    4. Gelöst: TR-064 external IP wird nicht aktualisiert
    • haselchen
      haselchen Most Active @Thomas Braun last edited by
      Was ist hiermit?
      + system.adapter.admin.0      : admin       : ubuntuserver            -  enabled, port: 8081, bind: 192.168.2.222, run as: admin
        system.adapter.web.0             : web           : ubuntuserver            - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        Thomas Braun Most Active @haselchen last edited by
        @haselchen
        Du meinst das Binding an die IP? Kann man machen.
        Auch wenn ich es nicht empfehlen würde.
          e-s @Thomas Braun last edited by
          Wieso da ein Desktop aktiv sein sollte, ist mir unklar. Egal, ist jetzt deaktiviert.
          den anderen Befehl habe ich schon mehrfach getestet:
          santa@ubuntuserver:/opt/iobroker$ iob upgrade iobroker.admin@6.17.14 --omit=dev
          Would you like to reinstall version 6.17.14 of admin now? [(y)es, (n)o]: y
          Update admin from @6.17.14 to @6.17.14
          host.ubuntuserver Adapter "system.adapter.admin.0" is stopped.
          NPM version: 10.7.0
          Installing iobroker.admin@6.17.14... (System call)
          up to date in 9s
          107 packages are looking for funding
            run `npm fund` for details
          upload [53] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js application/javascript
          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
          host.ubuntuserver Adapter "system.adapter.admin.0" is started
            Thomas Braun Most Active @e-s last edited by Thomas Braun
            @e-s
            Ich vermute die Meldung
            npm warn ERESOLVE overriding peer dependency
            npm warn While resolving: @iobroker/adapter-core@3.1.4
            npm warn Found: @iobroker/types@6.0.0
            npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
            npm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
            npm warn iobroker.admin@"6.17.14" from the root project
            npm warn
            npm warn Could not resolve dependency:
            npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
            npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
            npm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
            npm warn
            npm warn Conflicting peer dependency: @iobroker/types@5.0.19
            npm warn node_modules/@iobroker/types
            dürfte erstmal verschwunden sein.
              leider nein
              santa@ubuntuserver:/opt/iobroker$ iobroker upgrade tr-064@4.3.0 --debug
              Would you like to reinstall version 4.3.0 of tr-064 now? [(y)es, (n)o]: y
              Update tr-064 from @4.3.0 to @4.3.0
              NPM version: 10.7.0
              Installing iobroker.tr-064@4.3.0... (System call)
              npm warn
              npm warn
              up to date in 9s
              upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
              upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
              upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                @e-s
                cd /opt/iobroker && npm ls -a | grep -C4 ERR
                Hat aber alles nix mit dem Adapter tr-064 zu tun.
                  wenn einem aber schon ein Fehler auffällt, dann kann man ja hoffen, dass es den anderen Fehler mitbeseitigt.
                  santa@ubuntuserver:/opt/iobroker$ cd /opt/iobroker && npm ls -a | grep -C4 ERR
                  npm error code ELSPROBLEMS
                  npm error invalid: @iobroker/types@6.0.0 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/types
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-09T19_29_11_117Z-debug-0.log
                  interessiert dich das log?
                    @e-s
                    Eher
                    npm ls @iobroker/types
                    In dem Log dürfte nicht viel drin stehen.
