    4. [Neuer Adapter] Homepilot20
      Wildbill @mcm1957 last edited by
      @mcm1957 Gut möglich.
      @2hot4you Trag mal die IP direkt ein anstatt Domain und teste nochmal.
      Gruss, Jürgen
        Semenchkare @Wildbill last edited by
        @wildbill OK. habe gerade auf die 6.04 upgedatet, noch gleicher Fehler.
        hier mal das Protokoll beim Start
        host.iobroker
        	2024-06-13 19:35:59.166	info	Restart adapter system.adapter.homepilot20.0 because enabled
        host.iobroker
        	2024-06-13 19:35:59.166	error	instance system.adapter.homepilot20.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: Node.js v20.14.0
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        host.iobroker
        	2024-06-13 19:35:59.165	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
        host.iobroker
        	2024-06-13 19:35:59.164	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.homepilot20/main.js:2721:5)
        host.iobroker
        	2024-06-13 19:35:59.164	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.homepilot20/main.js:66:12)
        host.iobroker
        	2024-06-13 19:35:59.164	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
        host.iobroker
        	2024-06-13 19:35:59.164	error	Caught by controller[0]: ^
        host.iobroker
        	2024-06-13 19:35:59.164	error	Caught by controller[0]: adapter = new utils.Adapter(options);
        host.iobroker
        	2024-06-13 19:35:59.163	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.homepilot20/main.js:66
        • mcm1957
          mcm1957 @Semenchkare last edited by
          @semenchkare
          Wenn ich das richtig sehe ist der Adapter homepilot 20 NICHT im Repository gelistet.
          Bitte den Dev kontatieren dmit dieser den Adapter an js-controlelr 6 anpasst.
          Die Dependencies sind total veraltet - offenbar benutzt der Dev auch keine dependabot. Da der Adapter nicht im repository gelistet ist wurde auch auch keinem Grobreview unterzogen. Der Adapter kann daher (muss aber ntürlich nicht=) noch andere Probleme beinhalten. Da der Adapetr auch die standardmäßigen Github Tests nicht benutzt knn ü bder den notwendigen Anpasungsumfang nichts gesagt werden.
          Ich bin hier dann mal raus - bitet an den Dev des Adapters wenden. Sollte dieser Fragen haben, bitte m Telegramm Developer Channel melden.
          Der Vollständigkeit halber:
          Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
          Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
          Adapter die nur via GitHub installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
            @mcm1957 @Semenchkare Ich war mal so frei und habe bei Github ein Issue erstellt. Viel Hoffnungen mache ich mir da gerade allerdings leider nicht, da es von 2020 ein offenes issue vom iobroker-Adapter-Checker gibt, den doch ins Repo zu schieben, ohne dass eine Antwort von @homecineplexx erfolgt wäre.
            Gruss, Jürgen
            • mcm1957
              mcm1957 @Wildbill last edited by
              @wildbill
              Ev kann ich ja mal reinschaun. Will aber nix versprechen. Vor mitte Juli wg Urlaubs sicher nicht. Könnt mich gerne dann nochmal anfingen
                Micha 3 last edited by
                https://github.com/homecineplexx/ioBroker.homepilot20/issues/67
                zaphod2 created this issue in homecineplexx/ioBroker.homepilot20
                closed Compatibility check mit js-controller 6.0.1 #67
                • mcm1957
                  mcm1957 @Micha 3 last edited by
                  @micha-3 said in [Neuer Adapter] Homepilot20:
                  Offenbar hat homecineplex derzeit nur bedingt eine Motivation etwas zu fixen. Siehe das referenzierte Issue. Ich habe ihn explizit nochmal drum ersucht die Probleme zu beheben.
                  Falls (was ich nicht hoffe) dies nicht zu einer Lösung führt kann man immer noch überlegen wie wir weiter vorgehen können / sollen. Insbesondere sollte der Adapter ja auch mal in die Repositories aufgenommen werden.
                  Bitte mich ggF im Juli triggern.
