    4. Beta Test js-controller Kiera (v6.0)
    • foxriver76
      foxriver76 Developer @mcm1957 last edited by foxriver76
      @mcm1957 Ansonsten man kann es auch testen als nicht aktiver paw Nutzer, mit aktueller Beta paw installieren, der sollte crashen. Dann controller alpha installieren schauen dass er nicht mehr crashed und auch sonst alle adapter laufen.
        mrjeschke @foxriver76 last edited by
        @foxriver76
        Ich habe den paw-Adapter zum Test installiert.
        Startet mit js-controller alpha6.05 ohne Probleme.
        Es gibt aber ein paar states-Warnungen.
        2024-06-16 17:36:22.405 - warn: paw.0 (5767) State "connection_server_path_namespace.SM-T590.info.battery.level" has no existing object, this might lead to an error in future versions
        2024-06-16 17:36:22.408 - warn: paw.0 (5767) State "connection_server_path_namespace.SM-T590.info.battery.health" has no existing object, this might lead to an error in future versions
        2024-06-16 17:36:22.410 - warn: paw.0 (5767) State "connection_server_path_namespace.SM-T590.info.battery.temperature" has no existing object, this might lead to an error in future versions
        2024-06-16 17:36:22.411 - warn: paw.0 (5767) State "connection_server_path_namespace.SM-T590.info.battery.type" has no existing object, this might lead to an error in future versions
        2024-06-16 17:36:22.413 - warn: paw.0 (5767) State "connection_server_path_namespace.SM-T590.info.battery.voltage" has no existing object, this might lead to an error in future versions
        2024-06-16 17:40:52.816 - warn: paw.0 (11947) State "connection_server_path_namespace.SM-T590.info.tts.status" has no existing object, this might lead to an error in future versions
        2024-06-16 17:40:54.592 - warn: paw.0 (11947) State "connection_server_path_namespace.SM-T590.info.tts.status" has no existing object, this might lead to an error in future versions
          Flugschüler @mrjeschke last edited by Flugschüler
          @mrjeschke Kann ich bestätigen. Funktioniert wieder jeaaaaaaaa!!!!!!
          Diese Warnungen habe ich nicht.
            Homoran Global Moderator Administrators @Flugschüler last edited by
            @flugschüler sagte in Beta Test js-controller Kiera (v6.0):
            Diese Warnungen
            sind beim Neuanlegen der Adapterdatenpunkte "normal".
            M mcm1957 2 Replies Last reply Reply Quote 0
              mrjeschke @Homoran last edited by
              Auch mit
              am Anfang?
              Aber vermutlich habe ich in der app etwas falsch eingestellt.
              War ja nur zum Test.
              • mcm1957
                mcm1957 @Homoran last edited by
                @homoran said in Beta Test js-controller Kiera (v6.0):
                Diese Warnungen
                Normal nur unter Anführungszeichen. 😀
                Das kann in zukünftigen js-controller Versionen zu Problemen führen ... deshalb kommt ja die Warnung. Sollte der Dev fixen. Aber hier nicht sehr realistisch ...
                Aber wichtiger
                ÐANKE @foxriver76 für die super Lösungsidee u rasche Umsetzung.
                Halten wir mal gemeinsam noch ein wenig die Daumen dass sich keine negativen Sideeffects zeigen.
                  Thomas Braun Most Active @mcm1957 last edited by
                  @mcm1957 sagte in Beta Test js-controller Kiera (v6.0):
                  Ich fahre den 6.0.5-alpha.0-20240616-34d893b36 jedenfalls bislang ohne weiteren Auffälligkeiten auf meiner Kiste.