                      santa@ubuntuserver:/opt/iobroker$ npm ls @iobroker/types
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├─┬ iobroker.admin@6.17.14
                      │ ├─┬ @iobroker/adapter-core@3.1.4
                      │ │ └── @iobroker/types@6.0.0 deduped invalid: "^5.0.11" from node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                      │ ├─┬ @iobroker/socket-classes@1.5.0
                      │ │ └─┬ @iobroker/adapter-core@3.0.4
                      │ │   └── @iobroker/types@5.0.11 deduped
                      │ └── @iobroker/types@6.0.0 invalid: "^5.0.11" from node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                      ├─┬ iobroker.backitup@3.0.2
                      │ └─┬ @iobroker/adapter-core@3.1.6
                      ├─┬ iobroker.bosesoundtouch@0.11.1
                      │ └─┬ @iobroker/adapter-core@3.0.6
                      ├─┬ iobroker.deconz@1.4.1
                      │ └─┬ @iobroker/adapter-core@3.1.4
                      ├─┬ iobroker.device-reminder@3.1.2
                      ├─┬ iobroker.discord@2.3.0
                      ├─┬ iobroker.esphome@0.5.0-beta.8
                      ├─┬ iobroker.fb-checkpresence@1.2.4
                      ├─┬ iobroker.frontier_silicon@0.2.0
                      ├─┬ iobroker.hiob@0.1.4
                      ├─┬ iobroker.homeconnect@1.4.0
                      ├─┬ iobroker.influxdb@4.0.2
                      ├─┬ iobroker.javascript@8.5.0
                      ├─┬ iobroker.samsung_tizen@1.1.0
                      ├─┬ iobroker.samsung@0.6.0
                      ├─┬ iobroker.shelly@7.0.0
                      ├─┬ iobroker.simple-api@2.8.0
                      ├─┬ iobroker.socketio@6.7.0
                      ├─┬ iobroker.solarlog@2.3.0
                      ├─┬ iobroker.statistics@2.4.0
                      ├─┬ iobroker.synology@3.1.0
                      ├─┬ iobroker.tr-064@4.3.0
                      ├─┬ iobroker.weatherunderground@3.7.0
                      ├─┬ iobroker.web@6.2.6
                      ├─┬ iobroker.wled@0.7.3-beta.0
                      └─┬ iobroker.ws@2.6.1
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-09T19_33_56_303Z-debug-0.log
                        @e-s sagte in TR-064 external IP wird nicht aktualisiert:
                        Der Admin sieht bei mir anders aus:
                        │ ├─┬ @iobroker/adapter-core@3.1.6
                        │ │ └─┬ @iobroker/adapter-core@3.1.4
                        │ │   └── @iobroker/types@5.0.19 deduped
                          kann mich ein update auf node.js20 weiter bringen?
                            Da solltest du eh machen, nodejs@20 ist die derzeitige Empfehlung für den ioBroker.
                            iob nodejs-update 20
                            bringt dich hin.
                              kein Unterschied nach Update. Ausgaben bleiben alle identisch.
                              Hast du noch eine Idee?
                                @e-s
                                Bügel den admin noch mal rein.
                                Vielleicht auch zuvor mal deinstallieren:
                                iob del admin
                                  Leider auch nicht, eventuell muss ich backitup doch auch kurz deinstallieren.
                                  Skript v.2024-05-22
                                  *** BASE SYSTEM ***
                                   Static hostname: ubuntuserver
                                         Icon name: computer-desktop
                                           Chassis: desktop
                                  Operating System: Ubuntu 22.04.4 LTS
                                            Kernel: Linux 5.15.0-112-generic
                                      Architecture: x86-64
                                   Hardware Vendor: HP
                                    Hardware Model: ProLiant MicroServer
                                  model name      : AMD Turion(tm) II Neo N40L Dual-Core Processor
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  Systemuptime and Load:
                                   21:55:22 up 2 days,  3:05,  2 users,  load average: 1.46, 1.82, 1.53
                                  CPU threads: 2
                                  *** Time and Time Zones ***
                                                 Local time: Sun 2024-06-09 21:55:22 CEST
                                             Universal time: Sun 2024-06-09 19:55:22 UTC
                                                   RTC time: Sun 2024-06-09 19:55:22
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  santa
                                  HOME=/home/santa
                                  GROUPS=santa adm dialout cdrom sudo dip plugdev lxd docker iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  GROUPS=iobroker tty dialout audio video plugdev redis
                                  *** Display-Server-Setup ***
                                  Display-Server: false
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            3.8G        1.7G        585M         24M        1.5G        1.8G
                                  Swap:           3.8G        557M        3.3G
                                  Total:          7.6G        2.3G        3.8G
                                  Active iob-Instances:   23
                                           3785 M total memory
                                           1735 M used memory
                                            883 M active memory
                                           1851 M inactive memory
                                            585 M free memory
                                            693 M buffer memory
                                            771 M swap cache
                                           3808 M total swap
                                            557 M used swap
                                           3251 M free swap
                                  top - 21:55:22 up 2 days,  3:05,  2 users,  load average: 1.46, 1.82, 1.53
                                  Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  9.1 us,  6.1 sy,  0.0 ni, 81.8 id,  0.0 wa,  0.0 hi,  3.0 si,  0.0 st
                                  MiB Mem :   3785.9 total,    585.6 free,   1735.0 used,   1465.3 buff/cache
