    4. Beta Test js-controller Kiera (v6.0)
      Thomas Braun Most Active @mcm1957 last edited by
      @mcm1957 sagte in Beta Test js-controller Kiera (v6.0):
      Halten wir mal gemeinsam noch ein wenig die Daumen dass sich keine negativen Sideeffects zeigen.
      Ich fahre den 6.0.5-alpha.0-20240616-34d893b36 jedenfalls bislang ohne weiteren Auffälligkeiten auf meiner Kiste.
      • Feuersturm
        Feuersturm last edited by
        Update von meinem Testsystem1 Master-Slave System) auf js-controller 6.0.5:
        Im Admin sieht es so aus:
        Das hier meldet der Worx Adapter nach dem Update
        2024-06-16 21:12:52.899 - info: host.ioBrokerTestsystem instance system.adapter.worx.0 started with pid 46448
        2024-06-16 21:12:53.736 - error: host.ioBrokerTestsystem Caught by controller[0]: node:internal/modules/cjs/loader:1143
        2024-06-16 21:12:53.739 - error: host.ioBrokerTestsystem Caught by controller[0]: throw err;
        2024-06-16 21:12:53.742 - error: host.ioBrokerTestsystem Caught by controller[0]: ^
        2024-06-16 21:12:53.746 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
        2024-06-16 21:12:53.749 - error: host.ioBrokerTestsystem Caught by controller[0]: Require stack:
        2024-06-16 21:12:53.752 - error: host.ioBrokerTestsystem Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.worx/main.js
        2024-06-16 21:12:53.755 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
        2024-06-16 21:12:53.758 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
        2024-06-16 21:12:53.761 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        2024-06-16 21:12:53.765 - error: host.ioBrokerTestsystem Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-06-16 21:12:53.768 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.worx/main.js:7:15)
        2024-06-16 21:12:53.771 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-06-16 21:12:53.788 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        2024-06-16 21:12:53.792 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
        2024-06-16 21:12:53.807 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
        2024-06-16 21:12:53.810 - error: host.ioBrokerTestsystem Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
        2024-06-16 21:12:53.813 - error: host.ioBrokerTestsystem Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        2024-06-16 21:12:53.848 - error: host.ioBrokerTestsystem Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.worx/main.js' ]
        2024-06-16 21:12:53.852 - error: host.ioBrokerTestsystem Caught by controller[0]: }
        2024-06-16 21:12:53.883 - error: host.ioBrokerTestsystem Caught by controller[0]: Node.js v18.20.3
        2024-06-16 21:12:53.914 - error: host.ioBrokerTestsystem instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-06-16 21:12:53.917 - info: host.ioBrokerTestsystem Adapter system.adapter.worx.0 needs rebuild and will be restarted afterwards.
        2024-06-16 21:12:53.933 - info: host.ioBrokerTestsystem system.adapter.worx.0 will be rebuilt
        2024-06-16 21:12:53.938 - warn: host.ioBrokerTestsystem adapter "worx" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        2024-06-16 21:12:53.946 - info: host.ioBrokerTestsystem iobroker rebuild
        Der Adapter ist danach aber i.O. gestartet.