                  • Feuersturm
                    Feuersturm last edited by
                    Update von meinem Testsystem1 Master-Slave System) auf js-controller 6.0.5:
                    Im Admin sieht es so aus:
                    Das hier meldet der Worx Adapter nach dem Update
                    2024-06-16 21:12:52.899 - info: host.ioBrokerTestsystem instance system.adapter.worx.0 started with pid 46448
                    2024-06-16 21:12:53.736 - error: host.ioBrokerTestsystem Caught by controller[0]: node:internal/modules/cjs/loader:1143
                    2024-06-16 21:12:53.739 - error: host.ioBrokerTestsystem Caught by controller[0]: throw err;
                    2024-06-16 21:12:53.742 - error: host.ioBrokerTestsystem Caught by controller[0]: ^
                    2024-06-16 21:12:53.746 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
                    2024-06-16 21:12:53.749 - error: host.ioBrokerTestsystem Caught by controller[0]: Require stack:
                    2024-06-16 21:12:53.752 - error: host.ioBrokerTestsystem Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.worx/main.js
                    2024-06-16 21:12:53.755 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                    2024-06-16 21:12:53.758 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                    2024-06-16 21:12:53.761 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                    2024-06-16 21:12:53.765 - error: host.ioBrokerTestsystem Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                    2024-06-16 21:12:53.768 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.worx/main.js:7:15)
                    2024-06-16 21:12:53.771 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                    2024-06-16 21:12:53.788 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                    2024-06-16 21:12:53.792 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                    2024-06-16 21:12:53.807 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                    2024-06-16 21:12:53.810 - error: host.ioBrokerTestsystem Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                    2024-06-16 21:12:53.813 - error: host.ioBrokerTestsystem Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    2024-06-16 21:12:53.848 - error: host.ioBrokerTestsystem Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.worx/main.js' ]
                    2024-06-16 21:12:53.852 - error: host.ioBrokerTestsystem Caught by controller[0]: }
                    2024-06-16 21:12:53.883 - error: host.ioBrokerTestsystem Caught by controller[0]: Node.js v18.20.3
                    2024-06-16 21:12:53.914 - error: host.ioBrokerTestsystem instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-06-16 21:12:53.917 - info: host.ioBrokerTestsystem Adapter system.adapter.worx.0 needs rebuild and will be restarted afterwards.
                    2024-06-16 21:12:53.933 - info: host.ioBrokerTestsystem system.adapter.worx.0 will be rebuilt
                    2024-06-16 21:12:53.938 - warn: host.ioBrokerTestsystem adapter "worx" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                    2024-06-16 21:12:53.946 - info: host.ioBrokerTestsystem iobroker rebuild
                    Der Adapter ist danach aber i.O. gestartet.
                    Update vom Slave über Admin. Es kommt wieder die Meldung
                    In der Browserconsole sehe ich nichts auffällgies:
                    system.adapter.ical.2 console.ts:40:19
                    system.adapter.ical.3 console.ts:40:19
                    system.adapter.ical.4 console.ts:40:19
                    system.adapter.ical.5 console.ts:40:19
                    system.adapter.icons-material-png.0 console.ts:40:19
                    system.adapter.icons-mfd-svg.0 console.ts:40:19
                    system.adapter.icons-ultimate-png.0 console.ts:40:19
                    system.adapter.influxdb.0 console.ts:40:19
                    system.adapter.javascript.0 console.ts:40:19
                    system.adapter.mqtt.0 console.ts:40:19
                    system.adapter.nina.0 console.ts:40:19
                    system.adapter.openweathermap.0 console.ts:40:19
                    system.adapter.proxmox.0 console.ts:40:19
                    system.adapter.radar-trap.0 console.ts:40:19
                    system.adapter.rainbird.0 console.ts:40:19
                    system.adapter.samsung.0 console.ts:40:19
                    system.adapter.sayit.0 console.ts:40:19
                    system.adapter.scenes.0 console.ts:40:19
                    system.adapter.scheduler.0 console.ts:40:19
                    system.adapter.simple-api.0 console.ts:40:19
                    system.adapter.socketio.0 console.ts:40:19
                    system.adapter.spotify-premium.0 console.ts:40:19
                    system.adapter.sql.0 console.ts:40:19
                    system.adapter.tankerkoenig.0 console.ts:40:19
                    system.adapter.telegram.0 console.ts:40:19
                    system.adapter.tr-064.0 console.ts:40:19
                    system.adapter.trashschedule.0 console.ts:40:19
                    system.adapter.unifi.0 console.ts:40:19
                    system.adapter.valloxmv.0 console.ts:40:19
                    system.adapter.vis.0 console.ts:40:19
                    system.adapter.vis-2.0 console.ts:40:19