                                  MiB Swap:   3809.0 total,   3251.4 free,    557.6 used.   1800.3 avail Mem
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  Filesystem                        Type   Size  Used Avail Use% Mounted on
                                  tmpfs                             tmpfs  379M  2.9M  376M   1% /run
                                  /dev/mapper/ubuntu--vg-ubuntu--lv ext4    58G   35G   21G  63% /
                                  tmpfs                             tmpfs  1.9G     0  1.9G   0% /dev/shm
                                  tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                                  /dev/sda2                         ext4   974M  253M  654M  28% /boot
                                  /dev/md0                          ext4   917G  849G   22G  98% /media/HDD
                                  /dev/sdd1                         ext4   1.4T  943G  364G  73% /media/HDD/Videos
                                  tmpfs                             tmpfs  379M  4.0K  379M   1% /run/user/1000
                                  [Fri Jun  7 18:49:52 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                  [Fri Jun  7 18:49:54 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
                                  [Fri Jun  7 18:49:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                  [Fri Jun  7 18:49:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: usrquota,grpquota. Quota mode: writeback.
                                  [Fri Jun  7 18:50:12 2024] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: usrquota,grpquota. Quota mode: writeback.
                                  Show mounted filesystems:
                                  TARGET                                        SOURCE                            FSTYPE      OPTIONS
                                  /                                             /dev/mapper/ubuntu--vg-ubuntu--lv ext4        rw,relatime
                                  |-/sys                                        sysfs                             sysfs       rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/cgroup                            cgroup2                           cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                  | |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/bpf                               bpf                               bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/kernel/tracing                       tracefs                           tracefs     rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
                                  | `-/sys/kernel/config                        configfs                          configfs    rw,nosuid,nodev,noexec,relatime
                                  |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
                                  | |-/proc/sys/fs/binfmt_misc                  systemd-1                         autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18784
                                  | | `-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
                                  | `-/proc/fs/nfsd                             nfsd                              nfsd        rw,relatime
                                  |-/dev                                        udev                              devtmpfs    rw,nosuid,relatime,size=1846848k,nr_inodes=461712,mode=755,inode64
                                  | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                  | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,inode64
                                  | |-/dev/hugepages                            hugetlbfs                         hugetlbfs   rw,relatime,pagesize=2M
                                  | `-/dev/mqueue                               mqueue                            mqueue      rw,nosuid,nodev,noexec,relatime
                                  |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=387676k,mode=755,inode64
                                  | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                                  | |-/run/credentials/systemd-sysusers.service none                              ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/run/rpc_pipefs                           sunrpc                            rpc_pipefs  rw,relatime
                                  | |-/run/snapd/ns                             tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=387676k,mode=755,inode64
                                  | | |-/run/snapd/ns/lxd.mnt                   nsfs[mnt:[4026532309]]            nsfs        rw
                                  | | `-/run/snapd/ns/canonical-livepatch.mnt   nsfs[mnt:[4026532310]]            nsfs        rw
                                  | `-/run/user/1000                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=387672k,nr_inodes=96918,mode=700,uid=1000,gid=1000,inode64
                                  |-/snap/canonical-livepatch/264               /dev/loop0                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/canonical-livepatch/278               /dev/loop1                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/certbot/3700                          /dev/loop2                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/certbot/3834                          /dev/loop3                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core/16574                            /dev/loop4                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core/16928                            /dev/loop5                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core18/2812                           /dev/loop6                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core18/2823                           /dev/loop7                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core20/2318                           /dev/loop9                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core20/2264                           /dev/loop8                        squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core22/1122                           /dev/loop10                       squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/core22/1380                           /dev/loop11                       squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/lxd/23991                             /dev/loop12                       squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/lxd/24061                             /dev/loop13                       squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/snapd/21465                           /dev/loop14                       squashfs    ro,nodev,relatime,errors=continue
