Schedule wird nicht ausgeführt
@mimei sagte in Schedule wird nicht ausgeführt:
schedule('{"time":{"exactTime":true,"start":"09:43"},"period":{"days":1}}', async () => { console.log('Pumpe start neu'); });
schedule('{"time":{"exactTime":true,"start":"10:01"},"period":{"days":1}}', function RestartPumpe() { console.log('Pumpe start neu'); });und so?
Ro75.
@ro75 nichts, seltsam.
@mimei dann mach mal ein
iob diagund poste ALLEs hier in "CODE TAGS" rein. Dann kann hier ggfs. einer ein Problem erkennen.
Ro75.
@ro75 genügt dir das?
======================= SUMMARY ======================= v.2024-05-22 Static hostname: jportal1 Icon name: computer-vm Chassis: vm Virtualization: vmware Operating System: Ubuntu 20.04.6 LTS Kernel: Linux 5.4.0-182-generic Architecture: x86-64 Installation: vmware Kernel: x86_64 Userland: 64 bit Timezone: Etc/UTC (UTC, +0000) User-ID: 1000 Display-Server: false Boot Target: graphical.target Pending OS-Updates: 2 Pending iob updates: 2 Nodejs-Installation: /usr/bin/nodejs v18.20.3 /usr/bin/node v18.20.3 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 Recommended versions are nodejs 18.20.3 and npm 10.7.0 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 5.9G 3.4G 1.6G 1.0M 919M 2.3G Swap: 3.9G 38M 3.9G Total: 9.9G 3.4G 5.5G Active iob-Instances: 30 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.19 admin 6.13.16 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : jportal1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : jportal1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 11235 States: 9049 Size of iob-Database: 25M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== -
?? Da sollte doch was mit Europe/Berlin sein ?? + 2 Stunden
Ro75.
@ro75 Stimmt, ich habe mich zu sehr auf die Web-Oberfläche verlassen. Da wurde die korrekte Zeit wiedergegeben. Habe es auf OS-Ebene korrigiert. Dennoch wird weiterhin nichts ausgeführt.
spannenderweise funktioniert das hier:
schedule('{"time":{"start":"00:00","end":"24:00","mode":"minutes","interval":1},"period":{"days":1}}', async function () { console.log('pumpe 1 minute intervall'); });Muss also an der Uhrzeit liegen
@mimei mach von deiner VM mal ein neustart und danach nochmal
iob diagund dieses mal bitte ALLES, auch den REST
Ro75.
Bitte nicht irgendwas nachträglich ändern - da gibts irgendwann keinen Zusammenhang mehr.
Natürlich geht diese Variante - ist ja auch jede Minute. Dabei ist es egal ob die Uhr 2 Stunden zurück oder vor geht.
Deswegen, VM neu starten und nochmal
iob diagUnd dieses mal ALLES bitte.
Ro75.
@ro75 ok, ist aber eine ganze Menge
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.4.0-182-generic x86_64) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/pro System information as of Thu 13 Jun 2024 10:30:45 AM CEST System load: 0.31 Usage of /: 40.6% of 38.58GB Memory usage: 40% Swap usage: 0% Processes: 295 Users logged in: 0 IPv4 address for ens160: 192.168.2.131 IPv6 address for ens160: fd71:c0c8:f177:2b4f:4a:8bff:fec3:d1e7 * Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s just raised the bar for easy, resilient and secure K8s cluster deployment. https://ubuntu.com/engage/secure-kubernetes-at-the-edge Expanded Security Maintenance for Applications is not enabled. 15 updates can be applied immediately. To see these additional updates run: apt list --upgradable Enable ESM Apps to receive additional future security updates. See https://ubuntu.com/esm or run: sudo pro status New release '22.04.3 LTS' available. Run 'do-release-upgrade' to upgrade to it. Last login: Thu Jun 13 10:28:20 2024 from 192.168.2.95 pi@jportal1:~$ iob diag [sudo] password for pi: *** iob diag is starting up, please wait *** \|/-\|/-\| *** ioBroker Diagnosis *** Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen The following checks may give hints to potential malconfigurations or errors, please post them in our forum: https://forum.iobroker.net Just copy and paste the Summary Page, including the ``` characters at start and end. It helps us to help you! Press any key to continue======== Start marking the full check here =========
