    4. Beta Test js-controller Kiera (v6.0)
    • mcm1957
      mcm1957 @mrjeschke last edited by mcm1957
      @mrjeschke
      Du hast admin 7.x.x installiert; das ist ein Bug in admin.
      https://github.com/ioBroker/ioBroker.admin/issues/2498
      Admin 7.0.x wurde zurückgezogen. Downgrade admin auf den aktuellen LATEST Stand (6.x.x) via Konsole / Commandline
      Feuer-sturm created this issue in ioBroker/ioBroker.admin
      closed [bug]: No button for adapter update visible #2498
        mrjeschke @mcm1957 last edited by
        @mcm1957
        Danke, nach downgrade klappt es wieder.
          anwa last edited by Negalein
          hat hier noch jemand Probleme mit SourceAnalytix?
          host.ioBroker  2024-06-11 20:41:00.166	info	Restart adapter system.adapter.sourceanalytix.0 because enabled
          host.ioBroker  2024-06-11 20:41:00.166	error	instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: Node.js v20.14.0
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          host.ioBroker  2024-06-11 20:41:00.166	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31:36)
          host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
          host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: ^
          host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: class Sourceanalytix extends utils.Adapter {
          host.ioBroker  2024-06-11 20:41:00.165	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31
          host.ioBroker  2024-06-11 20:40:59.291	info	instance system.adapter.sourceanalytix.0 started with pid 207189
          Core adapters versions
          js-controller: 6.0.1
          admin: 7.0.1
          javascript: 8.5.2
          Calendar, eCharts machen auch probleme.
          • mcm1957
            mcm1957 @foxriver76 last edited by
            @foxriver76 said in Beta Test js-controller Kiera (v6.0):
            @mcm1957 Geht rflink in 2.1.7?
            Sieht leider nicht so aus:
            Siehe https://forum.iobroker.net/topic/75222/rflink-keine-serielle-schnittstelle/14
            host.GLT
            2024-06-11 20:10:24.709	info	Rebuild for adapter system.adapter.rflink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            host.GLT
            2024-06-11 20:10:24.709	error	instance system.adapter.rflink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: Node.js v20.14.0
            host.GLT
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1024:12)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1208:32)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: at Object.<anonymous> (C:\ioBroker\GLT\node_modules\iobroker.rflink\main.js:17:17)
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'supportsFeature')
            host.GLT
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: ^
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: if (adapter.supportsFeature && !adapter.supportsFeature('CONTROLLER_NPM_AUTO_REBUILD')) {
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[1]: C:\ioBroker\GLT\node_modules\iobroker.rflink\main.js:17
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\lib\binding\node-v115-win32-x64\bindings.node
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\default\install-root\bindings.node
            host.GLT
            2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\debug\install-root\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\release\install-root\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\compiled\20.14.0\win32\x64\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\default\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\Release\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\out\Release\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\Debug\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\out\Debug\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\Release\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\Debug\bindings.node
            host.GLT
            2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\bindings.node
            host.GLT
            2024-06-11 20:10:24.707	error	Caught by controller[0]: Cannot load serialport module : Error: Could not locate the bindings file. Tried:
            foxriver76 1 Reply Last reply Reply Quote 1
            • mcm1957
              mcm1957 @anwa last edited by
              @anwa said in Beta Test js-controller Kiera (v6.0):
              admin: 7.0.1
              javascript: 8.5.2
              Danke guter Anfang. Aber es wäre noch von Interesse welche version von sourceanalytix du hats 🙂
              Beitte detailliertere Fehlermeldungen incl. Versionen
                anwa last edited by
                Sorry, immer die neueste... 0.4.14
                  anwa last edited by anwa
                  Kalender (calendar) 1.2.0
                  host.ioBroker
                  2024-06-11 21:04:44.153	info	Restart adapter system.adapter.calendar.0 because enabled
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	instance system.adapter.calendar.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: Node.js v20.14.0
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.calendar/main.js:17:30)
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
                  host.ioBroker
                  2024-06-11 21:04:44.153	error	Caught by controller[0]: ^
                  host.ioBroker
                  2024-06-11 21:04:44.152	error	Caught by controller[0]: class Calendar extends utils.Adapter {
                  host.ioBroker
                  2024-06-11 21:04:44.152	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.calendar/main.js:17
                  Vermutlich der gleiche Fehler...
                  • mcm1957
                    @foxriver76
                    Bitte sourceanalytix auf die inkompaibel Liste.
                    Im Latest ist 0.4.14 mit "@iobroker/adapter-core": "^2.6.0" - das funkt nicht.
                    @Dutchman muss da ne neue Release mit aktuellem Adaptercore erstellen (außer du hast da Zugriff - hab aber keine Ahnung welchen Status die zwischenzeitlichen WIP Änderungen haben.