                                  |-/snap/snapd/21759                           /dev/loop15                       squashfs    ro,nodev,relatime,errors=continue
                                  |-/boot                                       /dev/sda2                         ext4        rw,relatime
                                  `-/media/HDD                                  /dev/md0                          ext4        rw,relatime,quota,usrquota,grpquota
                                    `-/media/HDD/Videos                         /dev/sdd1                         ext4        rw,nosuid,nodev,noexec,relatime,quota,usrquota,grpquota
                                  /var:
                                  10G     /var/
                                  4.1G    /var/log
                                  4.0G    /var/log/journal/a4cf029863be491d9b4015eb9e07f827
                                  3.7G    /var/lib
                                  Archived and active journals take up 3.9G in the file system.
                                  /opt/iobroker/backups:
                                  27M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  774M    /opt/iobroker/iobroker-data/
                                  618M    /opt/iobroker/iobroker-data/files
                                  281M    /opt/iobroker/iobroker-data/files/javascript.admin
                                  247M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                  245M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                  29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.7253116f.js.map
                                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2119138-if00
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v20.14.0
                                  /usr/bin/node           v20.14.0
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  /usr/bin/corepack       0.28.1
                                  nodejs:
                                    Installed: 20.14.0-1nodesource1
                                    Candidate: 20.14.0-1nodesource1
                                    Version table:
                                   *** 20.14.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                          100 /var/lib/dpkg/status
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                       12.22.9~dfsg-1ubuntu3.5 500
                                          500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                          500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                                       12.22.9~dfsg-1ubuntu3 500
                                          500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller:  5.0.19
                                  admin:          6.17.14
                                  javascript:     8.5.0
                                  nodejs modules from github:     2
                                  | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                  | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                  Adapter State
                                    system.adapter.alias-manager.0          : alias-manager         : ubuntuserver                             -  enabled
                                  + system.adapter.backitup.0               : backitup              : ubuntuserver                             -  enabled
                                  + system.adapter.bosesoundtouch.0         : bosesoundtouch        : ubuntuserver                             -  enabled
                                  + system.adapter.deconz.0                 : deconz                : ubuntuserver                             -  enabled, port: 8080
                                    system.adapter.device-reminder.0        : device-reminder       : ubuntuserver                             - disabled
                                    system.adapter.devices.0                : devices               : ubuntuserver                             -  enabled
                                  + system.adapter.discord.0                : discord               : ubuntuserver                             -  enabled
                                  + system.adapter.echarts.0                : echarts               : ubuntuserver                             -  enabled
                                  + system.adapter.esphome.0                : esphome               : ubuntuserver                             -  enabled
                                  + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ubuntuserver                             -  enabled
                                  + system.adapter.frontier_silicon.0       : frontier_silicon      : ubuntuserver                             -  enabled
                                  + system.adapter.hiob.0                   : hiob                  : ubuntuserver                             -  enabled, port: 8096
                                  + system.adapter.homeconnect.0            : homeconnect           : ubuntuserver                             -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : ubuntuserver                             -  enabled, port: 8086
                                  + system.adapter.javascript.0             : javascript            : ubuntuserver                             -  enabled
                                  + system.adapter.linkeddevices.0          : linkeddevices         : ubuntuserver                             -  enabled
                                    system.adapter.samsung.0                : samsung               : ubuntuserver                             - disabled
                                  + system.adapter.samsung_tizen.0          : samsung_tizen         : ubuntuserver                             -  enabled, port: 8002
