    4. slave start nicht mehr nach nodejs-update 20
      Thomas Braun Most Active @bahnuhr last edited by
      @bahnuhr sagte in slave start nicht mehr nach nodejs-update 20:
      Aber beim slave (raspi) war ich bisher vorsichtiger.
      Wie oft muss ich es eigentlich noch schreiben? 'Never tatsch a running süstäm' funktioniert NICHT!
      • bahnuhr
        anbei mal iob diag (ohne summary)
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: Pi-Strom-Wasser
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7+
              Architecture: arm
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         09:40:01 up 10 min,  1 user,  load average: 0.94, 1.09, 0.54
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        VCHI initialization failed
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        ~ Arm frequency capping has occurred
        ~ Throttling has occurred
        ~ Soft temperature limit has occurred
        *** Time and Time Zones ***
                       Local time: Sat 2024-06-15 09:40:01 CEST
                   Universal time: Sat 2024-06-15 07:40:01 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        dieter
        HOME=/home/dieter
        GROUPS=dieter sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           923M        125M        128M        6.0M        668M        727M
        Swap:           99M          0B         99M
        Total:         1.0G        125M        228M
        Active iob-Instances:   50
                  923 M total memory
                  126 M used memory
                  345 M active memory
                  360 M inactive memory
                  128 M free memory
                  175 M buffer memory
                  493 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 09:40:01 up 10 min,  1 user,  load average: 0.94, 1.09, 0.54
        Tasks: 121 total,   1 running, 120 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :    923.2 total,    128.2 free,    125.7 used,    669.3 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.    727.3 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       14G  4.6G  8.9G  34% /
        devtmpfs       devtmpfs  430M     0  430M   0% /dev
        tmpfs          tmpfs     462M     0  462M   0% /dev/shm
        tmpfs          tmpfs     462M  6.2M  456M   2% /run
        tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1002
        [Sat Jun 15 09:29:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Sat Jun 15 09:29:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Sat Jun 15 09:29:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Jun 15 09:29:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE         FSTYPE     OPTIONS
        /                                     /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=439400k,nr_inodes=109850,mode=755
        | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
        |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
        | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
        | | `-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
        | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
        | `-/sys/kernel/config                configfs       configfs   rw,relatime
        |-/proc                               proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1002                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94536k,mode=700,uid=1002,gid=1002
        `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.5G    /var/
        1.3G    /var/cache/apt/archives
        1.3G    /var/cache/apt
        1.3G    /var/cache
        93M     /var/lib
              Users in the 'systemd-journal' group can see all messages. Pass -q to
              turn off this notice.
        No journal files were opened due to insufficient permissions.
        /opt/iobroker/backups:
        du: cannot access '/opt/iobroker/backups/': No such file or directory
        /opt/iobroker/iobroker-data:
        11M     /opt/iobroker/iobroker-data/
        3.3M    /opt/iobroker/iobroker-data/files
        2.8M    /opt/iobroker/iobroker-data/files/info.admin
        2.4M    /opt/iobroker/iobroker-data/files/info.admin/lib
        2.4M    /opt/iobroker/iobroker-data/backup-objects
        1.6M    /opt/iobroker/iobroker-data/objects.jsonl
        1.6M    /opt/iobroker/iobroker-data/objects.json.migrated
        1.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        464K    /opt/iobroker/iobroker-data/backup-objects/2020-09-04_16-49_objects.json.gz
        464K    /opt/iobroker/iobroker-data/backup-objects/2020-09-03_11-33_objects.json.gz
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907T3PS-if00-port0
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH06GH5Y-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.3
        /usr/bin/node           v18.20.3
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.3-1nodesource1
          Candidate: 18.20.3-1nodesource1
          Version table:
         *** 18.20.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
        + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
          system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
          system.adapter.komoot.0                 : komoot                : iobroker                                 - disabled
        + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
          system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
          system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
        + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
        + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
        + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
        + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
        + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
        + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
          system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          - disabled
        + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
          system.adapter.sql.1                    : sql                   : iobroker                                 - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.telegram.1               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
          system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
          system.adapter.wled.0                   : wled                  : iobroker                                 - disabled
        + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "mbus"         : 2.6.1    , installed 2.6.1
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Objects and States
        Objects:        27223
        States:         22733
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17690      652/sshd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17692      652/sshd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17469      644/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14616      441/avahi-daemon: r
        udp        0      0 0.0.0.0:54543           0.0.0.0:*                           108        14618      441/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14617      441/avahi-daemon: r
        udp6       0      0 :::49598                :::*                                108        14619      441/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16577      644/dhcpcd
        2024-06-15 08:46:14.622  - info: host.Pi-Strom-Wasser stopInstance system.adapter.mbus.0 send kill signal
        2024-06-15 08:46:15.099  - info: smartmeter.1 (28095) terminating
        2024-06-15 08:46:15.103  - info: mbus.0 (28106) terminating
        2024-06-15 08:46:15.519  - info: host.Pi-Strom-Wasser instance system.adapter.smartmeter.1 terminated with code 0 (NO_ERROR)
        2024-06-15 08:46:15.673  - info: host.Pi-Strom-Wasser instance system.adapter.mbus.0 terminated with code 0 (NO_ERROR)
        2024-06-15 08:46:15.675  - info: host.Pi-Strom-Wasser All instances are stopped.
