    4. Vorsicht vor Update der FritzBox (7530ax auf 7.81)
    • MartinP
      MartinP @myssv last edited by
      Du musstest keine Credentials bei den entsprechenden Adaptern neu eintragen?
      Das hatte ich soweit ich mich Erinnere beim Update meiner 6591 auf 7.57, trotzdem sie sich durch das Update nicht geändert haben...
        myssv @MartinP last edited by myssv
        @martinp nein
        Aber jetzt ist der Fehler wieder da
        fb-checkpresence.0	2024-06-13 12:10:59.853	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2024-06-13 12:10:59.853	info	terminating
        fb-checkpresence.0	2024-06-13 12:10:59.853	info	cleaned everything up ...
        fb-checkpresence.0	2024-06-13 12:10:59.852	info	Got terminate signal TERMINATE_YOURSELF
        fb-checkpresence.0	2024-06-13 12:10:59.845	warn	onReady: Fb init: getSSLPort: DeviceInfo:1 GetSecurityPort: AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:10:59.844	warn	The user could have been blocked from the fritzbox due to authentification problems! Please stop the adapter and reboot the fritzbox. Then start and try again.
        fb-checkpresence.0	2024-06-13 12:10:53.815	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v20.14.0, js-controller: 5.0.19
        fb-checkpresence.0	2024-06-13 12:10:42.934	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath canceled
        fb-checkpresence.0	2024-06-13 12:10:42.933	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2024-06-13 12:10:42.933	info	terminating
        fb-checkpresence.0	2024-06-13 12:10:42.933	info	cleaned everything up ...
        fb-checkpresence.0	2024-06-13 12:10:42.931	info	Got terminate signal TERMINATE_YOURSELF
        fb-checkpresence.0	2024-06-13 12:10:16.321	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:10:02.317	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:09:20.282	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:08:52.252	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:08:38.246	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:07:56.215	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:07:28.190	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:07:14.182	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:06:32.144	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:06:04.115	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:05:50.108	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:05:08.071	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:04:40.043	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:04:26.036	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:03:43.998	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:03:15.972	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:03:01.965	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:02:19.929	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:01:51.899	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:01:37.891	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:00:55.856	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:00:27.827	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 12:00:13.821	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 11:59:31.784	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 11:59:03.756	warn	checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        fb-checkpresence.0	2024-06-13 11:58:49.749	warn	checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        Auch die AVM FON App verbindet sich wieder nicht.
        M Ro75 3 Replies Last reply Reply Quote 0
          myssv @myssv last edited by
          Auch eine Neueingabe der Zugangsdaten in der Instanz ändert nichts.
          • Ro75
            Ro75 @myssv last edited by
            @myssv sagte in Erledigt: Vorsicht vor Update der FritzBox (7530ax auf 7.81):
            Da stimmt was nicht.
            Ro75.
            • MartinP
              MartinP @Ro75 last edited by
              @ro75 Es könnte ja ein neues Problem in der 7.81 sein. Irgendeine Art von "Bot" detektion in der Fritzbox: Wenn zu häufig Logins erfolgen, stellt sie sich irgendwann stur
              Er hat ja das, was da empfohlen wurde schon einmal exerziert ...
              Nachdem ich gestern Abend schon mal alles neu gestartet hatte, habe ich eben die FritzBox noch einmal neu gestartet
              Ro75 1 Reply Last reply Reply Quote 0
              • Ro75
                Ro75 @MartinP last edited by
                @martinp oder es werden zu oft Daten (in Summe) via tr-064, upnp, fritzdect oder fb-checkpresence abgerufen. Welche Adapter mit Zugriff auf die FB laufen und wie diese ggfs. konfiguriert sind - ist bisher unbekannt, zumindest habe ich nichts gesehen.
                Ro75.
                  myssv @Ro75 last edited by myssv
                  @ro75 Da das Problem selbst mit der AVM FON App auftritt, werde ich im Bereich ioBroker gar nicht erst suchen. Erst Recht nicht, da direkt nach einem Neustart der FritzBox alles funktioniert.
                  Ich bin da schon mit AVM in Kontakt.
                  Das Problem war mit FritzOS 7.80 nicht vorhanden, sondern kam erst mit der 7.81.
                    Homoran Global Moderator Administrators @myssv last edited by Homoran
                    Die Logik verstehe ich nicht.
                    wenn in der 7.8.1
                    @martinp sagte in Erledigt: Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                    ist, und
                    @ro75 sagte in Erledigt: Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                    oder der fritz!fon App
                    abgerufen.
                    ein Reboot setzt die Boterkennung zurück
                    wäre in sich vollkommen schlüssig
                      myssv @Homoran last edited by myssv
                      @homoran sagte in Erledigt: Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                      Stimmt, da gebe ich Dir recht. Mein Satz oben ist Blödsinn!
                      Aber ich suche trotzdem nicht den Fehler im ioBroker 🙂
                        AVM kann es sich nicht erklären.
                        Habe denen nun mal die Zugriffe vom ioBroker aus durchgegeben:
                        Adapter: fb-checkpresence
                        alle 60 Sekunden
                        Adapter: fritzdect
                        alle 300 Sekunden
                        Adapter: tr-064
                        alle 10 Sekunden
                        Adapter: upnp
                        keine Angaben
                        Ich finde das jetzt nicht exessiv ...
                        • Ro75
                          Ro75 @myssv last edited by Ro75
                          @myssv sagte in Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                          Adapter: upnp
                          kommt drauf an, bei wie vielen dieser Datenpunkte (request) du da etwas über das "Zahnrad" (Cron) konfiguriert hast.
                          Ro75.
                          • Ro75
                            Adapter: tr-064
                            alle 10 Sekunden
                            gehe mal etwas höher, z.B. 15 Sekunden
                            Ro75.
                            • Ro75
                              Es wird aber laut Log ja nur von einem Adapter berichtet. Du hast aber insgesamt 4 Adapter aufgelistet. Also gehe ich mal davon aus, dass du die auch nutzt. Und von den 3 anderen kommt nichts im Log? Wenn nein, dann solltest du ggfs. mal bei "fb-checkpresence" näher nachfragen. Dann scheint dieser "intern" etwas auszulösen.
                              Ro75.
                                @ro75 sagte in Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                                Die sind alle hellgrau, also unbearbeitet:
                                  Testweise mal gemacht:
                                  • Ro75
                                    @myssv die Liste ist laut "Balken rechts" länger. Es betrifft aber nur alles was mit Firtzbox zu tun hat, der Rest interessiert in dem Fall nicht.
                                    Ro75.
                                      Mehr ging aber nicht in den Screenshot. Ich habe alle 7 Ebenen eingebelndet und geprüft. Alles grau 🙂
                                        Ich habe heute mal alle deaktiviert und dann die Fritz!Box neu gestartet um zu testen. Die FON App bleibt bis jetzt konstant verbunden. Das war vorher nicht der Fall.
                                        AVM prüft gerade, ob an der/den Stelle(n) was geändert wurde.
                                        • Ro75
                                          Vielleicht mal weitere User in der FB anlegen, also für Dect, TR-064 und fb-check... . Schauen was dann passiert. Wobei ich denke, das TR-064 und fb-check... das selbe intern machen werden und die gleichen Daten abfragen werden - ist nur so eine Vermutung.
                                          Ro75.
                                            Gute Idee, kann ja nicht schaden:
                                            5927
