ├── canvas@2.11.2
        ├── echarts@5.4.3
        ├── iobroker.accuweather@1.4.0
        ├── iobroker.admin@6.17.14
        ├── iobroker.alexa2@3.26.5
        ├── iobroker.backitup@3.0.2
        ├── iobroker.divera247@0.1.2
        ├── iobroker.dwd@2.8.5
        ├── iobroker.echarts@1.7.2
        ├── iobroker.ecovacs-deebot@1.4.15
        ├── iobroker.fullybrowser@3.0.12
        ├── iobroker.hmip@1.23.3
        ├── iobroker.ical@1.15.0
        ├── iobroker.influxdb@4.0.2
        ├── iobroker.info@2.0.0
        ├── iobroker.iot@3.3.0
        ├── iobroker.javascript@8.5.0
        ├── iobroker.js-controller@6.0.1-alpha.0-20240603-3deca26fa
        ├── iobroker.meross@1.17.0
        ├── iobroker.mqtt@5.2.0
        ├── iobroker.node-red@5.2.1
        ├── iobroker.nuki-extended@2.7.0
        ├── iobroker.openweathermap@1.0.4
        ├── iobroker.parser@2.1.0
        ├── iobroker.proxmox@2.3.0
        ├── iobroker.ring@5.0.1
        ├── iobroker.shelly@7.0.0
        ├── iobroker.simple-api@2.8.0
        ├── iobroker.socketio@6.7.0
        ├── iobroker.tankerkoenig@3.4.0
        ├── iobroker.telegram@3.4.0
        ├── iobroker.tr-064@4.3.0
        ├── iobroker.traccar@1.1.4
        ├── iobroker.trashschedule@3.3.0
        ├── iobroker.tuya@3.15.0
        ├── iobroker.upnp@1.0.21
        ├── iobroker.vis-2-widgets-energy@0.3.11
        ├── iobroker.vis-2-widgets-gauges@1.0.3
        ├── iobroker.vis-2-widgets-material@1.3.32
        ├── iobroker.vis-2@2.9.64
        ├── iobroker.vis@1.5.6
        ├── iobroker.web@6.2.6
        ├── iobroker.ws@2.6.1
        ├── jsdom@20.0.3
        ├── moment@2.29.4
        └── ring-client-api@12.0.1
          @thomas-braun said in iobroker npm warn ERESOLVE overriding peer dependencynpm:
          sudo usermod -aG adm tomtaz
          tomtaz@ioBroker:/opt/iobroker$ sudo systemctl set-default multi-user.target
          Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
          tomtaz@ioBroker:/opt/iobroker$ sudo usermod -aG adm tomtaz
          Beide Befehle ausgeführt:
          Und nun das neue diag
          Skript v.2024-05-22
          *** BASE SYSTEM ***
             Static hostname: ioBroker
                   Icon name: computer-vm
                     Chassis: vm
              Virtualization: kvm
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.0-30-amd64
                Architecture: x86-64
          model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           15:45:10 up 1 day, 19:09,  1 user,  load average: 0.36, 0.26, 0.37
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Sun 2024-06-09 15:45:10 CEST
                     Universal time: Sun 2024-06-09 13:45:10 UTC
                           RTC time: Sun 2024-06-09 13:45:11
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          tomtaz
          HOME=/home/tomtaz
          GROUPS=tomtaz cdrom floppy audio dip video plugdev netdev iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev redis
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:             13G        3.3G        8.3G        0.0K        2.4G         10G
          Swap:           2.0G          0B        2.0G
          Total:           16G        3.3G         10G
          Active iob-Instances:   31
                  13977 M total memory
                   3319 M used memory
                    930 M active memory
                   4464 M inactive memory
                   8257 M free memory
                    222 M buffer memory
                   2177 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          top - 15:45:10 up 1 day, 19:09,  1 user,  load average: 0.36, 0.26, 0.37
          Tasks: 127 total,   1 running, 126 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 12.9 us,  3.2 sy,  0.0 ni, 83.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  13977.1 total,   8258.8 free,   3318.7 used,   2399.6 buff/cache
          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  10352.5 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                 Type      Size  Used Avail Use% Mounted on