                  @apollon77 zur Info
                    homecineplexx @mcm1957 last edited by
                    @mcm1957 said in [Neuer Adapter] Homepilot20:
                    @apollon77 zur Info
                    sag mal...was genau schreibst du da für mist? du schreibst irgendwas am 14.juni um 19:47 ...meinst du jeder Entwickler sitzt 24 Stunden vor dem Pc? Es ist Wochenende da gibts auch was anderes. zum Thema JS-Controller 6.0 ..das schau ich mir erst an, wenn der nicht mehr Beta ist, dafür gabs auch schon ein Ticket und das hab ich dort auch hinterlegt!
                    und zum Thema der Developer mag nichts machen!! dann schau dir mal die Requests hier an und die Antwortzeiten bzw die implementierung diverser Wünsche....nur mal so nebenbei!
                    und nun noch einen schönen Sonntag
                    • mcm1957
                      mcm1957 @homecineplexx last edited by mcm1957
                      @homecineplexx
                      Na ja - von 14h am Tag red ich nicht.
                      Aber DU machst einen Issue erstellt am 11.6. das ein Startupproblem mit js-controller 6 beschreibt (https://github.com/homecineplexx/ioBroker.homepilot20/issues/67) am selben Tag einfach zu und schreibts dass du dir das derzeit nicht ansehen wirst:
                      Das weiß ich nicht und werd ich mir jetzt auch noch nicht anschauen, da der Js-Controller 6.0 erst Beta ist laut dem Beitrag https://forum.iobroker.net/topic/75206/beta-test-js-controller-kiera-v6-0
                      Mag jeder selbst beurteilen ob meine Aussage dass du derzeit nur bedingt eine Motivation hast was zu fixen stimmt :-). Immerhin schreibts du ja selbst, dass du derzeit nichts tun willst bzw. wirst.
                      Wie soll man die Aussage dass du dir das jetzt nicht ansehen wirst einstufen? Als hoch motiviert das rasch zu fixen !?!? Sorry.
                      Ich sag explizit DANKE dass du den Adapter erstellt hats. Aber ich möchte auch festhalten, dass die meisten Devs die Anpassungen an js-controller 6 zeitnahe vornehmen. Immerhin wollen bereits JETZT user den Adapter mit js-controlelr 6 benutzen.
                      https://forum.iobroker.net/topic/25206/neuer-adapter-homepilot20/219 meinst du ber wahrscheinlich nicht 🙂
                      EGAL:
                      Ich will mich hier nicht streiten. Mir ist klar dass Zeit eine knappe Sache ist. Und ich möchte explizit DANKE sagen dass du dich um den Adapter bisher gekümmert hast. Ev. findest du ja doch Zeit diesen an die aktuellen Standardas anzupassen aud such sauber in den Repositories zu veröffentlichen.
                      EDIT EDIT EDIT
                      Ich habe mir meine letzten Postings nun nach einiger Zeit nochmals durchgesehen und muss zugeben, dass mir die Aussage das @homecineplexxjetzt zur Zeit (!) nichts machen will wohl in die falsche Kehle geraten ist. Ich habe daher übertrieben aggressiv / ätzend geantwortet und möchte mich dafür in aller Form hier entschuldigen. Eine konstruktive Antwort mir einer Begründung warum es doch schon jetzt sinnvoll wäre zu reagieren wäre weit angebrachter gewesen.
                      So kann ich hier nur in aller Deutlichkeit ENTSCHULDIGUNG und DANKE für die nun super rasch erfolgte Anpassung sagen.
                      H 1 Reply Last reply Reply Quote 2
                        also ich hab jetzt eine 0.0.53 version veröffentlicht.
                        ich habs bei mir mit JS-Controller 5.0.19 und 6.0.4 getestet und es scheint zu funktionieren.
                        bitte um info darüber!
                        lg
                        mcm1957 M S 3 Replies Last reply Reply Quote 2
                        • mcm1957
                          @homecineplexx
                          DANKE
                            Micha 3 @homecineplexx last edited by Micha 3
                            @homecineplexx sagte in [Neuer Adapter] Homepilot20:
                            lg
                            Danke, funktioniert mit js-c 6.0.4 und auch mit der 6.0.5 alpha.