        Update vom Slave über Admin. Es kommt wieder die Meldung
        In der Browserconsole sehe ich nichts auffällgies:
        system.adapter.ical.2 console.ts:40:19
        system.adapter.ical.3 console.ts:40:19
        system.adapter.ical.4 console.ts:40:19
        system.adapter.ical.5 console.ts:40:19
        system.adapter.icons-material-png.0 console.ts:40:19
        system.adapter.icons-mfd-svg.0 console.ts:40:19
        system.adapter.icons-ultimate-png.0 console.ts:40:19
        system.adapter.influxdb.0 console.ts:40:19
        system.adapter.javascript.0 console.ts:40:19
        system.adapter.mqtt.0 console.ts:40:19
        system.adapter.nina.0 console.ts:40:19
        system.adapter.openweathermap.0 console.ts:40:19
        system.adapter.proxmox.0 console.ts:40:19
        system.adapter.radar-trap.0 console.ts:40:19
        system.adapter.rainbird.0 console.ts:40:19
        system.adapter.samsung.0 console.ts:40:19
        system.adapter.sayit.0 console.ts:40:19
        system.adapter.scenes.0 console.ts:40:19
        system.adapter.scheduler.0 console.ts:40:19
        system.adapter.simple-api.0 console.ts:40:19
        system.adapter.socketio.0 console.ts:40:19
        system.adapter.spotify-premium.0 console.ts:40:19
        system.adapter.sql.0 console.ts:40:19
        system.adapter.tankerkoenig.0 console.ts:40:19
        system.adapter.telegram.0 console.ts:40:19
        system.adapter.tr-064.0 console.ts:40:19
        system.adapter.trashschedule.0 console.ts:40:19
        system.adapter.unifi.0 console.ts:40:19
        system.adapter.valloxmv.0 console.ts:40:19
        system.adapter.vis.0 console.ts:40:19
        system.adapter.vis-2.0 console.ts:40:19
        system.adapter.vis-2-widgets-energy.0 console.ts:40:19
        system.adapter.vis-2-widgets-gauges.0 console.ts:40:19
        system.adapter.vis-2-widgets-jaeger-design.0 console.ts:40:19
        system.adapter.vis-2-widgets-material.0 console.ts:40:19
        system.adapter.vis-fancyswitch.0 console.ts:40:19
        system.adapter.vis-google-fonts.0 console.ts:40:19
        system.adapter.vis-history.0 console.ts:40:19
        system.adapter.vis-inventwo.0 console.ts:40:19
        system.adapter.vis-jqui-mfd.0 console.ts:40:19
        system.adapter.vis-justgage.0 console.ts:40:19
        system.adapter.vis-map.0 console.ts:40:19
        system.adapter.vis-materialdesign.0 console.ts:40:19
        system.adapter.vis-timeandweather.0 console.ts:40:19
        system.adapter.web.0 console.ts:40:19
        system.adapter.worx.0 console.ts:40:19
        getInstances: 512 console.ts:40:19
        Request update status from: http://192.168.178.77:8081/ 55 console.ts:40:19
        Request update status from: http://192.168.178.77:8081/ console.ts:40:19
        Update Testsystem2 (SingleHost)
        Auch die Meldung
        Output Browserconsole vom ganzen Updateprozess:
        iobroker.admin@6.17.14 1486.79b921ab.chunk.js:1:295856
        [2024-06-16T19:30:39.690Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Stored version: , new version: 6.17.14 1804.affd1d04.chunk.js:2:462544
        Connected: true 1804.affd1d04.chunk.js:2:462544
        Translate: esphome 1804.affd1d04.chunk.js:2:462544
        Translate: time 1804.affd1d04.chunk.js:2:462544
        Request update status from: http://192.168.178.105:8081/ 8 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:06.567Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:06.568Z] Start reconnect 0 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:06.610Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Request update status from: http://192.168.178.105:8081/ 2 1804.affd1d04.chunk.js:2:462544
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566266610&name=admin aufbauen. socket.io.js:140:22
        [2024-06-16T19:31:08.910Z] Start reconnect 1 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:08.910Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:08.910Z] Reconnect is already running 1 1804.affd1d04.chunk.js:2:462544
        Request update status from: http://192.168.178.105:8081/ 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:09.914Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Source-Map-Fehler: Error: NetworkError when attempting to fetch resource.