          udev                       devtmpfs  6.9G     0  6.9G   0% /dev
          tmpfs                      tmpfs     1.4G  516K  1.4G   1% /run
          /dev/sda2                  ext4       44G   23G   19G  56% /
          tmpfs                      tmpfs     6.9G     0  6.9G   0% /dev/shm
          tmpfs                      tmpfs     5.0M     0  5.0M   0% /run/lock
          /dev/sda1                  vfat      511M  5.8M  506M   2% /boot/efi
          //192.168.188.203/Ring     cifs      442G   51G  391G  12% /mnt/smbNas/ring
          //192.168.188.203/iobroker cifs      442G   51G  391G  12% /mnt/smbNas/iobroker
          tmpfs                      tmpfs     1.4G     0  1.4G   0% /run/user/1000
          [Fri Jun  7 20:35:41 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
          [Fri Jun  7 20:35:42 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
          Show mounted filesystems:
          TARGET                        SOURCE                     FSTYPE     OPTIONS
          /                             /dev/sda2                  ext4       rw,relatime,errors=remount-ro
          |-/sys                        sysfs                      sysfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security      securityfs                 securityfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup            cgroup2                    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore            pstore                     pstore     rw,nosuid,nodev,noexec,relatime
          | |-/sys/firmware/efi/efivars efivarfs                   efivarfs   rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf               none                       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/tracing       tracefs                    tracefs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/debug         debugfs                    debugfs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config        configfs                   configfs   rw,nosuid,nodev,noexec,relatime
          | `-/sys/fs/fuse/connections  fusectl                    fusectl    rw,nosuid,nodev,noexec,relatime
          |-/proc                       proc                       proc       rw,nosuid,nodev,noexec,relatime
          | `-/proc/sys/fs/binfmt_misc  systemd-1                  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1402
          |-/dev                        udev                       devtmpfs   rw,nosuid,relatime,size=7138428k,nr_inodes=1784607,mode=755
          | |-/dev/pts                  devpts                     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | |-/dev/shm                  tmpfs                      tmpfs      rw,nosuid,nodev
          | |-/dev/hugepages            hugetlbfs                  hugetlbfs  rw,relatime,pagesize=2M
          | `-/dev/mqueue               mqueue                     mqueue     rw,nosuid,nodev,noexec,relatime
          |-/run                        tmpfs                      tmpfs      rw,nosuid,nodev,noexec,relatime,size=1431256k,mode=755
          | |-/run/lock                 tmpfs                      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs           sunrpc                     rpc_pipefs rw,relatime
          | `-/run/user/1000            tmpfs                      tmpfs      rw,nosuid,nodev,relatime,size=1431252k,nr_inodes=357813,mode=700,uid=1000,gid=1000
          |-/boot/efi                   /dev/sda1                  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
          |-/mnt/smbNas/ring            //192.168.188.203/Ring     cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.188.203,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
          `-/mnt/smbNas/iobroker        //192.168.188.203/iobroker cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.188.203,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
          /var:
          5.1G    /var/
          4.0G    /var/log/journal/8ceb8e89cfec4839974812b8815506e2
          4.0G    /var/log
          802M    /var/lib
          Archived and active journals take up 48.0M in the file system.
