      bommel_030 @simatec last edited by
      @simatec
      Hi, ich habe mit der backitup >v3 Probleme beim sichern mein influxdb v2.
      2024-06-10 01:00:10.031	debug	Backup has started ...
      2024-06-10 01:00:20.033	debug	[iobroker/mount] nfs-mount command: "sudo mount 192.168.10.25:/volume1/backup/iobroker /opt/iobroker/backups"
      2024-06-10 01:00:20.099	debug	[iobroker/mount] mount successfully completed
      2024-06-10 01:00:20.100	debug	[iobroker/mount] done
      2024-06-10 01:00:25.722	debug	[iobroker/iobroker] host.iobroker-master 81154 states saved
      2024-06-10 01:00:27.018	debug	[iobroker/iobroker] host.iobroker-master 96012 objects saved
      2024-06-10 01:00:30.322	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_06_10-01_00_20_standard_vm_backupiobroker.tar.gz
      2024-06-10 01:00:30.322	debug	[iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
      2024-06-10 01:00:31.363	debug	[iobroker/iobroker] done
      2024-06-10 01:00:31.515	debug	[iobroker/influxDB] InfluxDB-Backup for influx_dauer is started ...
      2024-06-10 01:00:31.516	debug	[iobroker/influxDB] Start InfluxDB Backup ...
      2024-06-10 01:00:31.521	debug	[iobroker/influxDB] InfluxDB Backup tmp directory created
      2024-06-10 01:00:31.524	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-06-10 01:00:31.525	error	unhandled promise rejection: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x...
      2024-06-10 01:00:31.529	error	TypeError: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x... at validateArgumentNullCheck (node:child_process:973:11) at normalizeExecArgs (node:child_process:191:3) at Object.exec (node:child_process:233:16) at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/12-influxDB.js:79:17
      2024-06-10 01:00:31.530	error	Exception-Code: ERR_INVALID_ARG_VALUE: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x...
      2024-06-10 01:00:31.551	info	cleaned everything up...
      2024-06-10 01:00:31.552	info	terminating
      2024-06-10 01:00:31.552	debug	Plugin sentry destroyed
      2024-06-10 01:00:31.553	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-06-10 01:00:32.054	info	terminating
      2024-06-10 01:00:32.220	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-06-10 01:00:32.223	error	Caught by controller[1]: TypeError: The argument 'command' must be a string without null bytes. Received 'influx backup --bucket iobroker_never --host http://192.168.10.7:8086 -t WR`\fh\x0B\x00(Va\x00^\x0Ei\x06oByi\x009\r\x033#\x0F\x...
      2024-06-10 01:00:32.223	error	Caught by controller[1]: at validateArgumentNullCheck (node:child_process:973:11)
      2024-06-10 01:00:32.223	error	Caught by controller[1]: at normalizeExecArgs (node:child_process:191:3)
      2024-06-10 01:00:32.223	error	Caught by controller[1]: at Object.exec (node:child_process:233:16)
      2024-06-10 01:00:32.223	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/12-influxDB.js:79:17
      2024-06-10 01:00:32.223	error	instance system.adapter. terminated with code 6 (UNCAUGHT_EXCEPTION)
      Vorher läuft das Backup vom ioBroker problemlos durch, bei influx stürzt er scheinbar ab (Bekomme auch keine Benachrichtigung über einen Fehler) und führt danach problemlos das CCU Backup durch. Falls ich ein issue erstellen soll mache ich das gerne.
      • simatec
        simatec Developer Most Active @bommel_030 last edited by
        @bommel_030 Welche Version von Backitup ist installiert? Bitte poste mal deine Backitup Config als JSON
          bommel_030 @simatec last edited by bommel_030
          @simatec
          Installiert ist v3.0.2. Im JSON habe ich PW und Token unkenntlich gemacht.
          Dabei ist mir aufgefallen, die beiden Token unter "influxDBEvents" sehen "komisch" aus.
          Der unter "influxDBToken""normal":
          Wobei ich nicht weiß ob das ein Anzeigeeffekt von Notepad++ ist.
          • simatec
            @bommel_030 Bitte trage deine Token erneut in der Config ein und speichere sie.
            Danach sollte es funktionieren. In Version 3.0.1 gab es da eine Änderung.
              @simatec
              Danke, hätte ich auch selber drauf kommen können.... Mal schauen ob der Durchlauf heute Nacht noch mal meckert.
