    4. Gelöst: TR-064 external IP wird nicht aktualisiert
      Thomas Braun Most Active @haselchen last edited by
      @haselchen
      Du meinst das Binding an die IP? Kann man machen.
      Auch wenn ich es nicht empfehlen würde.
        e-s @Thomas Braun last edited by
        Wieso da ein Desktop aktiv sein sollte, ist mir unklar. Egal, ist jetzt deaktiviert.
        den anderen Befehl habe ich schon mehrfach getestet:
        santa@ubuntuserver:/opt/iobroker$ iob upgrade iobroker.admin@6.17.14 --omit=dev
        Would you like to reinstall version 6.17.14 of admin now? [(y)es, (n)o]: y
        Update admin from @6.17.14 to @6.17.14
        host.ubuntuserver Adapter "system.adapter.admin.0" is stopped.
        NPM version: 10.7.0
        Installing iobroker.admin@6.17.14... (System call)
        up to date in 9s
        107 packages are looking for funding
          run `npm fund` for details
        upload [53] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js custom/static/js/node_modules_react_index_js.bdd08e35.chunk.js application/javascript
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        host.ubuntuserver Adapter "system.adapter.admin.0" is started
          Thomas Braun Most Active @e-s last edited by Thomas Braun
          @e-s
          Ich vermute die Meldung
          npm warn ERESOLVE overriding peer dependency
          npm warn While resolving: @iobroker/adapter-core@3.1.4
          npm warn Found: @iobroker/types@6.0.0
          npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
          npm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
          npm warn iobroker.admin@"6.17.14" from the root project
          npm warn
          npm warn Could not resolve dependency:
          npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
          npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
          npm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
          npm warn
          npm warn Conflicting peer dependency: @iobroker/types@5.0.19
          npm warn node_modules/@iobroker/types
          dürfte erstmal verschwunden sein.
            leider nein
            santa@ubuntuserver:/opt/iobroker$ iobroker upgrade tr-064@4.3.0 --debug
            Would you like to reinstall version 4.3.0 of tr-064 now? [(y)es, (n)o]: y
            Update tr-064 from @4.3.0 to @4.3.0
            NPM version: 10.7.0
            Installing iobroker.tr-064@4.3.0... (System call)
            npm warn
            npm warn
            up to date in 9s
            upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
            upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
            upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
              @e-s
              cd /opt/iobroker && npm ls -a | grep -C4 ERR
              Hat aber alles nix mit dem Adapter tr-064 zu tun.
                wenn einem aber schon ein Fehler auffällt, dann kann man ja hoffen, dass es den anderen Fehler mitbeseitigt.
                santa@ubuntuserver:/opt/iobroker$ cd /opt/iobroker && npm ls -a | grep -C4 ERR
                npm error code ELSPROBLEMS
                npm error invalid: @iobroker/types@6.0.0 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/types
                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-09T19_29_11_117Z-debug-0.log
                interessiert dich das log?
                  @e-s
                  Eher
                  npm ls @iobroker/types
                  In dem Log dürfte nicht viel drin stehen.
