    4. Vorsicht vor Update der FritzBox (7530ax auf 7.81)
      myssv @Ro75 last edited by
      @ro75 sagte in Vorsicht vor Update der FritzBox (7530ax auf 7.81):
      Vielleicht mal weitere User in der FB anlegen, also für Dect, TR-064 und fb-check... .
      Gute Idee, kann ja nicht schaden:
        myssv last edited by
        Das war es nicht ...
        nur der fb_checkpresence wirft Fehler aus
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          Ro75 @myssv last edited by
          @myssv dann lasse testweise mal alles laufen, außer fb-checkpresence.
          Ro75.
            Hier das Fehlerpprotokoll vom Adapter
            2024-06-18 11:12:46.575  - info: fb-checkpresence.0 (170273) start fb-checkpresence.0: FRITZ!Box 7530 AX version: 256.07.81 ip-address: "192.168.115.1" - interval devices: 60 s - interval members: 30 s
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) configuration default connection: 1.WANPPPConnection.1
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) Hosts1-X_AVM-DE_GetHostListPath is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) Hosts1-X_AVM-DE_GetMeshListPath is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) Hosts1-GetSpecificHostEntry is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) DeviceInfo1-GetSecurityPort is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) WANCommonInterfaceConfig1-GetCommonLinkProperties is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) WANPPPConnection1-GetInfo is supported
            2024-06-18 11:12:46.576  - info: fb-checkpresence.0 (170273) WANIPConnection1-GetInfo is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) WLANConfiguration3-SetEnable is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) WLANConfiguration3-GetInfo is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) WLANConfiguration3-GetSecurityKeys is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) DeviceInfo1-GetInfo is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) X_AVM-DE_HostFilter-GetWANAccessByIP is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) DeviceConfig1-Reboot is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) WANPPPConnection1-ForceTermination is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
            2024-06-18 11:12:46.577  - info: fb-checkpresence.0 (170273) Layer3Forwarding1-GetDefaultConnectionService is supported
            2024-06-18 11:12:46.630  - info: fb-checkpresence.0 (170273) createGlobalObjects finished successfully
            2024-06-18 11:12:46.759  - info: fb-checkpresence.0 (170273) createMemberObjects finished successfully
            2024-06-18 11:12:48.082  - info: fb-checkpresence.0 (170273) createFbDeviceObjects finished successfully
            2024-06-18 11:12:48.082  - info: fb-checkpresence.0 (170273) states successfully subscribed
            2024-06-18 11:12:48.083  - info: fb-checkpresence.0 (170273) loop successfully started
            2024-06-18 11:12:49.343  - warn: fb-checkpresence.0 (170273) getActiveKarolin-Mirell:  Warning: The configured mac-address for member Karolin-Mirell was not found in the fritzbox. Please insert a valid mac-address!
            2024-06-18 11:12:49.343  - warn: fb-checkpresence.0 (170273) getActiveSorens-iPhone:  Warning: The configured mac-address for member Sorens-iPhone was not found in the fritzbox. Please insert a valid mac-address!
            2024-06-18 11:13:49.603  - info: fb-checkpresence.0 (170273) newActive Sonjas-iPhone false
            2024-06-18 11:41:00.085  - info: fb-checkpresence.0 (170273) newActive iPhone14-Volker false
            2024-06-18 11:44:01.334  - info: fb-checkpresence.0 (170273) newActive iPhone14-Volker true
            2024-06-18 11:45:31.894  - info: fb-checkpresence.0 (170273) newActive iPhone14-Volker false
            2024-06-18 12:12:42.349  - info: fb-checkpresence.0 (170273) newActive iPhone14-Volker true
            2024-06-18 12:58:05.726  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 12:58:47.733  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 12:59:01.738  - warn: fb-checkpresence.0 (170273) checkDevices:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 12:59:29.745  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:28:16.845  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:28:30.854  - warn: fb-checkpresence.0 (170273) checkDevices:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:28:58.875  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:38:17.505  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:38:59.537  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:39:13.543  - warn: fb-checkpresence.0 (170273) checkDevices:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:39:41.569  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:40:23.600  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:40:37.604  - warn: fb-checkpresence.0 (170273) checkDevices:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:41:05.625  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:41:47.654  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:42:01.659  - warn: fb-checkpresence.0 (170273) checkDevices:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
            2024-06-18 13:42:29.686  - warn: fb-checkpresence.0 (170273) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
              Ich habe viele Versuche gemacht, aber immer wieder kam es zu einem Verbindugsverlust bei der FON App.
