    4. Bose Soundtouch steuern
      der_Auge last edited by
      Habe die Version 0.1.3 heute neu installiert
      2017-12-28 11:39:20.633  - info: iobroker add bosesoundtouch
      2017-12-28 11:39:22.359  - info: iobroker npm install iobroker.bosesoundtouch --production --prefix "/opt/iobroker" (System call)
      2017-12-28 11:40:18.905  - info: iobroker host.ioServer install adapter bosesoundtouch
      2017-12-28 11:40:18.938  - info: iobroker got /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin
      2017-12-28 11:40:18.973  - info: iobroker upload [2] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/words.js words.js application/javascript
      2017-12-28 11:40:19.081  - info: iobroker upload [1] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/index.html index.html text/html
      2017-12-28 11:40:19.163  - info: iobroker upload [0] bosesoundtouch.admin /opt/iobroker/node_modules/iobroker.bosesoundtouch/admin/bosesoundtouch.png bosesoundtouch.png image/png
      2017-12-28 11:40:19.321  - info: iobroker host.ioServer object system.adapter.bosesoundtouch created
      2017-12-28 11:40:19.370  - info: iobroker host.ioServer create instance bosesoundtouch
      2017-12-28 11:40:19.396  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.outputCount created
      2017-12-28 11:40:19.435  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.inputCount created
      2017-12-28 11:40:19.475  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.uptime created
      2017-12-28 11:40:19.511  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.memRss created
      2017-12-28 11:40:19.547  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.memHeapTotal created
      2017-12-28 11:40:19.582  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.memHeapUsed created
      2017-12-28 11:40:19.616  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.connected created
      2017-12-28 11:40:19.650  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0.alive created
      2017-12-28 11:40:19.681  - info: host.ioServer object change system.adapter.bosesoundtouch.0
      2017-12-28 11:40:19.694  - info: iobroker host.ioServer object system.adapter.bosesoundtouch.0 created
      2017-12-28 11:40:19.718  - info: iobroker exit 0
      2017-12-28 11:42:42.173  - info: host.ioServer object change system.adapter.bosesoundtouch.0
      2017-12-28 11:43:36.740  - info: host.ioServer object change system.adapter.bosesoundtouch.0
      2017-12-28 11:43:36.757  - info: host.ioServer instance system.adapter.bosesoundtouch.0 started with pid 16778
      2017-12-28 11:43:37.128  - error: host.ioServer instance system.adapter.bosesoundtouch.0 terminated with code 10 (Cannot find start file of adapter)
      2017-12-28 11:43:37.130  - info: host.ioServer Restart adapter system.adapter.bosesoundtouch.0 because enabled
      2017-12-28 11:44:07.144  - info: host.ioServer instance system.adapter.bosesoundtouch.0 started with pid 16784
      2017-12-28 11:44:07.471  - error: host.ioServer instance system.adapter.bosesoundtouch.0 terminated with code 10 (Cannot find start file of adapter)
      2017-12-28 11:44:07.471  - info: host.ioServer Restart adapter system.adapter.bosesoundtouch.0 because enabled
      leider läuft der Adapter nicht
      Jürgen
        apollon77 last edited by
        Versuch bitte mal ein „iobroker upload bosesoundtouch“. Geht es dann?
        • SwedishChef
          SwedishChef last edited by
          @apollon77:
          @SwedishChef: legst du diese States or io-Package Definition an? Das hat aktuell noch das Problems als das nur bei anlegen einer Instanz ausgeführt wird und danach nicht nochmal 😞 musst du aktuell im Skript beim Start prüfen ob es da ist und ggf neu anlegen … ` Grundsätzlich danke für die schnelle Hilfe, verstehe aber leider nur Bahnhof. Verwende setObjectNotExist().
          Könntest du eventuell im Code nachsehen, ob's richtig ist oder nicht?
          Gesendet von meinem A0001 mit Tapatalk
            @apollon77:
            Versuch bitte mal ein „iobroker upload bosesoundtouch“. Geht es dann? `
            leider keine Verbesserung
            • SwedishChef
              @der_Auge:
              @apollon77:
              Versuch bitte mal ein „iobroker upload bosesoundtouch“. Geht es dann? leider keine Verbesserung Hatte eh das gleiche Problem, siehe weiter oben!
                Ok, mit "setObjectNotExists" ist alles gut. States/Objekte "reloaded" im Admin?
                Schaue später mal in den Code
                  Master77 last edited by
                  Bin jetzt erst mal wieder auf der Version 0.1.3. Sobald es was neues bezüglich Play Everywhere gibt werde ich es testen.
                  Gruß Markus
                  Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                  • N
                    Nanouk last edited by
                    Hallo in die Runde,
                    PlayEverywhere funktioniert doch.
                    Als Swedishchef das veröffentlicht hat hab ich es gleich getestet.