          /opt/iobroker/backups:
          6.6G    /opt/iobroker/backups/
          244K    /opt/iobroker/backups/influx
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          924M    /opt/iobroker/iobroker-data/files
          281M    /opt/iobroker/iobroker-data/files/javascript.admin
          247M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          245M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          34M     /opt/iobroker/iobroker-data/objects.jsonl
          29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.7253116f.js.map
          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.3
          /usr/bin/node           v18.20.3
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.3-1nodesource1
            Candidate: 18.20.3-1nodesource1
            Version table:
           *** 18.20.3-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.1-alpha.0-20240603-3deca26fa
          admin:          6.17.14
          javascript:     8.5.0
          nodejs modules from github:     0
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: tomtaz
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          + system.adapter.divera247.0              : divera247             : ioBroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 - disabled
          + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.traccar.0                : traccar               : ioBroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Stable (default): http://download.iobroker.net/sources-dist.json
          Active repo(s): Beta (latest)
          Installed ioBroker-Instances
          Used repository: Beta (latest)
          Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
          Adapter    "admin"        : 6.17.14  , installed 6.17.14
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.2    , installed 3.0.2
          Adapter    "divera247"    : 0.2.0    , installed 0.1.2  [Updatable]
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "hmip"         : 1.23.3   , installed 1.23.3
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.5.0    , installed 8.5.0
          Controller "js-controller": 5.0.19   , installed 6.0.1
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
          Adapter    "parser"       : 2.1.0    , installed 2.1.0
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "ring"         : 5.0.10   , installed 5.0.1  [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 3.4.0    , installed 3.4.0
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "traccar"      : 1.1.4    , installed 1.1.4
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
          Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
          Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
          Adapter    "web"          : 6.2.6    , installed 6.2.6
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Objects and States
          Objects:        15923
          States:         13376
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3620013    94314/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3619051    94314/iobroker.js-c
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11285      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13143      464/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       3619327    94403/node-red
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3621349    94638/io.shelly.1
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       3622287    94683/io.mqtt.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11289      1/init
          tcp6       0      0 :::80                   :::*                    LISTEN      1001       3619329    94403/node-red
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3619142    94332/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3626313    95332/io.web.0
          tcp6       0      0 :::51989                :::*                    LISTEN      1001       3621067    94578/io.nuki-exten
          tcp6       0      0 :::8086                 :::*                    LISTEN      998        13927      462/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13154      464/sshd: /usr/sbin
          udp        0      0 0.0.0.0:36148           0.0.0.0:*                           1001       3622327    94698/io.divera247.
          udp        0      0 0.0.0.0:36329           0.0.0.0:*                           1001       3619370    94426/io.telegram.0
          udp        0      0 0.0.0.0:44721           0.0.0.0:*                           1001       3619050    94314/iobroker.js-c
          udp        0      0 0.0.0.0:45091           0.0.0.0:*                           1001       3621050    94578/io.nuki-exten
          udp        0      0 0.0.0.0:53437           0.0.0.0:*                           1001       3623743    95164/io.javascript
          udp        0      0 192.168.188.202:5353    0.0.0.0:*                           1001       3622154    94653/io.tr-064.0
          udp        0      0 0.0.0.0:38273           0.0.0.0:*                           1001       3624891    95332/io.web.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       3621261    94623/io.shelly.0
          udp        0      0 0.0.0.0:54867           0.0.0.0:*                           1001       3619298    94388/io.node-red.0
          udp        0      0 0.0.0.0:46959           0.0.0.0:*                           1001       3622590    94743/io.info.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3621562    94668/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3621563    94668/io.tuya.0
          udp        0      0 0.0.0.0:56280           0.0.0.0:*                           1001       3991010    94638/io.shelly.1
          udp        0      0 0.0.0.0:56284           0.0.0.0:*                           1001       3622969    94728/io.echarts.0
          udp        0      0 0.0.0.0:56681           0.0.0.0:*                           1001       3624169    95190/io.parser.0
          udp        0      0 0.0.0.0:56910           0.0.0.0:*                           1001       3626070    95292/io.upnp.0
          udp        0      0 0.0.0.0:40680           0.0.0.0:*                           1001       3625919    95262/io.traccar.0
          udp        0      0 0.0.0.0:49155           0.0.0.0:*                           1001       3619120    94332/io.admin.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11286      1/init
          udp        0      0 0.0.0.0:49287           0.0.0.0:*                           1001       3624810    95307/io.vis-2.0
          udp        0      0 0.0.0.0:33292           0.0.0.0:*                           1001       3620852    94515/io.hmip.0
          udp        0      0 0.0.0.0:33684           0.0.0.0:*                           1001       3625592    95239/io.tankerkoen
          udp        0      0 0.0.0.0:34350           0.0.0.0:*                           1001       3619452    94456/io.accuweathe
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       3626419    95292/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       3619330    94403/node-red
          udp        0      0 0.0.0.0:34955           0.0.0.0:*                           1001       3619259    94368/io.influxdb.0
          udp        0      0 0.0.0.0:59626           0.0.0.0:*                           1001       3620732    94486/io.backitup.0
          udp        0      0 0.0.0.0:43509           0.0.0.0:*                           1001       3626388    95347/io.fullybrows
          udp        0      0 0.0.0.0:43866           0.0.0.0:*                           1001       3626068    95292/io.upnp.0
          udp6       0      0 :::111                  :::*                                0          11292      1/init
          2024-06-09 15:30:00.031  - info: javascript.0 (95164) script.js.Steuerung.Zeitsteuerung.airbowlBad: [DEBUG] Die Airbwol wird nicht eingeschaltet, da diese zuletzt am/um geschalten wurde: 09.06.2024, 15:25 und wird sich in ca. 55 Minuten anschalten.