                    system.adapter.vis-2-widgets-energy.0 console.ts:40:19
                    system.adapter.vis-2-widgets-gauges.0 console.ts:40:19
                    system.adapter.vis-2-widgets-jaeger-design.0 console.ts:40:19
                    system.adapter.vis-2-widgets-material.0 console.ts:40:19
                    system.adapter.vis-fancyswitch.0 console.ts:40:19
                    system.adapter.vis-google-fonts.0 console.ts:40:19
                    system.adapter.vis-history.0 console.ts:40:19
                    system.adapter.vis-inventwo.0 console.ts:40:19
                    system.adapter.vis-jqui-mfd.0 console.ts:40:19
                    system.adapter.vis-justgage.0 console.ts:40:19
                    system.adapter.vis-map.0 console.ts:40:19
                    system.adapter.vis-materialdesign.0 console.ts:40:19
                    system.adapter.vis-timeandweather.0 console.ts:40:19
                    system.adapter.web.0 console.ts:40:19
                    system.adapter.worx.0 console.ts:40:19
                    getInstances: 512 console.ts:40:19
                    Request update status from: http://192.168.178.77:8081/ 55 console.ts:40:19
                    Request update status from: http://192.168.178.77:8081/ console.ts:40:19
                    Update Testsystem2 (SingleHost)
                    Auch die Meldung
                    Output Browserconsole vom ganzen Updateprozess:
                    iobroker.admin@6.17.14 1486.79b921ab.chunk.js:1:295856
                    [2024-06-16T19:30:39.690Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Stored version: , new version: 6.17.14 1804.affd1d04.chunk.js:2:462544
                    Connected: true 1804.affd1d04.chunk.js:2:462544
                    Translate: esphome 1804.affd1d04.chunk.js:2:462544
                    Translate: time 1804.affd1d04.chunk.js:2:462544
                    Request update status from: http://192.168.178.105:8081/ 8 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:06.567Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:06.568Z] Start reconnect 0 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:06.610Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Request update status from: http://192.168.178.105:8081/ 2 1804.affd1d04.chunk.js:2:462544
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566266610&name=admin aufbauen. socket.io.js:140:22
                    [2024-06-16T19:31:08.910Z] Start reconnect 1 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:08.910Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:08.910Z] Reconnect is already running 1 1804.affd1d04.chunk.js:2:462544
                    Request update status from: http://192.168.178.105:8081/ 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:09.914Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Source-Map-Fehler: Error: NetworkError when attempting to fetch resource.
                    Ressourcen-Adresse: http://192.168.178.105:8081/static/js/1804.affd1d04.chunk.js
                    Source-Map-Adresse: 1804.affd1d04.chunk.js.map
                    Ressourcen-Adresse: http://192.168.178.105:8081/static/js/1486.79b921ab.chunk.js
                    Source-Map-Adresse: 1486.79b921ab.chunk.js.map
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566269915&name=admin aufbauen. socket.io.js:140:22
                    [2024-06-16T19:31:11.993Z] Start reconnect 2 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:11.994Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:11.995Z] Reconnect is already running 2 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:14.006Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566274007&name=admin aufbauen. socket.io.js:140:22
                    [2024-06-16T19:31:16.075Z] Start reconnect 3 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:16.076Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:16.076Z] Reconnect is already running 3 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:19.089Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566279090&name=admin aufbauen. socket.io.js:140:22
                    [2024-06-16T19:31:19.109Z] Start reconnect 4 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:19.110Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:19.111Z] Reconnect is already running 4 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:23.119Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566283120&name=admin aufbauen. socket.io.js:140:22
                    [2024-06-16T19:31:23.151Z] Start reconnect 5 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:23.152Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:23.152Z] Reconnect is already running 5 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:28.154Z] Try to connect 1804.affd1d04.chunk.js:2:462544
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566288155&name=admin aufbauen. socket.io.js:140:22
                    [2024-06-16T19:31:28.179Z] Start reconnect 5 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:28.180Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
                    [2024-06-16T19:31:28.180Z] Reconnect is already running 5 1804.affd1d04.chunk.js:2:462544
                    foxriver76 2 Replies Last reply Reply Quote 0
                      Diamand2k22 last edited by
                      @oxident
                      danke für die neue Version 0.0.6 auf git, ich werde sie testen und dir Feedback geben!
