    4. Test VIS 2 inventwo Widgets
      Digi-Bit @icebear last edited by
      Ich wollte mal höfflich nachfragen ob die Tabellen auch noch kommen für VIS-2 ?
         "tpl": "i-vis-jsontable",
         "data": {
           "bindings": [],
           "oid": "0_userdata.0.10_VIS-TAB8.Energie.3EM_1.Phase_C.2024.03_March.json",
           "iTblRowLimit": 33,
           "g_common": true,
           "iTableRefreshRate": 0,
           "iTblSortOrder": "asc",
           "iColCount": 3,
           "iOpacityAll": "1",
           "g_i-css": true,
           "iTblRowEvenColor": "",
           "iTblRowUnevenColor": "",
           "iTblHeaderColor": "",
           "iRowSpacing": 0,
           "iTblRowEvenTextColor": "#ffffff",
           "iTblRowUnevenTextColor": "#ffffff",
           "iTblHeaderTextColor": "#ffffff",
           "iBorderSize": "0",
           "iBorderStyleLeft": "none",
           "iBorderStyleRight": "none",
           "iBorderStyleUp": "none",
           "iBorderStyleDown": "none",
           "iBorderColor": "#ffffff",
           "iColShow1": "true",
           "iColName1": null,
           "iColAttr1": "day",
           "iTblCellPlaceholder1": null,
           "iColWidth1": "40",
           "iColPreText1": null,
           "iColAfterText1": "",
           "iTblHeadTextAlign1": "center",
           "iTblTextAlign1": "left",
           "iTblCellFormat1": "normal",
           "iTblCellDatetimeFormat1": null,
           "iTblCellDatetimeFormatInfo1": null,
           "iTblCellImageSize1": "200",
           "iTblCellBooleanCheckbox1": "false",
           "iTblCellBooleanColorFalse1": "#ff0000",
           "iTblCellBooleanColorTrue1": "#00ff00",
           "iTblCellNumberDecimals1": "2",
           "iTblCellNumberDecimalSeperator1": ".",
           "iTblCellNumberThousandSeperator1": ",",
           "iTblCellThresholdsDp1": null,
           "iTblCellThresholdsText1": null,
           "g_iTableCol-1": true,
           "iColShow2": "true",
           "iColName2": null,
           "iColAttr2": "kw",
           "iTblCellPlaceholder2": null,
           "iColWidth2": "70",
           "iColPreText2": null,
           "iColAfterText2": " KW",
           "iTblHeadTextAlign2": "center",
           "iTblTextAlign2": "right",
           "iTblCellFormat2": "normal",
           "iTblCellDatetimeFormat2": null,
           "iTblCellDatetimeFormatInfo2": null,
           "iTblCellImageSize2": "200",
           "iTblCellBooleanCheckbox2": "false",
           "iTblCellBooleanColorFalse2": "#ff0000",
           "iTblCellBooleanColorTrue2": "#00ff00",
           "iTblCellNumberDecimals2": "2",
           "iTblCellNumberDecimalSeperator2": ".",
           "iTblCellNumberThousandSeperator2": ",",
           "iTblCellThresholdsDp2": null,
           "iTblCellThresholdsText2": null,
           "g_iTableCol-2": true,
           "iColShow3": "true",
           "iColName3": null,
           "iColAttr3": "euro",
           "iTblCellPlaceholder3": null,
           "iColWidth3": null,
           "iColPreText3": null,
           "iColAfterText3": " €",
           "iTblHeadTextAlign3": "center",
           "iTblTextAlign3": "right",
           "iTblCellFormat3": "normal",
           "iTblCellDatetimeFormat3": null,
           "iTblCellDatetimeFormatInfo3": null,
           "iTblCellImageSize3": "200",
           "iTblCellBooleanCheckbox3": "false",
           "iTblCellBooleanColorFalse3": "#ff0000",
           "iTblCellBooleanColorTrue3": "#00ff00",
           "iTblCellNumberDecimals3": "2",
           "iTblCellNumberDecimalSeperator3": ".",
           "iTblCellNumberThousandSeperator3": ",",
           "iTblCellThresholdsDp3": null,
           "iTblCellThresholdsText3": null,
           "g_iTableCol-3": true,
           "g_css_font_text": true,
           "visibility-oid": "0_userdata.0.10_VIS-TAB8.Energie.3EM_1.Date_for_VIS",
           "visibility-cond": ">=",
           "visibility-val": "10032024",
           "visibility-groups": null,
           "visibility-groups-action": "hide",
           "g_visibility": true
         "style": {
           "bindings": [],
           "left": "600",
           "top": "96",
           "width": "190",
           "height": "540",
           "font-weight": "normal",
           "font-size": "12px"
         "widgetSet": "vis-inventwo",
         "_id": "i000001"
      Wäre echt Toll !
