    4. iobroker npm warn ERESOLVE overriding peer dependencynpm
      tomtaz @Thomas Braun last edited by
      tomtaz@ioBroker:/opt/iobroker$ cd /opt/iobroker && npm ls
      [sudo] Passwort für tomtaz:
      iobroker.inst@3.0.0 /opt/iobroker
      ├── @iobroker-javascript.0/axios@npm:axios@1.7.2
      ├── canvas@2.11.2
      ├── echarts@5.4.3
      ├── iobroker.accuweather@1.4.0
      ├── iobroker.admin@6.17.14
      ├── iobroker.alexa2@3.26.5
      ├── iobroker.backitup@3.0.2
      ├── iobroker.divera247@0.1.2
      ├── iobroker.dwd@2.8.5
      ├── iobroker.echarts@1.7.2
      ├── iobroker.ecovacs-deebot@1.4.15
      ├── iobroker.fullybrowser@3.0.12
      ├── iobroker.hmip@1.23.3
      ├── iobroker.ical@1.15.0
      ├── iobroker.influxdb@4.0.2
      ├── iobroker.info@2.0.0
      ├── iobroker.iot@3.3.0
      ├── iobroker.javascript@8.5.0
      ├── iobroker.js-controller@6.0.1-alpha.0-20240603-3deca26fa
      ├── iobroker.meross@1.17.0
      ├── iobroker.mqtt@5.2.0
      ├── iobroker.node-red@5.2.1
      ├── iobroker.nuki-extended@2.7.0
      ├── iobroker.openweathermap@1.0.4
      ├── iobroker.parser@2.1.0
      ├── iobroker.proxmox@2.3.0
      ├── iobroker.ring@5.0.1
      ├── iobroker.shelly@7.0.0
      ├── iobroker.simple-api@2.8.0
      ├── iobroker.socketio@6.7.0
      ├── iobroker.tankerkoenig@3.4.0
      ├── iobroker.telegram@3.4.0
      ├── iobroker.tr-064@4.3.0
      ├── iobroker.traccar@1.1.4
      ├── iobroker.trashschedule@3.3.0
      ├── iobroker.tuya@3.15.0
      ├── iobroker.upnp@1.0.21
      ├── iobroker.vis-2-widgets-energy@0.3.11
      ├── iobroker.vis-2-widgets-gauges@1.0.3
      ├── iobroker.vis-2-widgets-material@1.3.32
      ├── iobroker.vis-2@2.9.64
      ├── iobroker.vis@1.5.6
      ├── iobroker.web@6.2.6
      ├── iobroker.ws@2.6.1
      ├── jsdom@20.0.3
      ├── moment@2.29.4
      └── ring-client-api@12.0.1
        @thomas-braun said in iobroker npm warn ERESOLVE overriding peer dependencynpm:
        sudo usermod -aG adm tomtaz
        tomtaz@ioBroker:/opt/iobroker$ sudo systemctl set-default multi-user.target
        Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
        tomtaz@ioBroker:/opt/iobroker$ sudo usermod -aG adm tomtaz
        Beide Befehle ausgeführt:
        Und nun das neue diag
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: ioBroker
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-30-amd64
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         15:45:10 up 1 day, 19:09,  1 user,  load average: 0.36, 0.26, 0.37
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Sun 2024-06-09 15:45:10 CEST
                   Universal time: Sun 2024-06-09 13:45:10 UTC
                         RTC time: Sun 2024-06-09 13:45:11
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        tomtaz
        HOME=/home/tomtaz
        GROUPS=tomtaz cdrom floppy audio dip video plugdev netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev redis
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:             13G        3.3G        8.3G        0.0K        2.4G         10G
        Swap:           2.0G          0B        2.0G
        Total:           16G        3.3G         10G
        Active iob-Instances:   31
                13977 M total memory
                 3319 M used memory
                  930 M active memory
                 4464 M inactive memory
                 8257 M free memory
                  222 M buffer memory
                 2177 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        top - 15:45:10 up 1 day, 19:09,  1 user,  load average: 0.36, 0.26, 0.37
        Tasks: 127 total,   1 running, 126 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 12.9 us,  3.2 sy,  0.0 ni, 83.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  13977.1 total,   8258.8 free,   3318.7 used,   2399.6 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  10352.5 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                 Type      Size  Used Avail Use% Mounted on