                              Snigga @homecineplexx last edited by
                              @homecineplexx Danke funktioniert alles und deine Antwortzeiten sind extrem positiv. Bitte mach auch weiter so.
                                homecineplexx @Snigga last edited by
                                @snigga DANKESCHÖN...es freut mich zu hören
                                ab und zu hätte ich gern ein paar Devices zu testen. Vor allem mit den neuen Homepilot Sachen gibts immer wieder bissl Unterschiede
                                  Hullygully last edited by
                                  @homecineplexx Erstmal vielen Dank für diesen Adapter und deine Arbeit diesen zu pflegen.
                                  Ich hab aktuell die Version v0.0.53 installiert und kontaktiere zu meinem neuen Homepilot Gateway Premium. So weit funktioniert auch alles. Ich sehe meine Rollladenmotoren unter der Kategorie "Actuator".
                                  Jetzt zu meinem Problem:
                                  Ich habe am Gateway noch weitere Geräte angemeldet. Diese stehen leider nicht in deiner Liste der unterstützten Geräte.
                                  Es handelt sich um einen schaltbaren Steckdosen Zwischenstecker Smart (deviceNumber: 11301001)
                                  https://de.homepilot-smarthome.com/produkte/sicherheit-garage/sicherheitstechnik/zwischenstecker-smart
                                  und
                                  um einen Wandthermostaten Premium Smart (deviceNumber: 13501001_A)
                                  https://de.homepilot-smarthome.com/produkte/licht-heizung/heizungssteuerung/thermostat-premium-smart
                                  Könntest du bitte diese Geräte auch in deine Liste der unterstützen Geräte mit aufnehmen. Das wäre echt großartig!
                                  Hier die Ausgabe zu:
                                  %ip% /hp/v4/devices?devtype=Actuator
                                  {"response":"get_visible_devices","devices":
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":2,"did":3,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Rollladen - Küche","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10236020","uid":"490a3d_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":2,"did":4,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Rollladen - SZ Susi","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10236020","uid":"490a26_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":2,"did":5,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Rollladen - Wohnzimmerfenster","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10236020","uid":"49fdb6_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":2,"did":6,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Rollladen - Wohnzimmertür","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10236020","uid":"49fdd7_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":2,"did":7,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Rollladen - SZ Robby","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10236020","uid":"490a25_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":2,"did":8,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Rollladen - Büro","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10236020","uid":"490a1e_1","origin":"HomePilot"},
                                  {"description":"","deviceGroup":1,"did":9,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset4"},"messages":[],"name":"Zwischenstecker - Wohnzimmer - Schrank","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"11301001","uid":"46305d_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":5,"did":10,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset28"},"messages":[],"name":"Thermostat - Büro","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":175,"acttemperatur":231,"relaisstatus":0,"automaticvalue":215,"manualoverride":100},"visible":true,"deviceNumber":"13501001_A","uid":"73b10d_A_1","origin":"HomePilot","posMin":40,"posMax":400},