          2024-06-09 15:30:08.302  - info: host.ioBroker instance system.adapter.ical.0 having pid 109488 terminated with code 0 (NO_ERROR)
          2024-06-09 15:30:45.008  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 109524
          2024-06-09 15:30:47.032  - info: host.ioBroker instance system.adapter.dwd.0 having pid 109524 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-06-09 15:30:49.015  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 109539
          2024-06-09 15:30:50.214  - info: openweathermap.0 (109539) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
          2024-06-09 15:31:14.675  - info: openweathermap.0 (109539) Terminated (NO_ERROR): Without reason
          2024-06-09 15:31:15.195  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 109539 terminated with code 0 (NO_ERROR)
          2024-06-09 15:34:19.242  - info: web.0 (95332) ==> Connected system.user.admin from ::ffff:192.168.188.158
          2024-06-09 15:34:19.691  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm ist angegangen.
          2024-06-09 15:34:23.462  - info: web.0 (95332) ==> Connected system.user.admin from ::ffff:192.168.188.158
          2024-06-09 15:35:00.017  - info: host.ioBroker instance system.adapter.ical.0 started with pid 109680
          2024-06-09 15:35:07.735  - info: host.ioBroker instance system.adapter.ical.0 having pid 109680 terminated with code 0 (NO_ERROR)
          2024-06-09 15:38:49.643  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm wird ausgeschaltet
          2024-06-09 15:40:00.015  - info: host.ioBroker instance system.adapter.ical.0 started with pid 109839
          2024-06-09 15:40:00.029  - info: javascript.0 (95164) script.js.Steuerung.Zeitsteuerung.airbowlBad: [DEBUG] Die Airbwol wird nicht eingeschaltet, da diese zuletzt am/um geschalten wurde: 09.06.2024, 15:25 und wird sich in ca. 45 Minuten anschalten.
          2024-06-09 15:40:07.827  - info: host.ioBroker instance system.adapter.ical.0 having pid 109839 terminated with code 0 (NO_ERROR)
          2024-06-09 15:40:48.009  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 109876
          2024-06-09 15:40:49.076  - info: openweathermap.0 (109876) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
          2024-06-09 15:40:53.465  - info: openweathermap.0 (109876) Terminated (NO_ERROR): Without reason
          2024-06-09 15:40:53.984  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 109876 terminated with code 0 (NO_ERROR)
          2024-06-09 15:41:39.725  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm ist angegangen.
          2024-06-09 15:43:39.756  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm wird ausgeschaltet
          2024-06-09 15:45:00.012  - info: host.ioBroker instance system.adapter.ical.0 started with pid 110131
          2024-06-09 15:45:08.465  - info: host.ioBroker instance system.adapter.ical.0 having pid 110131 terminated with code 0 (NO_ERROR)
                                  v.2024-05-22
                     Chassis: vm
              Virtualization: kvm
          Installation:           kvm
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          Pending OS-Updates:     0
          Pending iob updates:    2
          Nodejs-Installation:
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          Recommended versions are nodejs 18.20.3 and npm 10.7.0
          MEMORY:
          Swap:           2.0G          0B        2.0G
          Total:           16G        3.3G         10G
          ioBroker Core:          js-controller           6.0.1-alpha.0-20240603-3deca26fa
                                  admin                   6.17.14
          Objects type: jsonl
          States  type: jsonl
          Objects:                15923
          States:                 13376
          Size of iob-Database:
          3.2M    /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun 3 Replies Last reply Reply Quote 0
            @tomtaz
            Nach Änderungen in den Gruppen einmal Neustart.