        udev                       devtmpfs  6.9G     0  6.9G   0% /dev
        tmpfs                      tmpfs     1.4G  516K  1.4G   1% /run
        /dev/sda2                  ext4       44G   23G   19G  56% /
        tmpfs                      tmpfs     6.9G     0  6.9G   0% /dev/shm
        tmpfs                      tmpfs     5.0M     0  5.0M   0% /run/lock
        /dev/sda1                  vfat      511M  5.8M  506M   2% /boot/efi
        //192.168.188.203/Ring     cifs      442G   51G  391G  12% /mnt/smbNas/ring
        //192.168.188.203/iobroker cifs      442G   51G  391G  12% /mnt/smbNas/iobroker
        tmpfs                      tmpfs     1.4G     0  1.4G   0% /run/user/1000
        [Fri Jun  7 20:35:41 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Jun  7 20:35:42 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems:
        TARGET                        SOURCE                     FSTYPE     OPTIONS
        /                             /dev/sda2                  ext4       rw,relatime,errors=remount-ro
        |-/sys                        sysfs                      sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security      securityfs                 securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup            cgroup2                    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore            pstore                     pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/firmware/efi/efivars efivarfs                   efivarfs   rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf               none                       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/tracing       tracefs                    tracefs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/debug         debugfs                    debugfs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config        configfs                   configfs   rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections  fusectl                    fusectl    rw,nosuid,nodev,noexec,relatime
        |-/proc                       proc                       proc       rw,nosuid,nodev,noexec,relatime
        | `-/proc/sys/fs/binfmt_misc  systemd-1                  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1402
        |-/dev                        udev                       devtmpfs   rw,nosuid,relatime,size=7138428k,nr_inodes=1784607,mode=755
        | |-/dev/pts                  devpts                     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                  tmpfs                      tmpfs      rw,nosuid,nodev
        | |-/dev/hugepages            hugetlbfs                  hugetlbfs  rw,relatime,pagesize=2M
        | `-/dev/mqueue               mqueue                     mqueue     rw,nosuid,nodev,noexec,relatime
        |-/run                        tmpfs                      tmpfs      rw,nosuid,nodev,noexec,relatime,size=1431256k,mode=755
        | |-/run/lock                 tmpfs                      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs           sunrpc                     rpc_pipefs rw,relatime
        | `-/run/user/1000            tmpfs                      tmpfs      rw,nosuid,nodev,relatime,size=1431252k,nr_inodes=357813,mode=700,uid=1000,gid=1000
        |-/boot/efi                   /dev/sda1                  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        |-/mnt/smbNas/ring            //192.168.188.203/Ring     cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.188.203,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
        `-/mnt/smbNas/iobroker        //192.168.188.203/iobroker cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.188.203,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
        /var:
        5.1G    /var/
        4.0G    /var/log/journal/8ceb8e89cfec4839974812b8815506e2
        4.0G    /var/log
        802M    /var/lib
        Archived and active journals take up 48.0M in the file system.
