    4. Beta Test js-controller Kiera (v6.0)
      mrjeschke @foxriver76 last edited by
      @foxriver76
      Wie mache ich jetzt adapter-updates über die Web-Oberfläche?
      Ich finde dort keinen Button mehr.
      Skript v.2024-05-22
      *** BASE SYSTEM ***
        Static hostname: iobroker
              Icon name: computer-container
                Chassis: container
         Virtualization: lxc
       Operating System: Debian GNU/Linux 11 (bullseye)
                 Kernel: Linux 6.8.4-3-pve
           Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-8500T CPU @ 2.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      16:53:33 up 1 day, 0 min,  1 user,  load average: 1.50, 0.99, 0.87
      CPU threads: 6
      *** Time and Time Zones ***
                    Local time: Tue 2024-06-11 16:53:33 CEST
                Universal time: Tue 2024-06-11 14:53:33 UTC
                      RTC time: n/a
                   NTP service: inactive
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      maik
      HOME=/home/maik
      GROUPS=maik adm tty dialout sudo audio video redis iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:             15G        4.2G        9.8G        0.0K        1.4G         11G
      Swap:           512M          0B        512M
      Total:           15G        4.2G         10G
      Active iob-Instances:   38
             15360 M total memory
              4183 M used memory
              4211 M active memory
              1105 M inactive memory
              9763 M free memory
                 0 M buffer memory
              1413 M swap cache
               512 M total swap
                 0 M used swap
               512 M free swap
      top - 16:53:33 up 1 day, 0 min,  1 user,  load average: 1.38, 0.98, 0.86
      Tasks:  70 total,   1 running,  69 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  8.8 us,  3.9 sy,  0.0 ni, 87.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15360.0 total,   9763.8 free,   4182.9 used,   1413.3 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.  11177.0 avail Mem
      *** FAILED SERVICES ***
       UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--181--disk--0 ext4       63G   14G   47G  23% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.3G  132K  6.3G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                SOURCE                           FSTYPE     OPTIONS
      /                                     /dev/mapper/pve-vm--181--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,size=6540772k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | `-/run/user/1000                    tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=3270384k,nr_inodes=817596,mode=700,uid=101000,gid=101000,inode64
      |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                       mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/.lxc/proc                    proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                     sys                              sysfs      rw,relatime
      | |-/dev/full                         udev[/full]                      devtmpfs   rw,nosuid,relatime,size=16318080k,nr_inodes=4079520,mode=755,inode64
      | |-/dev/null                         udev[/null]                      devtmpfs   rw,nosuid,relatime,size=16318080k,nr_inodes=4079520,mode=755,inode64
      | |-/dev/random                       udev[/random]                    devtmpfs   rw,nosuid,relatime,size=16318080k,nr_inodes=4079520,mode=755,inode64
      | |-/dev/tty                          udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=16318080k,nr_inodes=4079520,mode=755,inode64
      | |-/dev/urandom                      udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=16318080k,nr_inodes=4079520,mode=755,inode64
      | |-/dev/zero                         udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=16318080k,nr_inodes=4079520,mode=755,inode64
      | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                         devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                         devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
       |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
       |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
       |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
       `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      1.4G    /var/
      644M    /var/lib
      508M    /var/lib/redis
      479M    /var/log
      424M    /var/log/journal
      Archived and active journals take up 405.9M in the file system.