              @tomtaz
              Wo kommen die Module ohne iobroker im Pfad her?
              ├── canvas@2.11.2
              ├── echarts@5.4.3
              ├── moment@2.29.4
              Die dürften da eigentlich nicht auftauchen, denke ich.
                @tomtaz
                Installier den iobroker.admin@6.17.14 nochmal sauber rein.
                  Sorry, den hab ich vergessen 😞
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                             Chassis: vm
                      Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   16:03:42 up 4 min,  1 user,  load average: 0.55, 0.45, 0.19
                  CPU threads: 2
                                 Local time: Sun 2024-06-09 16:03:42 CEST
                             Universal time: Sun 2024-06-09 14:03:42 UTC
                                   RTC time: Sun 2024-06-09 14:03:43
                                NTP service: active
                            RTC in local TZ: no
                  tomtaz
                  HOME=/home/tomtaz
                  GROUPS=tomtaz adm cdrom floppy audio dip video plugdev netdev iobroker
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:             13G        2.4G         11G        0.0K        569M         11G
                  Swap:           2.0G          0B        2.0G
                  Total:           16G        2.4G         13G
                           2389 M used memory
                            206 M active memory
                           2522 M inactive memory
                          11018 M free memory
                             56 M buffer memory
                            512 M swap cache
                           2047 M total swap
                              0 M used swap
                           2047 M free swap
                  top - 16:03:42 up 4 min,  1 user,  load average: 0.55, 0.45, 0.19
                  Tasks: 131 total,   1 running, 130 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  13977.1 total,  11018.5 free,   2389.1 used,    569.5 buff/cache
                  MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  11321.7 avail Mem
                  *** FILESYSTEM ***
                  [Sun Jun  9 15:59:38 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                  [Sun Jun  9 15:59:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
                  | `-/proc/sys/fs/binfmt_misc  systemd-1                  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11229
                  /var:
                  5.1G    /var/
                  4.0G    /var/log
                  802M    /var/lib
                  Archived and active journals take up 3.9G in the file system.
                  916M    /opt/iobroker/iobroker-data/files
                  24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                  USB-Devices by-id:
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.17.14
                  javascript:     8.5.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        15919
                  States:         13462
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16518      831/io.shelly.1
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       16030      876/io.mqtt.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13901      538/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13894      538/iobroker.js-con
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          425        1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13800      467/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14093      614/node-red
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          429        1/init
                  tcp6       0      0 :::80                   :::*                    LISTEN      1001       14097      614/node-red
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13983      557/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20185      1500/io.web.0
                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       15240      771/io.nuki-extende
                  tcp6       0      0 :::8086                 :::*                    LISTEN      998        13276      456/influxd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13802      467/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:49153           0.0.0.0:*                           1001       20889      1475/io.vis-2.0
                  udp        0      0 0.0.0.0:41010           0.0.0.0:*                           1001       20781      1460/io.upnp.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          426        1/init
                  udp        0      0 0.0.0.0:57553           0.0.0.0:*                           1001       19708      1415/io.tankerkoeni
                  udp        0      0 0.0.0.0:49520           0.0.0.0:*                           1001       14273      708/io.backitup.0
                  udp        0      0 0.0.0.0:49618           0.0.0.0:*                           1001       14024      584/io.influxdb.0
                  udp        0      0 0.0.0.0:33527           0.0.0.0:*                           1001       16302      921/io.echarts.0
                  udp        0      0 0.0.0.0:58283           0.0.0.0:*                           1001       14757      599/io.node-red.0
                  udp        0      0 0.0.0.0:42258           0.0.0.0:*                           1001       20179      1500/io.web.0
                  udp        0      0 0.0.0.0:50692           0.0.0.0:*                           1001       20565      1430/io.traccar.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21139      1460/io.upnp.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       14098      614/node-red
                  udp        0      0 0.0.0.0:44130           0.0.0.0:*                           1001       21075      1515/io.fullybrowse
                  udp        0      0 0.0.0.0:52492           0.0.0.0:*                           1001       16384      936/io.info.0
                  udp        0      0 0.0.0.0:52591           0.0.0.0:*                           1001       13893      538/iobroker.js-con
                  udp        0      0 0.0.0.0:36931           0.0.0.0:*                           1001       14401      557/io.admin.0
                  udp        0      0 0.0.0.0:37330           0.0.0.0:*                           1001       20775      1460/io.upnp.0
                  udp        0      0 0.0.0.0:37612           0.0.0.0:*                           1001       14205      678/io.accuweather.
