    4. Beta Test js-controller Kiera (v6.0)
    • Feuersturm
      Feuersturm @DerGraf123 last edited by
      @dergraf123 mit dieser Fehlermeldung kann man die Probleme nicht lösen 😉
      • foxriver76
        foxriver76 Developer @DerGraf123 last edited by
        @dergraf123 gibt’s da auch ein log zu?
          DerGraf123 @foxriver76 last edited by
          Hier die Logs zu den Adaptern:
          SQL:
          host.iobroker
          2024-06-13 18:57:32.129	info	Restart adapter system.adapter.sql.0 because enabled
          host.iobroker
          2024-06-13 18:57:32.128	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[1]: Node.js v20.14.0
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:3481:5)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.sql/main.js:111:15)
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: ^
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: adapter = new utils.Adapter(options);
          host.iobroker
          2024-06-13 18:57:32.128	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sql/main.js:111
          host.iobroker
          2024-06-13 18:57:31.674	info	instance system.adapter.sql.0 started with pid 2283
          YAMAHA:
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          DAIKIN:
          host.iobroker
          2024-06-13 19:00:37.371	info	Restart adapter system.adapter.daikin.0 because enabled
          host.iobroker
          2024-06-13 19:00:37.371	error	instance system.adapter.daikin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[1]: Node.js v20.14.0
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.iobroker
          2024-06-13 19:00:37.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.daikin/daikin.js:661:5)
          host.iobroker
          2024-06-13 19:00:37.370	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.daikin/daikin.js:229:15)
          host.iobroker
          2024-06-13 19:00:37.370	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
          host.iobroker
          2024-06-13 19:00:37.370	error	Caught by controller[0]: ^
          host.iobroker
          2024-06-13 19:00:37.370	error	Caught by controller[0]: adapter = new utils.Adapter(options);
          host.iobroker
          2024-06-13 19:00:37.370	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.daikin/daikin.js:229
          host.iobroker
          2024-06-13 19:00:36.950	info	instance system.adapter.daikin.0 started with pid 2779
          A mcm1957 2 Replies Last reply Reply Quote 2
            ag @DerGraf123 last edited by
            Hallo.
            Gerade Master und 2 Slaves auf 6.0.4 aktualisiert.
            Alle installierten Instances laufen.
            • mcm1957
              mcm1957 @DerGraf123 last edited by mcm1957
              @dergraf123
              Sorry im moment nur handy.
              Aber falls noch nicht gepostet bitte die Versionen der Adapter posten.
              yahama braucht nen Update -> @Garfonso
              da du als Maintainer dort drinnen stehst hab ich den beim Cleanup der community Adapters nicht aktualissiert. Bitte so bald als möglich adapter-core und teste etc. aktualisierern. Danke
              daiki hat core 3.0.4 drinne, sollte eigentlich passen -> @apollon77
              wenn du Zeit hast ev trotzdem auf 3.1.4/6 hochziehen
              sql hat adapter-core": "^3.0.3" drinnen, sollte eigentlich passen. -> @foxriver76
              ev. hochziehen? Aber an sich sollte 3.x.x ja passen!?!?
              foxriver76 1 Reply Last reply Reply Quote 1
              • foxriver76
                foxriver76 Developer @mcm1957 last edited by foxriver76
                @mcm1957 Daikin hat leider im Release 2.6.0, SQL auch 2.6.0
                • mcm1957
                  mcm1957 @foxriver76 last edited by mcm1957
                  @foxriver76 said in Beta Test js-controller Kiera (v6.0):
                  Sorry,
                  Auf das hab ich nicht geschaut. Red dich bitte mit @Apollon77 wg. Daikin zusammen.
                  Bin nur temporär im Netz da openliga ne prioUpdate (wg. EM) brauchte.
                  • foxriver76
                    SQL 3.0.1 sollte laufen
                    • Feuersturm
                      Feuersturm last edited by
                      @foxriver76 Update von 6.0.2 auf 6.0.4 war auf beiden Testsystemen erfolgreich.
                      Es kam blieb nach dem Update aber diese Meldung stehen
                      • da_Woody
                        da_Woody @Thomas Braun last edited by
                        @thomas-braun sorry, konnte gestern nicht mehr weiter machen...