              • simatec
                @bommel_030 Kannst ja auch mit einem manuellen Backup testen
                • O
                  oFbEQnpoLKKl6mbY5e13 @simatec last edited by oFbEQnpoLKKl6mbY5e13
                  @simatec sagte in Test Adapter ioBroker.backitup v3.0.x:
                  @marc-berg Ich nehme das mal mit fürs nächste Dev Meeting mit
                  Was ist daraus geworden, denn du hast das nicht angesprochen?
                  https://forum.iobroker.net/topic/27267/test-adapter-iobroker-backitup-v3-0-x/2658
                  mcm1957 simatec 2 Replies Last reply Reply Quote 0
                  • mcm1957
                    mcm1957 @oFbEQnpoLKKl6mbY5e13 last edited by
                    @ofbeqnpolkkl6mby5e13
                    Sorry - aber warum hast DU das nicht IM Meeting angesprochen wenn du offenbar eh dabei warst? Wurde je mehrmals nachgefragt ob noch wer was hat ...
                    Schätze mal die Sache ist untergegangen ./ vergessen worden ...
                    • O
                      oFbEQnpoLKKl6mbY5e13 @mcm1957 last edited by
                      @mcm1957
                      Ich werde im Developer-Meeting nichts vortragen.
                      • mcm1957
                        Geht da ja nicht um vortragen sondern um ne Frage stellen bzw. eine potenzielles Thema anzusprechen dass dich ja interessiert. Wär ggF auch via Chat möglich gewesen. Kann mich nicht erinnern dass im Meeting schon mal wer angeschnautzt wurde weil er was gefragt / angeregt hat...
                        Schade, wär sicher sinnvoll gewesen es anzusprechen.
                        • simatec
                          simatec Developer Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
                          @ofbeqnpolkkl6mby5e13 sagte in Test Adapter ioBroker.backitup v3.0.x:
                          Eine Optimierung wurde bereits angeschoben und wird mit dem nächsten Update sicher kommen.
                          Thema ist also bereits geklärt und wurde deshalb nicht im Meeting angesprochen.
                            TT-Tom last edited by
                            @simatec
                            ich habe ein Problem mit dem Hochladen von Backupdateien.
                            das Fenster mit der Aufforderung eine Datei reinzuziehen öffnet sich, die Datei wird auch erkannt und dargestellt. Beim klick in das Fenster öffnet sich ein Dateiauswahlfenster und die gewählte Datei wird auch dann angezeigt. Was nicht funktioniert ist dann das hochladen nach dem Klick auf den Button. Das Fenster ist weg und und nur ein weißer Screen ohne Meldung. Habe schon geprüft das Popups erlaubt sind.
                            Ich nutze Safari.
                            Ist das Problem schon bekannt bzw. kann es jemand bestätigen??
                            Marc Berg simatec 2 Replies Last reply Reply Quote 0
                            • Marc Berg
                              Marc Berg Most Active @TT-Tom last edited by
                              @tt-tom sagte in Test Adapter ioBroker.backitup v3.0.x:
                              Nutzt du Container?
                                TT-Tom @Marc Berg last edited by
                                @marc-berg
                                ja, bin dabei mich mit Proxmox zu beschäftigen.
                                • Marc Berg
                                  Dann ist es wohl kein Thema, bei Docker (Bridge Netzwerk) müsste man weitere Ports mappen. Steht so auch explizit in der Backitup Doku.
                                    @marc-berg
                                    werde mal die Doku lesen, bei Proxmox gibt es doch auch Bridge Netzwerke. Bin wie gesagt am Anfang mit dem System
                                    • simatec
                                      simatec Developer Most Active @TT-Tom last edited by
                                      @simatec
                                      Ich nutze Safari.
                                      Ich habe gerade nochmal mit Chrome, Firefox und Edge getestet und es gibt bei keinem Browser Probleme.
                                      Welche Version des Adapters ist installiert? Gibt es im Debuglog eine Fehlermeldung? Schaue auch mal bitte in die Entwicklerkonsole des Browser, ob dort eventuell Fehlermeldungen kommen.
                                        TT-Tom @simatec last edited by TT-Tom
                                        @simatec
                                        ich habe zwei Tests jetzt durchgeführt.
