    4. Cannot download and install adapter "telegram@3.2.1"
      Thomas Braun Most Active @jmeister79 last edited by
      @jmeister79 sagte in Cannot download and install adapter "telegram@3.2.1":
      scheinbar war das ne doofe idee.
      Ja, so handelt man sich nämlich Inkonsistenzen ein.
      Nochmal:
      Vollständige Ausgabe von
      iob diag
      wird benötigt.
      jmeister79 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @jmeister79 last edited by Ro75
        @jmeister79 der js-controller ist mit Version 4 für die meisten Adapter zu alt.
        Ro75
        EDIT: ggfs auch NodeJS.
        • jmeister79
          jmeister79 @Thomas Braun last edited by
                                  v.2024-05-22
             Static hostname: iobrokerpi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               32 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     7
          node:internal/modules/cjs/loader:1143
            throw err;
          Error: Cannot find module 'axios'
          Require stack:
          - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
              at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
              at Module._load (node:internal/modules/cjs/loader:981:27)
              at Module.require (node:internal/modules/cjs/loader:1231:19)
              at require (node:internal/modules/helpers:177:18)
              at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
              at Module._compile (node:internal/modules/cjs/loader:1364:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
              at Module.load (node:internal/modules/cjs/loader:1203:32)
              at Module._load (node:internal/modules/cjs/loader:1019:12)
              at Module.require (node:internal/modules/cjs/loader:1231:19) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          Node.js v18.20.2
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/nodejs         v18.20.2
          /usr/bin/node           v18.20.2
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:            3.8G        2.7G        182M        0.0K        898M        948M
          Swap:            99M         99M        0.0K
          Total:          3.9G        2.8G        182M
          Active iob-Instances:   0
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.20.2
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.20.2
          ioBroker Core:          js-controller
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.20.2
                                  admin
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.20.2
          ioBroker Status:
          Objects:                0
          States:                 0
          Size of iob-Database:
          18M     /opt/iobroker/iobroker-data/objects.jsonl
          4.0M    /opt/iobroker/iobroker-data/states.jsonl
          Some problems detected, please run iob fix and try to have them fixed
          • jmeister79
            iob update:
            pi@iobrokerpi:~ $ iob update
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.20.2
            pi@iobrokerpi:~ $
            • jmeister79
              jmeister79 last edited by jmeister79
              spannend, das putty hier die ganzen Fehler schmeisst und die ssh Console auf dem handy nicht
              war ja auch der andere iobroker.... IDIOT
              • jmeister79
                Tja und jetzt läuft garnix mehr, update und upgrade geht nicht und nach nem restart ist auch der iobroker wech
                  Tja, dann kannst du ja jetzt die vernachlässigten Updates nachholen. Insbesondere des js-controllers.
                  iob stop
                  cd /opt/iobroker
                  npm install iobroker.js-controller@5.0.19
                  iob start
                  iob update
                  • jmeister79
                    @thomas-braun said in Cannot download and install adapter "telegram@3.2.1":
                    ok, wenn das so geht, kannst du mir kurz erklären wie das passiert das der iobroker sich selber so abschießt, wenn der js-controller alt sit? würde es gerne verstehen.
                      passiert das. Weil dann Abhängigkeiten nicht bedient werden können.
                      Deswegen funktioniert es ja auch nicht, das System einmal zu installieren und dann 'das running süstem never zu tatschen'.
                      Die einzelnen Komponenten (Betriebssystem; Laufzeitumgebung, js-controller, iob-Adapter) müssen halt mit einander richtig zusammenspielen. Das kannst du aber nur mit jeweils aktuellen, stabilen Versionen gewährleisten.
                      • jmeister79
                        @thomas-braun ok danke.
                        leider bringt
                        nix.
                        selber Fehler bei iob update
                          leider bringt
                          nix.
                          Zeigen. Komplette Ein- wie Ausgaben.
                          • jmeister79
                            @thomas-braun my bad, der iobroker lief noch, war unaufmerksam.
                            so ich update dann mal alles.
                            Aber nochmal doof gefragt:
                            Wenn ich n runden Stand hätte und NIX update, dann sollte es doch gehen (sofern es keine probleme mit den third parties gibt: Shelly, telegram, Xiaomi, Fronius, etc...) Es sit ja dann ein Inselsystem
                            Thomas Braun W 2 Replies Last reply Reply Quote 0
                              @jmeister79
                              Es wird immer Notwendigkeiten für Anpassungen geben.
                              Dein 'Inselbetrieb' ist nicht realistisch.
                                Wildbill @jmeister79 last edited by
                                @jmeister79 Inselbetrieb heißt aber dann auch, dass das Gerät für sich läuft. Keine Verbindung nach außen, nirgends hin, wo auch nur irgendwo eine Verbindung woandershin bestehen könnte. Also: Kein LAN-Kabel eingesteckt, kein WLAN eingerichtet. Dann, ja dann läuft der Inselbetrieb auf Dauer und vermutlich stabil!
                                Gruss, Jürgen
                                494
