    4. Beta Test js-controller Kiera (v6.0)
    • mcm1957
      mcm1957 @foxriver76 last edited by mcm1957
      @foxriver76 said in Beta Test js-controller Kiera (v6.0):
      @mcm1957 Daikin hat leider im Release 2.6.0, SQL auch 2.6.0
      Sorry,
      Auf das hab ich nicht geschaut. Red dich bitte mit @Apollon77 wg. Daikin zusammen.
      Bin nur temporär im Netz da openliga ne prioUpdate (wg. EM) brauchte.
      • foxriver76
        SQL 3.0.1 sollte laufen
        • Feuersturm
          Feuersturm last edited by
          @foxriver76 Update von 6.0.2 auf 6.0.4 war auf beiden Testsystemen erfolgreich.
          Es kam blieb nach dem Update aber diese Meldung stehen
          • da_Woody
            da_Woody @Thomas Braun last edited by
            @thomas-braun sorry, konnte gestern nicht mehr weiter machen...
            gerade versucht javascript neu zu starten mit folgendem log:
            javascript.0
            2024-06-14 05:43:13.308	info	terminating
            javascript.0
            2024-06-14 05:43:12.810	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            javascript.0
            2024-06-14 05:43:12.809	info	terminating
            javascript.0
            2024-06-14 05:43:12.707	error	Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
            javascript.0
            2024-06-14 05:43:12.706	error	Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json at exportsNotFound (node:internal/modules/esm/resolve:304:10) at packageExportsResolve (node:internal/modules/esm/resolve:651:9) at resolveExports (node:internal/modules/cjs/loader:592:36) at Function.Module._findPath (node:internal/modules/cjs/loader:669:31) at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27) at Function.resolve (node:internal/modules/helpers:190:19) at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34) at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
            javascript.0
            2024-06-14 05:43:12.706	error	unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
            javascript.0
            2024-06-14 05:43:12.706	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0
            2024-06-14 05:43:12.674	info	starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
            javascript.0
            2024-06-14 05:42:39.592	info	terminating
            javascript.0
            2024-06-14 05:42:39.092	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            javascript.0
            2024-06-14 05:42:39.091	info	terminating
            javascript.0
            2024-06-14 05:42:38.973	error	Exception-Code: ERR_PACKAGE_PATH_NOT_EXPORTED: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
            javascript.0
            2024-06-14 05:42:38.972	error	Error: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json at exportsNotFound (node:internal/modules/esm/resolve:304:10) at packageExportsResolve (node:internal/modules/esm/resolve:651:9) at resolveExports (node:internal/modules/cjs/loader:592:36) at Function.Module._findPath (node:internal/modules/cjs/loader:669:31) at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27) at Function.resolve (node:internal/modules/helpers:190:19) at listInstalledNodeModules (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:126:34) at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1836:36)
            javascript.0
            2024-06-14 05:42:38.972	error	unhandled promise rejection: Package subpath './package.json' is not defined by "exports" in /opt/iobroker/node_modules/@iobroker-javascript.0/regex/package.json
            javascript.0
            2024-06-14 05:42:38.971	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0
            2024-06-14 05:42:38.912	info	starting. Version 8.5.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.14.0, js-controller: 6.0.3
            • foxriver76
              foxriver76 Developer @da_Woody last edited by
              @da_woody bitte einfach auf 6.0.4 upgraden
              • foxriver76
                foxriver76 Developer @Feuersturm last edited by
                @feuersturm Hier wäre das Browser Log interessant falls es wieder passiert.
                • da_Woody
                  da_Woody @foxriver76 last edited by
                  @foxriver76 wurde mir gerade angeboten, gemacht, alle adapter grün! 👍
                  thnx für die prompte erledigung!
                  • MalleRalle
                    MalleRalle @foxriver76 last edited by
                    @foxriver76 sagte in Beta Test js-controller Kiera (v6.0):
                    @malleralle Ebenfalls nicht im Repo, hilft nur auf GitHub forken, adapter-core upgraden und von dort neu installieren.
                    Danke @foxriver76
                    Habe ich erfolgreich hinbekommen.
                    epson-workforce läuft bei mir wieder.
                    • mcm1957
                      mcm1957 @MalleRalle last edited by
                      @malleralle said in Beta Test js-controller Kiera (v6.0):
                      Danke @foxriver76
                      Wenn du oder der originale dev den Adapter ins Reponaufnehmenbwillst gerne melden. Kann nur sein dass ev noch andere Anpassungen notwendig sind um mindeststandard zu erreichen. Gibt ja vielleicht noch andere pot. User.