        /opt/iobroker/backups:
        6.6G    /opt/iobroker/backups/
        244K    /opt/iobroker/backups/influx
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        924M    /opt/iobroker/iobroker-data/files
        281M    /opt/iobroker/iobroker-data/files/javascript.admin
        247M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        245M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        34M     /opt/iobroker/iobroker-data/objects.jsonl
        29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.7253116f.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.3
        /usr/bin/node           v18.20.3
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.3-1nodesource1
          Candidate: 18.20.3-1nodesource1
          Version table:
         *** 18.20.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.1-alpha.0-20240603-3deca26fa
        admin:          6.17.14
        javascript:     8.5.0
        nodejs modules from github:     0
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: tomtaz
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.divera247.0              : divera247             : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 - disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
        + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
        + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.traccar.0                : traccar               : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Stable (default): http://download.iobroker.net/sources-dist.json
        Active repo(s): Beta (latest)
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.2    , installed 3.0.2
        Adapter    "divera247"    : 0.2.0    , installed 0.1.2  [Updatable]
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "hmip"         : 1.23.3   , installed 1.23.3
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.5.0    , installed 8.5.0
        Controller "js-controller": 5.0.19   , installed 6.0.1
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "parser"       : 2.1.0    , installed 2.1.0
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "ring"         : 5.0.10   , installed 5.0.1  [Updatable]
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.4.0    , installed 3.4.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "traccar"      : 1.1.4    , installed 1.1.4
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
        Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
        Adapter    "web"          : 6.2.6    , installed 6.2.6
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Objects and States
        Objects:        15923
        States:         13376
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3620013    94314/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3619051    94314/iobroker.js-c
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11285      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13143      464/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       3619327    94403/node-red
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3621349    94638/io.shelly.1
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       3622287    94683/io.mqtt.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          11289      1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      1001       3619329    94403/node-red
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3619142    94332/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3626313    95332/io.web.0
        tcp6       0      0 :::51989                :::*                    LISTEN      1001       3621067    94578/io.nuki-exten
        tcp6       0      0 :::8086                 :::*                    LISTEN      998        13927      462/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13154      464/sshd: /usr/sbin
        udp        0      0 0.0.0.0:36148           0.0.0.0:*                           1001       3622327    94698/io.divera247.
        udp        0      0 0.0.0.0:36329           0.0.0.0:*                           1001       3619370    94426/io.telegram.0
        udp        0      0 0.0.0.0:44721           0.0.0.0:*                           1001       3619050    94314/iobroker.js-c
        udp        0      0 0.0.0.0:45091           0.0.0.0:*                           1001       3621050    94578/io.nuki-exten
        udp        0      0 0.0.0.0:53437           0.0.0.0:*                           1001       3623743    95164/io.javascript
        udp        0      0 192.168.188.202:5353    0.0.0.0:*                           1001       3622154    94653/io.tr-064.0
        udp        0      0 0.0.0.0:38273           0.0.0.0:*                           1001       3624891    95332/io.web.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       3621261    94623/io.shelly.0
        udp        0      0 0.0.0.0:54867           0.0.0.0:*                           1001       3619298    94388/io.node-red.0
        udp        0      0 0.0.0.0:46959           0.0.0.0:*                           1001       3622590    94743/io.info.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3621562    94668/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3621563    94668/io.tuya.0
        udp        0      0 0.0.0.0:56280           0.0.0.0:*                           1001       3991010    94638/io.shelly.1
        udp        0      0 0.0.0.0:56284           0.0.0.0:*                           1001       3622969    94728/io.echarts.0
        udp        0      0 0.0.0.0:56681           0.0.0.0:*                           1001       3624169    95190/io.parser.0
        udp        0      0 0.0.0.0:56910           0.0.0.0:*                           1001       3626070    95292/io.upnp.0
        udp        0      0 0.0.0.0:40680           0.0.0.0:*                           1001       3625919    95262/io.traccar.0
        udp        0      0 0.0.0.0:49155           0.0.0.0:*                           1001       3619120    94332/io.admin.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11286      1/init
        udp        0      0 0.0.0.0:49287           0.0.0.0:*                           1001       3624810    95307/io.vis-2.0
        udp        0      0 0.0.0.0:33292           0.0.0.0:*                           1001       3620852    94515/io.hmip.0
        udp        0      0 0.0.0.0:33684           0.0.0.0:*                           1001       3625592    95239/io.tankerkoen
        udp        0      0 0.0.0.0:34350           0.0.0.0:*                           1001       3619452    94456/io.accuweathe
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       3626419    95292/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       3619330    94403/node-red
        udp        0      0 0.0.0.0:34955           0.0.0.0:*                           1001       3619259    94368/io.influxdb.0
        udp        0      0 0.0.0.0:59626           0.0.0.0:*                           1001       3620732    94486/io.backitup.0
        udp        0      0 0.0.0.0:43509           0.0.0.0:*                           1001       3626388    95347/io.fullybrows
        udp        0      0 0.0.0.0:43866           0.0.0.0:*                           1001       3626068    95292/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          11292      1/init
        2024-06-09 15:30:00.031  - info: javascript.0 (95164) script.js.Steuerung.Zeitsteuerung.airbowlBad: [DEBUG] Die Airbwol wird nicht eingeschaltet, da diese zuletzt am/um geschalten wurde: 09.06.2024, 15:25 und wird sich in ca. 55 Minuten anschalten.
