    4. Restlaufzeit Shelly Plug S
      Erich 1 @Homoran last edited by Homoran
        <variables>
          <variable id="`3-s]Pi^V2d8N9J-76fO">Rest</variable>
          <variable type="interval" id="Intervall">Intervall</variable>
        </variables>
        <block type="on" id=".0K53IaR?_D^E^0Qr5}A" x="63" y="88">
          <field name="OID">shelly.0.SHPLG-S#DDB4D9#1.Relay0.Switch</field>
          <field name="CONDITION">gt</field>
            <block type="variables_set" id="=VB)QX`VIsFqa?%dv*/+">
              <field name="VAR" id="`3-s]Pi^V2d8N9J-76fO">Rest</field>
                <block type="math_arithmetic" id="eS{QUa6y@lfj^#6,Oh#m">
                    <shadow type="math_number" id="7nK#jz~d3KX?o]fQ:M/w">
                      <field name="NUM">10</field>
                    <shadow type="math_number" id="K~b;$sQw#)NjQwQh`Aw.">
                      <field name="NUM">1</field>
                    <block type="get_value" id="P$3Tge$tbi#ee:DJmDR2">
                      <field name="OID">0_userdata.0.Datenpunkte.Gartenpumpe.Laufzeit</field>
                <block type="timeouts_setinterval" id="OIwHQs|PCd5#%oEjIa7K">
                  <field name="NAME">Intervall</field>
                  <field name="INTERVAL">6</field>
                    <block type="math_change" id="s;cX%Jh7wG?9Q!7Jqy=;">
                      <value name="DELTA">
                        <shadow type="math_number" id="Uivu%JL?GZJ%KmTMlk7;">
                          <field name="NUM">-1</field>
                        <block type="update" id="7t(p,Syit;%jem/{G5!j">
                          <field name="OID">0_userdata.0.Datenpunkte.Gartenpumpe.Restminuten</field>
                            <block type="math_arithmetic" id="]3]MzdqtYE0:d;}ou0b-">
                              <field name="OP">DIVIDE</field>
                                <shadow type="math_number" id="1yb@9@Vr^BR+-y4E?QsB">
                                <block type="variables_get" id="!~y2XoKP0yV0OQyK8pTw">
                                <shadow type="math_number" id="|nHD{4P4Q+|Wekr{5[Sj">
                            <block type="controls_if" id="oVv#NBAx]^NjD$#isELN">
                                <block type="logic_compare" id="r/.r#tf.+]ku0qZxOpfa">
                                  <field name="OP">LT</field>
                                    <block type="variables_get" id=".3XFGd.-1ZO~#./41o^v">
                                    <block type="math_number" id="VeJQlK+PMZ4{+In3D*Cc">
                                      <field name="NUM">0</field>
                                <block type="timeouts_clearinterval" id=".Swg1BM$Y*6{hK:7giFF">
                                    <block type="control" id="zv)}0mRZW|7pJKeJD(5w">
                                        <block type="logic_boolean" id="6,b[sF=en3kx5ZbgERlr">
      DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Erich 1 last edited by
        @erich-1 bitte einen Screenshot vom Skript zeigen.
          Homoran Global Moderator Administrators @Erich 1 last edited by
          @erich-1
          Das hier
          sieht irgendwie ganz anders aus als das
              @erich-1 wie weit zählt er ins negstive?
              dein Vergleichsoperator stimmt nicht ganz
                @homoran Ich lass ihn mal laufen. Aber auch wenn der Shelly vor dem Ablauf der vorgegebenen Zeit ausgeschaltet wird, dann läuft der Zähler ebenso weiter und dann eben auch in den Bereich unter 0.
                  Homoran Global Moderator Administrators @Erich 1 last edited by Homoran
                  @erich-1 sagte in Restlaufzeit Shelly Plug S:
                  Davon war ja auch nie die Rede, dass das abgefangen werden soll.
                  so steht es ja auch in deinem Blockly
                    @homoran Ja, das kann ich mir schon vorstellen. Aber den Fehler zu lokalisieren, ist für mich doch noch eine Herausforderung.
                      deswegen hab ich ihn dir ja genannt;
                      @homoran sagte in Restlaufzeit Shelly Plug S:
                        @homoran Im Moment sagt er -5,9 Minuten und ein Ende ist nicht in Sicht. er zählt vermutlich ewig weiter.
                        Da stehe ich doch noch irgendwie auf dem Schlauch. So fit in den Blocklys bin ich dann doch noch nicht.
                          das wundert mich allerdings!
                          hiernach
                          darf er bis -0.1 gehen.
                          was genau hast du gemacht?
                          wie sehen die beiden Datenpunkte Laufzeit und Restminuten aus?
                            paul53 @Erich 1 last edited by paul53
                            @erich-1 sagte: Im Moment sagt er -5,9 Minuten und ein Ende ist nicht in Sicht.
                            Wenn während der Laufzeit erneut aus- und wieder eingeschaltet wird, laufen mehrere Intervalle, die nicht gestoppt werden können. Um das zu verhindern, setze als ersten Befehl im Trigger zusätzlich ein "stop zyklische Ausführung Intervall".
                              Erich 1 @paul53 last edited by Erich 1
                              So klappt es auch noch nicht, es wird nach wie vor weitergezählt ...
                              Aber er hört bei -0,1 auf !!!
                                @homoran said in Restlaufzeit Shelly Plug S:
                                Da mache ich am Abend weiter, jetzt muss ich dann weg ...
                                  @erich-1 sagte: er hört bei -0,1 auf
                                  Er hört bei 0 auf, wenn der Vergleich geändert wird in
                                  falls Rest <= 0
                                    Nichts nachträglich hinzufügen, auch nicht wenn es das ist, was ich die ganze Zeit sage;
                                    hiernach
                                      @erich-1 sagte: wenn der Shelly vor dem Ablauf der vorgegebenen Zeit ausgeschaltet wird, dann läuft der Zähler ebenso weiter
                                      Soll er dann stehen bleiben? Dann müsste auf "wurde geändert" getriggert werden und "falls Wert" geprüft werden.
                                        @paul53 ...und im sonst wird die Restzeit auf 0 gesetzt und das Intervall gestoppt.
                                          @homoran sagte: ...und im sonst wird die Restzeit auf 0 gesetzt
                                          Das ist hier die Frage: Soll die Restanzeige beim vorzeitigen Ausschalten stehen bleiben oder auf 0 gesetzt werden?
                                            @paul53 Wenn die Restlaufzeit auf 0 gesetzt werden könnte, wenn der Shelly vorzeitig ausgeschaltet wird, wäre das natürlich ideal.
                                            2643