                      Mcm1957
                      • Diginix
                        Diginix last edited by
                        Mit JS-Controller 6 gibt es ja nun auch Benachrichtigung über verfügbare System Updates:
                        Zum einen ist der Titel des Hinweises falsch. Zum anderen habe ich diese Pakete bereits installiert, werde die Meldung aber nicht los. Nach Klick auf "Bestätigen" ist sie weg. Aber ein Reload des Browsertabs oder ein neuer Admin Tab, zeigt den Badge beim Host immer wieder an.
                        foxriver76 Thomas Braun 2 Replies Last reply Reply Quote 0
                        • foxriver76
                          foxriver76 Developer @Diginix last edited by
                          @diginix der Titel "Adapterwarnungen" meinst du? Dann Admin Issue anlegen.
                          Die Frage ist hast du die Paketupdates auch mit apt ausgeführt? Sonst wird es bei jedem Check neu generiert
                          Diginix 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @Diginix last edited by
                            @diginix
                            Das dürfte dieser Sonderstrick von Ubuntu sein, der sich da 'phased updates' nennt.
                            https://ubuntu.com/server/docs/about-apt-upgrade-and-phased-updates
                            • Diginix
                              Diginix @foxriver76 last edited by
                              @foxriver76 Ja, die Updates wurde installiert mit:
                              sudo apt update
                              sudo apt -y dist-upgrade
                              Aber ich sehe gerade, dass nicht alles inst wird:
                              The following upgrades have been deferred due to phasing:
                                cloud-init snapd
                              0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                              $ sudo apt list --upgradeable -a
                              Listing... Done
                              cloud-init/noble-updates 24.1.3-0ubuntu3.3 all [upgradable from: 24.1.3-0ubuntu3.2]
                              cloud-init/now 24.1.3-0ubuntu3.2 all [installed,upgradable to: 24.1.3-0ubuntu3.3]
                              cloud-init/noble 24.1.3-0ubuntu3 all
                              snapd/noble-updates 2.63+24.04 amd64 [upgradable from: 2.62+24.04build1]
                              snapd/noble,now 2.62+24.04build1 amd64 [installed,upgradable to: 2.63+24.04]
                              Von daher ist der Hinweis vom Host tatsächlich richtig.
                                Thomas Braun Most Active @Diginix last edited by Thomas Braun
                                @diginix sagte in Beta Test js-controller Kiera (v6.0):
                                Siehe meine Vermutung von zuvor.
                                Das sind 'phased updates'.
                                Schnubbibuntu halt...
                                • Diginix
                                  Diginix @Thomas Braun last edited by
                                  @thomas-braun Hab "phased updates" mal deaktiviert und nun ist alles aktuell und der JS-Controller meldet auch nichts mehr.
                                  • Diginix
                                    Ich warte mal ob es mit Admin v7 auch noch so ist. Der wurde ja anscheinend im beta repo vorerst nochmal zurückgezogen.
                                    • mcm1957
                                      mcm1957 @Diginix last edited by
                                      @foxriver76
                                      Paw ist inkompatibel. Bitte auf Liste.
                                      https://github.com/bondrogeen/ioBroker.paw/issues/52
                                      Allerdings ist dieser Adapter seeehr veraltet und npm hat auch keinen BF Zugriff. Migration in community wär daher nur mit neuem Namen möglich
                                      Kann ich ab Mitte Juli andenken wenn sich sonst niemand anbietet und Bedarf sowie tester vorhanden sonst sollte er in Pension gehen
                                      Mcm1957
                                      • mcm1957
                                        mcm1957 last edited by
                                        @mcm1957
                                        Nachtrag: Sieht soweit am Handy checkbar so aus als würdest zugehörige Android App gar nicht mehr existieren....
                                        Daher wahrscheinlich eher Fall für Pathologie ...
                                          Flugschüler @mcm1957 last edited by
                                          Die App kann man auf Apkpure downloaden.
                                          Paw Adapter hat ja bis vor kurzem noch funktioniert. Leider jetzt nicht mehr.
                                          Thomas Braun mcm1957 MalleRalle 3 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Flugschüler last edited by
                                            @flugschüler sagte in Beta Test js-controller Kiera (v6.0):
                                            Weil sich der Rest der Softwarewelt halt weiter dreht. Der Adapter ist ja seit Jahren nicht mehr angepasst worden.
                                            Der hat nur noch zufällig funktioniert.
                                            beta js-controller kiera test
                                            39
                                            331
                                            73620