                    Hinweis:: sourceanalytix ist nicht im stable
                      anwa last edited by
                      E-Charts (echarts) 1.7.2
                      host.ioBroker
                      2024-06-11 21:06:38.263	info	Restart adapter system.adapter.echarts.0 because enabled
                      host.ioBroker
                      2024-06-11 21:06:38.263	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.ioBroker
                      2024-06-11 21:06:38.263	error	Caught by controller[0]: Node.js v20.14.0
                      host.ioBroker
                      2024-06-11 21:06:38.263	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                      host.ioBroker
                      2024-06-11 21:06:38.263	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:325:5)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.echarts/main.js:70:15)
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: ^
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: adapter = new utils.Adapter(options);
                      host.ioBroker
                      2024-06-11 21:06:38.262	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.echarts/main.js:70
                      host.ioBroker
                      2024-06-11 21:06:37.428	info	instance system.adapter.echarts.0 started with pid 212103
                      host.ioBroker
                      2024-06-11 21:06:36.303	info	"system.adapter.echarts.0" enabled
                      • JB_Sullivan
                        JB_Sullivan last edited by
                        Ist nur eine Info Meldung, aber seit dem Update auf den 6er Controller, wirft einer von 5! Shelly 3EM diese Meldung ins Log.
                        Alles Shellys sind gleich konfiguriert und auf Berlin konfiguriert, aber nur einer wirft diese Meldung.
                        Weder in den ioB Basiseinstellungen noch in den Shelly Adapter Einstellungen gibt es einen Punkt wo man UTC einstellen oder ändern könnte.
                        Hängt das ggf. mit dem 6er Controller zusammen?
                        shelly.0
                        11596	2024-06-11 20:59:21.019	info	[Sys.timezone] 10.122.60.105 (shellyem3 / shellyem3-8CAAB561EFDE / SHEM-3#8CAAB561EFDE#1): Configured timezone "UTC-120" and system timezone "Europe/Berlin" do not match. Please check configuration
                        • mcm1957
                          Bitte für calendar ein Issue im Adapter repo erstellen.
                          Adapter core @iobroker/adapter-core": "^2.3.1" ist inkompatibel.
                          Allerdings ist der Adapter schon Jahre nicht mehr gewartet. Ich kann derzeit nicht sagen ob dieser gefixed oder deprectaed wird.
                          • foxriver76
                            foxriver76 Developer @JB_Sullivan last edited by
                            @jb_sullivan eher unwahrscheinlich also würde mich wundern..
                            • foxriver76
                              foxriver76 Developer @mcm1957 last edited by foxriver76
                              @mcm1957 puh und ne alte Version geht mit alt Controller? Schaut eher nach serialport speziell aus.. Villt Zusammenhang mit Node 20? Ja das Ding braucht mal Tests …
                              • mcm1957
                                mcm1957 @anwa last edited by mcm1957
                                @anwa
                                Bitte erstell in den Repositories für
                                • sourceanalytix
                                • calendar
                                • echarts
                                jeweils ein Issue
                                @foxriver76
                                Bitte setz diese VIER Adapter auf die Liste der inkompatiblen Adapter
                                • ad sourceanalytix
                                  Auf Github ist adaptercore schon auf einer (alten) 3.x.x. Alldings wurden auch div. Dinge erweitert / geändert. Da sollte @Dutchman eine saubere Release mit aktuellem adapter-core erstellen
                                • ad calendar
                                  Der Adapter ist verwaist. Dev ist seit langem inaktiv. Hier muss abgeklärt werden ob fullcalendar ein Ersatz wäre und / oder ob wir den Adapter in community verschieben wollen (und ihn dorr anpassen. Bitte ggF Bescheid geben, wenn ich ein Timeout Issue erstellen soll.
                                • ad echarts
                                  Der hat in der letzen Release noch nicht mal adapter-core benutzt. Auf Github wurde allerdings alles mögliche incl. adapter-core gemerged. Tests sind allerdings rot. Da muss wer sanieren. (iobroker orga, Zugriff sollte also da sein)
                                • ad contact
                                  Der contact Adapter ist ebenfalls von WLANkabel und verwaist. Benutzt @iobroker/adapter-core": "^2.2.1" - wird also ziemlich sicher auch nicht gehen.
                                • mcm1957
                                  OK, Issue beim Adapter ist offen. Von mir aus kann der zunächst als offen liegen bleiben. Kann ihn mir ca. Mitte Juli ansehen. Oder wer andere hat vorher Zeit. Setz ihn halt mal auf inkompatibel
                                  • foxriver76
                                    @mcm1957 ich habe eine 2.1.8 gemacht in der das Serialport geupdated wurde. Hoffe tut nun.
                                    mcm1957 JB_Sullivan 2 Replies Last reply Reply Quote 1
                                    • mcm1957
                                      @foxriver76
                                      Ich geh dann eher mal in standby modus. Muss morgen früh raus...
                                      • JB_Sullivan
                                        JB_Sullivan @foxriver76 last edited by
                                        @foxriver76
                                        Nicht ganz ......
                                        rflink.0
                                        15048	2024-06-11 22:00:56.233	error	Cannot open serial port "COM3": TypeError: SerialPort is not a constructor
                                        • foxriver76
                                          @jb_sullivan dann 2.1.9 ansonsten muss es sich jemand anschauen der das testen kann,
                                          • da_Woody
                                            da_Woody last edited by
                                            gerade update auf 6.0.2 gemacht, smartcontrol 2.0.1 will nicht mehr starten.
                                            https://github.com/iobroker-community-adapters/ioBroker.smartcontrol/issues/177
                                            sjfm-design created this issue in iobroker-community-adapters/ioBroker.smartcontrol
                                            closed nach update js-controller 6.0.2 smartcontrol 2.0.1 keine verbindung zu gerät/dienst #177
                                            beta js-controller kiera test
                                            39
                                            331
                                            79171
