    3. Einsteigerfragen
    4. ioBroker Admin und Vis startet nicht mehr
      Thomas Braun Most Active @x.Oli last edited by
      @x-oli sagte in ioBroker Admin und Vis startet nicht mehr:
      JavaScript heap out of memory
      Da geht dir auf dem sog. Heap der Speicher aus.
      Wie bist du denn da insgesamt unterwegs?
      iob diag
      sagt?
      • X
          @x-oli
          Schönes Urlaubsbild. War das Essen gut? Wetter auch?
          • X
            Der lädt und lädt und lädt .. dachte damit kann man "schon mal" was anfangen
            • X
              x.Oli last edited by x.Oli
              Skript v.2024-05-22
              *** BASE SYSTEM ***
              cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
              Hardware Vendor :
              Kernel          : armv7l
              Userland        : 32 bit
              Docker          : v6.1.0
              Virtualization  : Docker
              Kernel          : armv7l
              Userland        : 32 bit
              Systemuptime and Load:
               15:32:48 up  4:47,  0 users,  load average: 2.02, 2.05, 2.48
              CPU threads: 4
              *** Time and Time Zones ***
              Mon Jun 17 13:32:48 UTC 2024
              Mon Jun 17 15:32:48 CEST 2024
              CEST +0200
              Etc/UTC
              *** Users and Groups ***
              User that called 'iob diag':
              root
              HOME=/root
              GROUPS=root
              js-controller is not running
              *** Display-Server-Setup ***
              Display-Server: false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            8.1G        699M        5.1G        267M        2.3G        6.1G
              Swap:            23G          0B         23G
              Total:           31G        699M         28G
              Active iob-Instances:   1
                       8097 M total memory
                        699 M used memory
                       1753 M active memory
                        922 M inactive memory
                       5100 M free memory
                        357 M buffer memory
                       1940 M swap cache
                      23447 M total swap
                          0 M used swap
                      23447 M free swap
              top - 15:32:49 up  4:47,  0 users,  load average: 2.02, 2.05, 2.48
              Tasks:  11 total,   1 running,  10 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 15.4 us, 13.8 sy,  0.0 ni, 70.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8097.5 total,   5099.9 free,    699.8 used,   2297.8 buff/cache
              MiB Swap:  23447.2 total,  23447.2 free,      0.0 used.   6050.8 avail Mem
              *** FILESYSTEM ***
              Filesystem            Type     Size  Used Avail Use% Mounted on
              overlay               overlay  2.0T   28G  2.0T   2% /
              tmpfs                 tmpfs     64M     0   64M   0% /dev
              tmpfs                 tmpfs    4.0G     0  4.0G   0% /sys/fs/cgroup
              shm                   tmpfs     64M     0   64M   0% /dev/shm
              /dev/mapper/cachedev1 ext4     2.0T   28G  2.0T   2% /opt/iobroker
              [Mon Jun 17 10:45:33 2024] ext4_init_reserve_inode_table0: sda1, 5
              [Mon Jun 17 10:45:33 2024] ext4_init_reserve_inode_table2: sda1, 5, 0, 0, 4096
              [Mon Jun 17 10:45:33 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: data=ordered,barrier=1,nodelalloc
              [Mon Jun 17 10:45:34 2024] ext4_init_reserve_inode_table0: sda1, 5
              [Mon Jun 17 10:45:34 2024] ext4_init_reserve_inode_table2: sda1, 5, 0, 0, 4096
              [Mon Jun 17 10:45:34 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts:
              [Mon Jun 17 10:45:35 2024] ext4_init_reserve_inode_table0: sdb1, 5
              [Mon Jun 17 10:45:35 2024] ext4_init_reserve_inode_table2: sdb1, 5, 0, 0, 4096
              [Mon Jun 17 10:45:35 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts:
              [Mon Jun 17 10:45:37 2024] ext4_init_reserve_inode_table0: md9, 5
              [Mon Jun 17 10:45:37 2024] ext4_init_reserve_inode_table2: md9, 5, 0, 0, 4096
              [Mon Jun 17 10:45:37 2024] EXT4-fs (md9): mounted filesystem with ordered data mode. Opts: data=ordered,barrier=1,nodelalloc
              [Mon Jun 17 10:45:59 2024] ext4_init_reserve_inode_table0: dm-9, 3
              [Mon Jun 17 10:45:59 2024] ext4_init_reserve_inode_table2: dm-9, 3, 0, 0, 4096
              [Mon Jun 17 10:45:59 2024] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: data=ordered,barrier=1,nodelalloc
              [Mon Jun 17 10:46:01 2024] ext4_init_reserve_inode_table0: dm-10, 16384
              [Mon Jun 17 10:46:01 2024] ext4_init_reserve_inode_table2: dm-10, 16384, 0, 0, 4096
              [Mon Jun 17 10:46:01 2024] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv1,user_xattr,data=ordered,data_err=abort,delalloc,nopriv,nodiscard,noacl
              [Mon Jun 17 10:46:31 2024] ext4_init_reserve_inode_table0: md13, 4
              [Mon Jun 17 10:46:31 2024] ext4_init_reserve_inode_table2: md13, 4, 0, 0, 4096
              [Mon Jun 17 10:46:31 2024] EXT4-fs (md13): mounted filesystem with ordered data mode. Opts: data=ordered,barrier=1,nodelalloc
              Show mounted filesystems:
              TARGET                       SOURCE        FSTYPE  OPTIONS