      mfg
      Digi-Bit
      jkvarel 1 Reply Last reply Reply Quote 1
      • jkvarel
        jkvarel Developer @Digi-Bit last edited by
        @digi-bit ja wird kommen. Geplant ist, dass alles was der VIS 1 Adapter kann auch im VIS 2 Adapter enthalten sein wird. Wann was kommt kann ich leider nicht sagen.
        icebear 1 Reply Last reply Reply Quote 3
        • icebear
          icebear @jkvarel last edited by
          @jkvarel
          Ich hätte auch noch höflicherweise einen ("dinglichkeitswunsch") bei der Entwicklung der Widgets.
          Könnt ihr bitte beim 'View in Dialog' Widget die Optionen wie beim alten PopUp Widget einfügen, das man die Rahmenbreite und Farbe sowie die Position an der der Dialog erscheint verändern kann.
          Das fehlt mir echt.
          mfg
          Icebear
            @jkvarel sagte in Test VIS 2 inventwo Widgets:
            Kein ding, alles braucht seine Zeit 😉
            Wollte nur wissen ob es überhaupt irgend wann kommt, ich kann warten !
            mfg
            Digi-Bit
              sigi234 Forum Testing Most Active @Digi-Bit last edited by
              @digi-bit sagte in Test VIS 2 inventwo Widgets:
              https://github.com/inventwo/ioBroker.vis-2-widgets-inventwo/issues
              • icebear
                icebear last edited by icebear
                Hallo, beim Slider Widget will ich mir die Schritte anzeigen lassen, das funktioniert auch im Editor und in der Runtime auf dem Laptop.
                Wenn ich mir die VIS dann aber auf dem Tablet im FullyKiosk anzeigen lasse, dann seh ich die Schritte nicht mehr.
                Erst hab ich gedacht ich muß noch irgendwo die Farbe der Schrift festlegen (wäre übrigens noch ein Enhancement für den Slider) aber das get beim Slider Widget ja nicht explizit, sondern nur über Global Font&Text
                Hat das noch jemand, das die Schritte nicht angezeigt werden?
                Edit: Wenn ich den Hintergrund vom Widget auf 'Weiß' (#ffffff) setzte, dann seh ich auch auf dem Tablet die Schritte.
                Ergo, da ich ich auf dem Tablet einen dunkle Hintergrund verwende und die Schriftfarbe sich nicht anpassen läßt, wird auch nix angezeigt. (Nur warum gehts dann im Editor?)
                Edit2: Issue #25
                  heinzie last edited by
                  Habe heute auch mal die neue VIS 2 installiert und dazu dann die Version 0.1.9 der inventwo Widget
                  Leider werden mir diese aber im VIS 2 Editor (auch nach Neustart) nicht angezeigt.
                  Muss ich dazu noch irgend etwas anderes machen?
                  • Merlin123
                    Merlin123 @heinzie last edited by
                    @heinzie Vis2 mal neu gestartet? Wie hast Du die Widgets installiert?