                        gerade versucht javascript neu zu starten mit folgendem log:
                        javascript.0
                        2024-06-14 05:43:13.308	info	terminating
                        javascript.0
                        2024-06-14 05:43:12.810	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        javascript.0
                        2024-06-14 05:43:12.809	info	terminating
                        javascript.0
                        2024-06-14 05:43:12.707	error	Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                        javascript.0
                        2024-06-14 05:43:12.706	error	Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json at exportsNotFound (node:internal/modules/esm/resolve:304:10) at packageExportsResolve (node:internal/modules/esm/resolve:651:9) at resolveExports (node:internal/modules/cjs/loader:592:36) at Function.Module._findPath (node:internal/modules/cjs/loader:669:31) at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27) at Function.resolve (node:internal/modules/helpers:190:19) at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34) at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
                        javascript.0
                        2024-06-14 05:43:12.706	error	unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                        javascript.0
                        2024-06-14 05:43:12.706	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        javascript.0
                        2024-06-14 05:43:12.674	info	starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
                        javascript.0
                        2024-06-14 05:42:39.592	info	terminating
                        javascript.0
                        2024-06-14 05:42:39.092	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        javascript.0
                        2024-06-14 05:42:39.091	info	terminating
                        javascript.0
                        2024-06-14 05:42:38.973	error	Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                        javascript.0
                        2024-06-14 05:42:38.972	error	Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json at exportsNotFound (node:internal/modules/esm/resolve:304:10) at packageExportsResolve (node:internal/modules/esm/resolve:651:9) at resolveExports (node:internal/modules/cjs/loader:592:36) at Function.Module._findPath (node:internal/modules/cjs/loader:669:31) at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27) at Function.resolve (node:internal/modules/helpers:190:19) at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34) at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
                        javascript.0
                        2024-06-14 05:42:38.972	error	unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
                        javascript.0
                        2024-06-14 05:42:38.971	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        javascript.0
                        2024-06-14 05:42:38.912	info	starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
                        • foxriver76
                          foxriver76 Developer @da_Woody last edited by
                          @da_woody bitte einfach auf 6.0.4 upgraden
                          • foxriver76
                            foxriver76 Developer @Feuersturm last edited by
                            @feuersturm Hier wäre das Browser Log interessant falls es wieder passiert.
                            • da_Woody
                              da_Woody @foxriver76 last edited by
                              @foxriver76 wurde mir gerade angeboten, gemacht, alle adapter grün! 👍
                              thnx für die prompte erledigung!
                              • MalleRalle
                                MalleRalle @foxriver76 last edited by
                                @foxriver76 sagte in Beta Test js-controller Kiera (v6.0):
                                @malleralle Ebenfalls nicht im Repo, hilft nur auf GitHub forken, adapter-core upgraden und von dort neu installieren.
                                Danke @foxriver76
                                Habe ich erfolgreich hinbekommen.
                                epson-workforce läuft bei mir wieder.
                                • mcm1957
                                  mcm1957 @MalleRalle last edited by
                                  @malleralle said in Beta Test js-controller Kiera (v6.0):
                                  Danke @foxriver76
                                  Wenn du oder der originale dev den Adapter ins Reponaufnehmenbwillst gerne melden. Kann nur sein dass ev noch andere Anpassungen notwendig sind um mindeststandard zu erreichen. Gibt ja vielleicht noch andere pot. User.
                                  Mcm1957
                                  • Diginix
                                    Diginix last edited by
                                    Mit JS-Controller 6 gibt es ja nun auch Benachrichtigung über verfügbare System Updates:
                                    Zum einen ist der Titel des Hinweises falsch. Zum anderen habe ich diese Pakete bereits installiert, werde die Meldung aber nicht los. Nach Klick auf "Bestätigen" ist sie weg. Aber ein Reload des Browsertabs oder ein neuer Admin Tab, zeigt den Badge beim Host immer wieder an.
                                    foxriver76 Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • foxriver76
                                      foxriver76 Developer @Diginix last edited by
                                      @diginix der Titel "Adapterwarnungen" meinst du? Dann Admin Issue anlegen.
                                      Die Frage ist hast du die Paketupdates auch mit apt ausgeführt? Sonst wird es bei jedem Check neu generiert
                                      Diginix 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @Diginix last edited by
                                        @diginix
                                        Das dürfte dieser Sonderstrick von Ubuntu sein, der sich da 'phased updates' nennt.
                                        https://ubuntu.com/server/docs/about-apt-upgrade-and-phased-updates
                                        • Diginix
                                          Diginix @foxriver76 last edited by
                                          @foxriver76 Ja, die Updates wurde installiert mit:
                                          sudo apt update
                                          sudo apt -y dist-upgrade
                                          Aber ich sehe gerade, dass nicht alles inst wird:
                                          The following upgrades have been deferred due to phasing:
                                            cloud-init snapd
                                          0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                                          $ sudo apt list --upgradeable -a
                                          Listing... Done
                                          cloud-init/noble-updates 24.1.3-0ubuntu3.3 all [upgradable from: 24.1.3-0ubuntu3.2]
                                          cloud-init/now 24.1.3-0ubuntu3.2 all [installed,upgradable to: 24.1.3-0ubuntu3.3]
                                          cloud-init/noble 24.1.3-0ubuntu3 all
                                          snapd/noble-updates 2.63+24.04 amd64 [upgradable from: 2.62+24.04build1]
                                          snapd/noble,now 2.62+24.04build1 amd64 [installed,upgradable to: 2.63+24.04]
                                          Von daher ist der Hinweis vom Host tatsächlich richtig.
                                            Thomas Braun Most Active @Diginix last edited by Thomas Braun
                                            @diginix sagte in Beta Test js-controller Kiera (v6.0):
                                            Siehe meine Vermutung von zuvor.
                                            Das sind 'phased updates'.
                                            Schnubbibuntu halt...
                                            beta js-controller kiera test
                                            39
                                            331
                                            73598