                    santa@ubuntuserver:/opt/iobroker$ npm ls @iobroker/types
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├─┬ iobroker.admin@6.17.14
                    │ ├─┬ @iobroker/adapter-core@3.1.4
                    │ │ └── @iobroker/types@6.0.0 deduped invalid: "^5.0.11" from node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                    │ ├─┬ @iobroker/socket-classes@1.5.0
                    │ │ └─┬ @iobroker/adapter-core@3.0.4
                    │ │   └── @iobroker/types@5.0.11 deduped
                    │ └── @iobroker/types@6.0.0 invalid: "^5.0.11" from node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                    ├─┬ iobroker.backitup@3.0.2
                    │ └─┬ @iobroker/adapter-core@3.1.6
                    ├─┬ iobroker.bosesoundtouch@0.11.1
                    │ └─┬ @iobroker/adapter-core@3.0.6
                    ├─┬ iobroker.deconz@1.4.1
                    │ └─┬ @iobroker/adapter-core@3.1.4
                    ├─┬ iobroker.device-reminder@3.1.2
                    ├─┬ iobroker.discord@2.3.0
                    ├─┬ iobroker.esphome@0.5.0-beta.8
                    ├─┬ iobroker.fb-checkpresence@1.2.4
                    ├─┬ iobroker.frontier_silicon@0.2.0
                    ├─┬ iobroker.hiob@0.1.4
                    ├─┬ iobroker.homeconnect@1.4.0
                    ├─┬ iobroker.influxdb@4.0.2
                    ├─┬ iobroker.javascript@8.5.0
                    ├─┬ iobroker.samsung_tizen@1.1.0
                    ├─┬ iobroker.samsung@0.6.0
                    ├─┬ iobroker.shelly@7.0.0
                    ├─┬ iobroker.simple-api@2.8.0
                    ├─┬ iobroker.socketio@6.7.0
                    ├─┬ iobroker.solarlog@2.3.0
                    ├─┬ iobroker.statistics@2.4.0
                    ├─┬ iobroker.synology@3.1.0
                    ├─┬ iobroker.tr-064@4.3.0
                    ├─┬ iobroker.weatherunderground@3.7.0
                    ├─┬ iobroker.web@6.2.6
                    ├─┬ iobroker.wled@0.7.3-beta.0
                    └─┬ iobroker.ws@2.6.1
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-06-09T19_33_56_303Z-debug-0.log
                      @e-s sagte in TR-064 external IP wird nicht aktualisiert:
                      Der Admin sieht bei mir anders aus:
                      │ ├─┬ @iobroker/adapter-core@3.1.6
                      │ │ └─┬ @iobroker/adapter-core@3.1.4
                      │ │   └── @iobroker/types@5.0.19 deduped
                        kann mich ein update auf node.js20 weiter bringen?
                          Da solltest du eh machen, nodejs@20 ist die derzeitige Empfehlung für den ioBroker.
                          iob nodejs-update 20
                          bringt dich hin.
                            kein Unterschied nach Update. Ausgaben bleiben alle identisch.
                            Hast du noch eine Idee?
                              @e-s
                              Bügel den admin noch mal rein.
                              Vielleicht auch zuvor mal deinstallieren:
                              iob del admin
                                Leider auch nicht, eventuell muss ich backitup doch auch kurz deinstallieren.
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                 Static hostname: ubuntuserver
                                       Icon name: computer-desktop
                                         Chassis: desktop
                                Operating System: Ubuntu 22.04.4 LTS
                                          Kernel: Linux 5.15.0-112-generic
                                    Architecture: x86-64
                                 Hardware Vendor: HP
                                  Hardware Model: ProLiant MicroServer
                                model name      : AMD Turion(tm) II Neo N40L Dual-Core Processor
                                Docker          : false
                                Virtualization  : none
                                Kernel          : x86_64
                                Userland        : 64 bit
                                Systemuptime and Load:
                                 21:55:22 up 2 days,  3:05,  2 users,  load average: 1.46, 1.82, 1.53
                                CPU threads: 2
                                *** Time and Time Zones ***
                                               Local time: Sun 2024-06-09 21:55:22 CEST
                                           Universal time: Sun 2024-06-09 19:55:22 UTC
                                                 RTC time: Sun 2024-06-09 19:55:22
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                santa
                                HOME=/home/santa
                                GROUPS=santa adm dialout cdrom sudo dip plugdev lxd docker iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev redis
                                *** Display-Server-Setup ***
                                Display-Server: false
                                Desktop:
                                Terminal:       tty
                                Boot Target:    multi-user.target
                                *** MEMORY ***
                                Mem:            3.8G        1.7G        585M         24M        1.5G        1.8G
                                Swap:           3.8G        557M        3.3G
                                Total:          7.6G        2.3G        3.8G
                                Active iob-Instances:   23
                                         3785 M total memory
                                         1735 M used memory
                                          883 M active memory
                                         1851 M inactive memory
                                          585 M free memory
                                          693 M buffer memory
                                          771 M swap cache
                                         3808 M total swap
                                          557 M used swap
                                         3251 M free swap
                                top - 21:55:22 up 2 days,  3:05,  2 users,  load average: 1.46, 1.82, 1.53
                                Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  9.1 us,  6.1 sy,  0.0 ni, 81.8 id,  0.0 wa,  0.0 hi,  3.0 si,  0.0 st
                                MiB Mem :   3785.9 total,    585.6 free,   1735.0 used,   1465.3 buff/cache
                                MiB Swap:   3809.0 total,   3251.4 free,    557.6 used.   1800.3 avail Mem
                                *** FAILED SERVICES ***
                                0 loaded units listed.
