    • MichaelF
      MichaelF last edited by MichaelF
      Hi, grade nochmal versucht aller dings leider der gleiche Fehler :
      cript.js.common.NSPANEL_1_3_1_0: TypeScript compilation failed:let Icons = new IconsSelector(); ^ERROR: Cannot redeclare block-scoped variable 'Icons'.let timeoutSlider: any; ^ERROR: Cannot redeclare block-scoped variable 'timeoutSlider'.let vwIconColor = []; ^ERROR: Cannot redeclare block-scoped variable 'vwIconColor'.let weatherForecast: boolean; ^ERROR: Cannot redeclare block-scoped variable 'weatherForecast'.const Icons = new IconsSelector(); ^ERROR: Cannot redeclare block-scoped variable 'Icons'.let timeoutSlider: any; ^ERROR: Cannot redeclare block-scoped variable 'timeoutSlider'.let vwIconColor: number[] = []; ^ERROR: Cannot redeclare block-scoped variable 'vwIconColor'.let weatherForecast: boolean; ^ERROR: Cannot redeclare block-scoped variable 'weatherForecast'.const NSPanelStatTopic = NSPanelSendTopic.replace('.cmnd.', '.stat.').replace(/\.CustomSend$/g, '.'); ^ERROR: Cannot find name 'NSPanelSendTopic'. Did you mean 'NSPanelStatTopic'?
      der alte Script funktioniert weiterhin:
      javascript.0
      2024-06-08 21:17:36.499	info	script.js.common.NSPANEL_1_3_1_0: Debugmodus deaktiviert
      javascript.0
      2024-06-08 21:17:36.035	info	script.js.common.NSPANEL_1_3_1_0: Installed TFT Firmware: 53 / v4.3.1
      javascript.0
      2024-06-08 21:17:36.034	info	script.js.common.NSPANEL_1_3_1_0: Desired TFT Firmware: 53 / v4.3.1
      javascript.0
      2024-06-08 21:17:35.408	info	script.js.common.NSPANEL_1_3_1_0: registered 27 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0
      2024-06-08 21:17:35.329	info	script.js.common.NSPANEL_1_3_1_0: weather alias for accuweather.0. already exists
      javascript.0
      2024-06-08 21:17:35.315	info	script.js.common.NSPANEL_1_3_1_0: setObjects enabled - create Alias Channels possible
      javascript.0
      2024-06-08 21:17:35.260	warn	script.js.common.NSPANEL_1_3_1_0: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
      javascript.0
      2024-06-08 21:17:35.149	info	script.js.common.NSPANEL_1_3_1_0: source code did not change, using cached compilation result...
      javascript.0
      2024-06-08 21:17:34.055	info	Compiling TypeScript source script.js.common.NSPANEL_1_3_1_0
      javascript.0
      2024-06-08 21:17:32.252	info	Stopping script script.js.common.NSPANEL_1_3_1_0
        TT-Tom @MichaelF last edited by TT-Tom
        @michaelf welche Script Version nutzt du aktuell?? request nutzen wir nicht mehr. Lese dir bitte diese Seite durch
        • MichaelF
          Ja deshalb wollte ich ja aktualisieren.
          Ich habe im Moment :
          TypeScript v4.2.1.5 zur Steuerung des SONOFF NSPanel mit dem ioBroker by @Armilar / @TT-Tom / @Sternmiere / @Britzelpuf / @ravenS0ne
          - abgestimmt auf TFT 52 / v4.2.1 / BerryDriver 8 / Tasmota 13.1.0
          Der TFT ist schon aktuell also v4.3.3
          • icebear
            icebear @icebear last edited by
            @icebear said in SONOFF NSPanel mit Lovelace UI:
            @tt-tom
            Ja, kann ich machen, da ich das aber grad erst wieder von Hand auf die richtigen Werte eingestellt hab, muß ich mal abwarten bis das wieder geändert wurde.
            Sorry das ich mich jetzt erst melde.
            Das Problem hat sich gelöst, war wohl die Einstellung 'Updatemeldung eingeschaltet', nachdem ich das Update von v14.0 auf v14.1 gemacht habe, ist der Fehler nicht mehr aufgetreten.
            Ich hab dann auch gesehen das in den DP meine Einstellung immer mit dem Text der Updatemeldung überschrieben war.
            Naja, jetzt läufts ja und ich weiß woran es lag, Danke trotzdem für die Hinweise
            • Rene55
              Rene55 @TT-Tom last edited by Rene55
              @tt-tom Ich habe eben auf die neueste Scriptversion 4.4.0 upgedatet. Daraufhin bekam ich den Logeintrag, dass die TFT Firmware 54 gewünscht werde. Also auch das upgedatet - jetzt steht im Display System Data ERROR. Was nun?
              • Armilar
                Armilar Most Active Forum Testing @Rene55 last edited by Armilar
                @rene55
                Kann wohl mal hängen bleiben. Dann nochmals in der Tasmota-Konsole
                FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.4.0.tft
                ausführen.
                  @michaelf
                  wenn die jetzt auf die Aktuelle Script Version gehst, es gab ein Break-Change bei Version 4.3.3.10 und bei 4.3.3.30 hat sich die Config geändert. Der Berrytreiber ist auch schon bei Version 9.
                  Darum habe ich dir mal die Update - Seite verlinkt. Arbeite sie Punkt für Punkt ab, dann sollte der Umzug funktionieren. Wenn etwas unklar ist hier posten mit den Codezeilen, was nicht klar ist.