              /                            overlay        overlay rw,relatime,lowerdir=/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/MDHKLBLUOMLN2IILOFEXVPWYYR:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/2ICE3G26USP5NVPMCAZAKLR7QQ:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/THNQILDZ73V37ZFKX6VX23X4BY:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/3ZLNKDMCAM2YLLX5LIU7XPTNBF:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/ISHGEGZOH5RJTOVYFE6GKWKISP:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/DNRLD6YXALLPP3ZK2YQ5YUIQBI:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/KZGMW2LGI43JH2MTIU7PJIK43K:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/5KCKSNRENQGGKOZQ3FADL5PJGN:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/EPZS54GJUP6UPVN4LGTQSWAXYJ:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/A6DLUQC6XKOHDPFDKCGXMAGJY3:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/QMPGN475LYPBAAFOF7U6KZKVOE,upperdir=/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/c701b5d32457903c401059c6196702636a20c8bf6d5d3bf1700624fccf18ab85/diff,workdir=/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/c701b5d32457903c401059c6196702636a20c8bf6d5d3bf1700624fccf18ab85/work
              |-/proc                      proc        proc    rw,nosuid,nodev,noexec,relatime
              |-/dev                       tmpfs        tmpfs   rw,nosuid,size=65536k,mode=755
              | |-/dev/console             devpts[/0]        devpts  rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
              | |-/dev/pts                 devpts        devpts  rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
              | |-/dev/mqueue              mqueue        mqueue  rw,nosuid,nodev,noexec,relatime
              | `-/dev/shm                 shm        tmpfs   rw,nosuid,nodev,noexec,relatime,size=65536k
              |-/sys                       sysfs        sysfs   rw,nosuid,nodev,noexec,relatime
              | `-/sys/fs/cgroup           tmpfs        tmpfs   rw,nosuid,nodev,noexec,relatime,mode=755
              |   |-/sys/fs/cgroup/memory  none[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,memory
              |   |-/sys/fs/cgroup/cpu     cpu[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,cpu
              |   |-/sys/fs/cgroup/cpuset  cgroup[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,cpuset
              |   |-/sys/fs/cgroup/cpuacct cgroup[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,cpuacct
              |   |-/sys/fs/cgroup/blkio   cgroup[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,blkio
              |   |-/sys/fs/cgroup/devices cgroup[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,devices
              |   |-/sys/fs/cgroup/freezer cgroup[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,freezer
              |   `-/sys/fs/cgroup/systemd cgroup[/docker/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd]        cgroup  rw,nosuid,nodev,noexec,relatime,name=systemd
              |-/opt/iobroker              /dev/mapper/cachedev1[/Docker/iobroker-data]        ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
              |-/etc/resolv.conf           /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd/resolv.conf] ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
              |-/etc/hostname              /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd/hostname]    ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
              `-/etc/hosts                 /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fa94f29901b66cc16330b8e7e6d27954e7bac673a56443148c226d9e3034a1dd/hosts]       ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
              /var:
              35M     /var/
              32M     /var/lib
              17M     /var/lib/apt/lists
              17M     /var/lib/apt
              15M     /var/lib/dpkg
              /opt/iobroker/backups:
              115M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              717M    /opt/iobroker/iobroker-data/
              370M    /opt/iobroker/iobroker-data/files
              138M    /opt/iobroker/iobroker-data/files/javascript.admin
              118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              118M    /opt/iobroker/iobroker-data/backup-objects
              130M    /opt/iobroker/iobroker-data/states.jsonl
              100M    /opt/iobroker/iobroker-data/objects.jsonl
              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.17.1
              /usr/bin/node           v18.17.1
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              /usr/bin/corepack       0.18.0
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main armhf Packages
                      500 http://security.debian.org/debian-security bullseye-security/main armhf Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.13.16
              javascript:     8.3.1
              nodejs modules from github:     0
              Adapter State
                system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
                system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
                system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                system.adapter.exchangerates.0          : exchangerates         : ioBroker                                 - disabled
                system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 - disabled
                system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