        2024-06-09 15:30:08.302  - info: host.ioBroker instance system.adapter.ical.0 having pid 109488 terminated with code 0 (NO_ERROR)
        2024-06-09 15:30:45.008  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 109524
        2024-06-09 15:30:47.032  - info: host.ioBroker instance system.adapter.dwd.0 having pid 109524 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-06-09 15:30:49.015  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 109539
        2024-06-09 15:30:50.214  - info: openweathermap.0 (109539) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
        2024-06-09 15:31:14.675  - info: openweathermap.0 (109539) Terminated (NO_ERROR): Without reason
        2024-06-09 15:31:15.195  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 109539 terminated with code 0 (NO_ERROR)
        2024-06-09 15:34:19.242  - info: web.0 (95332) ==> Connected system.user.admin from ::ffff:192.168.188.158
        2024-06-09 15:34:19.691  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm ist angegangen.
        2024-06-09 15:34:23.462  - info: web.0 (95332) ==> Connected system.user.admin from ::ffff:192.168.188.158
        2024-06-09 15:35:00.017  - info: host.ioBroker instance system.adapter.ical.0 started with pid 109680
        2024-06-09 15:35:07.735  - info: host.ioBroker instance system.adapter.ical.0 having pid 109680 terminated with code 0 (NO_ERROR)
        2024-06-09 15:38:49.643  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm wird ausgeschaltet
        2024-06-09 15:40:00.015  - info: host.ioBroker instance system.adapter.ical.0 started with pid 109839
        2024-06-09 15:40:00.029  - info: javascript.0 (95164) script.js.Steuerung.Zeitsteuerung.airbowlBad: [DEBUG] Die Airbwol wird nicht eingeschaltet, da diese zuletzt am/um geschalten wurde: 09.06.2024, 15:25 und wird sich in ca. 45 Minuten anschalten.
        2024-06-09 15:40:07.827  - info: host.ioBroker instance system.adapter.ical.0 having pid 109839 terminated with code 0 (NO_ERROR)
        2024-06-09 15:40:48.009  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 109876
        2024-06-09 15:40:49.076  - info: openweathermap.0 (109876) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
        2024-06-09 15:40:53.465  - info: openweathermap.0 (109876) Terminated (NO_ERROR): Without reason
        2024-06-09 15:40:53.984  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 109876 terminated with code 0 (NO_ERROR)
        2024-06-09 15:41:39.725  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm ist angegangen.
        2024-06-09 15:43:39.756  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm wird ausgeschaltet
        2024-06-09 15:45:00.012  - info: host.ioBroker instance system.adapter.ical.0 started with pid 110131
        2024-06-09 15:45:08.465  - info: host.ioBroker instance system.adapter.ical.0 having pid 110131 terminated with code 0 (NO_ERROR)
                                v.2024-05-22
                   Chassis: vm
            Virtualization: kvm
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Pending OS-Updates:     0
        Pending iob updates:    2
        Nodejs-Installation:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        Recommended versions are nodejs 18.20.3 and npm 10.7.0
        MEMORY:
        Swap:           2.0G          0B        2.0G
        Total:           16G        3.3G         10G
        ioBroker Core:          js-controller           6.0.1-alpha.0-20240603-3deca26fa
                                admin                   6.17.14
        Objects type: jsonl
        States  type: jsonl
        Objects:                15923
        States:                 13376
        Size of iob-Database:
        3.2M    /opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @tomtaz last edited by
          @tomtaz
          Nach Änderungen in den Gruppen einmal Neustart.