                                *** FILESYSTEM ***
                                Filesystem                        Type   Size  Used Avail Use% Mounted on
                                tmpfs                             tmpfs  379M  2.9M  376M   1% /run
                                /dev/mapper/ubuntu--vg-ubuntu--lv ext4    58G   35G   21G  63% /
                                tmpfs                             tmpfs  1.9G     0  1.9G   0% /dev/shm
                                tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                                /dev/sda2                         ext4   974M  253M  654M  28% /boot
                                /dev/md0                          ext4   917G  849G   22G  98% /media/HDD
                                /dev/sdd1                         ext4   1.4T  943G  364G  73% /media/HDD/Videos
                                tmpfs                             tmpfs  379M  4.0K  379M   1% /run/user/1000
                                [Fri Jun  7 18:49:52 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                [Fri Jun  7 18:49:54 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
                                [Fri Jun  7 18:49:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                [Fri Jun  7 18:49:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: usrquota,grpquota. Quota mode: writeback.
                                [Fri Jun  7 18:50:12 2024] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: usrquota,grpquota. Quota mode: writeback.
                                Show mounted filesystems:
                                TARGET                                        SOURCE                            FSTYPE      OPTIONS
                                /                                             /dev/mapper/ubuntu--vg-ubuntu--lv ext4        rw,relatime
                                |-/sys                                        sysfs                             sysfs       rw,nosuid,nodev,noexec,relatime
                                | |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
                                | |-/sys/fs/cgroup                            cgroup2                           cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                | |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
                                | |-/sys/fs/bpf                               bpf                               bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                | |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
                                | |-/sys/kernel/tracing                       tracefs                           tracefs     rw,nosuid,nodev,noexec,relatime
                                | |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
                                | `-/sys/kernel/config                        configfs                          configfs    rw,nosuid,nodev,noexec,relatime
                                |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
                                | |-/proc/sys/fs/binfmt_misc                  systemd-1                         autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18784
                                | | `-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
                                | `-/proc/fs/nfsd                             nfsd                              nfsd        rw,relatime
                                |-/dev                                        udev                              devtmpfs    rw,nosuid,relatime,size=1846848k,nr_inodes=461712,mode=755,inode64
                                | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,inode64
                                | |-/dev/hugepages                            hugetlbfs                         hugetlbfs   rw,relatime,pagesize=2M
                                | `-/dev/mqueue                               mqueue                            mqueue      rw,nosuid,nodev,noexec,relatime
                                |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=387676k,mode=755,inode64
                                | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                                | |-/run/credentials/systemd-sysusers.service none                              ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/rpc_pipefs                           sunrpc                            rpc_pipefs  rw,relatime
                                | |-/run/snapd/ns                             tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=387676k,mode=755,inode64
                                | | |-/run/snapd/ns/lxd.mnt                   nsfs[mnt:[4026532309]]            nsfs        rw
                                | | `-/run/snapd/ns/canonical-livepatch.mnt   nsfs[mnt:[4026532310]]            nsfs        rw
                                | `-/run/user/1000                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=387672k,nr_inodes=96918,mode=700,uid=1000,gid=1000,inode64
                                |-/snap/canonical-livepatch/264               /dev/loop0                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/canonical-livepatch/278               /dev/loop1                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/certbot/3700                          /dev/loop2                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/certbot/3834                          /dev/loop3                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core/16574                            /dev/loop4                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core/16928                            /dev/loop5                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core18/2812                           /dev/loop6                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core18/2823                           /dev/loop7                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core20/2318                           /dev/loop9                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core20/2264                           /dev/loop8                        squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core22/1122                           /dev/loop10                       squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/core22/1380                           /dev/loop11                       squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/lxd/23991                             /dev/loop12                       squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/lxd/24061                             /dev/loop13                       squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/snapd/21465                           /dev/loop14                       squashfs    ro,nodev,relatime,errors=continue
                                |-/snap/snapd/21759                           /dev/loop15                       squashfs    ro,nodev,relatime,errors=continue
                                |-/boot                                       /dev/sda2                         ext4        rw,relatime
                                `-/media/HDD                                  /dev/md0                          ext4        rw,relatime,quota,usrquota,grpquota
                                  `-/media/HDD/Videos                         /dev/sdd1                         ext4        rw,nosuid,nodev,noexec,relatime,quota,usrquota,grpquota
                                /var:
                                10G     /var/
                                4.1G    /var/log
                                4.0G    /var/log/journal/a4cf029863be491d9b4015eb9e07f827
                                3.7G    /var/lib
                                Archived and active journals take up 3.9G in the file system.