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: jportal1 Icon name: computer-vm Chassis: vm Virtualization: vmware Operating System: Ubuntu 20.04.6 LTS Kernel: Linux 5.4.0-182-generic Architecture: x86-64 model name : Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz Docker : false Virtualization : vmware Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 10:31:27 up 9 min, 1 user, load average: 0.16, 0.23, 0.14 CPU threads: 4 *** Time and Time Zones *** Local time: Thu 2024-06-13 10:31:27 CEST Universal time: Thu 2024-06-13 08:31:27 UTC RTC time: Thu 2024-06-13 08:31:27 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm cdrom sudo dip plugdev lxd User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 5.9G 2.3G 2.6G 1.0M 1.1G 3.4G Swap: 3.9G 0B 3.9G Total: 9.9G 2.3G 6.5G Active iob-Instances: 29 5929 M total memory 2268 M used memory 2490 M active memory 490 M inactive memory 2567 M free memory 102 M buffer memory 991 M swap cache 3934 M total swap 0 M used swap 3934 M free swap *** top - Table Of Processes *** top - 10:31:27 up 9 min, 1 user, load average: 0.16, 0.23, 0.14 Tasks: 289 total, 1 running, 288 sleeping, 0 stopped, 0 zombie %Cpu(s): 6.0 us, 3.0 sy, 0.0 ni, 91.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 5929.4 total, 2567.2 free, 2268.4 used, 1093.8 buff/cache MiB Swap: 3935.0 total, 3935.0 free, 0.0 used. 3392.3 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 2.9G 0 2.9G 0% /dev tmpfs tmpfs 593M 1.4M 592M 1% /run /dev/mapper/ubuntu--vg-ubuntu--lv ext4 39G 16G 21G 43% / tmpfs tmpfs 2.9G 0 2.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 2.9G 0 2.9G 0% /sys/fs/cgroup /dev/loop1 squashfs 56M 56M 0 100% /snap/core18/2823 /dev/sda2 ext4 974M 210M 697M 24% /boot /dev/loop2 squashfs 64M 64M 0 100% /snap/core20/2318 /dev/loop0 squashfs 56M 56M 0 100% /snap/core18/2812 /dev/loop3 squashfs 64M 64M 0 100% /snap/core20/2264 /dev/loop4 squashfs 71M 71M 0 100% /snap/lxd/21029 /dev/loop5 squashfs 92M 92M 0 100% /snap/lxd/24061 /dev/loop7 squashfs 39M 39M 0 100% /snap/snapd/21465 /dev/loop6 squashfs 39M 39M 0 100% /snap/snapd/21759 tmpfs tmpfs 593M 4.0K 593M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu Jun 13 10:21:33 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null) [Thu Jun 13 10:21:34 2024] EXT4-fs (dm-0): re-mounted. Opts: (null) [Thu Jun 13 10:21:35 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup tmpfs tmpfs ro,nosuid,nodev,noexec,mode=755 | | |-/sys/fs/cgroup/unified cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate | | |-/sys/fs/cgroup/systemd cgroup cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd | | |-/sys/fs/cgroup/cpu,cpuacct cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct | | |-/sys/fs/cgroup/cpuset cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpuset | | |-/sys/fs/cgroup/hugetlb cgroup cgroup rw,nosuid,nodev,noexec,relatime,hugetlb | | |-/sys/fs/cgroup/memory cgroup cgroup rw,nosuid,nodev,noexec,relatime,memory | | |-/sys/fs/cgroup/freezer cgroup cgroup rw,nosuid,nodev,noexec,relatime,freezer | | |-/sys/fs/cgroup/net_cls,net_prio cgroup cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio | | |-/sys/fs/cgroup/blkio cgroup cgroup rw,nosuid,nodev,noexec,relatime,blkio | | |-/sys/fs/cgroup/perf_event cgroup cgroup rw,nosuid,nodev,noexec,relatime,perf_event | | |-/sys/fs/cgroup/pids cgroup cgroup rw,nosuid,nodev,noexec,relatime,pids | | |-/sys/fs/cgroup/rdma cgroup cgroup rw,nosuid,nodev,noexec,relatime,rdma | | `-/sys/fs/cgroup/devices cgroup cgroup rw,nosuid,nodev,noexec,relatime,devices | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime | `-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,nosuid,nodev,noexec,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18617 | `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime |-/dev udev devtmpfs rw,nosuid,noexec,relatime,size=2989104k,nr_inodes=747276,mode=755 | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/hugepages hugetlbfs hugetlbfs rw,relatime,pagesize=2M | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=607176k,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | |-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=607172k,mode=700,uid=1000,gid=1000 | `-/run/snapd/ns tmpfs[/snapd/ns] tmpfs rw,nosuid,nodev,noexec,relatime,size=607176k,mode=755 | `-/run/snapd/ns/lxd.mnt