                    Leider hatte ich mir mein komplettes System zerschossen und hab gestern erst anfangen können alles neu aufzusetzen.
                    Läuft zwar noch nicht alles wieder aber mit das erste war jetzt der Bose Adapter.
                    Eben nochmal PlayEverywhere gecheckt, funktioniert.
                    Viel rum versucht habe ich noch nicht.
                    Die Soundtouch10 in der Küche nutze ich aus Gewohnheit immer als Master.
                    Sobald ich in den Objekten den Haken bei playEverywhere setze gehen alle anderen mit an.
                    Ich hab es jetzt nur noch nicht mit anderen als Master versucht, außer der Soundtouch in der Küche, was bei mir eben bosesoundouch.0 ist.
                    Nanouk
                      Hallo zusammen
                      Ich habe bei mir die Soundtouch 130 auf bosesoundtouch.0 und meine Soundtouch 10 auf bosesoundtouch.1. (Ist .0 immer Master ?)
                      Ich habe wie angegeben Play Everywhere Version installiert. Die richtige Version hat er mir auch angezeigt, jedoch wird mir die Option in Objekte nicht angezeigt. Wo genau muss man denn den Haken setzen. Ein Bild wäre eventuell von Vorteil.
                      Gruß Markus
                      • N
                        Nein, .0 muss nicht zwingend Master sein.
                        Ich hab das bei allen Instanzen.
                        Den Status durch Haken auf True setzen, dann laufen alle anderen auch.
                        ~~![](</s><URL url=)http://leenolium.de/media/bose3.jpg" />
                        Nanouk
                        Sorry für das unscharfe Bild, hoffe Du kannst es erkennen.~~
                          Hi
                          Bild ist OK. Kann alles erkennen.
                          Ist das die Version 0.0.10 ?
                          Gruß Markus
                          • N
                            ja, ist die 0.0.10
                            • SwedishChef
                              Wenn playEverywhere eh schon grob funktioniert (hab ich offensichtlich übersehen), kann ich das ja auf den master branch mergen. Detailverbesserungen können dann auch hier noch gemacht werden.
                              Vielleicht sollte ich mir auch eine zweite
                              SoundTouch Box zulegen? 🙂
                                Fürchte muss ich auch … vor allem auch um ggf mit der "SoundTouch Audio Notification API" was zu machen. Meine Lifestyle wird das wohl nie unterstützen ...
                                Ingo
                                • N
                                  Na wenn das mal geht, dann kann mein Pi mit Fhem in den Ruhestand.
                                  Das ist der einzige Grund warum der noch läuft. :lol:
                                    ssiersdorfer last edited by
                                    Hallo zusammen.
                                    beschäftige mich jetzt auch mal mit dem Soundtouch Adapter.
                                    Das Teil ist klasse.
                                    Bei einem Gerät funktioniert das wunderbar. Wenn ich aber mehrere Instanzen erzeuge kann ich nur die erste Instanz bedienen.
                                    Insgesamt habe ich 5 Geräte.
                                    Im Anhang mal Fotos zum Verständnis.
                                    Die Buttons werden im Editier Modus angezeigt. Sobald ich den Editiermodus verlasse wird nix mehr angezeigt.
                                    Name, IP usw. geht.
                                    Weiss hier jemand was das sein könnte?
                                      DerOstfriese last edited by
                                      Leider kann ich dir nicht sagen woran das liegt, aber deine Ansicht gefällt mir - könntest du die wohl hier online stellen? Werde mich gleich mal dran machen und die "Everywhere" Funktion testen.
                                        cuuira last edited by
                                        Hallo Leute
                                        Bin komplett neu bei ioBroker und habe auch schon ein paar Adapter installiert, welche auch laufen… nun wollte ich den bosesoundtouch Adapter installieren, was laut Log auch passiert ist. Aber leider sehe ich ihn nicht unter Instanzen und bei Adapterreiter steht die ganze Zeit bearbeite. Habe den Adapter über die Katze unter Adapter installiert und diese https://github.com/SwedishChef1/ioBroke … all/master genutzt.
                                        Kann mir einer da weiter helfen?
                                        Gruß Cuuira
                                          @cuuira:
                                          Hallo Leute
                                          Gruß Cuuira `
                                          Hallo Cuuira
                                          willkommen in Forum und bei ioBroker
                                          du musst auf der Admin-Seite noch auf das kleine "+" rechts klicken um eine Instanz zu installieren
                                          Jürgen
                                            @der_Auge:
                                            du musst auf der Admin-Seite noch auf das kleine "+" rechts klicken um eine Instanz zu installieren `
                                            Würde ich ja gerne… aber mehr als auf meinem Bild oben steht dort nicht mehr!!! Es werden keine Adapter mehr angezeigt!
                                            286
                                            65429
