    • Armilar
      Armilar Most Active Forum Testing @adsfa last edited by
      @adsfa
      Aktuell würde ich Ende 2024 sagen
        australien @TT-Tom last edited by
        @tt-tom
        jetzt hab ich es nocheinmal probiert.
        das sind meine Fehler bei 8.3.1
        host.iobroker
        	2024-06-11 14:01:00.205	error	Caught by controller[0]: ReferenceError: request is not defined
        javascript.0
        	2024-06-11 14:01:00.024	error	at processImmediate (node:internal/timers:478:21)
        javascript.0
        	2024-06-11 14:01:00.024	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/scheduler.js:96:109)
        javascript.0
        	2024-06-11 14:01:00.024	error	at Object.cb (script.js.common.PV:7:5)
        javascript.0
        	2024-06-11 14:01:00.023	error	script.js.common.PV: ReferenceError: request is not defined
        javascript.0
        	2024-06-11 14:00:14.875	error	script.js.NSPanel.Panel1_110424_4_3_3_43: AxiosError: socket hang up at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:610:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:38:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketOnEnd (node:_http_client:525:9) at Socket.emit (node:events:529:35) at Socket.emit (node:domain:489:12) at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) { code: 'ECONNRESET', config: { transitional: { silentJSONParsing: true, forcedJSONParsing: true, clarifyTimeoutError: false }, adapter: [ 'xhr', 'http' ], transformRequest: [ [Function: transformRequest] ], transformResponse: [ [Function: transformResponse] ], timeout: 0, xsrfCookieName: 'XSRF-TOKEN', xsrfHeaderName: 'X-XSRF-TOKEN', maxContentLength: -1, maxBodyLength: -1, env: { FormData: [Function], Blob: [class Blob] }, validateStatus: [Function: validateStatus], headers: Object [AxiosHeaders] { Accept: 'application/json, text/plain, */*', 'Content-Type': undefined, 'User-Agent': 'ioBroker', 'Accept-Encoding': 'gzip, compress, deflate, br' }, method: 'get', url: 'http://10.68.0.178/cm?cmnd=Status0', data: undefined }, request: <ref *1> Writable { _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: false, decodeStrings: true, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: true, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: true, autoDestroy: true, errored: null, closed: false, closeEmitted: false, [Symbol(kOnFinished)]: [] }, _events: [Object: null prototype] { response: [Function: handleResponse], error: [Function: handleRequestError], socket: [Function: handleRequestSocket] }, _eventsCount: 3, _maxListeners: 100, _options: { maxRedirects: 21, maxBodyLength: Infinity, protocol: 'http:', path: '/cm?cmnd=Status0', method: 'GET', headers: [Object: null prototype], agents: [Object], auth: undefined, family: undefined, beforeRedirect: [Function: dispatchBeforeRedirect], beforeRedirects: [Object], hostname: '10.68.0.178', port: '', agent: undefined, nativeProtocols: [Object], pathname: '/cm', search: '?cmnd=Status0' }, _ended: true, _ending: true, _redirectCount: 0, _redirects: [], _requestBodyLength: 0, _requestBodyBuffers: [], _onNativeResponse: [Function (anonymous)], _currentRequest: ClientRequest { _events: [Object: null prototype], _eventsCount: 7, _maxListeners: 100, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, strictContentLength: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Socket], _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' + 'Accept: application/json, text/plain, */*\r\n' + 'User-Agent: ioBroker\r\n' + 'Accept-Encoding: gzip, compress, deflate, br\r\n' + 'sentry-trace: 13659d8493a74941ac422b4062f377eb-9966c26b55b4f6ad\r\n' + 'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.3.1,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=13659d8493a74941ac422b4062f377eb\r\n' + 'Host: 10.68.0.178\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, joinDuplicateHeaders: undefined, path: '/cm?cmnd=Status0', _ended: false, res: null, aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '10.68.0.178', protocol: 'http:', _redirectable: [Circular *1], [Symbol(kCapture)]: false, [Symbol(kBytesWritten)]: 0, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype], [Symbol(errored)]: null, [Symbol(kHighWaterMark)]: 16384, [Symbol(kRejectNonStandardBodyWrites)]: false, [Symbol(kUniqueHeaders)]: null }, _currentUrl: 'http://10.68.0.178/cm?cmnd=Status0', [Symbol(kCapture)]: false }, cause: Error: socket hang up at connResetException (node:internal/errors:720:14) at Socket.socketOnEnd (node:_http_client:525:23) at Socket.emit (node:events:529:35) at Socket.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1400:12) at processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET' } }