                                /opt/iobroker/backups:
                                27M     /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                774M    /opt/iobroker/iobroker-data/
                                618M    /opt/iobroker/iobroker-data/files
                                281M    /opt/iobroker/iobroker-data/files/javascript.admin
                                247M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                245M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.7253116f.js.map
                                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                                24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2119138-if00
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v20.14.0
                                /usr/bin/node           v20.14.0
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                /usr/bin/corepack       0.28.1
                                nodejs:
                                  Installed: 20.14.0-1nodesource1
                                  Candidate: 20.14.0-1nodesource1
                                  Version table:
                                 *** 20.14.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                     20.13.1-1nodesource1 1001
                                     20.13.0-1nodesource1 1001
                                     20.12.2-1nodesource1 1001
                                     20.12.1-1nodesource1 1001
                                     20.12.0-1nodesource1 1001
                                     20.11.1-1nodesource1 1001
                                     20.11.0-1nodesource1 1001
                                     20.10.0-1nodesource1 1001
                                     20.9.0-1nodesource1 1001
                                     20.8.1-1nodesource1 1001
                                     20.8.0-1nodesource1 1001
                                     20.7.0-1nodesource1 1001
                                     20.6.1-1nodesource1 1001
                                     20.6.0-1nodesource1 1001
                                     20.5.1-1nodesource1 1001
                                     20.5.0-1nodesource1 1001
                                     20.4.0-1nodesource1 1001
                                     20.3.1-1nodesource1 1001
                                     20.3.0-1nodesource1 1001
                                     20.2.0-1nodesource1 1001
                                     20.1.0-1nodesource1 1001
                                     20.0.0-1nodesource1 1001
                                     12.22.9~dfsg-1ubuntu3.5 500
                                        500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                        500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                                     12.22.9~dfsg-1ubuntu3 500
                                        500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                No problems detected
                                Errors in npm tree:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                js-controller:  5.0.19
                                admin:          6.17.14
                                javascript:     8.5.0
                                nodejs modules from github:     2
                                | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : ubuntuserver                             -  enabled, port: 8081, bind: 192.168.2.222, run as: admin
                                  system.adapter.alias-manager.0          : alias-manager         : ubuntuserver                             -  enabled
                                + system.adapter.backitup.0               : backitup              : ubuntuserver                             -  enabled
                                + system.adapter.bosesoundtouch.0         : bosesoundtouch        : ubuntuserver                             -  enabled
                                + system.adapter.deconz.0                 : deconz                : ubuntuserver                             -  enabled, port: 8080
                                  system.adapter.device-reminder.0        : device-reminder       : ubuntuserver                             - disabled
                                  system.adapter.devices.0                : devices               : ubuntuserver                             -  enabled
                                + system.adapter.discord.0                : discord               : ubuntuserver                             -  enabled
                                + system.adapter.echarts.0                : echarts               : ubuntuserver                             -  enabled
                                + system.adapter.esphome.0                : esphome               : ubuntuserver                             -  enabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ubuntuserver                             -  enabled
                                + system.adapter.frontier_silicon.0       : frontier_silicon      : ubuntuserver                             -  enabled
                                + system.adapter.hiob.0                   : hiob                  : ubuntuserver                             -  enabled, port: 8096
                                + system.adapter.homeconnect.0            : homeconnect           : ubuntuserver                             -  enabled
                                + system.adapter.influxdb.0               : influxdb              : ubuntuserver                             -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : ubuntuserver                             -  enabled
                                + system.adapter.linkeddevices.0          : linkeddevices         : ubuntuserver                             -  enabled
                                  system.adapter.samsung.0                : samsung               : ubuntuserver                             - disabled
                                + system.adapter.samsung_tizen.0          : samsung_tizen         : ubuntuserver                             -  enabled, port: 8002