                system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
                system.adapter.mihome.0                 : mihome                : ioBroker                                 - disabled, port: 9898, bind: 192.168.1.126
                system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
                system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
                system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
                system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
                system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                system.adapter.tankerkoenig.1           : tankerkoenig          : ioBroker                                 -  enabled
                system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
                system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                system.adapter.unifi-protect.0          : unifi-protect         : ioBroker                                 -  enabled
                system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8080, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "exchangerates": 0.1.0    , installed 0.1.0
              Adapter    "hmip"         : 1.22.0   , installed 1.22.0
              Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
              Adapter    "hue"          : 3.11.0   , installed 3.11.0
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "javascript"   : 8.3.1    , installed 8.3.1
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "parser"       : 2.1.0    , installed 2.1.0
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "radar2"       : 2.2.0    , installed 2.2.0
              Adapter    "scenes"       : 3.0.4    , installed 3.0.4
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "telegram"     : 3.3.2    , installed 3.3.2
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.15.0   , installed 3.15.0
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "unifi-protect": 1.0.0    , installed 1.0.0
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
              Adapter    "ws"           : 2.6.1    , installed 2.6.1
              Objects and States
              Objects:        126664
              States:         94109
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
              W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
              W: Some index files failed to download. They have been ignored, or old ones used instead.
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Get:4 https://apt.grafana.com stable InRelease [7661 B]
              Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
              Err:4 https://apt.grafana.com stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.11:40015        0.0.0.0:*               LISTEN      0          459951     -
              udp        0      0 127.0.0.11:35908        0.0.0.0:*                           0          459950     -
              2024-06-17 15:14:20.034  - info: host.ioBroker Adapter ical still running
              2024-06-17 15:14:21.583  - info: ical.0 (8199) processing URL: Tischtennis https://calendar.google.com/calendar/ical/6665d41eb9d239670dce8598134a649540a6418044fbe94836e76fac45281ffd%40group.calendar.google.com/public/basic.ics
              2024-06-17 15:14:21.742  - info: ical.0 (8199) processing URL: Geburtstage https://calendar.google.com/calendar/ical/5cpno4mivk581uvsid5vfunrt4%40group.calendar.google.com/public/basic.ics
              2024-06-17 15:14:22.090  - info: ical.0 (8199) processing URL: Muellkalender https://calendar.google.com/calendar/ical/4s5ukspsqbuurvbssflvleacoo%40group.calendar.google.com/public/basic.ics
              2024-06-17 15:14:22.692  - info: ical.0 (8199) processing URL: Feiertage https://calendar.google.com/calendar/ical/e63ctps0hbjl1o21hrhihc671g%40group.calendar.google.com/public/basic.ics
              2024-06-17 15:14:22.913  - info: ical.0 (8199) processing URL: Termine https://calendar.google.com/calendar/ical/j5pqrgg9uin4kh8kedp3jkhk58%40group.calendar.google.com/public/basic.ics
              2024-06-17 15:14:36.184  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:14:36.204  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:14:51.188  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:14:51.209  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:15:06.192  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:15:06.214  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:15:21.196  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:15:21.217  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:15:36.199  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:15:36.221  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:15:51.202  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:15:51.225  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:16:06.205  - error: ical.0 (8199) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              2024-06-17 15:16:06.230  - error: ical.0 (8199) States database error: connect ECONNREFUSED 127.0.0.1:9000
              2024-06-17 15:16:21.209  - info: ical.0 (8199) Objects database successfully reconnected
              2024-06-17 15:16:21.234  - info: ical.0 (8199) Objects database successfully reconnected
              2024-06-17 15:17:40.236  - info: ical.0 (8199) Terminated (NO_ERROR): Without reason
              2024-06-17 15:17:41.095  - warn: ical.0 (8199) get state error: Connection is closed.