nsfs[mnt:[4026532709]] nsfs rw |-/snap/core18/2823 /dev/loop1 squashfs ro,nodev,relatime |-/boot /dev/sda2 ext4 rw,relatime |-/snap/core20/2318 /dev/loop2 squashfs ro,nodev,relatime |-/snap/core18/2812 /dev/loop0 squashfs ro,nodev,relatime |-/snap/core20/2264 /dev/loop3 squashfs ro,nodev,relatime |-/snap/lxd/21029 /dev/loop4 squashfs ro,nodev,relatime |-/snap/lxd/24061 /dev/loop5 squashfs ro,nodev,relatime |-/snap/snapd/21465 /dev/loop7 squashfs ro,nodev,relatime `-/snap/snapd/21759 /dev/loop6 squashfs ro,nodev,relatime Files in neuralgic directories: /var: 5.0G /var/ 3.9G /var/log/journal/7cd3af3334434c68840140c756f4a504 3.9G /var/log/journal 3.9G /var/log 940M /var/lib Archived and active journals take up 3.8G in the file system. /opt/iobroker/backups: 84M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 713M /opt/iobroker/iobroker-data/ 582M /opt/iobroker/iobroker-data/files 149M /opt/iobroker/iobroker-data/files/vis-2 138M /opt/iobroker/iobroker-data/files/javascript.admin 118M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 38M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json 28M /opt/iobroker/iobroker-data/objects.jsonl 25M /opt/iobroker/iobroker-data/states.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014DA4A7A-if00 /dev/serial/by-id/usb-0658_0200-if00 HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyACM1 *** NodeJS-Installation *** /usr/bin/nodejs v18.20.3 /usr/bin/node v18.20.3 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.3-1nodesource1 Candidate: 18.20.3-1nodesource1 Version table: *** 18.20.3-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.20.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.20.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.20.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.19.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 10.19.0~dfsg-3ubuntu1.6 500 500 http://ch.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages 500 http://ch.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages 10.19.0~dfsg-3ubuntu1 500 500 http://ch.archive.ubuntu.com/ubuntu focal/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.19 admin: 6.13.16 javascript: 8.3.1 nodejs modules from github: 1 +-- iobroker.yahka@1.0.3 (git+ssh://git@github.com/mimeie/ioBroker.yahka.git#ec6793f07f0582431a8acc9e68774e8e26142d52) Adapter State + system.adapter.admin.0 : admin : jportal1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : jportal1 - enabled + system.adapter.bring.0 : bring : jportal1 - enabled system.adapter.cloud.0 : cloud : jportal1 - disabled system.adapter.devices.0 : devices : jportal1 - enabled + system.adapter.discovery.0 : discovery : jportal1 - enabled system.adapter.flot.0 : flot : jportal1 - disabled + system.adapter.followthesun.0 : followthesun : jportal1 - enabled + system.adapter.history.0 : history : jportal1 - enabled + system.adapter.influxdb.0 : influxdb : jportal1 - enabled, port: 80 + system.adapter.info.0 : info : jportal1 - enabled + system.adapter.iot.0 : iot : jportal1 - enabled + system.adapter.javascript.0 : javascript : jportal1 - enabled + system.adapter.logparser.0 : logparser : jportal1 - enabled + system.adapter.lovelace.0 : lovelace : jportal1 - enabled, port: 8091, bind: 0.0.0.0, run as: admin system.adapter.meteoalarm.0 : meteoalarm : jportal1 - enabled system.adapter.mobile.0 : mobile : jportal1 - disabled + system.adapter.modbus.0 : modbus : jportal1 - enabled system.adapter.netatmo-crawler.0 : netatmo-crawler : jportal1 - enabled + system.adapter.netatmo.0 : netatmo : jportal1 - enabled system.adapter.openweathermap.0 : openweathermap : jportal1 - enabled + system.adapter.ping.0 : ping : jportal1 - enabled system.adapter.plex.0 : plex : jportal1 - disabled + system.adapter.pushover.0 : pushover : jportal1 - enabled + system.adapter.shelly.0 : shelly : jportal1 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : jportal1 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.smartgarden.0 : smartgarden : jportal1 - disabled + system.adapter.sonos.0 : sonos : jportal1 - enabled + system.adapter.sprinklecontrol.0 : sprinklecontrol : jportal1 - enabled + system.adapter.statistics.0 : statistics : jportal1 - enabled + system.adapter.vis-2.0 : vis-2 : jportal1 - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : jportal1 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : jportal1 - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : jportal1 - disabled system.adapter.vis-justgage.0 : vis-justgage : jportal1 - disabled system.adapter.vis.0 : vis : jportal1 - enabled + system.adapter.vw-connect.0 : vw-connect : jportal1 - enabled + system.adapter.web.0 : web : jportal1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.worx.0 : worx : jportal1 - enabled + system.adapter.yahka.0 : yahka : jportal1 - enabled + system.adapter.zigbee.0 : zigbee : jportal1 - enabled, port: /dev/ttyACM1 + system.adapter.zwave2.0 : zwave2 : jportal1 - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : jportal1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : jportal1 - enabled + system.adapter.bring.0 : bring : jportal1 - enabled system.adapter.devices.0 : devices : jportal1 - enabled + system.adapter.discovery.0 : discovery : jportal1 - enabled + system.adapter.followthesun.0 : followthesun : jportal1 - enabled + system.adapter.history.0 : history : jportal1 - enabled + system.adapter.influxdb.0 : influxdb : jportal1 - enabled, port: 80 + system.adapter.info.0 : info : jportal1 - enabled + system.adapter.iot.0 : iot : jportal1 - enabled + system.adapter.javascript.0 : javascript : jportal1 - enabled + system.adapter.logparser.0 : logparser : jportal1 - enabled + system.adapter.lovelace.0 : lovelace : jportal1 - enabled, port: 8091, bind: 0.0.0.0, run as: admin system.adapter.meteoalarm.0 : meteoalarm : jportal1 - enabled + system.adapter.modbus.0 : modbus : jportal1 - enabled system.adapter.netatmo-crawler.0 : netatmo-crawler : jportal1 - enabled + system.adapter.netatmo.0 : netatmo : jportal1 - enabled system.adapter.openweathermap.0 : openweathermap : jportal1 - enabled + system.adapter.ping.0 : ping : jportal1 - enabled + system.adapter.pushover.0 : pushover : jportal1 - enabled + system.adapter.shelly.0 : shelly : jportal1 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : jportal1 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonos.0 : sonos : jportal1 - enabled + system.adapter.sprinklecontrol.0 : sprinklecontrol : jportal1 - enabled + system.adapter.statistics.0 : statistics : jportal1 - enabled + system.adapter.vis-2.0 : vis-2 : jportal1 - enabled system.adapter.vis.0 : vis : jportal1 - enabled + system.adapter.vw-connect.0 : vw-connect : jportal1 - enabled + system.adapter.web.0 : web : jportal1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.worx.0 : worx : jportal1 - enabled + system.adapter.yahka.0 : yahka : jportal1 - enabled + system.adapter.zigbee.0 : zigbee : jportal1 - enabled, port: /dev/ttyACM1 + system.adapter.zwave2.0 : zwave2 : jportal1 - enabled ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "bring" : 1.8.4 , installed 1.8.4 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.5.0 , installed 4.4.0 [Updatable] Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.0 , installed 0.5.0 Adapter "fullcalendar" : 2.3.4 , installed 2.3.4 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "javascript" : 8.3.1 , installed 8.3.1 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "logparser" : 2.2.2 , installed 2.2.2 Adapter "lovelace" : 4.1.8 , installed 4.1.8 Adapter "meteoalarm" : 3.0.2 , installed 3.0.2 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "modbus" : 6.1.0 , installed 6.1.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "onvif" : 1.1.3 , installed 1.1.3 Adapter "openweathermap": 1.0.4 , installed 1.0.4 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "plex" : 1.1.4 , installed 1.1.4 Adapter "pushover" : 3.0.6 , installed 3.