    3. Einsteigerfragen
    4. bekomme USB Stick nicht gemountet für backup
      Thomas Braun Most Active @final last edited by
      @final sagte in bekomme USB Stick nicht gemountet für backup:
      durch das kopieren aus der Konsole gehen die Zeilenumbrüche verloren
      Welches Terminal verwendest du denn?
      Hier geht das nämlich ohne Hantier:
      [thomas@roamer ~]$ mount | sort
      binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
      bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
      cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
      configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
      debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
      /dev/nvme0n1p1 on /efi type vfat (rw,relatime,fmask=0137,dmask=0027,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
      /dev/nvme0n1p2 on /home type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=257,subvol=/@home)
      /dev/nvme0n1p2 on / type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=256,subvol=/@)
      /dev/nvme0n1p2 on /var/cache type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=258,subvol=/@cache)
      /dev/nvme0n1p2 on /var/log type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=259,subvol=/@log)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
      devtmpfs on /dev type devtmpfs (rw,nosuid,size=4096k,nr_inodes=2008343,mode=755,inode64)
      efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
      hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
      mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
      portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
      proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
      pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
      securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
      systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5713)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
      tmpfs on /run/credentials/systemd-journald.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run/credentials/systemd-sysctl.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run/credentials/systemd-tmpfiles-setup-dev-early.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run/credentials/systemd-tmpfiles-setup-dev.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run/credentials/systemd-tmpfiles-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run/credentials/systemd-udev-load-credentials.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run/credentials/systemd-vconsole-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
      tmpfs on /run type tmpfs (rw,nosuid,nodev,size=3219116k,nr_inodes=819200,mode=755,inode64)
      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1609556k,nr_inodes=402389,mode=700,uid=1000,gid=1000,inode64)
      tmpfs on /tmp type tmpfs (rw,noatime,inode64)
      tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
      [thomas@roamer ~]$
        final @Thomas Braun last edited by
        Powershell unter Windows
          @final
          Die hab ich auch unter Windows verwendet. Hatte ich nie Probleme mit.
            Hm, keine Ahnung, vielleicht kopiere ich ja falsch. Naja.
            Hab ich das jetzt verstanden - weil nur root Schreibrechte hat, klappt es nicht?
              Dann füg die Zeilenumbrüche von Hand ein. So werde ich das jedenfalls nicht lesen.
                Klar, hab es per Hand angepasst.
                raspberrypi:/ $ mount |sort
                /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                /dev/mmcblk0p2 on / type ext4 (rw,noatime,commit=600)
                /dev/sda1 on /mnt/usbstick type ext4 (rw,relatime)
                proc on /proc type proc (rw,relatime)
                ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
                ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
                ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
                ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
                sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=94304k,mode=755)
                tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=94304k,nr_inodes=23576,mode=700,uid=1000,gid=1000)
                udev on /dev type devtmpfs (rw,nosuid,relatime,size=334764k,nr_inodes=83691,mode=755)
                  @final
                  Was hast du eigentlich für einen seltsamen Prompt?
                    ich hab nur den namen vor dem @raspberrypi rausgeschnitten
                      @final
                      Und der hat kein Home?
                      Veränder an der Ausgabe nichts.
                        Doch, wieso.
                        Achso - ich bin anscheinend irgendwann mal mit cd .. aus home raus, wenn du das meinst?
                        Hab bewusst nix verändert.
                        @raspberrypi:/ $ ls -f
                        lost+found  mnt  srv  dev  tmp  bin  etc  media  boot  .  lib  usr  sbin  home  ..  var  root  proc  sys  run  opt
                          Thomas Braun Most Active @final last edited by Thomas Braun
                          Doch, wieso.
                          Weil es u. U. wichtig ist, mit welchem user du in welchem Verzeichnis stehst, deswegen.
                          Stell dich wieder in dein home.
                          Die /etc/fstab schaut wie aus?
                            Homoran Global Moderator Administrators @final last edited by
                            @raspberrypi
                            und da vorne steht wirklich nichts davor?
                              final @Homoran last edited by
                              @homoran said in bekomme USB Stick nicht gemountet für backup:
                              doch, der username (nicht root).
                                @final
                                Text nie als Screenshot, immer in Textform in CodeTags hier rein
                                  sorry, war ablenkt 😞
                                    final @final last edited by
                                    @Thomas-Braun
                                    Nabend.
                                    Schon eine Idee woran es liegen könnte? Muss ich dem Ordner /mnt/usbstick andere Rechte geben, damit der iob drauf schreiben kann?
                                      Text? Dann in Textform hier rein. Wie gesagt, Screenshots schau ich mir nicht an.
                                        proc	/proc	proc	defaults	0	0
                                        PARTUUID=d2bed0db-01	/boot/firmware	vfat	defaults	0	2
                                        PARTUUID=d2bed0db-02	/				ext4	defaults,noatime,commit=600 0	1
                                        UUID=9e950934-a656-4909-ac5e-b658ee72204e	/mnt/usbstick	ext4	defaults	0	2
                                        #/dev/sda1	/mnt/usbstick	ext4	defaults	0	2
                                          Trag da mal
                                          UUID=9e950934-a656-4909-ac5e-b658ee72204e	/mnt/usbstick	ext4	defaults,noauto,users	0	2
                                          ein.
                                          In den Optionen von Backitup dann den Haken bei 'Als root mounten' entfernen und die Kiste neustarten.
                                            mach ich - sobald ich das System wieder zum laufen bekomme. Aus irgendeinem Grund startet der Raspi nicht mehr richtig, schon mehrfach versucht. Hab ein ungutes Gefühl...
                                            Ein RPi5 kommt heute, den muss ich aber dann erstmal neu aufsetzen.
                                            Allerdings kommt ja dann da das gleiche Thema zum Tragen - werde also dann die fstab wie vorgeschlagen befüllen und dann Rückmeldung geben.
                                            Eine Info könnte ich aber gut gebrauchen: wenn ich jetzt nicht mehr auf den alten Raspi komme - wie kann ich auf die SD Karte zugreifen und mir die letzte Sicherung runter kopieren? Damit das gerade nicht passiert war ja eigentlich der USB Stick gedacht...
                                            2179