                                  + system.adapter.shelly.0                 : shelly                : ubuntuserver                             -  enabled, port: 1885, bind: 192.168.2.222
                                  + system.adapter.simple-api.0             : simple-api            : ubuntuserver                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.socketio.0               : socketio              : ubuntuserver                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.solarlog.0               : solarlog              : ubuntuserver                             - disabled, port: 80
                                    system.adapter.statistics.0             : statistics            : ubuntuserver                             - disabled
                                  + system.adapter.synology.0               : synology              : ubuntuserver                             -  enabled, port: 5001
                                  + system.adapter.tr-064.0                 : tr-064                : ubuntuserver                             -  enabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : ubuntuserver                             - disabled
                                  + system.adapter.wiffi-wz.0               : wiffi-wz              : ubuntuserver                             -  enabled
                                  + system.adapter.wled.0                   : wled                  : ubuntuserver                             -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): beta
                                  Installed ioBroker-Instances
                                  Used repository: beta
                                  Adapter    "admin"        : 6.17.14  , installed 6.17.14
                                  Adapter    "backitup"     : 3.0.2    , installed 3.0.2
                                  Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
                                  Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                  Adapter    "discord"      : 2.3.0    , installed 2.3.0
                                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                  Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
                                  Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                  Adapter    "frontier_silicon": 0.2.0 , installed 0.2.0
                                  Adapter    "hiob"         : 0.1.4    , installed 0.1.4
                                  Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
                                  Adapter    "javascript"   : 8.5.0    , installed 8.5.0
                                  Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                  Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                  Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                  Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                  Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                  Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                  Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                  Adapter    "web"          : 6.2.6    , installed 6.2.6
                                  Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                                  Adapter    "wled"         : 0.7.3-beta.0, installed 0.7.3-beta.0
                                  Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                  Objects and States
                                  Objects:        8594
                                  States:         7873
                                  Hit:1 http://phoscon.de/apt/deconz jammy-beta InRelease
                                  Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                                  Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                                  Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                                  Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                                  Hit:6 https://download.docker.com/linux/ubuntu jammy InRelease
                                  Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Hit:8 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security InRelease
                                  Hit:9 https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates InRelease
                                  Hit:10 https://esm.ubuntu.com/infra/ubuntu jammy-infra-security InRelease
                                  Hit:11 https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:37221           0.0.0.0:*               LISTEN      0          25703      846/rpc.mountd
                                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          26515      1075/smbd
                                  tcp        0      0 0.0.0.0:20877           0.0.0.0:*               LISTEN      1000       26870      857/deCONZ
                                  tcp        0      0 0.0.0.0:33247           0.0.0.0:*               LISTEN      114        25754      849/rpc.statd
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25336      910/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          26091      -
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19746      1/init
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2047882    410638/iobroker.js-
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2049555    410638/iobroker.js-
                                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          26516      1075/smbd
                                  tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      116        26347      884/redis-server 12
                                  tcp        0      0 0.0.0.0:56265           0.0.0.0:*               LISTEN      0          25685      846/rpc.mountd
                                  tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      115        27345      1104/mysqld
                                  tcp        0      0 192.168.2.222:8081      0.0.0.0:*               LISTEN      1001       2052571    411557/io.admin.0
                                  tcp        0      0 192.168.2.222:8181      0.0.0.0:*               LISTEN      1001       2050813    411162/io.wiffi-wz.