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartgarden" : 2.0.0 , installed 2.0.0 Adapter "socketio" : 6.7.0 , installed 6.7.0 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "sprinklecontrol": 0.2.13 , installed 0.2.13 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "vis" : 1.5.6 , installed 1.5.4 [Updatable] Adapter "vis-2" : 2.9.32 , installed 2.9.32 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "worx" : 3.0.2 , installed 3.0.2 Adapter "ws" : 2.6.1 , installed 2.6.1 Adapter "yahka" : 1.0.3 , installed 1.85.6 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Adapter "zwave2" : 3.1.0 , installed 3.1.0 Objects and States Please stand by - This may take a while Objects: 11235 States: 9068 *** OS-Repositories and Updates *** Hit:1 http://ch.archive.ubuntu.com/ubuntu focal InRelease Hit:2 http://ch.archive.ubuntu.com/ubuntu focal-updates InRelease Hit:3 http://ch.archive.ubuntu.com/ubuntu focal-backports InRelease Hit:4 http://ch.archive.ubuntu.com/ubuntu focal-security InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 2 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 17495 1/init tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 101 23908 863/systemd-resolve tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 27491 997/sshd: /usr/sbin tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 30327 1386/io.shelly.0 tcp 0 0 127.0.0.1:42269 0.0.0.0:* LISTEN 1001 38514 2292/io.yahka.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 25298 932/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 25290 932/iobroker.js-con tcp6 0 0 :::111 :::* LISTEN 0 16716 1/init tcp6 0 0 :::8081 :::* LISTEN 1001 29841 1128/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 38486 2275/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 27493 997/sshd: /usr/sbin tcp6 0 0 :::8087 :::* LISTEN 1001 36049 2176/io.simple-api. tcp6 0 0 :::8091 :::* LISTEN 1001 38572 2327/io.lovelace.0 tcp6 0 0 :::42277 :::* LISTEN 1001 38507 2292/io.yahka.0 tcp6 0 0 :::3500 :::* LISTEN 1001 33354 1403/io.sonos.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 119 24121 875/avahi-daemon: r udp 0 0 0.0.0.0:59580 0.0.0.0:* 119 24123 875/avahi-daemon: r udp 0 0 127.0.0.53:53 0.0.0.0:* 101 23907 863/systemd-resolve udp 0 0 192.168.2.131:68 0.0.0.0:* 100 23900 861/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 16713 1/init udp6 0 0 :::45337 :::* 119 24124 875/avahi-daemon: r udp6 0 0 :::5353 :::* 119 24122 875/avahi-daemon: r udp6 0 0 :::111 :::* 0 15947 1/init *** Log File - Last 25 Lines *** 2024-06-13 10:31:37.943 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.77 (shellyswitch25 / shellyswitch25-E09806955090 / SHSW-25#E09806955090#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:38.299 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.160 (shelly1 / shelly1-E8DB84D653CE / SHSW-1#E8DB84D653CE#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:38.635 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.128 (shelly1 / shelly1-8CAAB5614780 / SHSW-1#8CAAB5614780#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:38.824 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.70 (shellyplus1 / shellyplus1-441793a902c8 / shellyplus1#441793a902c8#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:39.285 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.159 (shellyswitch25 / shellyswitch25-98CDAC1F29E8 / SHSW-25#98CDAC1F29E8#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:40.976 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.90 (shellyswitch25 / shellyswitch25-4C752532EF87 / SHSW-25#4C752532EF87#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.179 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.81 (shelly1minig3 / shelly1minig3-84fce637a9a8 / shelly1minig3#84fce637a9a8#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.218 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.85 (shellyplus1pm / shellyplus1pm-7c87ce65ced0 / shellyplus1pm#7c87ce65ced0#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.322 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.109 (shellyswitch25 / shellyswitch25-D8BFC01A2FCA / SHSW-25#D8BFC01A2FCA#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.527 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.130 (shellyem / shellyem-34945477FCE1 / SHEM#34945477FCE1#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.574 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.41 (shellyem3 / shellyem3-244CAB43606C / SHEM-3#244CAB43606C#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.656 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.107 (shellyplus2pm / shellyplus2pm-c049ef8b43d4 / shellyplus2pm#c049ef8b43d4#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:41.756 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.144 (shellydimmer2 / shellydimmer2-349454723A33 / SHDM-2#349454723A33#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:42.467 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.150 (shellydimmer2 / shellydimmer2-3494547236C5 / SHDM-2#3494547236C5#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:43.697 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.160 (shelly1 / shelly1-E8DB84D653CE / SHSW-1#E8DB84D653CE#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:43.749 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.132 (shellyswitch25 / shellyswitch25-3C6105E55D18 / SHSW-25#3C6105E55D18#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:43.966 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.128 (shelly1 / shelly1-8CAAB5614780 / SHSW-1#8CAAB5614780#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:44.070 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.70 (shellyplus1 / shellyplus1-441793a902c8 / shellyplus1#441793a902c8#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:46.458 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.81 (shelly1minig3 / shelly1minig3-84fce637a9a8 / shelly1minig3#84fce637a9a8#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:46.486 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.85 (shellyplus1pm / shellyplus1pm-7c87ce65ced0 / shellyplus1pm#7c87ce65ced0#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:46.820 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.41 (shellyem3 / shellyem3-244CAB43606C / SHEM-3#244CAB43606C#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:46.860 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.130 (shellyem / shellyem-34945477FCE1 / SHEM#34945477FCE1#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:46.901 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.144 (shellydimmer2 / shellydimmer2-349454723A33 / SHDM-2#349454723A33#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:47.031 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.107 (shellyplus2pm / shellyplus2pm-c049ef8b43d4 / shellyplus2pm#c049ef8b43d4#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration 2024-06-13 10:31:47.727 - info: shelly.0 (1386) [Sys.timezone] 192.168.2.150 (shellydimmer2 / shellydimmer2-3494547236C5 / SHDM-2#3494547236C5#1): Configured timezone "Europe/Zurich" and system timezone "Europe/Berlin" do not match. Please check configuration============ Mark until here for C&P =============
iob diag has finished.
Press any key for a summary
Copy text starting here:
======================= SUMMARY ======================= v.2024-05-22 Static hostname: jportal1 Icon name: computer-vm Chassis: vm Virtualization: vmware Operating System: Ubuntu 20.04.6 LTS Kernel: Linux 5.4.0-182-generic Architecture: x86-64 Installation: vmware Kernel: x86_64 Userland: 64 bit Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 Display-Server: false Boot Target: graphical.target Pending OS-Updates: 2 Pending iob updates: 2 Nodejs-Installation: /usr/bin/nodejs v18.20.3 /usr/bin/node v18.20.3 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 Recommended versions are nodejs 18.20.3 and npm 10.7.0 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 5.9G 2.2G 2.6G 1.0M 1.1G 3.4G Swap: 3.9G 0B 3.9G Total: 9.9G 2.2G 6.5G Active iob-Instances: 29 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.19 admin 6.13.16 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : jportal1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : jportal1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 11235 States: 9068 Size of iob-Database: 28M /opt/iobroker/iobroker-data/objects.jsonl 25M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ======================= Mark text until here for copying ===
pi@jportal1:~$ -
@mimei wenn du in den shellies Zürich als Zeitzone hast, solltest du nicht nach Berlin umziehen.
Du darfst auch den Server in Zürich lassen -
@homoran danke, habe gerade die Meldungen gesehen. Ich bereinige jetzt das sauber nach Zürich und mache dann nochmals eine Diagnose
Es funktioniert nun in allen Varianten. Danke vielmals!