                                        System 1: Raspi4 mit stable Versionen von JS-Controller, Admin und Backitup
                                        Log
                                        backitup.0
                                        	2024-06-21 14:13:02.448	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        backitup.0
                                        	2024-06-21 14:13:02.510	debug	Objects client ready ... initialize now
                                        backitup.0
                                        	2024-06-21 14:13:02.512	debug	Objects create System PubSub Client
                                        backitup.0
                                        	2024-06-21 14:13:02.514	debug	Objects create User PubSub Client
                                        backitup.0
                                        	2024-06-21 14:13:02.613	debug	Objects client initialize lua scripts
                                        backitup.0
                                        	2024-06-21 14:13:02.624	debug	Objects connected to redis: 127.0.0.1:9001
                                        backitup.0
                                        	2024-06-21 14:13:02.693	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                        backitup.0
                                        	2024-06-21 14:13:02.725	debug	States create System PubSub Client
                                        backitup.0
                                        	2024-06-21 14:13:02.728	debug	States create User PubSub Client
                                        backitup.0
                                        	2024-06-21 14:13:02.826	debug	States connected to redis: 127.0.0.1:9000
                                        backitup.0
                                        	2024-06-21 14:13:02.941	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                                        backitup.0
                                        	2024-06-21 14:13:03.029	debug	Plugin sentry destroyed because not initialized correctly
                                        backitup.0
                                        	2024-06-21 14:13:04.095	info	starting. Version 2.11.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.14.0, js-controller: 5.0.19
                                        backitup.0
                                        	2024-06-21 14:13:04.159	debug	Backitup has recognized a linux system
                                        backitup.0
                                        	2024-06-21 14:13:04.185	info	[iobroker] backup will be activated at 03:46 every 2 day(s)
                                        backitup.0
                                        	2024-06-21 14:13:06.888	debug	detect backup file 1 from NAS: iobroker_2024_06_15-03_46_10_IOBrocker_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:13:06.889	debug	detect backup file 2 from NAS: iobroker_2024_06_17-03_46_10_IOBrocker_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:13:06.889	debug	detect backup file 3 from NAS: iobroker_2024_06_19-03_46_10_IOBrocker_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:13:06.889	debug	detect backup file 4 from NAS: iobroker_2024_06_19-20_42_30_IOBrocker_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:13:06.890	debug	detect backup file 5 from NAS: iobroker_2024_06_21-03_49_08_IOBrocker_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:13:06.891	debug	detect last backup file: iobroker_2024_06_21-03_49_08_IOBrocker_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:13:52.811	debug	The local storage check was completed successfully. On the host "iobmaster" are currently 475349 MB free space available!
                                        backitup.0
                                        	2024-06-21 14:15:00.522	debug	Upload server Connections could not be closed
                                        backitup.0
                                        	2024-06-21 14:15:00.523	debug	Upload server Connections could not be closed
                                        backitup.0
                                        	2024-06-21 14:15:00.546	debug	Uploadserver on port 34303 started
                                        backitup.0
                                        	2024-06-21 14:17:43.645	debug	The local storage check was completed successfully. On the host "iobmaster" are currently 475348 MB free space available!
                                        backitup.0
                                        	2024-06-21 14:17:56.299	debug	Backup list be read ...
                                        backitup.0
                                        	2024-06-21 14:18:23.150	debug	Downloadserver on port 36637 started
                                        backitup.0
                                        	2024-06-21 14:18:23.172	debug	Download finish ...
                                        backitup.0
                                        	2024-06-21 14:19:17.487	debug	The local storage check was completed successfully. On the host "iobmaster" are currently 475348 MB free space available!
                                        backitup.0
                                        	2024-06-21 14:19:52.037	debug	Uploadserver is running on Port 34303...