                                  {"description":"","deviceGroup":1,"did":12,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset4"},"messages":[],"name":"Zwischenstecker - SZ Susi - Schranklicht","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"11301001","uid":"462f0f_1","origin":"HomePilot"},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":5,"did":13,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset28"},"messages":[],"name":"Thermostat - Flur","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":180,"acttemperatur":224,"relaisstatus":0,"automaticvalue":180,"manualoverride":100},"visible":true,"deviceNumber":"13501001_A","uid":"73b107_A_1","origin":"HomePilot","posMin":40,"posMax":400},
                                  {"description":"Deine Gerätebeschreibung","deviceGroup":5,"did":16,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset28"},"messages":[],"name":"Thermostat - SZ Robby","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":215,"acttemperatur":225,"relaisstatus":0,"automaticvalue":215,"manualoverride":0},"visible":true,"deviceNumber":"13501001_A","uid":"73b0d0_A_1","origin":"HomePilot","posMin":40,"posMax":400},
                                  {"description":"","deviceGroup":1,"did":19,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset4"},"messages":[],"name":"Zwischenstecker - Wohnzimmer - Vitrine","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"11301001","uid":"4630ab_1","origin":"HomePilot"}
                                  %ip% /hp/devices/9 / 12 und 19
                                  {"error_description":"OK","error_code":0,"payload":{"device":{"capabilities":[{"name":"STAIRWAY_MODE_CFG","value":"false","read_only":false,"timestamp":1720321463},{"name":"POS_UP_CMD","read_only":false,"timestamp":-1},{"name":"VERSION_CFG","value":"4.7-2","read_only":false,"timestamp":1720321463},{"name":"INC_CMD","read_only":false,"timestamp":-1},{"name":"PROD_CODE_DEVICE_LOC","value":"11301001","read_only":false,"timestamp":-1},{"name":"REACHABILITY_EVT","value":"true","read_only":true,"timestamp":1720321463},{"name":"TURN_OFF_CMD","read_only":false,"timestamp":-1},{"name":"RESET_WO_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"NAME_DEVICE_LOC","value":"Zwischenstecker - Wohnzimmer - Schrank","read_only":false,"timestamp":-1},{"name":"PROT_ID_DEVICE_LOC","value":"46305d_1","read_only":false,"timestamp":-1},{"name":"INTF_ID_DEVICE_LOC","value":"3","read_only":false,"timestamp":-1},{"name":"ICONSET_LOC","value":"iconset4","read_only":false,"timestamp":-1},{"name":"STAIRWAY_DUR_CFG","value":"180.0","min_value":"0.0","max_value":"3276.5","step_size":"0.1","read_only":false,"timestamp":1720321463},{"name":"DEVICE_TYPE_LOC","value":"1","read_only":false,"timestamp":-1},{"name":"TURN_ON_CMD","read_only":false,"timestamp":-1},{"name":"ICONSET_INV_LOC","value":"false","read_only":false,"timestamp":-1},{"name":"RMT_STOP_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"REQ_STATUS_CMD","read_only":false,"timestamp":-1},{"name":"RESET_FULL_CMD","read_only":false,"timestamp":-1},{"name":"PUSH_CMD","read_only":false,"timestamp":-1},{"name":"PAIRING_CONFIRMED_LOC","value":"true","read_only":false,"timestamp":-1},{"name":"PROTOCOL_ID_CFG","value":"46305d","read_only":false,"timestamp":-1},{"name":"ID_DEVICE_LOC","value":"9","read_only":false,"timestamp":-1},{"name":"CURR_SWITCH_POS_CFG","value":"false","read_only":false,"timestamp":1720321463},{"name":"RMT_START_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"STOP_CMD","value":"false","read_only":false,"timestamp":-1},{"name":"VIS_DEVICE_LOC","value":"true","read_only":false,"timestamp":-1},{"name":"RMT_START_UNPAIR_CMD","read_only":false,"timestamp":-1},{"name":"INVERSE_MODE_CFG","value":"true","read_only":false,"timestamp":1720321463},{"name":"POS_DOWN_CMD","read_only":false,"timestamp":-1},{"name":"DESCR_DEVICE_LOC","value":"","read_only":false,"timestamp":-1},{"name":"PING_CMD","read_only":false,"timestamp":-1},{"name":"DEC_CMD","read_only":false,"timestamp":-1}],"scenes":[],"automation":[]}}}