            @tomtaz
            Wo kommen die Module ohne iobroker im Pfad her?
            ├── canvas@2.11.2
            ├── echarts@5.4.3
            ├── moment@2.29.4
            Die dürften da eigentlich nicht auftauchen, denke ich.
              @tomtaz
              Installier den iobroker.admin@6.17.14 nochmal sauber rein.
                Sorry, den hab ich vergessen 😞
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 16:03:42 up 4 min,  1 user,  load average: 0.55, 0.45, 0.19
                CPU threads: 2
                               Local time: Sun 2024-06-09 16:03:42 CEST
                           Universal time: Sun 2024-06-09 14:03:42 UTC
                                 RTC time: Sun 2024-06-09 14:03:43
                              NTP service: active
                          RTC in local TZ: no
                tomtaz
                HOME=/home/tomtaz
                GROUPS=tomtaz adm cdrom floppy audio dip video plugdev netdev iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             13G        2.4G         11G        0.0K        569M         11G
                Swap:           2.0G          0B        2.0G
                Total:           16G        2.4G         13G
                         2389 M used memory
                          206 M active memory
                         2522 M inactive memory
                        11018 M free memory
                           56 M buffer memory
                          512 M swap cache
                         2047 M total swap
                            0 M used swap
                         2047 M free swap
                top - 16:03:42 up 4 min,  1 user,  load average: 0.55, 0.45, 0.19
                Tasks: 131 total,   1 running, 130 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  13977.1 total,  11018.5 free,   2389.1 used,    569.5 buff/cache
                MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  11321.7 avail Mem
                *** FILESYSTEM ***
                [Sun Jun  9 15:59:38 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                [Sun Jun  9 15:59:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
                | `-/proc/sys/fs/binfmt_misc  systemd-1                  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11229
                /var:
                5.1G    /var/
                4.0G    /var/log
                802M    /var/lib
                Archived and active journals take up 3.9G in the file system.
                916M    /opt/iobroker/iobroker-data/files
                24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                USB-Devices by-id:
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.17.14
                javascript:     8.5.0
                Adapter State
                + instance is alive
                Objects and States
                Objects:        15919
                States:         13462
                Pending Updates: 0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16518      831/io.shelly.1
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       16030      876/io.mqtt.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13901      538/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13894      538/iobroker.js-con
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          425        1/init
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13800      467/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14093      614/node-red
                tcp6       0      0 :::111                  :::*                    LISTEN      0          429        1/init
                tcp6       0      0 :::80                   :::*                    LISTEN      1001       14097      614/node-red
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13983      557/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20185      1500/io.web.0
                tcp6       0      0 :::51989                :::*                    LISTEN      1001       15240      771/io.nuki-extende
                tcp6       0      0 :::8086                 :::*                    LISTEN      998        13276      456/influxd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          13802      467/sshd: /usr/sbin
                udp        0      0 0.0.0.0:49153           0.0.0.0:*                           1001       20889      1475/io.vis-2.0
                udp        0      0 0.0.0.0:41010           0.0.0.0:*                           1001       20781      1460/io.upnp.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          426        1/init
                udp        0      0 0.0.0.0:57553           0.0.0.0:*                           1001       19708      1415/io.tankerkoeni
                udp        0      0 0.0.0.0:49520           0.0.0.0:*                           1001       14273      708/io.backitup.0
                udp        0      0 0.0.0.0:49618           0.0.0.0:*                           1001       14024      584/io.influxdb.0
                udp        0      0 0.0.0.0:33527           0.0.0.0:*                           1001       16302      921/io.echarts.0
                udp        0      0 0.0.0.0:58283           0.0.0.0:*                           1001       14757      599/io.node-red.0
                udp        0      0 0.0.0.0:42258           0.0.0.0:*                           1001       20179      1500/io.web.0
                udp        0      0 0.0.0.0:50692           0.0.0.0:*                           1001       20565      1430/io.traccar.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21139      1460/io.upnp.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       14098      614/node-red
                udp        0      0 0.0.0.0:44130           0.0.0.0:*                           1001       21075      1515/io.fullybrowse
                udp        0      0 0.0.0.0:52492           0.0.0.0:*                           1001       16384      936/io.info.0
                udp        0      0 0.0.0.0:52591           0.0.0.0:*                           1001       13893      538/iobroker.js-con
                udp        0      0 0.0.0.0:36931           0.0.0.0:*                           1001       14401      557/io.admin.0
                udp        0      0 0.0.0.0:37330           0.0.0.0:*                           1001       20775      1460/io.upnp.0
                udp        0      0 0.0.0.0:37612           0.0.0.0:*                           1001       14205      678/io.accuweather.