                                + system.adapter.shelly.0                 : shelly                : ubuntuserver                             -  enabled, port: 1885, bind: 192.168.2.222
                                + system.adapter.simple-api.0             : simple-api            : ubuntuserver                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.socketio.0               : socketio              : ubuntuserver                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                  system.adapter.solarlog.0               : solarlog              : ubuntuserver                             - disabled, port: 80
                                  system.adapter.statistics.0             : statistics            : ubuntuserver                             - disabled
                                + system.adapter.synology.0               : synology              : ubuntuserver                             -  enabled, port: 5001
                                + system.adapter.tr-064.0                 : tr-064                : ubuntuserver                             -  enabled
                                  system.adapter.weatherunderground.0     : weatherunderground    : ubuntuserver                             - disabled
                                  system.adapter.web.0                    : web                   : ubuntuserver                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.wiffi-wz.0               : wiffi-wz              : ubuntuserver                             -  enabled
                                + system.adapter.wled.0                   : wled                  : ubuntuserver                             -  enabled
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): beta
                                Installed ioBroker-Instances
                                Used repository: beta
                                Adapter    "admin"        : 6.17.14  , installed 6.17.14
                                Adapter    "backitup"     : 3.0.2    , installed 3.0.2
                                Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
                                Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                Adapter    "discord"      : 2.3.0    , installed 2.3.0
                                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
                                Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                Adapter    "frontier_silicon": 0.2.0 , installed 0.2.0
                                Adapter    "hiob"         : 0.1.4    , installed 0.1.4
                                Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
                                Adapter    "javascript"   : 8.5.0    , installed 8.5.0
                                Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                Adapter    "web"          : 6.2.6    , installed 6.2.6
                                Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                                Adapter    "wled"         : 0.7.3-beta.0, installed 0.7.3-beta.0
                                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                Objects and States
                                Objects:        8594
                                States:         7873
                                Hit:1 http://phoscon.de/apt/deconz jammy-beta InRelease
                                Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                                Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                                Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                                Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                                Hit:6 https://download.docker.com/linux/ubuntu jammy InRelease
                                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Hit:8 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security InRelease
                                Hit:9 https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates InRelease
                                Hit:10 https://esm.ubuntu.com/infra/ubuntu jammy-infra-security InRelease
                                Hit:11 https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 0.0.0.0:37221           0.0.0.0:*               LISTEN      0          25703      846/rpc.mountd
                                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          26515      1075/smbd
                                tcp        0      0 0.0.0.0:20877           0.0.0.0:*               LISTEN      1000       26870      857/deCONZ
                                tcp        0      0 0.0.0.0:33247           0.0.0.0:*               LISTEN      114        25754      849/rpc.statd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25336      910/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          26091      -
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19746      1/init
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2047882    410638/iobroker.js-
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2049555    410638/iobroker.js-
                                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          26516      1075/smbd
                                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      116        26347      884/redis-server 12
                                tcp        0      0 0.0.0.0:56265           0.0.0.0:*               LISTEN      0          25685      846/rpc.mountd
                                tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      115        27345      1104/mysqld
                                tcp        0      0 192.168.2.222:8081      0.0.0.0:*               LISTEN      1001       2052571    411557/io.admin.0
                                tcp        0      0 192.168.2.222:8181      0.0.0.0:*               LISTEN      1001       2050813    411162/io.wiffi-wz.