                  udp        0      0 0.0.0.0:45815           0.0.0.0:*                           1001       15068      723/io.hmip.0
                  udp        0      0 0.0.0.0:45883           0.0.0.0:*                           1001       17942      1385/io.parser.0
                  udp        0      0 192.168.188.202:5353    0.0.0.0:*                           1001       15871      846/io.tr-064.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16448      816/io.shelly.0
                  udp        0      0 0.0.0.0:47203           0.0.0.0:*                           1001       16841      891/io.divera247.0
                  udp        0      0 0.0.0.0:55599           0.0.0.0:*                           1001       15576      771/io.nuki-extende
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15926      861/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15927      861/io.tuya.0
                  udp        0      0 0.0.0.0:48183           0.0.0.0:*                           1001       14818      637/io.telegram.0
                  udp        0      0 0.0.0.0:49008           0.0.0.0:*                           1001       17800      1351/io.javascript.
                  udp6       0      0 :::111                  :::*                                0          432        1/init
                  2024-06-09 16:01:35.592  - info: javascript.0 (1351) script.js.Steuerung.Automation.traccar: [DEBUG] in the past hour, the script traccar have send 0000 setState commands
                  2024-06-09 16:01:35.623  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G090XG1214720TXQ [Küche] success proceed while Trigger Mode is On! 0 left...
                  2024-06-09 16:01:36.547  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Incomming Changes for alexa device #G090XG1211830A5N[{"name":"Schlafzimmer","serialNumber":"G090XG1211830A5N","summary":"","creationTime":1717941689256,"domainApplicationId":"","domainApplicationName":"","cardContent":"","card":"","answerText":"","utteranceType":"ROUTINES_3P","domain":"Echo.SDK","intent":"Unknown"}]
                  2024-06-09 16:01:36.556  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Ignoring History becouse no activ Command
                  2024-06-09 16:01:36.589  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G090XG1214720WES [Kinderzimmer] success proceed while Trigger Mode is On! 0 left...
                  2024-06-09 16:01:37.057  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: [DEBUG] Specified last Commands cleared, while trigger-mode is on...
                  2024-06-09 16:01:37.486  - info: host.ioBroker instance system.adapter.trashschedule.0 started with pid 1445
                  2024-06-09 16:01:37.592  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G091AA1215130RXA [Büro] success proceed while Trigger Mode is On! 0 left...
                  2024-06-09 16:01:38.599  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G2A0U20493460BF6 [Wohnzimmer] success proceed while Trigger Mode is On! 0 left...
                  2024-06-09 16:01:40.780  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Incomming Changes for alexa device #G091AA1215130RXA[{"name":"Büro","serialNumber":"G091AA1215130RXA","summary":"","creationTime":1717941692235,"domainApplicationId":"","domainApplicationName":"","cardContent":"","card":"","answerText":"","utteranceType":"ROUTINES_3P","domain":"Echo.SDK","intent":"Unknown"}]
                  2024-06-09 16:01:40.780  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Ignoring History becouse no activ Command
                  2024-06-09 16:01:41.282  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: [DEBUG] Specified last Commands cleared, while trigger-mode is on...