                                  tcp        0      0 0.0.0.0:19828           0.0.0.0:*               LISTEN      0          25315      892/oscam
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      997        26675      921/influxd
                                  tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          26909      1227/perl
                                  tcp        0      0 0.0.0.0:59137           0.0.0.0:*               LISTEN      0          25695      846/rpc.mountd
                                  tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       1816103    364963/python3
                                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       26438      857/deCONZ
                                  tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      115        28922      1104/mysqld
                                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        25053      834/systemd-resolve
                                  tcp        0      0 0.0.0.0:36399           0.0.0.0:*               LISTEN      0          26152      -
                                  tcp6       0      0 :::57625                :::*                    LISTEN      0          25699      846/rpc.mountd
                                  tcp6       0      0 :::445                  :::*                    LISTEN      0          26513      1075/smbd
                                  tcp6       0      0 :::443                  :::*                    LISTEN      0          25561      1081/apache2
                                  tcp6       0      0 :::43069                :::*                    LISTEN      0          25707      846/rpc.mountd
                                  tcp6       0      0 :::21                   :::*                    LISTEN      0          25287      911/vsftpd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          25338      910/sshd: /usr/sbin
                                  tcp6       0      0 :::2049                 :::*                    LISTEN      0          26127      -
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          19748      1/init
                                  tcp6       0      0 :::80                   :::*                    LISTEN      0          25557      1081/apache2
                                  tcp6       0      0 :::139                  :::*                    LISTEN      0          26514      1075/smbd
                                  tcp6       0      0 ::1:6379                :::*                    LISTEN      116        26348      884/redis-server 12
                                  tcp6       0      0 :::42125                :::*                    LISTEN      0          26154      -
                                  tcp6       0      0 :::8096                 :::*                    LISTEN      1001       2051218    410961/io.hiob.0
                                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2051523    411138/io.socketio.
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      997        29320      921/influxd
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2051511    411117/io.simple-ap
                                  tcp6       0      0 :::52769                :::*                    LISTEN      114        25760      849/rpc.statd
                                  tcp6       0      0 :::40569                :::*                    LISTEN      0          25691      846/rpc.mountd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2051538    411200/io.wled.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2050743    411057/io.esphome.0
                                  udp        0      0 192.168.2.222:5353      0.0.0.0:*                           1001       2051173    410917/io.tr-064.0
                                  udp        0      0 172.18.0.1:5353         0.0.0.0:*                           1000       1816113    364963/python3
                                  udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       1816112    364963/python3
                                  udp        0      0 192.168.2.222:5353      0.0.0.0:*                           1000       1816111    364963/python3
                                  udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       1816110    364963/python3
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1816104    364963/python3
                                  udp        0      0 0.0.0.0:42362           0.0.0.0:*                           0          25693      846/rpc.mountd
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       2050323    410894/io.shelly.0
                                  udp        0      0 0.0.0.0:56887           0.0.0.0:*                           0          25701      846/rpc.mountd
                                  udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          26910      1227/perl
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2050227    410848/io.deconz.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       27695      857/deCONZ
                                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        25052      834/systemd-resolve
                                  udp        0      0 192.168.2.222:68        0.0.0.0:*                           100        669432     832/systemd-network
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19747      1/init
                                  udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          670380     880/nmbd
                                  udp        0      0 192.168.2.222:137       0.0.0.0:*                           0          670379     880/nmbd
                                  udp        0      0 172.18.255.255:137      0.0.0.0:*                           0          33107      880/nmbd
                                  udp        0      0 172.18.0.1:137          0.0.0.0:*                           0          33106      880/nmbd
                                  udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          33103      880/nmbd
                                  udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          33102      880/nmbd
                                  udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          25482      880/nmbd
                                  udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          670382     880/nmbd
                                  udp        0      0 192.168.2.222:138       0.0.0.0:*                           0          670381     880/nmbd
                                  udp        0      0 172.18.255.255:138      0.0.0.0:*                           0          33109      880/nmbd
                                  udp        0      0 172.18.0.1:138          0.0.0.0:*                           0          33108      880/nmbd