              2024-06-17 15:17:41.096  - warn: ical.0 (8199) get state error: DB closed
                                      v.2024-05-22
              model name      : Annapurna Labs Alpine AL314 Quad-core ARM Cortex-A15 CPU @ 1.70GHz
              Kernel          : armv7l
              Userland        : armhf
              Docker          : v6.1.0
              Installation:           Docker
              Kernel:                 armv7l
              Userland:               32 bit
              Timezone:               CEST +0200
              User-ID:                0
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              Recommended versions are nodejs  and npm
              MEMORY:
              Mem:            8.1G        699M        5.1G        267M        2.3G        6.0G
              Swap:            23G          0B         23G
              Total:           31G        699M         28G
              ioBroker Core:          js-controller           5.0.19
                                      admin                   6.13.16
              ioBroker Status:        iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              Objects:                126664
              States:                 94109
              Size of iob-Database:
              • X
                Ist irgendetwas auffällig ?
                  @x-oli
                  Docker : v6.1.0
                  Mittlerweile sind wir bei v9.irgendwas
                  Soweit ich das verfolge.
                  • X
                    Oh je .. damit könnte das was zu tun haben ? Ich gebe zu um den Container habe ich mich nie gekümmert.
                    OK .. ich möchte das alles mal wieder auf Stand haben, bin da aber leider nicht so firm drin.
                    Backup läuft immer auf den "Heap" Fehler. Bringt es was mir eine .tar Datei von dem gesamten Container zu sichern ? Bekomme ich iobroker dann wieder integriert oder lässt das Container Update den ioBroker Ordner in Ruhe ?
                    Ein Update würde ich jetzt "so" machen:
                    docker pull iobroker/iobroker:latest
                    Passt das ?
                    Vielen Dank schon mal
                      @x-oli
                      Von Docker hab ich weiter keine Ahnung.
                      Aber die Doku dazu ist ganz gut.
                      • X
                        Ich habe jetzt mal einen neuen Container mit ioBroker (latest) erstellt. In den Admin Bereich komme ich wie sonst auch wieder rein, aber ist halt alles nackt. Jetzt bleibt die Frage wie ich die Daten vom alten Container in den Neuen bekomme.
                        • Marc Berg
                          Marc Berg Most Active @x.Oli last edited by
                          Wenn mich nicht alles täuscht, kann man unter QNAP die Container duplizieren. Damit werden alle Einstellungen inkl. der Volumes "mitgenommen". Du solltest also den alten Container beenden, duplizieren (hier das latest Image auswählen) und den neuen Container starten. Damit werden die ioBroker-Daten übernommen.
                          Vorher natürlich den neu erstellten "leeren" Container löschen.
                          • X
                            @Marc-Berg
                            Vielen Dank für den Hinweis. Das habe ich tatsächlich immer außer Acht gelassen.
                            • Container ist jetzt auf dem neuesten Stand mit den ioBroker Daten von zuvor.
                            • Situation ist leider noch immer die Gleiche --> Admin Oberfläche lädt sich tot und startet nicht
                            • beim starten des Containers gibt es jetzt aber ein paar mehr Infos --> vielleicht hilft das jemandem ? Mir ist tatsächlich schon beim alten Container aufgefallen, dass er immer an der Instanz "tankerkoenig.1" zu kämpfen hatte. Kann ich die manuell (ohne Admin Oberfläche) komplett löschen, um da einen Fehler auszuschließen ?