                                tcp        0      0 0.0.0.0:19828           0.0.0.0:*               LISTEN      0          25315      892/oscam
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      997        26675      921/influxd
                                tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          26909      1227/perl
                                tcp        0      0 0.0.0.0:59137           0.0.0.0:*               LISTEN      0          25695      846/rpc.mountd
                                tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       1816103    364963/python3
                                tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       26438      857/deCONZ
                                tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      115        28922      1104/mysqld
                                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        25053      834/systemd-resolve
                                tcp        0      0 0.0.0.0:36399           0.0.0.0:*               LISTEN      0          26152      -
                                tcp6       0      0 :::57625                :::*                    LISTEN      0          25699      846/rpc.mountd
                                tcp6       0      0 :::445                  :::*                    LISTEN      0          26513      1075/smbd
                                tcp6       0      0 :::443                  :::*                    LISTEN      0          25561      1081/apache2
                                tcp6       0      0 :::43069                :::*                    LISTEN      0          25707      846/rpc.mountd
                                tcp6       0      0 :::21                   :::*                    LISTEN      0          25287      911/vsftpd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          25338      910/sshd: /usr/sbin
                                tcp6       0      0 :::2049                 :::*                    LISTEN      0          26127      -
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          19748      1/init
                                tcp6       0      0 :::80                   :::*                    LISTEN      0          25557      1081/apache2
                                tcp6       0      0 :::139                  :::*                    LISTEN      0          26514      1075/smbd
                                tcp6       0      0 ::1:6379                :::*                    LISTEN      116        26348      884/redis-server 12
                                tcp6       0      0 :::42125                :::*                    LISTEN      0          26154      -
                                tcp6       0      0 :::8096                 :::*                    LISTEN      1001       2051218    410961/io.hiob.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2051523    411138/io.socketio.
                                tcp6       0      0 :::8086                 :::*                    LISTEN      997        29320      921/influxd
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2051511    411117/io.simple-ap
                                tcp6       0      0 :::52769                :::*                    LISTEN      114        25760      849/rpc.statd
                                tcp6       0      0 :::40569                :::*                    LISTEN      0          25691      846/rpc.mountd
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2051538    411200/io.wled.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2050743    411057/io.esphome.0
                                udp        0      0 192.168.2.222:5353      0.0.0.0:*                           1001       2051173    410917/io.tr-064.0
                                udp        0      0 172.18.0.1:5353         0.0.0.0:*                           1000       1816113    364963/python3
                                udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       1816112    364963/python3
                                udp        0      0 192.168.2.222:5353      0.0.0.0:*                           1000       1816111    364963/python3
                                udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       1816110    364963/python3
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1816104    364963/python3
                                udp        0      0 0.0.0.0:42362           0.0.0.0:*                           0          25693      846/rpc.mountd
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       2050323    410894/io.shelly.0
                                udp        0      0 0.0.0.0:56887           0.0.0.0:*                           0          25701      846/rpc.mountd
                                udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          26910      1227/perl
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2050227    410848/io.deconz.0
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       27695      857/deCONZ
                                udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        25052      834/systemd-resolve
                                udp        0      0 192.168.2.222:68        0.0.0.0:*                           100        669432     832/systemd-network
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19747      1/init
                                udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          670380     880/nmbd
                                udp        0      0 192.168.2.222:137       0.0.0.0:*                           0          670379     880/nmbd
                                udp        0      0 172.18.255.255:137      0.0.0.0:*                           0          33107      880/nmbd
                                udp        0      0 172.18.0.1:137          0.0.0.0:*                           0          33106      880/nmbd
                                udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          33103      880/nmbd
                                udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          33102      880/nmbd
                                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          25482      880/nmbd
                                udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          670382     880/nmbd
                                udp        0      0 192.168.2.222:138       0.0.0.0:*                           0          670381     880/nmbd
                                udp        0      0 172.18.255.255:138      0.0.0.0:*                           0          33109      880/nmbd
                                udp        0      0 172.18.0.1:138          0.0.0.0:*                           0          33108      880/nmbd
                                udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          33105      880/nmbd