        Ressourcen-Adresse: http://192.168.178.105:8081/static/js/1804.affd1d04.chunk.js
        Source-Map-Adresse: 1804.affd1d04.chunk.js.map
        Ressourcen-Adresse: http://192.168.178.105:8081/static/js/1486.79b921ab.chunk.js
        Source-Map-Adresse: 1486.79b921ab.chunk.js.map
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566269915&name=admin aufbauen. socket.io.js:140:22
        [2024-06-16T19:31:11.993Z] Start reconnect 2 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:11.994Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:11.995Z] Reconnect is already running 2 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:14.006Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566274007&name=admin aufbauen. socket.io.js:140:22
        [2024-06-16T19:31:16.075Z] Start reconnect 3 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:16.076Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:16.076Z] Reconnect is already running 3 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:19.089Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566279090&name=admin aufbauen. socket.io.js:140:22
        [2024-06-16T19:31:19.109Z] Start reconnect 4 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:19.110Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:19.111Z] Reconnect is already running 4 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:23.119Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566283120&name=admin aufbauen. socket.io.js:140:22
        [2024-06-16T19:31:23.151Z] Start reconnect 5 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:23.152Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:23.152Z] Reconnect is already running 5 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:28.154Z] Try to connect 1804.affd1d04.chunk.js:2:462544
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566288155&name=admin aufbauen. socket.io.js:140:22
        [2024-06-16T19:31:28.179Z] Start reconnect 5 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:28.180Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
        [2024-06-16T19:31:28.180Z] Reconnect is already running 5 1804.affd1d04.chunk.js:2:462544
        foxriver76 2 Replies Last reply Reply Quote 0
          Diamand2k22 last edited by
          @oxident
          danke für die neue Version 0.0.6 auf git, ich werde sie testen und dir Feedback geben!
          • foxriver76
            foxriver76 Developer @Feuersturm last edited by foxriver76
            @feuersturm Upsi, eigentlich sollte die nicht als latest getaggt sein und daher nicht per UI verfügbar sein.. habe es gefixt, ist aber auch nicht so wild insgesamt
            Bzgl der Fehglermeldung beim UI Upgrade habe ich was im Admin geändert aber es gibt noch keine neue Version, da BF da aktuell am umstrukturieren ist.
            • foxriver76
              @feuersturm sagte in Beta Test js-controller Kiera (v6.0):
              Ansonsten ist http://192.168.178.77:8081 die IP vom Slave Admin? Und https ist disabled korrekt?
              • Feuersturm
                Feuersturm @foxriver76 last edited by
                @foxriver76 sagte in Beta Test js-controller Kiera (v6.0):
                http://192.168.178.77:8081 ist die IP vom Master wo Admin läuft
                http://192.168.178.78 ist die IP vom Slave, dort läuft kein seperater Admin
                https ist disabled, korrekt.
                • foxriver76
                  @feuersturm ah okay, kannst du mal ein issue mit den Details im Admin machen. Weil er fragt da den falschen Host an wenn der Admin gar nicht auf dem Host läuft der geupgradet wird
                  • Feuersturm
                    @foxriver76 die Erklärung passt aber nicht zu meinem zweiten Testsystem in dem Beitrag, wo auch der Fehler kommt, es aber nur ein singlehost ist.
                    F foxriver76 2 Replies Last reply Reply Quote 0
                      fuchs1978 @Feuersturm last edited by
                      Gibt es eigentlich im neuen Controller nur die Möglichkeit als Admin ein Adapter Update durchzuführen? Früher konnte man dich einfach auf die neue Versionsnummer drücken. Das geht bei mir nicht mehr.
                      Feuersturm mcm1957 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active last edited by
                        @fuchs1978 sagte in Beta Test js-controller Kiera (v6.0):
                        Admin 7.x am Start? Der ist zurüückgezogen worden.
                        • Feuersturm
                          Feuersturm @fuchs1978 last edited by
                          @fuchs1978 die 6.0.4 ist die aktuelle Beta Version. Die 6.0.5 ist eine Alpha welche gestern fälschlicherweise gestern als beta getaggt war. Daher siehst du sie im Admin gerade nicht
                          Beantwortet das deine Frage, ansonsten hab ich nicht verstanden was du wissen möchtest.