                udp        0      0 0.0.0.0:45815           0.0.0.0:*                           1001       15068      723/io.hmip.0
                udp        0      0 0.0.0.0:45883           0.0.0.0:*                           1001       17942      1385/io.parser.0
                udp        0      0 192.168.188.202:5353    0.0.0.0:*                           1001       15871      846/io.tr-064.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16448      816/io.shelly.0
                udp        0      0 0.0.0.0:47203           0.0.0.0:*                           1001       16841      891/io.divera247.0
                udp        0      0 0.0.0.0:55599           0.0.0.0:*                           1001       15576      771/io.nuki-extende
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15926      861/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15927      861/io.tuya.0
                udp        0      0 0.0.0.0:48183           0.0.0.0:*                           1001       14818      637/io.telegram.0
                udp        0      0 0.0.0.0:49008           0.0.0.0:*                           1001       17800      1351/io.javascript.
                udp6       0      0 :::111                  :::*                                0          432        1/init
                2024-06-09 16:01:35.592  - info: javascript.0 (1351) script.js.Steuerung.Automation.traccar: [DEBUG] in the past hour, the script traccar have send 0000 setState commands
                2024-06-09 16:01:35.623  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G090XG1214720TXQ [Küche] success proceed while Trigger Mode is On! 0 left...
                2024-06-09 16:01:36.547  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Incomming Changes for alexa device #G090XG1211830A5N[{"name":"Schlafzimmer","serialNumber":"G090XG1211830A5N","summary":"","creationTime":1717941689256,"domainApplicationId":"","domainApplicationName":"","cardContent":"","card":"","answerText":"","utteranceType":"ROUTINES_3P","domain":"Echo.SDK","intent":"Unknown"}]
                2024-06-09 16:01:36.556  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Ignoring History becouse no activ Command
                2024-06-09 16:01:36.589  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G090XG1214720WES [Kinderzimmer] success proceed while Trigger Mode is On! 0 left...
                2024-06-09 16:01:37.057  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: [DEBUG] Specified last Commands cleared, while trigger-mode is on...
                2024-06-09 16:01:37.486  - info: host.ioBroker instance system.adapter.trashschedule.0 started with pid 1445
                2024-06-09 16:01:37.592  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G091AA1215130RXA [Büro] success proceed while Trigger Mode is On! 0 left...
                2024-06-09 16:01:38.599  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G2A0U20493460BF6 [Wohnzimmer] success proceed while Trigger Mode is On! 0 left...
                2024-06-09 16:01:40.780  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Incomming Changes for alexa device #G091AA1215130RXA[{"name":"Büro","serialNumber":"G091AA1215130RXA","summary":"","creationTime":1717941692235,"domainApplicationId":"","domainApplicationName":"","cardContent":"","card":"","answerText":"","utteranceType":"ROUTINES_3P","domain":"Echo.SDK","intent":"Unknown"}]
                2024-06-09 16:01:40.780  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Ignoring History becouse no activ Command
                2024-06-09 16:01:41.282  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: [DEBUG] Specified last Commands cleared, while trigger-mode is on...