                            -------------------------     2024-06-17 18:09:09      -------------------------
                            -----              Welcome to your ioBroker Docker container!              -----
                            -----                    Startupscript is now running!                     -----
                            -----                          Please be patient!                          -----
                            -----                          System Information                          -----
                            -----                    arch:                armv7l                       -----
                            -----                    hostname:            ioBroker                     -----
                            -----                          Version Information                         -----
                            -----                    image:               v9.1.2                       -----
                            -----                    build:               2024-06-13T23:44:37+00:00    -----
                            -----                    node:                v18.20.3                     -----
                            -----                    npm:                 10.8.1                       -----
                            -----                        Environment Variables                         -----
                            -----                    SETGID:              1000                         -----
                            -----                    SETUID:              1000                         -----
                            -----                   Step 1 of 5: Preparing Container                   -----
                            -----             Step 2 of 5: Detecting ioBroker Installation             -----
                            Existing installation of ioBroker detected in "/opt/iobroker".
                            -----             Step 3 of 5: Checking ioBroker Installation              -----
                            (Re)setting permissions (This might take a while! Please be patient!)... Done.
                            Checking database connection... Done.
                            Hostname in ioBroker matches the hostname of this container.
                            No action required.
                            -----                Step 4 of 5: Applying Special Settings                -----
                            Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                            For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                            -----                    Step 5 of 5: ioBroker Startup                     -----
                            Starting ioBroker...
                            ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                            host.ioBroker check instance "system.adapter.admin.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.influxdb.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.javascript.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.scenes.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.telegram.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.backitup.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.alexa2.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.cloud.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.exchangerates.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.hmip.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.homeconnect.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.hue.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.ical.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.radar2.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.shelly.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.tuya.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.unifi-protect.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.unifi.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.mihome.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.mihome-vacuum.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.nuki-extended.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.discovery.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.daswetter.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.device-reminder.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.info.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.parser.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.pollenflug.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.tankerkoenig.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.text2command.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.trashschedule.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-bars.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-colorpicker.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-fancyswitch.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-hqwidgets.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-inventwo.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-jqui-mfd.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-justgage.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-rgraph.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis-timeandweather.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.vis.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.web.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.parcel.0" for host "ioBroker"
                            host.ioBroker check instance "system.adapter.tankerkoenig.1" for host "ioBroker"
                            This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            TypeError: Cannot read properties of undefined (reading 'name')
                                at Hue.getSensorChannelById (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1325:23)
                                at Hue.handleSensorUpdate (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1178:34)
                                at Hue.handleUpdate (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1154:24)
                                at HuePushClient.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1117:30)
                                at HuePushClient.emit (node:events:517:28)
                                at HuePushClient.emit (node:domain:489:12)
