    4. IoBroker und VIS verweigert Zugriff
      Homoran Global Moderator Administrators @Loco last edited by
      @loco sagte in IoBroker und VIS verweigert Zugriff:
      Hättet ihr ein Tip was das jetzt sein kann?
      ohne irgendwelchen handfesten Fakten, leider nein!
      • Ro75
        Ro75 @Loco last edited by Ro75
        @loco wie hast du das Rückspielen gestartet? Und ie lange hast du bis zu den nächsten Ativitäten geartet?
        Ro75.
        EDIT: Möglicherweise immer wieder falsche Vorgehensweise? Vielleicht mal Schritt für Schritt mit ggfs. Nachfragen
        Ro75 1 Reply Last reply Reply Quote 0
          Loco @Homoran last edited by
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.6.31+rpt-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           15:33:35 up 19:04,  2 users,  load average: 1.54, 2.75, 3.04
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          *** Time and Time Zones ***
                         Local time: Wed 2024-06-12 15:33:36 CEST
                     Universal time: Wed 2024-06-12 13:33:36 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          HOME=/home/ioBroker
          GROUPS=ioBroker adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            4.0G        1.4G        548M        1.2M        2.1G        2.5G
          Swap:           209M        262K        209M
          Total:          4.2G        1.4G        758M
          Active iob-Instances:   18
                   3792 M total memory
                   1365 M used memory
                   1477 M active memory
                   1597 M inactive memory
                    522 M free memory
                     89 M buffer memory
                   1890 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 15:33:36 up 19:04,  2 users,  load average: 1.54, 2.75, 3.04
          Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 11.1 us, 11.1 sy,  0.0 ni, 66.7 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3792.1 total,    522.1 free,   1366.3 used,   1980.6 buff/cache
          MiB Swap:    200.0 total,    199.7 free,      0.2 used.   2425.8 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.2M  379M   1% /run
          /dev/mmcblk0p2 ext4       29G  5.3G   22G  20% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Tue Jun 11 20:29:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:3E:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=41700a7d-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
          [Tue Jun 11 20:29:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
          [Tue Jun 11 20:29:17 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET                                                  SOURCE         FSTYPE      OPTIONS
          /                                                       /dev/mmcblk0p2 ext4        rw,noatime
          |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
          | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
          |-/proc                                                 proc           proc        rw,relatime
          | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5380
          |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
          |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671308k,nr_inodes=417827,mode=755
          | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
          | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
          |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
          | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
          | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
          `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          640M    /var/
          206M    /var/cache
          200M    /var/cache/apt
          165M    /var/lib
          133M    /var/lib/apt/lists
          Archived and active journals take up 68.1M in the file system.
          /opt/iobroker/backups:
          36M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          702M    /opt/iobroker/iobroker-data/
          672M    /opt/iobroker/iobroker-data/files
          169M    /opt/iobroker/iobroker-data/files/vis-2
          138M    /opt/iobroker/iobroker-data/files/javascript.admin
          118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.14.0
          /usr/bin/node           v20.14.0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.1
          nodejs:
            Installed: 20.14.0-1nodesource1
            Candidate: 20.14.0-1nodesource1
            Version table:
           *** 20.14.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u1 500
               18.13.0+dfsg1-1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.13.16
          javascript:     8.3.1
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
            system.adapter.hue.1                    : hue                   : raspberrypi                              - disabled, port: 443
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
            system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
          Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "hue"          : 3.11.0   , installed 3.11.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
          Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
          Objects and States
          Objects:        5639
          States:         5073
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 1
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       379259     42074/io.sonoff.0
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       378305     42147/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4820       679/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       377951     41804/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       377946     41804/iobroker.js-c
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       400758     45178/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       376374     41919/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4822       679/sshd: /usr/sbin
          udp        0      0 0.0.0.0:53320           0.0.0.0:*                           104        895        526/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        893        526/avahi-daemon: r
          udp6       0      0 :::34751                :::*                                104        896        526/avahi-daemon: r
          udp6       0      0 fe80::92db:af89:7c1:546 :::*                                0          18972      612/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        894        526/avahi-daemon: r
          2024-06-12 15:32:57.107  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-06-12 15:32:57.107  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
          2024-06-12 15:33:18.219  - info: sonoff.0 (42074) Client [sOnOff_Tisch] connection closed: closed
          2024-06-12 15:33:18.628  - info: sonoff.0 (42074) Client [sOnOff_Tisch] connected with secret 1718199198626_1235
          2024-06-12 15:33:27.192  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 45635
          2024-06-12 15:33:29.831  - info: tr-064.0 (45635) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v20.14.0, js-controller: 5.0.19
          2024-06-12 15:33:30.920  - error: tr-064.0 (45635) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
          2024-06-12 15:33:30.922  - error: tr-064.0 (45635) ~
          2024-06-12 15:33:30.923  - error: tr-064.0 (45635) ~~ Fatal error. Can not connect to your FritzBox.