                                udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          33104      880/nmbd
                                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          25483      880/nmbd
                                udp        0      0 0.0.0.0:51528           0.0.0.0:*                           0          26151      -
                                udp        0      0 0.0.0.0:51576           0.0.0.0:*                           0          25682      846/rpc.mountd
                                udp        0      0 0.0.0.0:55745           0.0.0.0:*                           114        25751      849/rpc.statd
                                udp        0      0 127.0.0.1:601           0.0.0.0:*                           0          25746      849/rpc.statd
                                udp        0      0 0.0.0.0:55932           0.0.0.0:*                           1001       2064213    -
                                udp6       0      0 :::50327                :::*                                114        25757      849/rpc.statd
                                udp6       0      0 :::42287                :::*                                0          25688      846/rpc.mountd
                                udp6       0      0 :::54724                :::*                                0          26153      -
                                udp6       0      0 :::50719                :::*                                0          25697      846/rpc.mountd
                                udp6       0      0 :::1900                 :::*                                1001       2050230    410848/io.deconz.0
                                udp6       0      0 :::1900                 :::*                                1001       2050229    410848/io.deconz.0
                                udp6       0      0 :::1900                 :::*                                1001       2050228    410848/io.deconz.0
                                udp6       0      0 :::111                  :::*                                0          19749      1/init
                                udp6       0      0 :::49322                :::*                                0          25705      846/rpc.mountd
                                udp6       0      0 fe80::461e:a1ff:fe3:546 :::*                                100        669407     832/systemd-network
                                2024-06-09 21:52:40.114  - info: admin.0 (410669) terminating
                                2024-06-09 21:52:40.411  - info: host.ubuntuserver stopInstance system.adapter.admin.0 killing pid 410669
                                2024-06-09 21:52:40.581  - warn: admin.0 (410669) redis get simple-api.0.info.extension, error - Connection is closed.
                                2024-06-09 21:52:40.584  - warn: admin.0 (410669) Cannot get view: Connection is closed.
                                2024-06-09 21:52:40.883  - info: host.ubuntuserver instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-06-09 21:52:50.856  - info: host.ubuntuserver "system.adapter.admin.0" enabled
                                2024-06-09 21:52:50.976  - info: host.ubuntuserver instance system.adapter.admin.0 started with pid 411557
                                2024-06-09 21:52:55.472  - info: admin.0 (411557) starting. Version 6.17.14 in /opt/iobroker/node_modules/iobroker.admin, node: v20.14.0, js-controller: 5.0.19
                                2024-06-09 21:52:55.537  - info: admin.0 (411557) requesting all objects
                                2024-06-09 21:52:57.634  - info: admin.0 (411557) received all objects
                                2024-06-09 21:52:58.151  - info: admin.0 (411557) socket.io server listening on port 8081
                                2024-06-09 21:52:58.154  - info: admin.0 (411557) http server listening on port 8081
                                2024-06-09 21:52:58.154  - info: admin.0 (411557) Use link "http://127.0.0.1:8081" to configure.
                                2024-06-09 21:52:58.228  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.237  - info: admin.0 (411557) <== Disconnect system.user.admin from 192.168.2.9 admin
                                2024-06-09 21:52:58.241  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.259  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.274  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.285  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.294  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.304  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.326  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.338  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:52:58.354  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                2024-06-09 21:53:02.227  - info: admin.0 (411557) ==> Connected system.user.admin from 192.168.2.9
                                                        v.2024-05-22
                                         Chassis: desktop
                                 Hardware Vendor: HP
                                Installation:           native
                                Kernel:                 x86_64
                                Userland:               64 bit
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                MEMORY:
                                Mem:            3.8G        1.8G        189M         24M        1.8G        1.7G
                                Total:          7.6G        2.4G        3.4G
                                ioBroker Core:          js-controller           5.0.19
                                                        admin                   6.17.14
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                8594
                                States:                 7873
                                Size of iob-Database:
                                22M     /opt/iobroker/iobroker-data/objects.jsonl
                                9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                                9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                6.5M    /opt/iobroker/iobroker-data/states.jsonl
                                2.5M    /opt/iobroker/iobroker-data/states.json.migrated
                                2.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                santa@ubuntuserver:/opt/iobroker$ iob del admin
                                Delete adapter "admin"
                                host.ubuntuserver Counted 1 instances of admin
                                Cannot remove adapter "admin", because instance "backitup" depends on it!
                                NPM version: 10.7.0
                                up to date in 8s
                                  e-s @e-s last edited by
                                  @Thomas-Braun
                                  So, der Fehler im Admin NPM ist mit JS 6.0.1 und Admin 7.0.1 weg.