                          • da_Woody
                            da_Woody @Feuersturm last edited by
                            @feuersturm bei mir ist die 6.0.5 vor 10 minuten aufgetaucht. bis jetzt keine auffälligkeiten.
                            • foxriver76
                              @feuersturm Jop aber hier ist es definitiv ein Problem mit der ip evtl auch noch was anderes aber von der ip kann er nix bekommen
                              • Feuersturm
                                @foxriver76 ok, issue mache ich dann fertig.
                                foxriver76 1 Reply Last reply Reply Quote 1
                                • foxriver76
                                  6.0.5 ist jetzt offizielle Beta mit den Änderungen der Alpha
                                  • foxriver76
                                    @feuersturm Danke. Habe mal grob geschaut. Bitte im Issue das Host Objekt vom Slave posten und nach Möglichkeit auch die iobroker.json vom Slave. Da er Daten aus den beiden Quellen nutzt um die IP zu finden.
                                    • mcm1957
                                      mcm1957 @fuchs1978 last edited by
                                      @fuchs1978 said in Beta Test js-controller Kiera (v6.0):
                                      Wenn du damit meinst dass es in der Adapterliste im Admin keinen Update Button gibt: das ist ein bekannter Fehler in admin 7.0.1. Admin 7.0.1 wurde zurückgezogen. Bitte downgrade auf aktuelle LATEST Version 6.x.x)
                                      • Feuersturm
                                        Issue ist angelegt https://github.com/ioBroker/ioBroker.admin/issues/2505
                                        Feuer-sturm created this issue in ioBroker/ioBroker.admin
                                        closed [bug]: js-controller update - unexpected character at line 1 coloum 1 of the JSON data #2505
                                        • JB_Sullivan
                                          JB_Sullivan last edited by
                                          Möglicherweise hat es nichts mit dem js-controller zu tun, aber ich bilde mir ein, das ich bei Adapter Installationen/Updates VOR js-controller 6.xxx nicht diese ganzen Warnmeldungen hatte.
                                          Ja ich weiß, sind "nur" Warnmeldungen, aber auch Warnungen haben ja oftmals einen Hintergrund. Kann man das hier generell ignorieren? Wenn die Meldungen keine Bedeutung haben, kann man das für den Enduser nicht ausblendbar machen?
                                          Also eine Checkbox, ob man die Meldungen abschalten möchte? So könnten Entwickler, die mit diesen Meldungen ggf. mehr anfangen können, sich diese Meldungen auch weiterhin anzeigen lassen.
                                          Nur mal so ins unreine gesprochen ......
                                          npm warn ERESOLVE overriding peer dependency
                                          npm warn While resolving: @iobroker/adapter-core@3.1.4 npm warn Found: @iobroker/types@6.0.0 npm warn node_modules/iobroker.admin/node_modules/@iobroker/types npm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14 npm warn node_modules/iobroker.admin npm warn iobroker.admin@"stable" from the root project npm warn npm warn Could not resolve dependency: npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14 npm warn node_modules/iobroker.admin npm warn npm warn Conflicting peer dependency: @iobroker/types@5.0.19 npm warn node_modules/@iobroker/types npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14 npm warn node_modules/iobroker.admin
                                          foxriver76 ESP8266 Thomas Braun 3 Replies Last reply Reply Quote 0
                                          • foxriver76
                                            foxriver76 Developer @JB_Sullivan last edited by
                                            @jb_sullivan Gerne admin issue machen, dort ist https://github.com/ioBroker/ioBroker.admin/blob/761ded4f4947cef7d051dd74e11b5f785e652c25/packages/admin/package.json#L28 types als Production Dependency angegeben, das ist definitiv falsch.
                                            1.0k
                                            beta js-controller kiera test
                                            39
                                            331
                                            73710