        javascript.0
        	2024-06-11 13:59:32.686	error	npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        javascript.0
        	2024-06-11 13:59:22.656	error	npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        javascript.0
        	2024-06-11 13:59:22.632	error	npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
        javascript.0
        	2024-06-11 13:59:22.575	error	npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        javascript.0
        	2024-06-11 13:59:22.517	error	npm warn deprecated har-validator@5.1.5: this library is no longer supported
        so sind meine Einstellungen
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        • Armilar
          Armilar Most Active Forum Testing @australien last edited by
          @australien sagte in SONOFF NSPanel mit Lovelace UI:
          Läuft das Panel nicht?
          Einziges Problem scheint das Script "PV" zu sein. Das nutzt scheinbar Request.
          T A 2 Replies Last reply Reply Quote 1
            TT-Tom @Armilar last edited by
            @armilar
            AxiosError -> entweder kurz aufgehangen, würde das Script nochmal starten und dann schauen, ob sich der Fehler wiederholt
            Armilar 1 Reply Last reply Reply Quote 1
            • Armilar
              Armilar Most Active Forum Testing @TT-Tom last edited by
              @tt-tom
              Das kann schon mal vorkommen... Sehe ich nicht wirklich als Error
                @armilar ich auch nicht, darum würde ich nochmal starten. Tippe da auch eher auf kurze Überlastung der Netzwerkverbindungen.
                  australien @Armilar last edited by
                  @armilar
                  das Script PV liest nur meine xml in Datenpunkte
                  const parser = require('xml2js').parseString;
                  const url = 'http://10.68.0.85/measurements.xml';
                  const idSolar = '0_userdata.0.SolarFrontier.';
                  schedule('{"time":{"start":"sunrise","end":"sunset","mode":"minutes","interval":1},"period":{"days":1}}', function() {
                      request(url, function(error, response, result) {
                          if(!error) parser(result, function(err, obj) {
                              if(!err) {
                                  // log(obj); // Ausgabe posten!
                                  const messung = obj.root.Device[0].Measurements[0].Measurement;
                                  for(let obj of messung) {
                                      // log(obj.$.Type + ': ' + parseFloat(obj.$.Value) + ' ' + obj.$.Unit);
                                      if (existsState(idSolar + obj.$.Type)) setState(idSolar + obj.$.Type, parseFloat(obj.$.Value), true);
                                      else createState(idSolar + obj.$.Type, {name: obj.$.Type, type: 'number'});
                  Armilar T 2 Replies Last reply Reply Quote 0
                  • Armilar
                    @australien
                    und das funktioniert? Da fehlt ganz oben:
                    const request = require('request');
                    Du solltest mittelfristig in httpGet oder Axios umbauen...
                    A T 2 Replies Last reply Reply Quote 0
                      @armilar bis jetzt hat es funktioniert, habe jetzt die Zeile eingefügt und die Empfehlung bekommen es auf httpGet umzubauen.
                      Kenne mich leider nicht mit javascript aus und bin erst im Anfangstadium. Wo kann ich da etwas darüber (httpGet) nachlesen?
                      Das Script wandelt wie gesagt xml in DP um.
                        TT-Tom @Armilar last edited by TT-Tom
                        @australien mit der neuen JavaScript Version ist request weggefallen. Stell um auf httpget.
