    4. Beta Test js-controller Kiera (v6.0)
      todde @da_Woody last edited by todde
      @da_woody genau das gleiche Problem hatte ich auch in der Kombination js-controller 6.0.3 und javascript 8.5.2. Ich bin deshalb wieder zurück auf 6.0.2.
      Im Log stand:
      2024-06-13 06:05:08.734 - info: javascript.0 (2051145) starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
      2024-06-13 06:05:08.957 - error: javascript.0 (2051145) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-06-13 06:05:08.961 - error: javascript.0 (2051145) unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/cheerio/package.json
      2024-06-13 06:05:08.962 - error: javascript.0 (2051145) Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/cheerio/package.json
      at exportsNotFound (node:internal/modules/esm/resolve:304:10)
      at packageExportsResolve (node:internal/modules/esm/resolve:651:9)
      at resolveExports (node:internal/modules/cjs/loader:592:36)
      at Function.Module._findPath (node:internal/modules/cjs/loader:669:31)
      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27)
      at Function.resolve (node:internal/modules/helpers:190:19)
      at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34)
      at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
      2024-06-13 06:05:08.964 - error: javascript.0 (2051145) Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/cheerio/package.json
      2024-06-13 06:05:09.028 - info: javascript.0 (2051145) terminating
      2024-06-13 06:05:09.030 - warn: javascript.0 (2051145) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-06-13 06:05:09.526 - info: javascript.0 (2051145) terminating
      2024-06-13 06:05:10.159 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-06-13 06:05:10.160 - error: host.iobroker Caught by controller[1]: Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/cheerio/package.json
      2024-06-13 06:05:10.160 - error: host.iobroker Caught by controller[1]: at exportsNotFound (node:internal/modules/esm/resolve:304:10)
      2024-06-13 06:05:10.161 - error: host.iobroker Caught by controller[1]: at packageExportsResolve (node:internal/modules/esm/resolve:651:9)
      2024-06-13 06:05:10.161 - error: host.iobroker Caught by controller[1]: at resolveExports (node:internal/modules/cjs/loader:592:36)
      2024-06-13 06:05:10.161 - error: host.iobroker Caught by controller[1]: at Function.Module._findPath (node:internal/modules/cjs/loader:669:31)
      2024-06-13 06:05:10.162 - error: host.iobroker Caught by controller[1]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27)
      2024-06-13 06:05:10.162 - error: host.iobroker Caught by controller[1]: at Function.resolve (node:internal/modules/helpers:190:19)
      2024-06-13 06:05:10.163 - error: host.iobroker Caught by controller[1]: at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34)
      2024-06-13 06:05:10.163 - error: host.iobroker Caught by controller[1]: at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
      2024-06-13 06:05:10.163 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      Issue in GitHub beim Javascript Adapter ist offen
      https://github.com/ioBroker/ioBroker.javascript/issues/1610
      todde99 created this issue in ioBroker/ioBroker.javascript
      closed [Bug]: Adapter does not start with js-controller 6.0.3 #1610
      MalleRalle foxriver76 2 Replies Last reply Reply Quote 0
      • MalleRalle
        MalleRalle @todde last edited by MalleRalle
        Ich habe auch noch einen Adapter gefunden der nicht mehr läuft
        epson_workforce ( https://github.com/rrov1/ioBroker.epson_workforce)
        host.rockpro64
        2024-06-13 08:25:48.407	error	instance system.adapter.epson_workforce.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: Node.js v20.14.0
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
        host.rockpro64
        2024-06-13 08:25:48.407	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.epson_workforce/main.js:14:21)
        host.rockpro64
        2024-06-13 08:25:48.406	error	Caught by controller[0]: TypeError: utils.Adapter is not a function
        host.rockpro64
        2024-06-13 08:25:48.406	error	Caught by controller[0]: ^
        host.rockpro64
        2024-06-13 08:25:48.406	error	Caught by controller[0]: var adapter = utils.Adapter({
        host.rockpro64
        2024-06-13 08:25:48.406	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.epson_workforce/main.js:14
        • foxriver76
          foxriver76 Developer @todde last edited by
          @todde ja es wird eine 6.0.4 kommen heute die das fixt
          • foxriver76
            foxriver76 Developer @Diamand2k22 last edited by foxriver76
            @diamand2k22 sagte in Beta Test js-controller Kiera (v6.0):
            ioBroker.blueconnect
            Den gibts aber nicht im Repository so wie ich das sehe. Evtl. hier ein Issue machen https://github.com/mameier1234/ioBroker.blueconnect/issues
            • foxriver76
              foxriver76 Developer @MalleRalle last edited by
              @malleralle Ebenfalls nicht im Repo, hilft nur auf GitHub forken, adapter-core upgraden und von dort neu installieren.