                                  Uninstall npm packet "iobroker.tr-064" for a clean re-installation
                                  removed 8 packages in 7s
                                  NPM version: 10.7.0
                                  npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                  added 8 packages in 9s
                                  Aber wie du schon vermutet hattest, hatte das nichts mit meinem eigentlichen Fehler zu tun. Weiterhin werden die Objekte nicht befüllt. Alles andere funktioniert.
                                  Hast du noch eine Idee, oder jemand anderes?
                                    @Thomas-Braun @amg_666 @haselchen
                                    Habe jetzt dem Adapter und somit die Instanz gelöscht und neu installiert.
                                    Zusätzlich den User auf der FB auch neu angelegt, aber ohne Erfolg.
                                    Ich habe nun keine Idee mehr.
                                    Könnt ihr mir einen Gefallen tun und eventuell eine neue Instanz anlegen? Vielleicht wird beim Anlegen der States jetzt etwas falsch gemacht.
                                    Oder hat jemand noch eine Idee, wen ich sonst fragen könnte oder was ich testen könnte?
                                    • amg_666
                                      amg_666 @e-s last edited by amg_666
                                      Alte Instanz angehalten und neue Instanz anglegt:
                                      tr-064.3
                                      	2024-06-12 18:11:50.703	info	starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.20.3, js-controller: 6.0.2
                                      host.iobroker
                                      	2024-06-12 18:11:47.554	info	instance system.adapter.tr-064.3 started with pid 305350
                                      host.iobroker
                                      	2024-06-12 18:11:44.282	info	instance system.adapter.tr-064.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      admin.0
                                      	2024-06-12 18:11:44.113	info	<== Disconnect system.user.admin from ::ffff:192.168.1.3
                                      tr-064.3
                                      	2024-06-12 18:11:43.541	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      tr-064.3
                                      	2024-06-12 18:11:43.537	info	terminating
                                      tr-064.3
                                      	2024-06-12 18:11:43.534	info	Got terminate signal TERMINATE_YOURSELF
                                      host.iobroker
                                      	2024-06-12 18:11:43.533	info	stopInstance system.adapter.tr-064.3 send kill signal
                                      host.iobroker
                                      admin.0
                                      tr-064.3
                                      	2024-06-12 18:11:44.043	info	terminating
                                      tr-064.3
                                      tr-064.3
                                      Instanz ist "grün"
                                      und im DP tr-064.3.states.externalIP steht meine korrekte externe IP Adresse...
                                      Edit: Zur Sicherheit noch die Einstellungen des Adapters
                                        e-s @amg_666 last edited by
                                        @amg_666
                                        Danke, jetzt gehen mir langsam wirklich die Ideen aus.
                                        Alles andere funktioniert und der FB-checkpresence Adapter kann die IP auslesen.
                                        Will eigentlich ungern beide Adapter laufen lassen.
                                        In den Einstellungen habe ich noch mDNS und JSON aktiv, das sollte damit nichts zu tun haben.
                                        • amg_666
                                          amg_666 last edited by amg_666
                                          @e-s ich hab die neue Instanz wieder gelöscht und die alte gestartet, bei der ist auch mDNS und JSON aktiv, das sollte also kein Thema sein.
                                          Was ist denn jetzt das Problem: Dass der DP "External IP" nicht aktualisiert wird oder dass alle DP des tr-064 Adapters nicht aktualisiert werden? Bei letzterem hätte ich auf falschen user/falsches Passwort getippt.
                                          Welche Berechtigungen hat der User in der Fritzbox?
                                          Bei mir ist das im Menu System-Fritz!Box-Benutzer:
                                              Zugang aus dem Internet
                                              FRITZ!Box-Einstellungen
                                              Sprachnachrichten, Faxnachrichten, FRITZ!App Fon und Anrufliste
                                              Smart Home
                                          Mindestens die ersten beiden solltest du auch eingerichtet haben
                                            e-s @amg_666 last edited by e-s
                                            @amg_666
                                            Devices und anruflisten funktionieren einwandfrei und auch immer sofort.
                                            Nur eben die states zu ip bleiben komplett leer.
                                            Deswegen bin ich ja so verwundert.
                                            Berechtigungen sind auch so vorhanden.
                                            Edit:
                                            Smart Home
                                            2403