                                  %ip% /hp/devices/10 / 13 und 16
                                  {"error_description":"OK","error_code":0,"payload":{"device":{"capabilities":[{"name":"TEMPERATURE_INT_CFG","value":"23.1","min_value":"-40.0","max_value":"80.0","step_size":"0.1","read_only":false,"timestamp":1720350523},{"name":"POS_UP_CMD","read_only":false,"timestamp":-1},{"name":"INC_CMD","read_only":false,"timestamp":-1},{"name":"VERSION_CFG","value":"2.2-2","read_only":false,"timestamp":1720350523},{"name":"PROD_CODE_DEVICE_LOC","value":"13501001_A","read_only":false,"timestamp":-1},{"name":"REACHABILITY_EVT","value":"true","read_only":true,"timestamp":1720350523},{"name":"RESET_WO_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"NAME_DEVICE_LOC","value":"Thermostat - Büro","read_only":false,"timestamp":-1},{"name":"PROT_ID_DEVICE_LOC","value":"73b10d_A_1","read_only":false,"timestamp":-1},{"name":"CURR_TEMPERATURE_THRESH_CFG","value":"1","min_value":"1","max_value":"4","step_size":"1","read_only":false,"timestamp":1720350523},{"name":"INTF_ID_DEVICE_LOC","value":"3","read_only":false,"timestamp":-1},{"name":"ICONSET_LOC","value":"iconset28","read_only":false,"timestamp":-1},{"name":"DEVICE_TYPE_LOC","value":"5","read_only":false,"timestamp":-1},{"name":"RELAIS_STATE_CFG","value":"false","read_only":false,"timestamp":1720350523},{"name":"ICONSET_INV_LOC","value":"false","read_only":false,"timestamp":-1},{"name":"RMT_STOP_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"REQ_STATUS_CMD","read_only":false,"timestamp":-1},{"name":"MAN_OVERW_ACTUATOR_CFG","value":"true","read_only":false,"timestamp":1720350523},{"name":"TARGET_TEMPERATURE_CFG","value":"17.5","min_value":"4.0","max_value":"40.0","step_size":"0.5","read_only":false,"timestamp":1720350523},{"name":"RESET_FULL_CMD","read_only":false,"timestamp":-1},{"name":"PUSH_CMD","read_only":false,"timestamp":-1},{"name":"PAIRING_CONFIRMED_LOC","value":"true","read_only":false,"timestamp":-1},{"name":"TEMPERATURE_THRESH_2_CFG","value":"17.0","min_value":"4.0","max_value":"40.0","step_size":"0.5","read_only":false,"timestamp":1720350523},{"name":"ID_DEVICE_LOC","value":"10","read_only":false,"timestamp":-1},{"name":"PROTOCOL_ID_CFG","value":"73b10d","read_only":false,"timestamp":-1},{"name":"RMT_START_PAIR_CMD","read_only":false,"timestamp":-1},{"name":"TEMPERATURE_THRESH_3_CFG","value":"21.5","min_value":"4.0","max_value":"40.0","step_size":"0.5","read_only":false,"timestamp":1720350523},{"name":"TEMPERATURE_THRESH_1_CFG","value":"21.5","min_value":"4.0","max_value":"40.0","step_size":"0.5","read_only":false,"timestamp":1720350523},{"name":"STOP_CMD","value":"false","read_only":false,"timestamp":-1},{"name":"VIS_DEVICE_LOC","value":"true","read_only":false,"timestamp":-1},{"name":"RMT_START_UNPAIR_CMD","read_only":false,"timestamp":-1},{"name":"TEMPERATURE_THRESH_4_CFG","value":"17.0","min_value":"4.0","max_value":"40.0","step_size":"0.5","read_only":false,"timestamp":1720350523},{"name":"POS_DOWN_CMD","read_only":false,"timestamp":-1},{"name":"DESCR_DEVICE_LOC","value":"Deine Gerätebeschreibung","read_only":false,"timestamp":-1},{"name":"PING_CMD","read_only":false,"timestamp":-1},{"name":"DEC_CMD","read_only":false,"timestamp":-1}],"scenes":[],"automation":[]}}}
                                  Ich hoffe du kannst was mit diesen Angaben anfangen. Wenn du noch weitere Daten brauchst, lass es mich bitte wissen.
                                  LG
                                  Hullygully
                                    homecineplexx @Hullygully last edited by
                                    @hullygully said in [Neuer Adapter] Homepilot20:
                                    hallo
                                    ja, schau ich mir an, aber heute wirds bissl eng.