                2024-06-09 16:01:41.544  - info: host.ioBroker instance system.adapter.upnp.0 started with pid 1460
                2024-06-09 16:01:43.053  - info: upnp.0 (1460) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
                2024-06-09 16:01:43.064  - info: upnp.0 (1460) Auto discover: true
                2024-06-09 16:01:45.753  - info: host.ioBroker instance system.adapter.vis-2.0 started with pid 1475
                2024-06-09 16:01:46.796  - error: vis-2.0 (1475) No license found for vis-2. Please get one on https://iobroker.net !
                2024-06-09 16:01:49.455  - info: host.ioBroker instance system.adapter.web.0 started with pid 1500
                2024-06-09 16:01:50.633  - info: web.0 (1500) starting. Version 6.2.6 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
                2024-06-09 16:01:50.716  - info: web.0 (1500) socket.io server listening on port 8082
                2024-06-09 16:01:50.723  - info: web.0 (1500) http server listening on port 8082
                2024-06-09 16:01:50.973  - info: web.0 (1500) ==> Connected system.user.admin from ::ffff:192.168.188.158
                2024-06-09 16:01:53.525  - info: host.ioBroker instance system.adapter.fullybrowser.0 started with pid 1515
                2024-06-09 16:01:54.467  - warn: fullybrowser.0 (1515) Adapter instance settings: REST API timeout of undefined ms is not allowed, set to default of 10000ms
                2024-06-09 16:01:58.066  - info: web.0 (1500) ==> Connected system.user.admin from ::ffff:192.168.188.158
                                        v.2024-05-22
                           Chassis: vm
                    Virtualization: kvm
                Installation:           kvm
                Kernel:                 x86_64
                Userland:               64 bit
                User-ID:                1000
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                MEMORY:
                Mem:             13G        2.4G         10G        0.0K        787M         11G
                Swap:           2.0G          0B        2.0G
                Total:           16G        2.4G         12G
                                        admin                   6.17.14
                Objects type: jsonl
                States  type: jsonl
                Objects:                15919
                States:                 13462
                23M     /opt/iobroker/iobroker-data/objects.jsonl
                3.0M    /opt/iobroker/iobroker-data/states.jsonl
                  Wo diese herkommen, kann ich Dir beim besten willen nicht sagen. Echarts nutze ich aber und den ring-client-api auch für die Ring-Cams
                  @tomtaz
                  tomtaz@ioBroker:/opt/iobroker$ npm install iobroker.admin@6.17.14
                  npm warn While resolving: @iobroker/adapter-core@3.1.4
                  npm warn Found: @iobroker/types@6.0.0
                  npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
                  npm warn   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
                  npm warn     iobroker.admin@"6.17.14" from the root project
                  npm warn
                  npm warn Could not resolve dependency:
                  npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
                  npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                  npm warn   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
                  npm warn
                  npm warn Conflicting peer dependency: @iobroker/types@5.0.19
                  npm warn node_modules/@iobroker/types
                  up to date in 4s
                  174 packages are looking for funding
                    run `npm fund` for details
                    @tomtaz
                    Aber echarts muss so im tree stehen:
                    Das haste mal irgendwann irgendwie in das System gedübelt.
                    Bitte nicht direkt npm-Kommandos verwenden. Das führt nämlich unter Umständen genau zu solchen schrägen Installationen.
                    iob upgrade iobroker.admin@6.17.14 --omit=dev
                      @tomtaz
                      Neben deinem strubbeligen npm-tree kommt die Ursprungsmeldung von dem js-controller in der Alpha-Version.
                      Auf meinem System kommt nämlich:
                      echad@chet:/opt/iobroker $ iob stop
                      echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                      npm warn
                      npm warn
                      up to date in 8s
                      190 packages are looking for funding
                        Ahh ok, Danke für die Info. Dann muss es wohl von der Alpha.
                        Bloß wie korrigiere ich nun die
                        ├── canvas@2.11.2
                        ├── echarts@5.4.3
                        ├── moment@2.29.4
                        am besten korrigiert? Per NPM deinstallieren?