                    Bei mir sieht das so aus:
                      heinzie @Merlin123 last edited by heinzie
                      @merlin123 sagte in Test VIS 2 inventwo Widgets:
                      Die VIS habe ich mehrmals neu gestartet und auch den iobroker einmal neu.
                      Geladen habe ich von hier und dann über die Katze installiert.
                      • Merlin123
                        @heinzie Dann ist das Problem klar... Deinstalliere den und installiere ihn, wie hier im ersten Post beschrieben:
                        Der Adapter ist noch nicht in der Adapterliste drin (pull request ist bereits erstellt), kann aber über npm installiert werden, nicht mit dem GitHub Link. Das klappt nicht.
                        H mcm1957 2 Replies Last reply Reply Quote 0
                          Vielen Dank, hat funktioniert.
                          • mcm1957
                            mcm1957 @Merlin123 last edited by
                            @merlin123 said in Test VIS 2 inventwo Widgets:
                            Bitte verweise nur dann auf alte Postings wenn du weist was du schreibst. Dein Posting ist schlicht und einfach FALSCH.
                            Der Adapter vis-2-widgets-inventwo ist sowohl im LATEST als auch im STABLE Repositiry verfügbar.
                            • mcm1957
                              mcm1957 @mcm1957 last edited by
                              @jkvarel
                              Bitte korrier gelegtlich dein Eröffnungsposting. Der Adapter sollte ganz normal installierbar sein. Wenn nicht wäre der Fehler zu suchen
                              DANKE
                                e-i-k-e last edited by e-i-k-e
                                Bei mir wird wird es unter vis-2 auch nicht angezeigt,. Hab den Adapter soeben mal neu installiert und vis-2 neu gestartet, keine Besserung,
                                • Merlin123
                                  Merlin123 @e-i-k-e last edited by
                                  @e-i-k-e Wie hast Du installiert?
                                    ich mache gerade meine ersten versuche mit den inventwo Widgets.
                                    Ein Sache ist mir jetzt aufgefallen, wenn ich einen normalen Button verwende mit z.B. Hintergrundfarbe grün für true und rot für false ( Zustand von dem verwendeten Objekt) funktioniert das im Browser auf dem PC einwandfrei.
                                    Wenn ich das auf einem Tablet (Android) mache ist die Funktion auch gegeben. Beim Umschalten wechselt die Farbe des Button dann aber nicht direkt von grün nach rot sondern zeigt zwischendurch noch einmal die Farbe blau an. Macht er aber nur wenn ich direkt am Tablet bediene.
                                    Ist das ggf. eine Einstellungssache?
                                      heinzie @heinzie last edited by
                                      @heinzie hat sich hier erledigt, scheint am Browser zu liegen
                                      • Merlin123
                                        Hab hier ein komisches Problem. Seit kurzem wird auf dem Handy mit Chrome alles so angezeigt. Ich kann jetzt aber leider nicht sagen, seit wann genau das ist, da ich die VIS auf dem Handy nur selten aufrufe:
                                        Auf dem Rechner und mit dem Fullybrowser sieht es so aus:
                                        Hat jemand eine Idee, was das Problem sein könnte?
                                        • icebear
                                          Meinst du das die Widgets auf dem Handy schwarz sind und im Fullybrowser weiß?
                                          Oder was ist das Problem?
                                          • Merlin123
                                            Merlin123 @icebear last edited by Merlin123
                                            @icebear
                                            Update:
                                            Hab eben die Ursache gefunden:
                                            Wenn beim Standardzustand die Inhaltsfarbe usw. nicht gesetzt ist scheint Chrome unter Android sich anders als Chrome unter Windows oder der Fullybrowser zu verhalten.
                                            Das ist ja seltsam....
                                            Ja genau. Die Farben stimmen da absolut nicht. Hier noch andere Widgets, wo man es auch sieht. (Oder teilweise halt nichts mehr sieht)
                                            icebear 1 Reply Last reply Reply Quote 0
                                            134
                                            22651