                        Gibt eine Menge Thread dazu schon. Schau mal ins JavaScript Verzeichnis
                          TT-Tom @australien last edited by
                          @australien so aus dem stehgreif fällt result weg und response liefert jetzt alle Infos und Daten. response.data
                          • Armilar
                            Armilar Most Active Forum Testing @australien last edited by Armilar
                            @australien
                            Als Ansatz für den Umbau
                            httpGet('http://10.68.0.85/measurements.xml', { timeout: 2000, responseType: 'text' }, async (err, response) => {
                                console.info(response.statusCode);
                                console.info(response.data);
                            EDIT: Innerhalb der for-Schleife dürften auch noch ein paar Klammern rein:
                                               if (existsState(idSolar + obj.$.Type)) {
                                               } else {
                              @armilar ich habe jetzt das daraus gemacht, funktioniert.
                              oder kann ich die zweiter ?err auch noch weglassen?
                              	httpGet(url, { timeout: 2000, responseType: 'text' }, async (err, response) => {
                              		// console.info(response.statusCode);
                              		if(!err) parser(response.data, function(err, obj) {
                              			if(!err) {
                              					else {createState(idSolar + obj.$.Type, {name: obj.$.Type, type: 'number'});}
                              • Armilar
                                @australien
                                macht aus meiner Sicht schon Sinn, da es zwei völlig unterschiedliche Funktionen sind. Wäre jetzt also, wenn erfolgreich abgeholt und geparsed, dann nur verarbeiten... Passt
                                  @armilar danke! auch and @TT-Tom
                                    Joker @Armilar last edited by
                                    @armilar said in SONOFF NSPanel mit Lovelace UI:
                                    @joker
                                    Nimm da mal das ".ACTUAL" raus. Das ermittelt das Script selbst, sofern der ALIAS korrekt ist.
                                    Das hat super geklappt, das war der entscheidene Hinweis, Eine Frage habe ich noch, vielleicht will ich auch zuviel.
                                    Wenn ich die PowerCard mit dem Screensaver verwende, aktualisieren sich die Verbrauchswerte nicht, obwohl der Jason Datenpunkt neu beschrieben wird. Bei Screen always on, aktualisieren sich die Verbrauchswerte. Gibt es da einen Befehl für, das sich die Card neu lädt? Oder gibt es die Funktion nicht? Wichtig für die Funktion ist es nicht, sieht aber Schick aus.
                                    Viele Grüße
                                    • Armilar
                                      Armilar Most Active Forum Testing @Joker last edited by
                                      @joker
                                      geht nur bei alwaysOn - gibt da auch keinen Befehl. Ansonsten würde die komplette Seite immer wieder gerendert werden. Du brauchst die Seite aber nur wieder verlassen, damit der Screensaver kommt...
                                        @joker
                                        das heißt, wenn ich das NSPanel nur als Anzeige für den Energiefluss nutzen möchte, brauch ich einen Workaround
                                        1. Page Energiefluss -> IoBroker erkennt Screensaver off -> Iobroker Page wechseln auf 2. Page Energiefluss always on
                                          -> Iobroker nach ablauf timer -> Iobroker Page wechseln auf 1. Page -> Screensaverzeit NSPanel auf 2sec.
                                        Ob das klappt, eigentlich was für lange Winterabende..
                                        Trotzdem ist das ein so mächtiges Script, wahnsinn was man aus so einen NSPanel alles rausholen kann - Respekt!
                                          adsfa last edited by adsfa
                                          Guten morgen,
                                          hat mal jemand versucht einen Snapshot eines Kamerabildes auf dem Display anzuzeigen?
                                          Macht das Sinn oder ist die Qualität zu gering?
                                          Die Idee ist es, das wenn geklingelt wird (Reolink POE Doorbell) ein Snapshot auf allen NS Panels angezeigt wird. Muss kein Videostream sein, man soll ja nur sehen wer da ist und nicht jede Bewegung.
                                          Danke 🙂
                                            TT-Tom @adsfa last edited by
                                            @adsfa es gehen keine Bilder, ob bewegt oder statisch.
                                            A 1 Reply Last reply Reply Quote 2
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6251740