                                        Upload ohne ersichtlichen Erfolg, wenn wo werden die Dateien abgelegt. ich gehe mal vom aktuellen Speicherort für die Backups
                                        Beim Download bekam ich diese Fehlermeldung
                                        mein zweites System ist ein Proxmox Container mit den Beta Versionen
                                        Log
                                        backitup.0
                                        	2024-06-21 14:31:21.221	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        backitup.0
                                        	2024-06-21 14:31:21.230	debug	Objects client ready ... initialize now
                                        backitup.0
                                        	2024-06-21 14:31:21.231	debug	Objects create System PubSub Client
                                        backitup.0
                                        	2024-06-21 14:31:21.231	debug	Objects create User PubSub Client
                                        backitup.0
                                        	2024-06-21 14:31:21.240	debug	Objects client initialize lua scripts
                                        backitup.0
                                        	2024-06-21 14:31:21.243	debug	Objects connected to redis: 127.0.0.1:9001
                                        backitup.0
                                        	2024-06-21 14:31:21.249	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                        backitup.0
                                        	2024-06-21 14:31:21.252	debug	States create System PubSub Client
                                        backitup.0
                                        	2024-06-21 14:31:21.253	debug	States create User PubSub Client
                                        backitup.0
                                        	2024-06-21 14:31:21.299	debug	States connected to redis: 127.0.0.1:9000
                                        backitup.0
                                        	2024-06-21 14:31:21.310	debug	Plugin sentry Initialize Plugin (enabled=true)
                                        backitup.0
                                        	2024-06-21 14:31:21.439	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.14.0, js-controller: 6.0.5
                                        backitup.0
                                        	2024-06-21 14:31:21.445	debug	BackItUp has recognized a linux system
                                        backitup.0
                                        	2024-06-21 14:31:21.458	info	[iobroker] backup will be activated at 02:40 every 2 day(s)
                                        backitup.0
                                        	2024-06-21 14:31:23.604	debug	detect backup file 1 from NAS: iobroker_2024_06_19-15_51_15_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:31:23.605	debug	detect backup file 2 from NAS: iobroker_2024_06_21-02_40_10_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:31:23.605	debug	detect last backup file: iobroker_2024_06_21-02_40_10_backupiobroker.tar.gz
                                        backitup.0
                                        	2024-06-21 14:31:57.675	debug	Reading backup list...
                                        backitup.0
                                        	2024-06-21 14:31:59.675	debug	Backup list was read: {"data":{"nas / copy":{"iobroker":[{"path":"/mnt/Stick/iobroker_2024_06_19-15_51_15_backupiobroker.tar.gz","name":"iobroker_2024_06_19-15_51_15_backupiobroker.tar.gz","size":4198492},{"path":"/mnt/Stick/iobroker_2024_06_21-02_40_10_backupiobroker.tar.gz","name":"iobroker_2024_06_21-02_40_10_backupiobroker.tar.gz","size":4197591}],"javascripts":[{"path":"/mnt/Stick/javascripts_2024_06_19-15_51_19_backupiobroker.tar.gz","name":"javascripts_2024_06_19-15_51_19_backupiobroker.tar.gz","size":400444},{"path":"/mnt/Stick/javascripts_2024_06_21-02_40_14_backupiobroker.tar.gz","name":"javascripts_2024_06_21-02_40_14_backupiobroker.tar.gz","size":400445}]}}}
                                        backitup.0
                                        	2024-06-21 14:32:04.225	debug	Download https server started on port 36933
                                        backitup.0
                                        	2024-06-21 14:32:57.538	debug	Upload server connections could not be closed
                                        backitup.0
                                        backitup.0
                                        	2024-06-21 14:32:57.541	debug	Upload https server started on port 36803
                                        der Download funktioniert ohne Probleme nach Bestätigung von Zertifikat und Popup
                                        der Upload endet nach dem Start mit einen leeren Fenster.
                                        • simatec
                                          @tt-tom ich denke dein Hauptproblem sind die Zertifikate. Entweder du erstellst mal für den iobroker gültige Zertifikate, die dein Browser / System kennt, oder wenn du iobroker nur lokal nutzt, schalte https aus.
                                          • simatec
                                            simatec Developer Most Active last edited by simatec
                                            Ab sofort steht die Version 3.0.12 auf Github und in der Beta Repo zur Verfügung.
                                            Changelog
                                            3.0.12 (2024-08-01)
                                            • (simatec) Backup Log for History added
                                            • (simatec) Added separate selection for deleting FTP backups
                                            • (simatec) Added separate selection for deleting Onedrive backups
                                            • (simatec) Added separate selection for deleting Webdav backups
                                            • (simatec) Added separate selection for deleting Dropbox backups
                                            • (simatec) Added separate selection for deleting Googledrive backups
                                            • (simatec) Improved log outputs
                                            • (simatec) Source code cleaned up
                                            • (simatec) dependencies updated
                                            Ab dieser Version speichert Backitup die Backup Logs und man kann diese im Nachhinein im Backitup Tab unter "Backup Historie" einsehen.
                                            Des Weiteren können nun für die Cloud Speicher und für FTP die Anzahl der Backups separat eingestellt werden.
                                            Man kann nur z.B. lokal 10 Backups vorhalten und in der Cloud 30 Backups.
                                            1 Reply Last reply Reply Quote 7
                                            170
                                            2780
                                            2373313