                  2024-06-09 16:01:41.544  - info: host.ioBroker instance system.adapter.upnp.0 started with pid 1460
                  2024-06-09 16:01:43.053  - info: upnp.0 (1460) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
                  2024-06-09 16:01:43.064  - info: upnp.0 (1460) Auto discover: true
                  2024-06-09 16:01:45.753  - info: host.ioBroker instance system.adapter.vis-2.0 started with pid 1475
                  2024-06-09 16:01:46.796  - error: vis-2.0 (1475) No license found for vis-2. Please get one on https://iobroker.net !
                  2024-06-09 16:01:49.455  - info: host.ioBroker instance system.adapter.web.0 started with pid 1500
                  2024-06-09 16:01:50.633  - info: web.0 (1500) starting. Version 6.2.6 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
                  2024-06-09 16:01:50.716  - info: web.0 (1500) socket.io server listening on port 8082
                  2024-06-09 16:01:50.723  - info: web.0 (1500) http server listening on port 8082
                  2024-06-09 16:01:50.973  - info: web.0 (1500) ==> Connected system.user.admin from ::ffff:192.168.188.158
                  2024-06-09 16:01:53.525  - info: host.ioBroker instance system.adapter.fullybrowser.0 started with pid 1515
                  2024-06-09 16:01:54.467  - warn: fullybrowser.0 (1515) Adapter instance settings: REST API timeout of undefined ms is not allowed, set to default of 10000ms
                  2024-06-09 16:01:58.066  - info: web.0 (1500) ==> Connected system.user.admin from ::ffff:192.168.188.158
                                          v.2024-05-22
                             Chassis: vm
                      Virtualization: kvm
                  Installation:           kvm
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                1000
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  MEMORY:
                  Mem:             13G        2.4G         10G        0.0K        787M         11G
                  Swap:           2.0G          0B        2.0G
                  Total:           16G        2.4G         12G
                                          admin                   6.17.14
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                15919
                  States:                 13462
                  23M     /opt/iobroker/iobroker-data/objects.jsonl
                  3.0M    /opt/iobroker/iobroker-data/states.jsonl
                    Wo diese herkommen, kann ich Dir beim besten willen nicht sagen. Echarts nutze ich aber und den ring-client-api auch für die Ring-Cams
                    @tomtaz
                    tomtaz@ioBroker:/opt/iobroker$ npm install iobroker.admin@6.17.14
                    npm warn While resolving: @iobroker/adapter-core@3.1.4
                    npm warn Found: @iobroker/types@6.0.0
                    npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
                    npm warn   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
                    npm warn     iobroker.admin@"6.17.14" from the root project
                    npm warn
                    npm warn Could not resolve dependency:
                    npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
                    npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                    npm warn   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
                    npm warn
                    npm warn Conflicting peer dependency: @iobroker/types@5.0.19
                    npm warn node_modules/@iobroker/types
                    up to date in 4s
                    174 packages are looking for funding
                      run `npm fund` for details
                      @tomtaz
                      Aber echarts muss so im tree stehen:
                      Das haste mal irgendwann irgendwie in das System gedübelt.
                      Bitte nicht direkt npm-Kommandos verwenden. Das führt nämlich unter Umständen genau zu solchen schrägen Installationen.
                      iob upgrade iobroker.admin@6.17.14 --omit=dev
                        @tomtaz
                        Neben deinem strubbeligen npm-tree kommt die Ursprungsmeldung von dem js-controller in der Alpha-Version.
                        Auf meinem System kommt nämlich:
                        echad@chet:/opt/iobroker $ iob stop
                        echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                        npm warn
                        npm warn
                        up to date in 8s
                        190 packages are looking for funding
                          Ahh ok, Danke für die Info. Dann muss es wohl von der Alpha.
                          Bloß wie korrigiere ich nun die
                          ├── canvas@2.11.2
                          ├── echarts@5.4.3
                          ├── moment@2.29.4
                          am besten korrigiert? Per NPM deinstallieren?