      /opt/iobroker/backups:
      229M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.8G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      269M    /opt/iobroker/iobroker-data/esphome.0/.esphome
      265M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      40M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.14.0
      /usr/bin/node           v20.14.0
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.1
      nodejs:
       Installed: 20.14.0-1nodesource1
       Candidate: 20.14.0-1nodesource1
       Version table:
      *** 20.14.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             100 /var/lib/dpkg/status
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          12.22.12~dfsg-1~deb11u4 500
             500 http://deb.debian.org/debian bullseye/main amd64 Packages
             500 http://security.debian.org bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  6.0.1
      admin:          7.0.1
      javascript:     8.5.1
      nodejs modules from github:     1
      +-- iobroker.hiob@0.1.4 (git+ssh://git@github.com/moba15/ioBroker.hiob.git#9b983e7b527fea28ac141f257ee284603b2b0a48)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 80, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
       system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
       system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
       system.adapter.devices.0                : devices               : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.hiob.0                   : hiob                  : iobroker                                 -  enabled, port: 8090
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
       system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
       system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
       system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
       system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
       system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
       system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
       system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
       system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
       system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
       system.adapter.material.0               : material              : iobroker                                 - disabled
      + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
       system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
       system.adapter.odl.0                    : odl                   : iobroker                                 -  enabled
       system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8099, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
       system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
       system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
       system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 - disabled
       system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
       system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: iobroker                                 - disabled
       system.adapter.vis-2-widgets-sweethome3d.0: vis-2-widgets-sweethome3d: iobroker                                 - disabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
       system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
       system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
       system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
       system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
       system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
       system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
       system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
       system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
       system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
       system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
       system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
       system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
       system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
       system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
       system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://172.16.4.137:6638
      + instance is alive
      ioBroker-Repositories
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
      Adapter    "admin"        : 6.17.14  , installed 7.0.1
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "awtrix-light" : 1.2.1    , installed 1.2.1
      Adapter    "backitup"     : 3.0.3    , installed 3.0.3
      Adapter    "birthdays"    : 3.0.0    , installed 3.0.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
      Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hiob"         : 0.1.4    , installed 0.1.4
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "javascript"   : 8.5.2    , installed 8.5.1  [Updatable]
      Controller "js-controller": 6.0.1    , installed 6.0.1
      Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "odl"          : 3.0.1    , installed 3.0.1
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "rest-api"     : 2.0.1    , installed 2.0.1
      Adapter    "scenes"       : 3.0.4    , installed 3.0.4
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
      Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
      Adapter    "vis-2-widgets-jaeger-design": 1.1.27, installed 1.1.27
      Adapter    "vis-2-widgets-material": 1.3.33, installed 1.3.33
      Adapter    "vis-2-widgets-radar-trap": 2.0.0, installed 2.0.0
      Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.2.6    , installed 6.2.6
      Adapter    "wled"         : 0.7.3-beta.0, installed 0.7.2 [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        11170
      States:         10067
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 http://deb.volian.org/volian scar InRelease
      Hit:7 https://packages.redis.io/deb bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       260863260  26101/python3
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        259791586  121/systemd-resolve
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          259796348  308/master
      tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       260859432  25971/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       260853395  25698/node-red
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          259796075  1/init
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        259791608  142/redis-server 12
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        259791592  121/systemd-resolve
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        259791589  121/systemd-resolve
      tcp6       0      0 :::8099                 :::*                    LISTEN      1001       260880940  26720/io.socketio.0
      tcp6       0      0 :::8090                 :::*                    LISTEN      1001       260858927  25866/io.hiob.0
      tcp6       0      0 :::8093                 :::*                    LISTEN      1001       260881753  26690/io.rest-api.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       260883960  26826/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       260850634  25611/io.admin.1
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       260883533  26705/io.simple-api
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       260883398  26856/io.ws.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          259796349  308/master
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        259791609  142/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          259794293  1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          259796077  1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      1001       260850553  25584/io.admin.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       260862597  26104/io.fullybrows
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       260858881  25851/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       260876264  26841/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       260865135  26080/io.esphome.0
      udp        0      0 172.16.4.181:5353       0.0.0.0:*                           1001       260863267  26101/python3
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       260863266  26101/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       260863261  26101/python3
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        259791585  121/systemd-resolve
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       260858882  25851/io.harmony.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        259791591  121/systemd-resolve
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          259792563  83/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          259796076  1/init
      udp6       0      0 :::5355                 :::*                                104        259791588  121/systemd-resolve
      udp6       0      0 :::111                  :::*                                0          259796078  1/init
      • mcm1957
        mcm1957 @mrjeschke last edited by mcm1957
        @mrjeschke
        Du hast admin 7.x.x installiert; das ist ein Bug in admin.
        https://github.com/ioBroker/ioBroker.admin/issues/2498
        Admin 7.0.x wurde zurückgezogen. Downgrade admin auf den aktuellen LATEST Stand (6.x.x) via Konsole / Commandline
        Feuer-sturm created this issue in ioBroker/ioBroker.admin
        closed [bug]: No button for adapter update visible #2498
          mrjeschke @mcm1957 last edited by
          @mcm1957
          Danke, nach downgrade klappt es wieder.
            anwa last edited by Negalein
            hat hier noch jemand Probleme mit SourceAnalytix?
            host.ioBroker  2024-06-11 20:41:00.166	info	Restart adapter system.adapter.sourceanalytix.0 because enabled
            host.ioBroker  2024-06-11 20:41:00.166	error	instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: Node.js v20.14.0
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
            host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
            host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31:36)
            host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
            host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: ^
            host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: class Sourceanalytix extends utils.Adapter {
            host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31
            host.ioBroker  2024-06-11 20:40:59.291	info	instance system.adapter.sourceanalytix.0 started with pid 207189
            admin: 7.0.1
            javascript: 8.5.2
            Calendar, eCharts machen auch probleme.