        2024-06-15 08:46:15.825  - info: host.Pi-Strom-Wasser terminated
        2024-06-15 09:38:12.825  - info: host.Pi-Strom-Wasser iobroker.js-controller version 5.0.19 js-controller starting
        2024-06-15 09:38:12.839  - info: host.Pi-Strom-Wasser Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2024-06-15 09:38:12.841  - info: host.Pi-Strom-Wasser hostname: Pi-Strom-Wasser, node: v18.20.3
        2024-06-15 09:38:12.842  - info: host.Pi-Strom-Wasser ip addresses: 192.168.243.121 2a03:93e0:200:990:1a81:eafd:7b4e:8439 fe80::ba9d:7d05:f73f:4dd5
        2024-06-15 09:38:13.248  - info: host.Pi-Strom-Wasser connected to Objects and States
        2024-06-15 09:38:13.303  - info: host.Pi-Strom-Wasser Node.js version has changed from 18.20.2 to 18.20.3
        2024-06-15 09:38:13.326  - info: host.Pi-Strom-Wasser added notifications configuration of host
        2024-06-15 09:38:13.351  - info: host.Pi-Strom-Wasser Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2024-06-15 09:38:15.097  - info: host.Pi-Strom-Wasser 90 instances found
        2024-06-15 09:38:15.191  - info: host.Pi-Strom-Wasser starting 2 instances
        2024-06-15 09:38:15.551  - info: host.Pi-Strom-Wasser instance system.adapter.smartmeter.1 started with pid 1757
        2024-06-15 09:38:19.523  - info: host.Pi-Strom-Wasser instance system.adapter.mbus.0 started with pid 1764
        2024-06-15 09:38:22.437  - info: smartmeter.1 (1757) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.20.3, js-controller: 5.0.19
        2024-06-15 09:38:23.711  - info: smartmeter.1 (1757) Received 10 values, 10 updated
        2024-06-15 09:38:25.325  - info: mbus.0 (1764) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.mbus, node: v18.20.3, js-controller: 5.0.19
        2024-06-15 09:38:25.408  - info: mbus.0 (1764) Default Update Interval: 900
        2024-06-15 09:38:25.411  - info: mbus.0 (1764) Initialize M-Bus Serial to /dev/lesewasser with 115200baud
        2024-06-15 09:38:25.418  - info: mbus.0 (1764) Schedule initialization for M-Bus-ID 17834338B4090107 with update interval 900
          immerhin, und damit
          Kernel : armv7l
          aber wie befürchtet
          und dafür gibt es kein node20 mehr
          • bahnuhr
            bahnuhr Forum Testing Most Active @Homoran last edited by
            War der Raspi wo wir vor 5 jahren (oder so; am Anfang von smartmeter) rum probiert hatten, dass wir die Verbindung zum smartmeter und mbus hin bekommen.
            hatten wir damals extra noch ne rules geschrieben um die id korrekt zuzuweisen.
            sowas damals:
            SUBSYSTEM=="tty", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="AH06GH5Y", SYMLINK+="lesestrom"
            SUBSYSTEM=="tty", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="AH06GH5Z", SYMLINK+="lesevoltaik"
            SUBSYSTEM=="tty", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="A907T3PS", SYMLINK+="lesewasser"
            Mittlerweile müsste smartmeter dies ja auslesen können.
            @Thomas-Braun
            Und deshalb hatte ich dies bisher nicht geändert.
            Aber jetzt hab ich ja einen Grund.
              Dann installier da jetzt neu ein reines 64Bit-System.
              Und die Spannungsversorgung und die Kühlung würde ich mir auch anschauen:
                @bahnuhr nimm ne neue Karte und spiel den Bücherwurm drauf.
                iobroker ohne jeden Adapter
                Dann koppeln.
                Wenn's schief geht hast du noch die alte Karte.
                • bahnuhr
                  @homoran sagte in slave start nicht mehr nach nodejs-update 20:
                  Dann koppeln.
                  yes, genau das war auch meine Idee eben.