                            Thomas Braun Most Active @tomtaz last edited by Thomas Braun
                            @tomtaz sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                            Wenn sie auch per npm reingedrückt worden sind ja.
                              @thomas-braun sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                              schon gar nicht im falschen Verzeichnis!
                              aber genau dort von wo sie auch installiert wurden
                                Diamand2k22 @Homoran last edited by
                                @Thomas-Braun
                                bei mir ist leider auch was strubbelig, zumindest bekomm ich den selben Fehler wie tomtaz.
                                aber npm tree schaut sauber aus!
                                pi4b@pi4b:~$ cd /opt/iobroker && npm ls
                                ├── iobroker.adguard@0.0.8
                                ├── iobroker.alarm@3.6.0
                                ├── iobroker.alias-manager@1.2.6
                                ├── iobroker.backitup@3.0.5
                                ├── iobroker.blueconnect@0.0.5 (git+ssh://git@github.com/kopierschnitte/ioBroker        .blueconnect.git#f50eada99eaffdd21802ee0cbd5bcff4fd42469d)
                                ├── iobroker.bmw@2.8.0
                                ├── iobroker.bydhvs@1.5.0
                                ├── iobroker.daswetter@3.1.15
                                ├── iobroker.device-reminder@3.1.2
                                ├── iobroker.device-watcher@2.12.1
                                ├── iobroker.discovery@4.5.0
                                ├── iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBr        oker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
                                ├── iobroker.evcc@0.1.1
                                ├── iobroker.fritzdect@2.5.9
                                ├── iobroker.fronius-solarweb@0.1.0
                                ├── iobroker.fronius-wattpilot@4.6.3
                                ├── iobroker.fronius@2.1.0
                                ├── iobroker.ham@5.3.1
                                ├── iobroker.heizoel@1.0.3
                                ├── iobroker.icons-mfd-svg@1.2.0
                                ├── iobroker.intex@0.1.5
                                ├── iobroker.javascript@8.6.0
                                ├── iobroker.js-controller@5.0.19
                                ├── iobroker.lovelace@4.1.10
                                ├── iobroker.midea@0.0.7
                                ├── iobroker.modbus@6.2.3
                                ├── iobroker.oilfox@4.3.0
                                ├── iobroker.opendtu@1.0.1
                                ├── iobroker.ping@1.6.2
                                ├── iobroker.pushover@3.0.6
                                ├── iobroker.rpi2@1.3.2
                                ├── iobroker.synology@3.1.0
                                ├── iobroker.telegram@3.5.3
                                ├── iobroker.tibberlink@3.3.1
                                ├── iobroker.vis-inventwo@3.3.4
                                ├── iobroker.vis-materialdesign@0.5.9
                                ├── iobroker.whatsapp-cmb@0.3.0
                                └── iobroker.zigbee2mqtt@2.13.6
                                  Thomas Braun Most Active @Diamand2k22 last edited by
                                  @diamand2k22
                                  Der strubbelige npm tree ist ja auch nur eine Begleiterscheinung.
                                  Was genau wird dir in dein LogFile geschrieben?
                                    Diamand2k22 @Thomas Braun last edited by
                                    $ iobroker add vis-icontwo auto --host pi4b --debug
                                    NPM version: 10.7.0
                                    Installing iobroker.vis-icontwo@1.5.0... (System call)
                                    npm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                                    npm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                                    Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                                      @diamand2k22
                                      Installier den admin nochmal frisch drüber.
                                        du meinst so oder
                                          @diamand2k22
                                          Ganz genau.
                                          • haus-automatisierung
                                            haus-automatisierung Developer Most Active @Diamand2k22 last edited by haus-automatisierung
                                            @diamand2k22 sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                                            Das liegt an der Definition der dependencies im admin (@iobroker/types sollte eine devDependency sein). PR wurde schon erstellt: https://github.com/ioBroker/ioBroker.admin/pull/2507
                                            foxriver76 created this issue in ioBroker/ioBroker.admin
                                            closed try to fix ci #2507
                                            1492
