    4. Puppeteer startet nicht mehr
      Homoran Global Moderator Administrators @Jensen last edited by
      @jensen sagte in Plötzlich ReferenceError: request is not defined:
      Sind die Sachen die hier diskutiert werden auch die Ursache, daß Puppeteer nicht mehr funktioniert?
      Was steht denn bei puppetier im (debug-) Log?
      Jensen 1 Reply Last reply Reply Quote 0
      • Jensen
        Jensen @Homoran last edited by
        Der Adapter startet gar nicht mehr.
          und
          @homoran sagte in Plötzlich ReferenceError: request is not defined:
          beim Versuch zu starten?
          • Jensen
            2024-06-18 09:23:35.235  - info: puppeteer.0 (12032) starting. Version 0.3.0 in C:/ioBroker/node_modules/iobroker.puppeteer, node: v18.19.1, js-controller: 5.0.19
            2024-06-18 09:23:35.247  - debug: puppeteer.0 (12032) Additional arguments: []
            2024-06-18 09:23:35.253  - error: puppeteer.0 (12032) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-06-18 09:23:35.253  - error: puppeteer.0 (12032) unhandled promise rejection: Could not find Chrome (ver. 126.0.6478.61). This can occur if either
             1. you did not perform an installation before running the script (e.g. `npx puppeteer browsers install chrome`) or
             2. your cache path is incorrectly configured (which is: C:\WINDOWS\system32\config\systemprofile\.cache\puppeteer).
            For (2), check out our guide on configuring puppeteer at https://pptr.dev/guides/configuration.
            2024-06-18 09:23:35.254  - error: puppeteer.0 (12032) Error: Could not find Chrome (ver. 126.0.6478.61). This can occur if either
                at ChromeLauncher.resolveExecutablePath (C:\ioBroker\node_modules\puppeteer-core\lib\cjs\puppeteer\node\ProductLauncher.js:295:27)
                at ChromeLauncher.executablePath (C:\ioBroker\node_modules\puppeteer-core\lib\cjs\puppeteer\node\ChromeLauncher.js:209:25)
                at ChromeLauncher.computeLaunchArguments (C:\ioBroker\node_modules\puppeteer-core\lib\cjs\puppeteer\node\ChromeLauncher.js:89:37)
                at async ChromeLauncher.launch (C:\ioBroker\node_modules\puppeteer-core\lib\cjs\puppeteer\node\ProductLauncher.js:70:28)
                at async PuppeteerAdapter.onReady (C:\ioBroker\node_modules\iobroker.puppeteer\build\main.js:38:20)
            2024-06-18 09:23:35.254  - error: puppeteer.0 (12032) Could not find Chrome (ver. 126.0.6478.61). This can occur if either
            2024-06-18 09:23:35.258  - info: puppeteer.0 (12032) terminating
            2024-06-18 09:23:35.258  - warn: puppeteer.0 (12032) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-06-18 09:23:35.771  - info: puppeteer.0 (12032) terminating
            Homoran Jensen 2 Replies Last reply Reply Quote 0
              @jensen ich hab das mal abgetrennt.
              Bitte Threadtitel anpassen
              • Jensen
                Jensen @Jensen last edited by
                @Homoran
                hier noch ein Log
                2024-06-18 09:31:33.525 - info: host.IpsServerWB instance system.adapter.puppeteer.0 started with pid 15660
                2024-06-18 09:31:35.556 - debug: puppeteer.0 (15660) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2024-06-18 09:31:35.588 - debug: puppeteer.0 (15660) Objects client ready ... initialize now
                2024-06-18 09:31:35.589 - debug: puppeteer.0 (15660) Objects create System PubSub Client
                2024-06-18 09:31:35.590 - debug: puppeteer.0 (15660) Objects create User PubSub Client
                2024-06-18 09:31:35.637 - debug: puppeteer.0 (15660) Objects client initialize lua scripts
                2024-06-18 09:31:35.642 - debug: puppeteer.0 (15660) Objects connected to redis: 127.0.0.1:9001
                2024-06-18 09:31:35.674 - debug: puppeteer.0 (15660) Redis States: Use Redis connection: 127.0.0.1:9000
                2024-06-18 09:31:35.693 - debug: puppeteer.0 (15660) States create System PubSub Client
                2024-06-18 09:31:35.694 - debug: puppeteer.0 (15660) States create User PubSub Client
                2024-06-18 09:31:35.721 - debug: puppeteer.0 (15660) States connected to redis: 127.0.0.1:9000
                2024-06-18 09:31:35.823 - info: puppeteer.0 (15660) starting. Version 0.3.0 in C:/ioBroker/node_modules/iobroker.puppeteer, node: v18.19.1, js-controller: 5.0.19
                2024-06-18 09:31:35.833 - debug: puppeteer.0 (15660) Additional arguments: []
                2024-06-18 09:31:35.839 - error: puppeteer.0 (15660) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-06-18 09:31:35.839 - error: puppeteer.0 (15660) unhandled promise rejection: Could not find Chrome (ver. 126.0.6478.61). This can occur if either
                2024-06-18 09:31:35.840 - error: puppeteer.0 (15660) Error: Could not find Chrome (ver. 126.0.6478.61). This can occur if either
                2024-06-18 09:31:35.840 - error: puppeteer.0 (15660) Could not find Chrome (ver. 126.0.6478.61). This can occur if either
                2024-06-18 09:31:35.845 - info: puppeteer.0 (15660) terminating
                2024-06-18 09:31:35.845 - warn: puppeteer.0 (15660) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-06-18 09:31:36.348 - info: puppeteer.0 (15660) terminating
                2024-06-18 09:31:36.432 - error: host.IpsServerWB instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2024-06-18 09:31:36.432 - info: host.IpsServerWB Restart adapter system.adapter.puppeteer.0 because enabled
                • Jensen
                  Ich habe die in den Fehlermeldungen angegebene Installation wiederholt.
                  Dann habe ich die Verzeichnisse überprüft und festgestellt, daß die vorherige Version unter
                  C:\Windows\System32\config\systemprofile.cache\puppeteer
                  lag, aber die neue im Benutzerverzeichnis
                  C:\Users\blablabla.cache\puppeteer
                  Dann habe ich den Inhalt vom Benutzerverzeichnis in das Systemverzeichnis kopiert,
                  und seitdem läuft wieder alles.
                  Vielleicht hätte eine Neuinstallation des Adapters auch zu diesem Ergebnis geführt, aber ich bin erst mal froh, daß ich wieder Images erzeugen kann, da ich das oft benutze.
                    @jensen sagte in Puppeteer startet nicht mehr:
                    dafür sind logs da!
                      Thomas Braun Most Active @Jensen last edited by Thomas Braun
                      npm Kommandos werden immer im cwd (current working directory) ausgeführt. Deswegen ist es wichtig dabei im passenden Verzeichnis zu stehen.
                      Macht man nicht, weil da symlinks nicht berücksichtigt werden.
                        @thomas-braun sagte in Puppeteer startet nicht mehr:
                        Windows
                          Gilt auch für Windooze.
                          734