                                    wenn ich was brauche, meld ich mich bei dir
                                    lg
                                      mehrtuerer666 last edited by
                                      Guten Tag !
                                      Bin bisher noch Laie und steig bei den ganzen scripten noch nicht ganz durch - werd mich jedoch einarbeiten.
                                      Ist es mir grundsätzlich möglich meinen Rademacher homepilot
                                      (Schwarze Bauform 2017 inkl usb Stick)
                                      In ein loxone System zu integrieren ?
                                      Hab einen wettersensor und hauptsächlich 20x Duo fern motorrohraktoren unterputz.
                                      Würde somit gern die automatische rolladensteuerung Tag und Nacht und Wärme vom Rademacher ins loxone implementieren.
                                      Samson71 H 2 Replies Last reply Reply Quote 0
                                      • Samson71
                                        Samson71 Global Moderator @mehrtuerer666 last edited by Samson71
                                        @mehrtuerer666 sagte in [Neuer Adapter] Homepilot20:
                                        Das hat jetzt WAS genau mit der Integration in ioBroker bzw. dem Adapter zu tun?
                                        Die Frage gehört wohl eher ins Loxone-Forum.
                                          homecineplexx @mehrtuerer666 last edited by
                                          @mehrtuerer666 said in [Neuer Adapter] Homepilot20:
                                          Guten Tag !
                                          Hallo
                                          also ich denke prinzipiell wird das schon möglich sein.
                                          und wenns über umwege mit ioBroker und Node-Red ins KNX geht, aber besser du fragst Leute die mit Loxone zu tun haben
                                            pk68 @homecineplexx last edited by
                                            @homecineplexx Hallo, wäre es möglich deinen Adapter um den Gurtwickler RolloTron classic smart (10142345) zu erweitern? Von den Bedienelementen und den Daten sollte er ähnlich zu dem RolloTron Standard DuoFern 1400 (14234511) sein, welcher schon im Adapter implementiert ist. Das Gehäuse ist nun komplett weiß und statt Rademacher steht HomePilot drauf.
                                            Ich nutzte hier eine Steuerung HomePilot 2 (9496-2-SW) mit 2x RolloTron Standard DuoFern 1400 (14234511) und 2x RolloTron Basis DuoFern 1200 (18234511).
                                            Hier noch ein paar Infos zu dem neuen RolloTron classic smart:
                                            <ip>/v4/devices?devtype=Actuator
                                              "response": "get_visible_devices",
                                              "devices": [
                                                  "description": "RolloTron classic smart",
                                                  "deviceGroup": 2,
                                                  "did": 1010005,
                                                  "hasErrors": 0,
                                                  "iconSetInverted": 0,
                                                  "iconSet": {
                                                    "k": "iconset8"
                                                  "messages": [],
                                                  "name": "Rollo SZ neu",
                                                  "properties": {
                                                    "closingContact": 3,
                                                    "dawn": 3,
                                                    "dusk": 3,
                                                    "motion": 3,
                                                    "rain": 3,
                                                    "smartphone": 3,
                                                    "smoke": 3,
                                                    "sun": 3,
                                                    "temperature": 3,
                                                    "time": 3,
                                                    "trigger": 3,
                                                    "warning": 3,
                                                    "wind": 3
                                                  "statusValid": true,
                                                  "statusesMap": {
                                                    "Position": 6
                                                  "visible": true,
                                                  "deviceNumber": "10142345",
                                                  "uid": "407afd_1",
                                                  "voiceControlledBy": "",
                                                  "origin": "HomePilot"
                                                  "description": "RolloTron Standard DuoFern 1400",
                                                  "deviceGroup": 2,
                                                  "did": 1010004,
                                                  "hasErrors": 0,
                                                  "iconSet": {
                                                    "k": "iconset8"
                                                  "messages": [],
                                                  "name": "Rollo WZ",
                                                  "properties": {
                                                    "dawn": 3,
                                                    "dusk": 3,
                                                    "motion": 3,
                                                    "rain": 3,
                                                    "smartphone": 3,
                                                    "smoke": 3,
                                                    "sun": 3,
                                                    "temperature": 3,
                                                    "time": 1,
                                                    "trigger": 2,
                                                    "warning": 3,
                                                    "wind": 3
                                                  "statusesMap": {
                                                    "Manuellbetrieb": 100,
                                                    "Position": 0
                                                  "visible": true,
                                                  "deviceNumber": "14234511",
                                                  "uid": "404c60_1",
                                                  "deviceGroup": 2,
                                                  "did": 1010003,