              mcm1957 MalleRalle 2 Replies Last reply Reply Quote 1
              • mcm1957
                mcm1957 @foxriver76 last edited by
                Bitte bei Adaptern die nicht im Repository ( zumindest im LATEST) sind direkt an die Entwickler wenden. Nicht umsonst wird immer Wieder drauf hingewiesen NICHT von Github zu installieren ausser uf Anrwgung bzw in Abstimmung mit dem Dev. Und wenn es einen Adapter gibt der nicht im Repo ust Bitte den Dev ersuchen eine Aufnahme zu veranlassen.
                GitHub Only Adapter können (müssen aber natürlich nicht) beliebige Inkompatibilitäten aufweisen.
                  fuchs1978 @fuchs1978 last edited by
                  @fuchs1978 said in Beta Test js-controller Kiera (v6.0):
                  Ich habe in 6.0.3 wieder ein Problem mit den NPM Modulen die eingebettet sind:
                  https://forum.iobroker.net/topic/75258/nochmal-npm-module-im-controller-6-0-3/1
                  Mit 6.0.4 geht's wieder, Dankeschön
                    DerGraf123 last edited by
                    Hallo Zusammen,
                    habe gerade mal 6.0.4 ausprobiert.
                    Bei mir laufen "sql", "yamaha" und "daikin" nicht.
                    Back to 5.0.19 und alles ist wieder tutti 🙂
                    Gruß DerGraf
                    Feuersturm foxriver76 2 Replies Last reply Reply Quote 0
                    • Feuersturm
                      Feuersturm @DerGraf123 last edited by
                      @dergraf123 mit dieser Fehlermeldung kann man die Probleme nicht lösen 😉
                      • foxriver76
                        foxriver76 Developer @DerGraf123 last edited by
                        @dergraf123 gibt’s da auch ein log zu?
                          DerGraf123 @foxriver76 last edited by
                          Hier die Logs zu den Adaptern:
                          SQL:
                          host.iobroker
                          2024-06-13 18:57:32.129	info	Restart adapter system.adapter.sql.0 because enabled
                          host.iobroker
                          2024-06-13 18:57:32.128	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[1]: Node.js v20.14.0
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:3481:5)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.sql/main.js:111:15)
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: ^
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: adapter = new utils.Adapter(options);
                          host.iobroker
                          2024-06-13 18:57:32.128	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sql/main.js:111
                          host.iobroker
                          2024-06-13 18:57:31.674	info	instance system.adapter.sql.0 started with pid 2283
                          YAMAHA:
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          host.iobroker
                          DAIKIN:
                          host.iobroker
                          2024-06-13 19:00:37.371	info	Restart adapter system.adapter.daikin.0 because enabled
                          host.iobroker
                          2024-06-13 19:00:37.371	error	instance system.adapter.daikin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[1]: Node.js v20.14.0
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          host.iobroker
                          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.daikin/daikin.js:661:5)
                          host.iobroker
                          2024-06-13 19:00:37.370	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.daikin/daikin.js:229:15)
                          host.iobroker
                          2024-06-13 19:00:37.370	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                          host.iobroker
                          2024-06-13 19:00:37.370	error	Caught by controller[0]: ^
                          host.iobroker
                          2024-06-13 19:00:37.370	error	Caught by controller[0]: adapter = new utils.Adapter(options);
                          host.iobroker
                          2024-06-13 19:00:37.370	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.daikin/daikin.js:229
                          host.iobroker
                          2024-06-13 19:00:36.950	info	instance system.adapter.daikin.0 started with pid 2779
                          A mcm1957 2 Replies Last reply Reply Quote 2
                            ag @DerGraf123 last edited by
                            Hallo.
                            Gerade Master und 2 Slaves auf 6.0.4 aktualisiert.
                            Alle installierten Instances laufen.
                            • mcm1957
                              mcm1957 @DerGraf123 last edited by mcm1957
                              @dergraf123
                              Sorry im moment nur handy.