                  MichaelF 1 Reply Last reply Reply Quote 1
                  • Rene55
                    Rene55 @Armilar last edited by
                    @armilar Danke, das hat geholfen. Der vorige Updateversuch ist wohl bei 85% hängen geblieben. Jetzt läufts wieder 😊
                    • MichaelF
                      MichaelF @TT-Tom last edited by
                      @tt-tom
                      Danke 🙂 hab es hinbekommen.
                        Joker @Armilar last edited by
                        Hallo, ich probiere gerade die CardPower in mein NSPanel zu bekommen, da bin ich auf dieses Beispeil Blockly gestossen, was mir schonmal vom Verständnis sehr viel weiter gebraucht hat. Bei mir wird nun auch ein Jason erzeugt, leider kapiere ich irgendwie nicht, wie ich den Pfad in das Script von dem NSPanel schreiben soll. Ich bekomme bei dem Beispiel Jason aus dem Blockly schon den Fehler. Das Script ist das 4.4.0.1
                        Wäre für eine Hilfe dankbar
                        @armilar said in SONOFF NSPanel mit Lovelace UI:
                        @carlos
                        Habe jetzt mal ein neues Blocky-Beispiel für die cardPower zum spielen und ausprobieren gebaut.
                        "cardPower simple example"
                        Das Blockly:
                        https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/Blockly/cardPower_simple_example.xml
                        Beim ersten Aufruf sollte die card so aussehen:
                        Die restlichen Variablen können analog der id: 1 verändert werden, oder durch Datenpunkte mit echter Logik ersetzt werden.
                        Ich denke das wird dem allgemeinen Verständnis helfen...
                        PS.:
                        • direction wurde im Script noch nie abgefragt und ist deshalb im Beispiel auch nicht mehr enthalten
                        • speed_id_1-6 kann auch negative Werte enthalten und kehrt somit die Laufrichtung des Punktes um (Empfehlung -5 bis +5)
                        • Der mittlere größere Block hat kein Speed
                        • Ich habe einen Timer eingebaut, der jede Minute das JSONzusammenbaut und in den Datenpunkt schreibt. Bei Bedarf die Zeit ändern oder durch einen Trigger ersetzten
                        • Die Farben gehen von 0=weiß, 1=grün bis 10=rot
                          @joker
                          Wie sieht denn dein json aus.
                          Da Du zwei Seiten erstellt hast. Läuft denn die Demo Seite?
                          • Armilar
                            Armilar Most Active Forum Testing @Joker last edited by
                            @joker
                            in dem Blockly verweist du auf einen Datenpunkt in den das JSON geschrieben wird
                            Folglich ist das der Datenpunkt, der existieren und von dir manuell in 0_userdata angelegt werden muss.
                            In deiner Script-Variable zeigst du aber auf einen völlig anderen Datenpunkt:
                            Abgesehen davon sollte es ein Alias vom Typ Info sein, der auf den o.a. Datenpunkt (NSPanel_Datenpunkt im Blockly) zeigt.
                            Im Blockly selbst sollten noch die Values, z.B. zu deinem Stromverbrauch zugeordnet werden, damit auch Werte in die cardPower fließen.
                            Rene55 J 2 Replies Last reply Reply Quote 1
                            • MichaelF
                              Hi, muss doch nochmal schreiben.
                              Habe grade festgesellt das die Card Dimmmodus bei dem zweiten Display leer ist.
                              Ich glaube das hatte ich schon mal aber ich weis beim besten willen nicht mehr woran es lag.
                              Kann mir vielleicht nochmal jemand ein Tipp geben.
                              Ich glaube ich habe es gefunden, hier fehlt der Ordner:
                              kann ich diesen irgendwie neu anlegen lassen ?
                                @michaelf
                                bitte Prüfe ob diese Ordner unter 0_userdata vorhanden ist
                                        NSPanel_Path + 'NSPanel_Dimmode_brightnessDay'
                                 	NSPanel_Path + 'NSPanel_Dimmode_hourDay'
                                 	NSPanel_Path + 'NSPanel_Dimmode_brightnessNight'
                                 	NSPanel_Path + 'NSPanel_Dimmode_hourNight'
                                ggf löschen und Script neu starten
                                MichaelF 1 Reply Last reply Reply Quote 0
                                • MichaelF
                                  @tt-tom
                                  Hat geklappt, riesen Dank.
                                  Grüsse
                                  • Rene55
                                    @armilar Ich hatte ja vorige Tage geschrieben, dass der Update-Vorgang TFT 54 hängen geblieben ist. Nach deinem Tip konnte das Update komplett geladen werden und das Panel lief wieder. Gestern und heute kam wieder das Wartungspanel zum Update auf TFT 54 und fing dann wieder bei 85% an. Ich gehe davon aus, dass das so nicht richtig ist.
                                      TT-Tom @Rene55 last edited by
                                      @rene55
                                      Kannst du bitte mal im Script schauen was bei dir hier steht
                                      const desired_display_firmware_version = 53;
                                      • Rene55
                                        @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                                        Scheint richtig zu sein: const desired_display_firmware_version = 54;
                                        T Armilar 2 Replies Last reply Reply Quote 0
                                          @rene55
                                          schau mal bitte unter 0_userdata nach was hier steht
                                          • Armilar
                                            @rene55
                                            Es gibt keine 54...
                                            Die aktuelle TFT-Version ist die 4.4.0 und hat die 53 behalten.
                                            Es gab für eine sehr kurze Zeit eine Skript-Version mit der 54
                                            Wurde aber kurzerhand wieder korrigiert.
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6239941