            • mcm1957
              mcm1957 @foxriver76 last edited by
              @foxriver76 said in Beta Test js-controller Kiera (v6.0):
              @mcm1957 Geht rflink in 2.1.7?
              Sieht leider nicht so aus:
              Siehe https://forum.iobroker.net/topic/75222/rflink-keine-serielle-schnittstelle/14
              host.GLT
              2024-06-11 20:10:24.709	info	Rebuild for adapter system.adapter.rflink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              host.GLT
              2024-06-11 20:10:24.709	error	instance system.adapter.rflink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: Node.js v20.14.0
              host.GLT
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1024:12)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1208:32)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: at Object.<anonymous> (C:\ioBroker\GLT\node_modules\iobroker.rflink\main.js:17:17)
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'supportsFeature')
              host.GLT
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: ^
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: if (adapter.supportsFeature && !adapter.supportsFeature('CONTROLLER_NPM_AUTO_REBUILD')) {
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[1]: C:\ioBroker\GLT\node_modules\iobroker.rflink\main.js:17
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\lib\binding\node-v115-win32-x64\bindings.node
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\default\install-root\bindings.node
              host.GLT
              2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\debug\install-root\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\release\install-root\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\compiled\20.14.0\win32\x64\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\default\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\Release\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\out\Release\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\Debug\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\out\Debug\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\Release\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\Debug\bindings.node
              host.GLT
              2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\bindings.node
              host.GLT
              2024-06-11 20:10:24.707	error	Caught by controller[0]: Cannot load serialport module : Error: Could not locate the bindings file. Tried:
              foxriver76 1 Reply Last reply Reply Quote 1
              • mcm1957
                mcm1957 @anwa last edited by
                @anwa said in Beta Test js-controller Kiera (v6.0):
                admin: 7.0.1
                javascript: 8.5.2
                Danke guter Anfang. Aber es wäre noch von Interesse welche version von sourceanalytix du hats 🙂
                Beitte detailliertere Fehlermeldungen incl. Versionen
                  anwa last edited by
                  Sorry, immer die neueste... 0.4.14
                    anwa last edited by anwa
                    Kalender (calendar) 1.2.0
                    host.ioBroker
                    2024-06-11 21:04:44.153	info	Restart adapter system.adapter.calendar.0 because enabled
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	instance system.adapter.calendar.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: Node.js v20.14.0
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.calendar/main.js:17:30)
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
                    host.ioBroker
                    2024-06-11 21:04:44.153	error	Caught by controller[0]: ^
                    host.ioBroker
                    2024-06-11 21:04:44.152	error	Caught by controller[0]: class Calendar extends utils.Adapter {
                    host.ioBroker
                    2024-06-11 21:04:44.152	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.calendar/main.js:17
                    Vermutlich der gleiche Fehler...
                    • mcm1957
                      @foxriver76
                      Bitte sourceanalytix auf die inkompaibel Liste.
                      Im Latest ist 0.4.14 mit "@iobroker/adapter-core": "^2.6.0" - das funkt nicht.
                      @Dutchman muss da ne neue Release mit aktuellem Adaptercore erstellen (außer du hast da Zugriff - hab aber keine Ahnung welchen Status die zwischenzeitlichen WIP Änderungen haben.
                      Hinweis:: sourceanalytix ist nicht im stable
                        anwa last edited by
                        E-Charts (echarts) 1.7.2
                        host.ioBroker
                        2024-06-11 21:06:38.263	info	Restart adapter system.adapter.echarts.0 because enabled
                        host.ioBroker
                        2024-06-11 21:06:38.263	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.ioBroker
                        2024-06-11 21:06:38.263	error	Caught by controller[0]: Node.js v20.14.0
                        host.ioBroker
                        2024-06-11 21:06:38.263	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                        host.ioBroker
                        2024-06-11 21:06:38.263	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:325:5)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.echarts/main.js:70:15)
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: ^
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: adapter = new utils.Adapter(options);
                        host.ioBroker
                        2024-06-11 21:06:38.262	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.echarts/main.js:70
                        host.ioBroker
                        2024-06-11 21:06:37.428	info	instance system.adapter.echarts.0 started with pid 212103
                        host.ioBroker
                        2024-06-11 21:06:36.303	info	"system.adapter.echarts.0" enabled
                        • JB_Sullivan
                          JB_Sullivan last edited by
                          Ist nur eine Info Meldung, aber seit dem Update auf den 6er Controller, wirft einer von 5! Shelly 3EM diese Meldung ins Log.