                                                  "hasErrors": 0,
                                                  "iconSet": {
                                                    "k": "iconset8"
                                                  "messages": [],
                                                  "name": "Rollo WZ Balkon",
                                                  "properties": {
                                                    "dawn": 3,
                                                    "dusk": 3,
                                                    "motion": 3,
                                                    "rain": 3,
                                                    "smartphone": 3,
                                                    "smoke": 3,
                                                    "sun": 3,
                                                    "temperature": 3,
                                                    "time": 1,
                                                    "trigger": 2,
                                                    "warning": 3,
                                                    "wind": 3
                                                  "statusesMap": {
                                                    "Position": 0
                                                  "visible": true,
                                                  "uid": "404c77_1",
                                                  "description": "RolloTron Basis DuoFern 1200",
                                                  "deviceGroup": 2,
                                                  "did": 1010001,
                                                  "hasErrors": 0,
                                                  "iconSet": {
                                                    "k": "iconset8"
                                                  "messages": [],
                                                  "name": "Rollo SZ",
                                                  "properties": {
                                                    "dawn": 3,
                                                    "dusk": 3,
                                                    "motion": 3,
                                                    "rain": 3,
                                                    "smartphone": 3,
                                                    "smoke": 3,
                                                    "sun": 3,
                                                    "temperature": 3,
                                                    "time": 1,
                                                    "trigger": 2,
                                                    "warning": 3,
                                                    "wind": 3
                                                  "statusesMap": {
                                                    "Position": 60
                                                  "visible": true,
                                                  "uid": "4043a6_1",
                                                  "deviceGroup": 2,
                                                  "did": 1010000,
                                                  "hasErrors": 0,
                                                  "iconSet": {
                                                    "k": "iconset8"
                                                  "messages": [],
                                                  "name": "Rollo Küche",
                                                  "properties": {
                                                    "dawn": 3,
                                                    "dusk": 3,
                                                    "motion": 3,
                                                    "rain": 3,
                                                    "smartphone": 3,
                                                    "smoke": 3,
                                                    "sun": 3,
                                                    "temperature": 3,
                                                    "time": 1,
                                                    "trigger": 2,
                                                    "warning": 3,
                                                    "wind": 3
                                                  "statusesMap": {
                                                    "Position": 0
                                                  "visible": true,
                                                  "uid": "404ba9_1",
                                            <ip>/v4/devices/1010005
                                              "response": "get_device",
                                              "device": {
                                                "deviceGroup": 2,
                                                "did": 1010005,
                                                "hasErrors": 0,
                                                "iconSet": {
                                                  "k": "iconset8"
                                                "messages": [],
                                                "properties": {
                                                  "dawn": 3,
                                                  "dusk": 3,
                                                  "motion": 3,
                                                  "rain": 3,
                                                  "smartphone": 3,
                                                  "smoke": 3,
                                                  "sun": 3,
                                                  "temperature": 3,
                                                  "time": 3,
                                                  "trigger": 3,
                                                  "warning": 3,
                                                  "wind": 3
                                                "statusesMap": {
                                                  "Position": 6
                                                "visible": true,
                                                "uid": "407afd_1",
                                                "origin": "HomePilot",
                                                "sceneConfig": [
                                                  "GOTO_POS_CMD",
                                                  "POS_DOWN_CMD",
                                                  "POS_UP_CMD",
                                                  "STOP_CMD"
                                            Wäre super wenn du dies implementieren könnstest. Viele Dank schon mal im Voraus.
                                            adapter
                                            56
                                            261
                                            45452