                                  udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          33105      880/nmbd
                                  udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          33104      880/nmbd
                                  udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          25483      880/nmbd
                                  udp        0      0 0.0.0.0:51528           0.0.0.0:*                           0          26151      -
                                  udp        0      0 0.0.0.0:51576           0.0.0.0:*                           0          25682      846/rpc.mountd
                                  udp        0      0 0.0.0.0:55745           0.0.0.0:*                           114        25751      849/rpc.statd
                                  udp        0      0 127.0.0.1:601           0.0.0.0:*                           0          25746      849/rpc.statd
                                  udp        0      0 0.0.0.0:55932           0.0.0.0:*                           1001       2064213    -
                                  udp6       0      0 :::50327                :::*                                114        25757      849/rpc.statd
                                  udp6       0      0 :::42287                :::*                                0          25688      846/rpc.mountd
                                  udp6       0      0 :::54724                :::*                                0          26153      -
                                  udp6       0      0 :::50719                :::*                                0          25697      846/rpc.mountd
                                  udp6       0      0 :::1900                 :::*                                1001       2050230    410848/io.deconz.0
                                  udp6       0      0 :::1900                 :::*                                1001       2050229    410848/io.deconz.0
                                  udp6       0      0 :::1900                 :::*                                1001       2050228    410848/io.deconz.0
                                  udp6       0      0 :::111                  :::*                                0          19749      1/init
                                  udp6       0      0 :::49322                :::*                                0          25705      846/rpc.mountd
                                  udp6       0      0 fe80::461e:a1ff:fe3:546 :::*                                100        669407     832/systemd-network
                                  2024-06-09 21:52:40.114  - info: admin.0 (410669) terminating
                                  2024-06-09 21:52:40.411  - info: host.ubuntuserver stopInstance system.adapter.admin.0 killing pid 410669
                                  2024-06-09 21:52:40.581  - warn: admin.0 (410669) redis get simple-api.0.info.extension, error - Connection is closed.
                                  2024-06-09 21:52:40.584  - warn: admin.0 (410669) Cannot get view: Connection is closed.
                                  2024-06-09 21:52:40.883  - info: host.ubuntuserver instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-06-09 21:52:50.856  - info: host.ubuntuserver "system.adapter.admin.0" enabled
                                  2024-06-09 21:52:50.976  - info: host.ubuntuserver instance system.adapter.admin.0 started with pid 411557
                                  2024-06-09 21:52:55.472  - info: admin.0 (411557) starting. Version 6.17.14 in /opt/iobroker/node_modules/iobroker.admin, node: v20.14.0, js-controller: 5.0.19
                                  2024-06-09 21:52:55.537  - info: admin.0 (411557) requesting all objects
                                  2024-06-09 21:52:57.634  - info: admin.0 (411557) received all objects
                                  2024-06-09 21:52:58.151  - info: admin.0 (411557) socket.io server listening on port 8081
                                  2024-06-09 21:52:58.154  - info: admin.0 (411557) http server listening on port 8081
                                  2024-06-09 21:52:58.154  - info: admin.0 (411557) Use link "http://127.0.0.1:8081" to configure.
                                  2024-06-09 21:52:58.228  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.237  - info: admin.0 (411557) <== Disconnect system.user.admin from 192.168.2.9 admin
                                  2024-06-09 21:52:58.241  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.259  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.274  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.285  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.294  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.304  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.326  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.338  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:52:58.354  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                  2024-06-09 21:53:02.227  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                                          v.2024-05-22
                                           Chassis: desktop
                                   Hardware Vendor: HP
                                  Installation:           native
                                  Kernel:                 x86_64
                                  Userland:               64 bit
                                  Timezone:               Europe/Berlin (CEST, +0200)
                                  User-ID:                1000
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                  MEMORY:
                                  Mem:            3.8G        1.8G        189M         24M        1.8G        1.7G
                                  Total:          7.6G        2.4G        3.4G
                                  ioBroker Core:          js-controller           5.0.19
                                                          admin                   6.17.14
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                8594
                                  States:                 7873
                                  Size of iob-Database:
                                  22M     /opt/iobroker/iobroker-data/objects.jsonl
                                  9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                                  9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  6.5M    /opt/iobroker/iobroker-data/states.jsonl
                                  2.5M    /opt/iobroker/iobroker-data/states.json.migrated
                                  2.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  santa@ubuntuserver:/opt/iobroker$ iob del admin
                                  Delete adapter "admin"
                                  host.ubuntuserver Counted 1 instances of admin
                                  Cannot remove adapter "admin", because instance "backitup" depends on it!