                              Aber falls noch nicht gepostet bitte die Versionen der Adapter posten.
                              yahama braucht nen Update -> @Garfonso
                              da du als Maintainer dort drinnen stehst hab ich den beim Cleanup der community Adapters nicht aktualissiert. Bitte so bald als möglich adapter-core und teste etc. aktualisierern. Danke
                              daiki hat core 3.0.4 drinne, sollte eigentlich passen -> @apollon77
                              wenn du Zeit hast ev trotzdem auf 3.1.4/6 hochziehen
                              sql hat adapter-core": "^3.0.3" drinnen, sollte eigentlich passen. -> @foxriver76
                              ev. hochziehen? Aber an sich sollte 3.x.x ja passen!?!?
                              foxriver76 1 Reply Last reply Reply Quote 1
                              • foxriver76
                                foxriver76 Developer @mcm1957 last edited by foxriver76
                                @mcm1957 Daikin hat leider im Release 2.6.0, SQL auch 2.6.0
                                • mcm1957
                                  mcm1957 @foxriver76 last edited by mcm1957
                                  @foxriver76 said in Beta Test js-controller Kiera (v6.0):
                                  Sorry,
                                  Auf das hab ich nicht geschaut. Red dich bitte mit @Apollon77 wg. Daikin zusammen.
                                  Bin nur temporär im Netz da openliga ne prioUpdate (wg. EM) brauchte.
                                  • foxriver76
                                    SQL 3.0.1 sollte laufen
                                    • Feuersturm
                                      Feuersturm last edited by
                                      @foxriver76 Update von 6.0.2 auf 6.0.4 war auf beiden Testsystemen erfolgreich.
                                      Es kam blieb nach dem Update aber diese Meldung stehen
                                      • da_Woody
                                        da_Woody @Thomas Braun last edited by
                                        @thomas-braun sorry, konnte gestern nicht mehr weiter machen...
                                        gerade versucht javascript neu zu starten mit folgendem log:
                                        javascript.0
                                        2024-06-14 05:43:13.308	info	terminating
                                        javascript.0
                                        2024-06-14 05:43:12.810	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        javascript.0
                                        2024-06-14 05:43:12.809	info	terminating
                                        javascript.0
                                        2024-06-14 05:43:12.707	error	Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                                        javascript.0
                                        2024-06-14 05:43:12.706	error	Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json at exportsNotFound (node:internal/modules/esm/resolve:304:10) at packageExportsResolve (node:internal/modules/esm/resolve:651:9) at resolveExports (node:internal/modules/cjs/loader:592:36) at Function.Module._findPath (node:internal/modules/cjs/loader:669:31) at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27) at Function.resolve (node:internal/modules/helpers:190:19) at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34) at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
                                        javascript.0
                                        2024-06-14 05:43:12.706	error	unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                                        javascript.0
                                        2024-06-14 05:43:12.706	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        javascript.0
                                        2024-06-14 05:43:12.674	info	starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
                                        javascript.0
                                        2024-06-14 05:42:39.592	info	terminating
                                        javascript.0
                                        2024-06-14 05:42:39.092	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        javascript.0
                                        2024-06-14 05:42:39.091	info	terminating
                                        javascript.0
                                        2024-06-14 05:42:38.973	error	Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                                        javascript.0
                                        2024-06-14 05:42:38.972	error	Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json at exportsNotFound (node:internal/modules/esm/resolve:304:10) at packageExportsResolve (node:internal/modules/esm/resolve:651:9) at resolveExports (node:internal/modules/cjs/loader:592:36) at Function.Module._findPath (node:internal/modules/cjs/loader:669:31) at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27) at Function.resolve (node:internal/modules/helpers:190:19) at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34) at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
                                        javascript.0
                                        2024-06-14 05:42:38.972	error	unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                                        javascript.0
                                        2024-06-14 05:42:38.971	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        javascript.0
                                        2024-06-14 05:42:38.912	info	starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
                                        • foxriver76
                                          foxriver76 Developer @da_Woody last edited by
                                          @da_woody bitte einfach auf 6.0.4 upgraden
                                          • foxriver76
                                            foxriver76 Developer @Feuersturm last edited by
                                            @feuersturm Hier wäre das Browser Log interessant falls es wieder passiert.
                                            beta js-controller kiera test
                                            39
                                            331
                                            73574