                                at _emit (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:287:17)
                                at parseEventStreamLine (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:302:9)
                                at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:259:11)
                                at IncomingMessage.emit (node:events:517:28)
                            Error: DB closed
                                at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                at Object.onceWrapper (node:events:632:26)
                                at Socket.emit (node:events:517:28)
                                at Socket.emit (node:domain:489:12)
                                at TCP.<anonymous> (node:net:350:12)
                            /bin/sh: 1: mdadm: not found
                            ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                            /bin/sh: 1: hcitool: not found
                            Hier mal ein aktueller Auszug von iob diag:
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                            Hardware Vendor :
                            Kernel          : armv7l
                            Userland        : 32 bit
                            Docker          : v9.1.2
                            Kernel          : armv7l
                            Userland        : 32 bit
                             18:45:05 up  7:59,  0 user,  load average: 3.81, 4.12, 3.87
                            CPU threads: 4
                            Mon Jun 17 16:45:05 UTC 2024
                            Mon Jun 17 18:45:05 CEST 2024
                            CEST +0200
                            Etc/UTC
                            root
                            HOME=/root
                            GROUPS=root
                            iobroker
                            HOME=/opt/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:            8.5G        4.4G        1.6G        280M        3.9G        4.0G
                            Swap:            24G         81K         24G
                            Total:           33G        4.4G         26G
                            Active iob-Instances:   28
                                     8097 M total memory
                                     4237 M used memory
                                     4080 M active memory
                                     2043 M inactive memory
                                     1545 M free memory
                                      278 M buffer memory
                                     3422 M swap cache
                                    23447 M total swap
                                        0 M used swap
                                    23447 M free swap
                            top - 18:45:06 up  7:59,  0 user,  load average: 3.81, 4.12, 3.87
                            Tasks:  35 total,   2 running,  33 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 23.1 us,  7.7 sy,  0.0 ni, 46.2 id, 23.1 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   8097.5 total,   1544.4 free,   4238.7 used,   3701.3 buff/cache
                            MiB Swap:  23447.2 total,  23447.2 free,      0.1 used.   3858.8 avail Mem
                            *** FILESYSTEM ***
                            overlay               overlay  2.0T   31G  2.0T   2% /
                            /dev/mapper/cachedev1 ext4     2.0T   31G  2.0T   2% /opt/iobroker
                            /                            overlay        overlay rw,relatime,lowerdir=/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/WQR5E6SXTVQJ3ES4UHWS2NJBO2:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/LGQKPLH4TJVX66HW53PEAMMOBZ:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/N6ZWQF7JHJOOMJ5GQG2BJFLYUX:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/FNXVVOHORB6MF3G6UGCLA6LXJY:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/SLN5PJ2RFME5LSHURHYVZQZXEK:/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/l/GXH372PFBBKWLGGTIW7OBOKXUY,upperdir=/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/a4cb0f3d0ee9908eddff0b52dace1fc41858a61aed339c6e85ec7255c6071ca6/diff,workdir=/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/a4cb0f3d0ee9908eddff0b52dace1fc41858a61aed339c6e85ec7255c6071ca6/work
                            |   |-/sys/fs/cgroup/memory  none[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,memory
                            |   |-/sys/fs/cgroup/cpu     cpu[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,cpu
                            |   |-/sys/fs/cgroup/cpuset  cgroup[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,cpuset
                            |   |-/sys/fs/cgroup/cpuacct cgroup[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,cpuacct
                            |   |-/sys/fs/cgroup/blkio   cgroup[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,blkio
                            |   |-/sys/fs/cgroup/devices cgroup[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,devices
                            |   |-/sys/fs/cgroup/freezer cgroup[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,freezer
                            |   `-/sys/fs/cgroup/systemd cgroup[/docker/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3]        cgroup  rw,nosuid,nodev,noexec,relatime,name=systemd
                            |-/etc/resolv.conf           /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3/resolv.conf] ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
                            |-/etc/hostname              /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3/hostname]    ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
                            `-/etc/hosts                 /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/ae954e88bb7fa7d6b47d8ebc2a5ce8d925550873c78d06e05d1720f8c20087b3/hosts]       ext4    rw,relatime,no_mbcache,(null),stripe=256,data=ordered,jqfmt=vfsv1,usrjquota=aquota.user
                            /var:
                            15M     /var/
                            13M     /var/lib/dpkg
                            13M     /var/lib
                            12M     /var/lib/dpkg/info
                            1.9M    /var/cache
                            725M    /opt/iobroker/iobroker-data/