                                  NPM version: 10.7.0
                                  up to date in 8s
                                    e-s @e-s last edited by
                                    @Thomas-Braun
                                    So, der Fehler im Admin NPM ist mit JS 6.0.1 und Admin 7.0.1 weg.
                                    Uninstall npm packet "iobroker.tr-064" for a clean re-installation
                                    removed 8 packages in 7s
                                    NPM version: 10.7.0
                                    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                    added 8 packages in 9s
                                    Aber wie du schon vermutet hattest, hatte das nichts mit meinem eigentlichen Fehler zu tun. Weiterhin werden die Objekte nicht befüllt. Alles andere funktioniert.
                                    Hast du noch eine Idee, oder jemand anderes?
                                      @Thomas-Braun @amg_666 @haselchen
                                      Habe jetzt dem Adapter und somit die Instanz gelöscht und neu installiert.
                                      Zusätzlich den User auf der FB auch neu angelegt, aber ohne Erfolg.
                                      Ich habe nun keine Idee mehr.
                                      Könnt ihr mir einen Gefallen tun und eventuell eine neue Instanz anlegen? Vielleicht wird beim Anlegen der States jetzt etwas falsch gemacht.
                                      Oder hat jemand noch eine Idee, wen ich sonst fragen könnte oder was ich testen könnte?
                                      • amg_666
                                        amg_666 @e-s last edited by amg_666
                                        Alte Instanz angehalten und neue Instanz anglegt:
                                        tr-064.3
                                        	2024-06-12 18:11:50.703	info	starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.20.3, js-controller: 6.0.2
                                        host.iobroker
                                        	2024-06-12 18:11:47.554	info	instance system.adapter.tr-064.3 started with pid 305350
                                        host.iobroker
                                        	2024-06-12 18:11:44.282	info	instance system.adapter.tr-064.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        admin.0
                                        	2024-06-12 18:11:44.113	info	<== Disconnect system.user.admin from ::ffff:192.168.1.3
                                        tr-064.3
                                        	2024-06-12 18:11:43.541	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        tr-064.3
                                        	2024-06-12 18:11:43.537	info	terminating
                                        tr-064.3
                                        	2024-06-12 18:11:43.534	info	Got terminate signal TERMINATE_YOURSELF
                                        host.iobroker
                                        	2024-06-12 18:11:43.533	info	stopInstance system.adapter.tr-064.3 send kill signal
                                        host.iobroker
                                        admin.0
                                        tr-064.3
                                        	2024-06-12 18:11:44.043	info	terminating
                                        tr-064.3
                                        tr-064.3
                                        Instanz ist "grün"
                                        und im DP tr-064.3.states.externalIP steht meine korrekte externe IP Adresse...
                                        Edit: Zur Sicherheit noch die Einstellungen des Adapters
                                          e-s @amg_666 last edited by
                                          @amg_666
                                          Danke, jetzt gehen mir langsam wirklich die Ideen aus.
                                          Alles andere funktioniert und der FB-checkpresence Adapter kann die IP auslesen.
                                          Will eigentlich ungern beide Adapter laufen lassen.
                                          In den Einstellungen habe ich noch mDNS und JSON aktiv, das sollte damit nichts zu tun haben.
                                          • amg_666
                                            amg_666 last edited by amg_666
                                            @e-s ich hab die neue Instanz wieder gelöscht und die alte gestartet, bei der ist auch mDNS und JSON aktiv, das sollte also kein Thema sein.
                                            Was ist denn jetzt das Problem: Dass der DP "External IP" nicht aktualisiert wird oder dass alle DP des tr-064 Adapters nicht aktualisiert werden? Bei letzterem hätte ich auf falschen user/falsches Passwort getippt.
                                            Welche Berechtigungen hat der User in der Fritzbox?
                                            Bei mir ist das im Menu System-Fritz!Box-Benutzer:
                                                Zugang aus dem Internet
                                                FRITZ!Box-Einstellungen
                                                Sprachnachrichten, Faxnachrichten, FRITZ!App Fon und Anrufliste
                                                Smart Home
                                            Mindestens die ersten beiden solltest du auch eingerichtet haben
                                            2397