          2024-06-12 15:33:30.923  - error: tr-064.0 (45635) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
          2024-06-12 15:33:30.924  - error: tr-064.0 (45635) ~
          2024-06-12 15:33:30.926  - warn: tr-064.0 (45635) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
          2024-06-12 15:33:31.507  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-06-12 15:33:31.508  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
          2024-06-12 15:34:01.597  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 45926
          2024-06-12 15:34:08.282  - info: tr-064.0 (45926) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v20.14.0, js-controller: 5.0.19
          2024-06-12 15:34:09.476  - error: tr-064.0 (45926) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
          2024-06-12 15:34:09.477  - error: tr-064.0 (45926) ~
          2024-06-12 15:34:09.478  - error: tr-064.0 (45926) ~~ Fatal error. Can not connect to your FritzBox.
          2024-06-12 15:34:09.478  - error: tr-064.0 (45926) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
          2024-06-12 15:34:09.479  - error: tr-064.0 (45926) ~
          2024-06-12 15:34:09.481  - warn: tr-064.0 (45926) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
          2024-06-12 15:34:11.011  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-06-12 15:34:11.012  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
          2024-06-12 15:34:41.122  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 46761
          iob diag has finished.
            Homoran Global Moderator Administrators @Homoran last edited by
            @homoran sagte in IoBroker und VIS verweigert Zugriff:
            welche Controller Version steckt im Backup?
            Kam eine Meldung diesbezüglich?
              Nein! War einfach so alles weg....
              Also, dann nochmal. SD-Karte platt machen und komplett neu installieren. Ich hab ja jetzt Routine darin.
              • Ro75
                Ro75 @Ro75 last edited by Ro75
                @ro75 sagte in IoBroker und VIS verweigert Zugriff:
                @Routine - kann manchmal schwierig sein.
                Ro75.
                EDIT: Und bitte ein Netzteil anschließen.
                  Vor dem endgültigen Start des Restore kommt die Meldung
                    Na ja, ich hab ja schon einiges in der Vis erstellt, das war schon ganz gut für mich! entsprechend hatte ich ja auch schon Umgang mit der Erstellung einer Vis. Entsprechend bin ich jetzt auch völlig ratlos warum nichts mehr geht und ich auch keinen Weg finde alles wieder herzustellen...
                      @loco Bitte geh systematisch an die Installation ran.
                      Die vis ist im Backup. Die bekommst du ja wieder.
                        @Homoran :
                        Ich versuche jetzt so vorzugehen wie hier in diesem Chat von euch vorgeschlagen wurde!
                        Aber mal eine andere Frage, wenn ich einen Stand erreicht habe der für mich wichtig wäre, kann ich irgendwie ein Image von der SD-Karte erstellen? Damit würde ich oder evtl. auch andere die ähnliches durchlaufen viel Zeit sparen!
                        D.h. immer wenn ich einen Stand erreicht habe der wichtig wäre, würde ich ein neues Image der SD-Karte machen wollen. Wie könnte das gehen, mit welchen Tools - Backup und Restore!?
                        Aktuell läuft die Installation noch! Muß auch noch die fehlenden Adapter neu installieren. Denke morgen gehts weiter...
                        • Ro75
                          Das ist zweischneidig.
                          1. JA, es gibt Programme mit denen man die SD-Karte klonen kann. An dieser Stelle werde ich aber keine Werbung für eines dieser Programme machen. WEIL, falls sich irgendwelche Fehler (Software wie auch Hardware) eingeschlichen haben sollten, dann sind diese auch im Clone (Backup) mit drin und im Ernstfall würdest du dir die Fehler auf eine frische Karte ziehen!
                          2. Besser wäre Backitup einzurichten. Dann hast du im Ernstfall gleich mehrere Kopien einer Sicherung. Einmal lokal, einmal via FTP. Diese Sicherung läuft, wenn das alles korrekt eingerichtet, dann auch täglich.
                          Ro75.
                            Loco @Ro75 last edited by Loco
                            @ro75
                            Habe jetzt alles neu installiert, bekomme aber diese Fehlermeldungen beim starten der VIS. Was bedeutet das?
                            • Ro75
                              @loco das ist ok, ab dem zweiten Aufruf kommt diese Meldung nicht mehr.
                              Ro75.
                                @ro75
                                okay, aber meine VIS ist nicht da. Habe nur so eine "default-VIS". Mein Backup ist aber nicht da.
                                ich versuche jetzt mal dies: npm i iobroker.js-controller@4.0.24 --omit=dev --force
                                Ro75 Homoran 3 Replies Last reply Reply Quote 0
                                • Ro75
                                  @loco von wann ist die Backup-Datei?
                                    nein!!!
                                      @ro75
                                      9.6.2024 das wäre mein letzter Stand. Das ist aber auch die alte node.js Version enthalten 4xxxx
                                        @loco wir sind wieder an dem Punkt, an dem du schrittweise deutlich mehr Informationen geben solltest!
                                        hast du es denn eingespielt?
                                        davon schreibst du nichts und zeigst auch nichts.
                                        kam dabei eine Meldung, dss der Controller nicht kompatibel ist?
                                        gezeigt hast du wieder nichts, bevor du den Restore möglicherweise falsch gestartet hast.
                                        Möglicherweise ist der Restore auch wegen der vermuteten Inkompatibilität abgebrochen worden
                                        Eine entsprechende Meldung wäre in dem Output gewesen.
                                        Zeigen, zeigen, zeigen!
                                        nur dann kann man wirklich helfen.
                                          node 4???
                                          wir sind bei 20!
                                          • Ro75
                                            Ro75 @Homoran last edited by
                                            @homoran er meint sicherlich js-controller.
                                            11747