                            134M    /opt/iobroker/iobroker-data/states.jsonl
                            104M    /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/nodejs         v18.20.3
                            /usr/bin/node           v18.20.3
                            /usr/bin/npm            10.8.1
                            /usr/bin/npx            10.8.1
                            /usr/bin/corepack       0.28.0
                            nodejs:
                              Installed: 18.20.3-1nodesource1
                              Candidate: 18.20.3-1nodesource1
                              Version table:
                             *** 18.20.3-1nodesource1 100
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     8.3.1
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                            + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
                            + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                            + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                            + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                            + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
                            + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                            + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                            + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
                            + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                            + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
                            + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                            + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
                            + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
                            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                            + system.adapter.tankerkoenig.1           : tankerkoenig          : ioBroker                                 -  enabled
                            + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                            + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                            + system.adapter.unifi-protect.0          : unifi-protect         : ioBroker                                 -  enabled
                            + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8080, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            Objects and States
                            Objects:        127333
                            States:         94827
                            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       2515595    239/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2511648    239/iobroker.js-con
                            tcp        0      0 127.0.0.11:45065        0.0.0.0:*               LISTEN      0          2489265    -
                            tcp6       0      0 :::8080                 :::*                    LISTEN      1000       2587606    685/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2564590    280/io.admin.0
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       2590846    472/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       2590847    472/io.tuya.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       2606932    449/io.shelly.0
                            udp        0      0 127.0.0.11:46114        0.0.0.0:*                           0          2489264    -
                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       2564502    438/io.radar2.0
                            2024-06-17 18:51:28.058  - info: shelly.0 (449) [authEnabled] 192.168.1.37 (shelly1pm / shelly1pm-D8BFC01A0D3F / SHSW-PM#D8BFC01A0D3F#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.069  - info: shelly.0 (449) [authEnabled] 192.168.1.173 (shelly1pm / shelly1pm-F4CFA2E3885F / SHSW-PM#F4CFA2E3885F#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.073  - info: shelly.0 (449) [authEnabled] 192.168.1.95 (shelly1pm / shelly1pm-E09806A9C7ED / SHSW-PM#E09806A9C7ED#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.103  - info: shelly.0 (449) [authEnabled] 192.168.1.49 (shelly1pm / shelly1pm-F4CFA2E3B04B / SHSW-PM#F4CFA2E3B04B#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.145  - info: shelly.0 (449) [authEnabled] 192.168.1.75 (shelly1pm / shelly1pm-F4CFA2E3AF49 / SHSW-PM#F4CFA2E3AF49#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.213  - info: shelly.0 (449) [authEnabled] 192.168.1.151 (shelly1pm / shelly1pm-8CAAB542FD4A / SHSW-PM#8CAAB542FD4A#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.218  - info: shelly.0 (449) [authEnabled] 192.168.1.52 (shelly1pm / shelly1pm-D8BFC01A09FE / SHSW-PM#D8BFC01A09FE#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.399  - info: shelly.0 (449) [authEnabled] 192.168.1.45 (shelly1pm / shelly1pm-D8BFC01A19CB / SHSW-PM#D8BFC01A19CB#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.567  - info: shelly.0 (449) [authEnabled] 192.168.1.192 (shelly1pm / shelly1pm-E89F6D851685 / SHSW-PM#E89F6D851685#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.778  - info: shelly.0 (449) [authEnabled] 192.168.1.96 (shelly1pm / shelly1pm-D8BFC019C5AC / SHSW-PM#D8BFC019C5AC#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.790  - info: shelly.0 (449) [authEnabled] 192.168.1.59 (shellyswitch25 / shellyswitch25-483FDA4DA761 / SHSW-25#483FDA4DA761#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.850  - info: shelly.0 (449) [authEnabled] 192.168.1.189 (shellyswitch25 / shellyswitch25-40F520009F32 / SHSW-25#40F520009F32#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.900  - info: shelly.0 (449) [authEnabled] 192.168.1.91 (shellyswitch25 / shellyswitch25-10521CF1375C / SHSW-25#10521CF1375C#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.930  - info: shelly.0 (449) [authEnabled] 192.168.1.42 (shellyswitch25 / shellyswitch25-483FDA4CFBD4 / SHSW-25#483FDA4CFBD4#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:28.962  - warn: parser.0 (595) Cannot read link "http://192.168.1.118/general/information.html?kind=item": AxiosError: timeout of 60000ms exceeded
                            2024-06-17 18:51:28.964  - warn: parser.0 (595) Cannot read link "http://192.168.1.118/general/information.html?kind=item": AxiosError: timeout of 60000ms exceeded