                  • bahnuhr
                    So, neue SD funktioniert.
                    bookworm ist installiert.
                    Nun klappt multihost nicht.
                    Wie immer nach folgender Anleitung:
                    https://www.iobroker.net/#de/documentation/config/multihost.md
                    Beim Master kommt:
                    Beim Slave kommt:
                    Jemand eine Idee ?
                      Jemand eine Idee ?
                      Viele!
                      gleiche Datenbank?
                      jsonl, redis, file?
                      selber Hostname beim slave?
                      beide Hosts neu gestartet?
                      iob setup custom probiert?
                      • bahnuhr
                        Danke Rainer.
                        gleiche Datenbank?
                        ja, beide jsonl
                        natürlich nicht.
                        slave hat: stromwasser
                        natürlich
                        Ja, siehe oben.
                        nach dieser Anleitung:
                          Homoran Global Moderator Administrators @bahnuhr last edited by Homoran
                          natürlich nicht.
                          sorry! Frage war nicht exakt.
                          Selber Name wie vorher?
                          Ja, siehe oben.
                          ich finde den output dazu nicht (als text in code-tags 😁 )
                          • bahnuhr
                            jetzt wird es merkwürdig.
                            Wenn ich auf dem slave eingebe, kommt:
                            dieter@stromwasser:~ $ iob multihost browse
                            No Multihost server found. Make sure iobroker is running on the host where you enabled multihost discovery (and it is not this host)!
                            Wenn ich bei meinem master auf host gehe, sehe ich den neuen aber:
                            stromwasser ist der neue.
                            PI-Strom-Wasser der alte.
                            Frage:
                            Warum wird bei iob multihost browse dies nicht angezeigt ?
                              also nicht der selbe Hostname!
                              Abgesehen davon dass ich das nicht mag, weil ich nicht sehe was da passiert:
                              • bahnuhr
                                bahnuhr Forum Testing Most Active @Homoran last edited by bahnuhr
                                Ja, und was sagt mir das jetzt.
                                Na klar läuft iob auf dem host und auch auf dem master. Ich verstehe diese Satz nicht wirklich.
                                  Na klar läuft iob auf dem host.
                                  auf dem Master, auf dem auch hoffentlich noch das multihost enable aktiv ist.
                                  • bahnuhr
                                    Ja, ist es.
                                    Multihost discovery server: enabled
                                    Discovery authentication:   enabled
                                    Persistent activation:      disabled
                                    Objects:                    jsonl on 0.0.0.0
                                    States:                     jsonl on 0.0.0.0
                                    • bahnuhr
                                      @Homoran
                                      @Thomas-Braun
                                      So, mal Rückinfo von mir.
                                      bookworm installiert nach der Anleitung von @Thomas-Braun
                                      file:///Z:/iobroker/Installation%20_%20Update/Installation%20auf%20Raspi%20-%20Einfacher%20geht's%20nicht.html
                                      Dies hat geklappt und dann iob installiert.
                                      Erst war der host ein anderer. Dann wieder alles neu. Passt.
                                      Aber multihost klappt nicht mehr mit nodejs 20
                                      Es kommt immer o.g. Fehler. Im master bei hosts wird der slave grün dargestellt. Aber mbus und auch smartmeter lesen den slave nicht mehr aus. Die angeschlossenen Geräte werden in der Instanz nicht angezeigt.
                                      Fazit für mich:
                                      Ich bekomme es nicht hin und habe die nodejs18 SD wieder rein getan.
                                      i.S. von Thomas: never change hat zumindest aktuell für mich dann doch wieder Sinn.
                                      Weil ich es einfach nicht hinbekomme.
                                      Vielleicht könnte das ja mal jemand mit mehr know how mal testen.
                                      mfg
                                      Dieter
                                        und wo kam dann dein neuer Host stromwasser her?
                                        Da muss die Kopplung doch geklappt haben.
                                        Der war doch grün.
                                        Weil du einen andeten Hostmnamen nutzst!
                                        Dann musst du die Instanzen diesem neuen Host zuordnen.
                                        Deswegen solltest du ja den selben Hostnamen verwenden
                                        bahnuhr 2 Replies Last reply Reply Quote 0
                                        • bahnuhr
                                          Rainer, das hab ich alles durch.
                                          Wie geschrieben hab ich nochmal alles neu gemacht.
                                          und dann mit dem richtigen host.
                                          Auch das klappte nicht.
                                          • bahnuhr
                                            Hab sogar das backup vom master von heute nacht eingespielt.
                                            Daten von heute sind nun weg.
                                            Aber mit nodejs20 geht es nicht.
                                            Alte SD beim slave rein; und alles läuft.
                                            nodejs update
                                            4695