              Der Support meinte zwar, es könnte eine heiße Spur sein, aber ich kann da keine feste Regel finden.
              Habe heute Morgen als letzten Schritt mal alle 4 deaktiviert und warte nun mal wieder ab.
              • Ro75
                @myssv und du hast die neu angelegten Benutzer in der FB auch auf die Adapter verteilt?
                Auch wenn du immer nur einen Adapter an hattest, wurde dann der jeweilige Benutzer geblockt? Wenn ja, lief denn ein anderer Adapter mit einem anderen User?
                Ro75.
                  @ro75 Ja, ich habe natürlich die Benutzer auch in den jeweiligen Instanzen geändert.
                  In den Logs vom ioBroker ist nach wie vor nur zu erkennen, wenn der fb_checkpresence keine Verbindung mehr hat. Die anderen Adapter schmeißen keine Fehler. Vielleicht laufen die ja auch weiter?
                  Meine Testapp war jedesmal die AVM FON-App. Die ist mir halt sehr wichtig.
                  • Ro75
                    @myssv sagte in Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                    Das wäre aber insbesondere wichtig abzuklären.
                    Ri75.
                      Für mich ist jetzt wie gesagt erst mal die FON App wichtig. Da will ich nicht noch an vielen anderen Schrauben drehen, sondern einen Fehler nach dem Anderen abklären. Und deswegen warte ich jetzt erst mal ab, wie es sich ganz ohne ioBroker Zugriff verhält.
                      • Ro75
                        @myssv wenn die anderen Adapter aber weiterhin Daten liefern, dann ist der Verursacher fb-check... Und das wäre für alles andere schon wichtig.
                        Ro75.
                          Auch wenn alle 4 Instanzen deaktiviert sind, bekomme ich den Fehler:
                          • Ro75
                            @myssv was steht denn im Systemlog der FB?
                            Ro75.
                              Sorry, war eine Falschmeldung 😞
                              Die Adapter waren doch wieder aktiv, obwohl ich sie eigentlich beendet hatte.
                              • Ro75
                                @myssv dann nochmal wiederholen. Aber unabhängig davon, was sagt das Log der FB dazu?
                                Ro75.
                                  Nichts was mich stutzig macht (außer die DNS-Störung gerade)
                                    Ich habe den Spieß nun mal umgedreht und alle Adapter angelassen.
                                    Als die FON App keine Verbindung mehr hatte, habe ich den UPNP Adapter deaktiviert und sofort hat die APP eine Verbindung bekommen.
                                    Das Spielchen mache ich jetzt mit den anderen 3 Adapter auch mal ...
                                      myssv last edited by myssv
                                      Es scheint der UPNP Adapter zu sein.
                                      Ich hatte wieder keine Verbindung mit der FON-App zur Fritzbox. Daraufhin habe ich nacheinander TR-064, fritzdect und fb-checkpresence deaktviert und die App hat keine Verbindung bekommen. Dann extra ein wenig gewartet und es nichts passiert. Dann auf eine neue Uhrzeit gewartet und dann den UPNP-Adapter deaktivert.
                                      Sofort im Anschluss hat die App die Verbindung gesucht und sich verbunden:
                                      bdf986a1-61e3-4c4e-bc25-b5283c308e70-Bildschirmfoto 2024-06-20 um 08.18.08.jpeg0f4f72a3-cbde-4d96-a366-0363565ad4b8-Bildschirmfoto 2024-06-20 um 08.18.26.jpeg 20a676d8-4d3b-4dcf-8571-f1a1303da188-Bildschirmfoto 2024-06-20 um 08.18.36.jpeg
                                      An der Uhrzeit kann man sehen, alles innerhalb einer Minute.
                                        AVM wollte nun, dass ich den ioBroker und mein NAS mal komplett herunter fahre und stromlos schalte.
                                        Dann die Fritz!Box neu starten und schauen, ob der Fehler wieder auftritt.
                                        Nach den Erfahrungen oben würde ich sagen er tritt nicht wieder auf und AVM sagt, ich soll mich an die ioBroker Community wenden ...
                                        Schaun mer mal.
                                          Homoran Global Moderator Administrators @myssv last edited by
                                          richtig!
                                          ...und AVM liest hier mit 👼
                                            myssv @Homoran last edited by
                                            @homoran sagte in Vorsicht vor Update der FritzBox (7530ax auf 7.81):
                                            Das wäre gut, dann erspare ich mir die doppelte Tipperei ...
                                            Weist Du es vom Hörensagen oder bist Du selber bei AVM?
                                            5929