                      • foxriver76
                        foxriver76 Developer @Feuersturm last edited by foxriver76
                        @feuersturm Upsi, eigentlich sollte die nicht als latest getaggt sein und daher nicht per UI verfügbar sein.. habe es gefixt, ist aber auch nicht so wild insgesamt
                        Bzgl der Fehglermeldung beim UI Upgrade habe ich was im Admin geändert aber es gibt noch keine neue Version, da BF da aktuell am umstrukturieren ist.
                        • foxriver76
                          @feuersturm sagte in Beta Test js-controller Kiera (v6.0):
                          Ansonsten ist http://192.168.178.77:8081 die IP vom Slave Admin? Und https ist disabled korrekt?
                          • Feuersturm
                            Feuersturm @foxriver76 last edited by
                            @foxriver76 sagte in Beta Test js-controller Kiera (v6.0):
                            http://192.168.178.77:8081 ist die IP vom Master wo Admin läuft
                            http://192.168.178.78 ist die IP vom Slave, dort läuft kein seperater Admin
                            https ist disabled, korrekt.
                            • foxriver76
                              @feuersturm ah okay, kannst du mal ein issue mit den Details im Admin machen. Weil er fragt da den falschen Host an wenn der Admin gar nicht auf dem Host läuft der geupgradet wird
                              • Feuersturm
                                @foxriver76 die Erklärung passt aber nicht zu meinem zweiten Testsystem in dem Beitrag, wo auch der Fehler kommt, es aber nur ein singlehost ist.
                                F foxriver76 2 Replies Last reply Reply Quote 0
                                  fuchs1978 @Feuersturm last edited by
                                  Gibt es eigentlich im neuen Controller nur die Möglichkeit als Admin ein Adapter Update durchzuführen? Früher konnte man dich einfach auf die neue Versionsnummer drücken. Das geht bei mir nicht mehr.
                                  Feuersturm mcm1957 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active last edited by
                                    @fuchs1978 sagte in Beta Test js-controller Kiera (v6.0):
                                    Admin 7.x am Start? Der ist zurüückgezogen worden.
                                    • Feuersturm
                                      Feuersturm @fuchs1978 last edited by
                                      @fuchs1978 die 6.0.4 ist die aktuelle Beta Version. Die 6.0.5 ist eine Alpha welche gestern fälschlicherweise gestern als beta getaggt war. Daher siehst du sie im Admin gerade nicht
                                      Beantwortet das deine Frage, ansonsten hab ich nicht verstanden was du wissen möchtest.
                                      • da_Woody
                                        da_Woody @Feuersturm last edited by
                                        @feuersturm bei mir ist die 6.0.5 vor 10 minuten aufgetaucht. bis jetzt keine auffälligkeiten.
                                        • foxriver76
                                          @feuersturm Jop aber hier ist es definitiv ein Problem mit der ip evtl auch noch was anderes aber von der ip kann er nix bekommen
                                          • Feuersturm
                                            @foxriver76 ok, issue mache ich dann fertig.
                                            foxriver76 1 Reply Last reply Reply Quote 1
                                            beta js-controller kiera test
                                            39
                                            331
                                            73628