                          Thomas Braun Most Active @tomtaz last edited by Thomas Braun
                          @tomtaz sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                          Wenn sie auch per npm reingedrückt worden sind ja.
                            @thomas-braun sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                            schon gar nicht im falschen Verzeichnis!
                            aber genau dort von wo sie auch installiert wurden
                              Diamand2k22 @Homoran last edited by
                              @Thomas-Braun
                              bei mir ist leider auch was strubbelig, zumindest bekomm ich den selben Fehler wie tomtaz.
                              aber npm tree schaut sauber aus!
                              pi4b@pi4b:~$ cd /opt/iobroker && npm ls
                              ├── iobroker.adguard@0.0.8
                              ├── iobroker.alarm@3.6.0
                              ├── iobroker.alias-manager@1.2.6
                              ├── iobroker.backitup@3.0.5
                              ├── iobroker.blueconnect@0.0.5 (git+ssh://git@github.com/kopierschnitte/ioBroker        .blueconnect.git#f50eada99eaffdd21802ee0cbd5bcff4fd42469d)
                              ├── iobroker.bmw@2.8.0
                              ├── iobroker.bydhvs@1.5.0
                              ├── iobroker.daswetter@3.1.15
                              ├── iobroker.device-reminder@3.1.2
                              ├── iobroker.device-watcher@2.12.1
                              ├── iobroker.discovery@4.5.0
                              ├── iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBr        oker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
                              ├── iobroker.evcc@0.1.1
                              ├── iobroker.fritzdect@2.5.9
                              ├── iobroker.fronius-solarweb@0.1.0
                              ├── iobroker.fronius-wattpilot@4.6.3
                              ├── iobroker.fronius@2.1.0
                              ├── iobroker.ham@5.3.1
                              ├── iobroker.heizoel@1.0.3
                              ├── iobroker.icons-mfd-svg@1.2.0
                              ├── iobroker.intex@0.1.5
                              ├── iobroker.javascript@8.6.0
                              ├── iobroker.js-controller@5.0.19
                              ├── iobroker.lovelace@4.1.10
                              ├── iobroker.midea@0.0.7
                              ├── iobroker.modbus@6.2.3
                              ├── iobroker.oilfox@4.3.0
                              ├── iobroker.opendtu@1.0.1
                              ├── iobroker.ping@1.6.2
                              ├── iobroker.pushover@3.0.6
                              ├── iobroker.rpi2@1.3.2
                              ├── iobroker.synology@3.1.0
                              ├── iobroker.telegram@3.5.3
                              ├── iobroker.tibberlink@3.3.1
                              ├── iobroker.vis-inventwo@3.3.4
                              ├── iobroker.vis-materialdesign@0.5.9
                              ├── iobroker.whatsapp-cmb@0.3.0
                              └── iobroker.zigbee2mqtt@2.13.6
                                Thomas Braun Most Active @Diamand2k22 last edited by
                                @diamand2k22
                                Der strubbelige npm tree ist ja auch nur eine Begleiterscheinung.
                                Was genau wird dir in dein LogFile geschrieben?
                                  Diamand2k22 @Thomas Braun last edited by
                                  $ iobroker add vis-icontwo auto --host pi4b --debug
                                  NPM version: 10.7.0
                                  Installing iobroker.vis-icontwo@1.5.0... (System call)
                                  npm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                                  npm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                                  Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                                    @diamand2k22
                                    Installier den admin nochmal frisch drüber.
                                      du meinst so oder
                                        @diamand2k22
                                        Ganz genau.
                                        • haus-automatisierung
                                          haus-automatisierung Developer Most Active @Diamand2k22 last edited by haus-automatisierung
                                          @diamand2k22 sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                                          Das liegt an der Definition der dependencies im admin (@iobroker/types sollte eine devDependency sein). PR wurde schon erstellt: https://github.com/ioBroker/ioBroker.admin/pull/2507
                                          foxriver76 created this issue in ioBroker/ioBroker.admin
                                          closed try to fix ci #2507
                                            @haus-automatisierung
                                            passt, danke für den Hinweis 👍
                                            1492