                          Alles Shellys sind gleich konfiguriert und auf Berlin konfiguriert, aber nur einer wirft diese Meldung.
                          Weder in den ioB Basiseinstellungen noch in den Shelly Adapter Einstellungen gibt es einen Punkt wo man UTC einstellen oder ändern könnte.
                          Hängt das ggf. mit dem 6er Controller zusammen?
                          shelly.0
                          11596	2024-06-11 20:59:21.019	info	[Sys.timezone] 10.122.60.105 (shellyem3 / shellyem3-8CAAB561EFDE / SHEM-3#8CAAB561EFDE#1): Configured timezone "UTC-120" and system timezone "Europe/Berlin" do not match. Please check configuration
                          • mcm1957
                            Bitte für calendar ein Issue im Adapter repo erstellen.
                            Adapter core @iobroker/adapter-core": "^2.3.1" ist inkompatibel.
                            Allerdings ist der Adapter schon Jahre nicht mehr gewartet. Ich kann derzeit nicht sagen ob dieser gefixed oder deprectaed wird.
                            • foxriver76
                              foxriver76 Developer @JB_Sullivan last edited by
                              @jb_sullivan eher unwahrscheinlich also würde mich wundern..
                              • foxriver76
                                foxriver76 Developer @mcm1957 last edited by foxriver76
                                @mcm1957 puh und ne alte Version geht mit alt Controller? Schaut eher nach serialport speziell aus.. Villt Zusammenhang mit Node 20? Ja das Ding braucht mal Tests …
                                • mcm1957
                                  mcm1957 @anwa last edited by mcm1957
                                  @anwa
                                  Bitte erstell in den Repositories für
                                  • sourceanalytix
                                  • calendar
                                  • echarts
                                  jeweils ein Issue
                                  @foxriver76
                                  Bitte setz diese VIER Adapter auf die Liste der inkompatiblen Adapter
                                  • ad sourceanalytix
                                    Auf Github ist adaptercore schon auf einer (alten) 3.x.x. Alldings wurden auch div. Dinge erweitert / geändert. Da sollte @Dutchman eine saubere Release mit aktuellem adapter-core erstellen
                                  • ad calendar
                                    Der Adapter ist verwaist. Dev ist seit langem inaktiv. Hier muss abgeklärt werden ob fullcalendar ein Ersatz wäre und / oder ob wir den Adapter in community verschieben wollen (und ihn dorr anpassen. Bitte ggF Bescheid geben, wenn ich ein Timeout Issue erstellen soll.
                                  • ad echarts
                                    Der hat in der letzen Release noch nicht mal adapter-core benutzt. Auf Github wurde allerdings alles mögliche incl. adapter-core gemerged. Tests sind allerdings rot. Da muss wer sanieren. (iobroker orga, Zugriff sollte also da sein)
                                  • ad contact
                                    Der contact Adapter ist ebenfalls von WLANkabel und verwaist. Benutzt @iobroker/adapter-core": "^2.2.1" - wird also ziemlich sicher auch nicht gehen.
                                  • mcm1957
                                    OK, Issue beim Adapter ist offen. Von mir aus kann der zunächst als offen liegen bleiben. Kann ihn mir ca. Mitte Juli ansehen. Oder wer andere hat vorher Zeit. Setz ihn halt mal auf inkompatibel
                                    • foxriver76
                                      @mcm1957 ich habe eine 2.1.8 gemacht in der das Serialport geupdated wurde. Hoffe tut nun.
                                      mcm1957 JB_Sullivan 2 Replies Last reply Reply Quote 1
                                      • mcm1957
                                        @foxriver76
                                        Ich geh dann eher mal in standby modus. Muss morgen früh raus...
                                        • JB_Sullivan
                                          JB_Sullivan @foxriver76 last edited by
                                          @foxriver76
                                          Nicht ganz ......
                                          rflink.0
                                          15048	2024-06-11 22:00:56.233	error	Cannot open serial port "COM3": TypeError: SerialPort is not a constructor
                                          • foxriver76
                                            @jb_sullivan dann 2.1.9 ansonsten muss es sich jemand anschauen der das testen kann,
                                            beta js-controller kiera test
                                            39
                                            331
                                            79171