                            2024-06-17 18:51:28.990  - info: shelly.0 (449) [authEnabled] 192.168.1.114 (shelly1pm / shelly1pm-D8BFC01A1497 / SHSW-PM#D8BFC01A1497#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:29.009  - info: shelly.0 (449) [authEnabled] 192.168.1.148 (shelly1pm / shelly1pm-D8BFC019C8FF / SHSW-PM#D8BFC019C8FF#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:29.168  - info: shelly.0 (449) [authEnabled] 192.168.1.111 (shelly1pm / shelly1pm-D8BFC019C74F / SHSW-PM#D8BFC019C74F#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:29.189  - info: shelly.0 (449) [authEnabled] 192.168.1.115 (shelly1pm / shelly1pm-D8BFC01A17FD / SHSW-PM#D8BFC01A17FD#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:29.270  - info: shelly.0 (449) [authEnabled] 192.168.1.100 (shelly1pm / shelly1pm-D8BFC01A10F1 / SHSW-PM#D8BFC01A10F1#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:29.662  - info: shelly.0 (449) [authEnabled] 192.168.1.147 (shelly1pm / shelly1pm-D8BFC019C211 / SHSW-PM#D8BFC019C211#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:30.445  - info: shelly.0 (449) [authEnabled] 192.168.1.164 (shellyswitch25 / shellyswitch25-F4CFA2E0B332 / SHSW-25#F4CFA2E0B332#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:31.149  - info: shelly.0 (449) [authEnabled] 192.168.1.108 (shelly1pm / shelly1pm-D8BFC01A134D / SHSW-PM#D8BFC01A134D#1): This device is not protected via restricted login (see adapter documentation for details)
                            2024-06-17 18:51:35.084  - info: shelly.0 (449) [authEnabled] 192.168.1.109 (shelly1pm / shelly1pm-E09806A9FEBF / SHSW-PM#E09806A9FEBF#1): This device is not protected via restricted login (see adapter documentation for details)
                            und noch dazu das "Summary":
                            Kernel          : armv7l
                            Userland        : armhf
                            Docker          : v9.1.2
                            Kernel:                 armv7l
                            Userland:               32 bit
                            User-ID:                0
                            /usr/bin/npm            10.8.1
                            /usr/bin/npx            10.8.1
                            Recommended versions are nodejs 18.20.3 and npm 10.7.0
                            MEMORY:
                            Mem:            8.5G        4.5G        1.6G        280M        3.8G        4.0G
                            Swap:            24G        184K         24G
                            Total:           33G        4.5G         26G
                                                    admin                   6.13.16
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                127333
                            States:                 94827
                            111M    /opt/iobroker/iobroker-data/objects.jsonl
                            140M    /opt/iobroker/iobroker-data/states.jsonl
                            Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                            • Ro75
                              Ro75 @x.Oli last edited by
                              @x-oli deine Festplatte, dein Dateisystem hat einen Treffer.
                              Ro75.
                                CPU threads: 4
                                Die Kiste ist aber auch schon gut ausgelastet...
                                Die Fehlermeldungen kommen aber nicht vom tankerkoenig sondern von hue.
                                iob stop hue
                                und dann mal schauen was da passiert.
                                  Thomas Braun Most Active @Ro75 last edited by
                                  @ro75 sagte in ioBroker Admin und Vis startet nicht mehr:
                                  Oh, ja, das schaut nach Trouble aus. Hab ich übersehen.
                                  • X
                                    lässt sich nicht stoppen:
                                    iob stop hue
                                     Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
                                    Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                                        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23)
                                        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                    @ro75 said in ioBroker Admin und Vis startet nicht mehr:
                                    Ro75.
                                    Was genau meinte ihr damit ? Woran sehe ich das ? Sollte ich Festplatte tauschen ? Da hängt ein RAID mit 2 Platten drin.
                                    Ja das merke ich auch .. obwohl die Leistung gar nicht zu wenig ist und da eigentlich nicht viel drauf läuft.
                                      @x-oli
                                      Hier ruft das Dateisystem um Hilfe:
                                      • X
                                        Wird man sich wahrscheinlich nicht drauf verlassen können, wenn das System Fehler ausspuckt.
                                        Kann das mit meinen Problemen zu tun haben und sollte / muß die Platte getauscht werden, oder gibt es da andere Lösungen ?
                                          @x-oli
                                          Das kann auch vom RAM kommen.
                                          Google mal nach den Fehlermeldungen.
                                          • X
                                            @thomas-braun said in ioBroker Admin und Vis startet nicht mehr:
                                            sda1
                                            Guten Morgen
                                            Oh je .. das klingt nach großen Problemen. Das Thema RAM ist schnell zu testen. Ich werde heute oder morgen mal ein neues Modul einsetzen. Die Festplatten lasse ich gerade mal "intensiv" testen .. der sollte mir da ja irgendwas anzeigen wenn Sektoren kaputt sind ?!
                                            Es ist halt alles so mega langsam durch diese hohe Auslastung. Gibt es noch etwas Anderes was ich angehen und testen kann ?
                                            LG Oli
                                            Ro75 1 Reply Last reply Reply Quote 0
                                            1334
