Backitup und FritzNAS - bekomme ich nicht hin!
@thomas-braun said in Backitup und FritzNAS - bekomme ich nicht hin!:
iob diag
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: raspi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : armv7l Userland : 32 bit Systemuptime and Load: 21:47:01 up 14:10, 1 user, load average: 1.37, 0.95, 0.83 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Fri 2024-06-21 21:47:01 CEST Universal time: Fri 2024-06-21 19:47:01 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video bluetooth redis gpio i2c *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.8G 463M 0.0K 1.5G 1.8G Swap: 99M 83M 16M Total: 3.9G 1.9G 479M Active iob-Instances: 30 3786 M total memory 1846 M used memory 1158 M active memory 2051 M inactive memory 463 M free memory 89 M buffer memory 1386 M swap cache 99 M total swap 83 M used swap 16 M free swap *** top - Table Of Processes *** top - 21:47:01 up 14:10, 1 user, load average: 1.37, 0.95, 0.83 Tasks: 180 total, 2 running, 178 sleeping, 0 stopped, 0 zombie %Cpu(s): 9.0 us, 9.0 sy, 0.0 ni, 80.8 id, 0.0 wa, 0.0 hi, 1.3 si, 0.0 st MiB Mem : 3786.2 total, 463.2 free, 1846.4 used, 1476.6 buff/cache MiB Swap: 100.0 total, 16.1 free, 83.9 used. 1807.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 117G 24G 88G 21% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 758M 824K 757M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sdb1 ext4 113G 79G 29G 74% /backup /dev/sda1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 379M 16K 379M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Jun 21 07:36:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Fri Jun 21 07:36:10 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [Fri Jun 21 07:36:10 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Fri Jun 21 07:36:12 2024] EXT4-fs (sda2): re-mounted. Opts: (null) [Fri Jun 21 07:36:13 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null) Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime,stripe=8191 |-/dev devtmpfs devtmpfs rw,relatime,size=1773668k,nr_inodes=84274,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot | |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime | `-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=775416k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=387704k,nr_inodes=96926,mode=700,uid=1000,gid=1000 |-/backup /dev/sdb1 ext4 ro,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 7.9G /var/ 3.4G /var/lib 3.4G /var/cache/apt 3.4G /var/cache 3.3G /var/cache/apt/archives Archived and active journals take up 1.0G in the file system. /opt/iobroker/backups: 6.2G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.2G /opt/iobroker/iobroker-data/ 554M /opt/iobroker/iobroker-data/backup-objects 434M /opt/iobroker/iobroker-data/files 139M /opt/iobroker/iobroker-data/files/javascript.admin 118M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 41M /opt/iobroker/iobroker-data/states.json.old 41M /opt/iobroker/iobroker-data/states.json.bak 34M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 19M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f0aafe52a4ed11a13181582981d5c7-if00-port0 Your zigbee.0 COM-Port is matching 'by-id'. Very good! *** NodeJS-Installation *** /usr/bin/nodejs v18.20.3 /usr/bin/node v18.20.3 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.3-1nodesource1 Candidate: 18.20.3-1nodesource1 Version table: *** 18.20.3-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.19 admin: 6.13.16 javascript: 8.3.1 nodejs modules from github: 0 Adapter State + system.adapter.admin.1 : admin : raspi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspi - enabled + system.adapter.backitup.0 : backitup : raspi - enabled + system.adapter.chromecast.0 : chromecast : raspi - enabled + system.adapter.cloud.0 : cloud : raspi - enabled system.adapter.feiertage.0 : feiertage : raspi - enabled system.adapter.flot.0 : flot : raspi - enabled system.adapter.hue.0 : hue : raspi - disabled, port: 443 system.adapter.ical.0 : ical : raspi - enabled system.adapter.icons-icons8.0 : icons-icons8 : raspi - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspi - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi - enabled + system.adapter.javascript.0 : javascript : raspi - enabled system.adapter.luftdaten.0 : luftdaten : raspi - enabled system.adapter.luftdaten.1 : luftdaten : raspi - enabled system.adapter.mqtt.0 : mqtt : raspi - disabled, port: 1884, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : raspi - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : raspi - enabled + system.adapter.nuki.0 : nuki : raspi - enabled + system.adapter.ping.0 : ping : raspi - enabled + system.adapter.pushover.0 : pushover : raspi - enabled + system.adapter.reolink.0 : reolink : raspi - enabled + system.adapter.reolink.1 : reolink : raspi - enabled + system.adapter.reolink.2 : reolink : raspi - enabled + system.adapter.reolink.3 : reolink : raspi - enabled + system.adapter.reolink.4 : reolink : raspi - enabled + system.adapter.samsung_tizen.0 : samsung_tizen : raspi - enabled, port: 8002 + system.adapter.sayit.0 : sayit : raspi - enabled + system.adapter.sayit.1 : sayit : raspi - enabled + system.adapter.sayit.2 : sayit : raspi - enabled + system.adapter.sayit.3 : sayit : raspi - enabled + system.adapter.sayit.4 : sayit : raspi - enabled + system.adapter.sayit.5 : sayit : raspi - enabled + system.adapter.shelly.0 : shelly : raspi - enabled, port: 1885, bind: 0.0.0.0 system.adapter.shelly.1 : shelly : raspi - disabled, port: 1882, bind: 0.0.0.0 + system.adapter.signal-cmb.0 : signal-cmb : raspi - enabled + system.adapter.simple-api.0 : simple-api : raspi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.2 : sourceanalytix : raspi - enabled + system.adapter.sql.0 : sql : raspi - enabled, port: 0 system.adapter.statistics.0 : statistics : raspi - disabled + system.adapter.telegram.0 : telegram : raspi - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : raspi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspi - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : raspi - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : raspi - enabled system.adapter.vis-history.0 : vis-history : raspi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspi - enabled system.adapter.vis-justgage.0 : vis-justgage : raspi - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspi - enabled system.adapter.vis-metro.0 : vis-metro : raspi - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspi - enabled system.adapter.vis.0 : vis : raspi - enabled + system.adapter.web.0 : web : raspi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f0aafe52a4ed11a13181582981d5c7-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : raspi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.samsung_tizen.0 : samsung_tizen : raspi - enabled, port: 8002 + system.adapter.shelly.0 : shelly : raspi - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sql.0 : sql : raspi - enabled, port: 0 + system.adapter.telegram.0 : telegram : raspi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f0aafe52a4ed11a13181582981d5c7-if00-port0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.13.16 , installed 6.13.16 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "chromecast" : 3.4.0 , installed 3.4.0 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "deconz" : 1.4.1 , installed 1.4.1 Adapter "discovery" : 4.5.0 , installed 4.4.0 [Updatable] Adapter "fb-checkpresence": 1.2.4 , installed 1.2.4 Adapter "feiertage" : 1.2.0 , installed 1.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fullybrowser" : 3.0.12 , installed 3.0.12 Adapter "hue" : 3.11.0 , installed 3.11.0 Adapter "ical" : 1.15.0 , installed 1.15.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "iqontrol" : 2.3.0 , installed 2.3.0 Adapter "javascript" : 8.3.1 , installed 8.3.1 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "luftdaten" : 3.1.0 , installed 3.1.0 Adapter "moma" : 1.2.9 , installed 1.2.9 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "net-tools" : 1.0.11 , installed 1.0.11 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "nuki" : 1.6.0 , installed 1.6.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "owntracks" : 1.0.5 , installed 1.0.5 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 3.0.6 , installed 3.0.6 Adapter "reolink" : 1.1.0 , installed 1.1.0 Adapter "samsung_tizen": 1.1.0 , installed 1.1.0 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "shelly" : 7.0.0 , installed 6.9.0 [Updatable] Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.0 , installed 6.7.0 Adapter "sonoff" : 3.1.0 , installed 3.0.3 [Updatable] Adapter "spotify-premium": 1.5.0 , installed 1.5.0 Adapter "sql" : 2.2.0 , installed 2.2.0 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "telegram" : 3.3.2 , installed 3.3.2 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "vis" : 1.5.6 , installed 1.5.4 [Updatable] Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "wiobrowser" : 2.0.2 , installed 2.0.2 Adapter "ws" : 2.6.1 , installed 2.6.1 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Objects and States Please stand by - This may take a while Objects: 7520 States: 5910 *** OS-Repositories and Updates *** Hit:1 http://phoscon.de/apt/deconz bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 4 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 9985 486/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 10067 450/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 12286 1257/io.sonoff.0 tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 14999 1533/io.shelly.0 tcp 0 0 192.168.178.53:9092 0.0.0.0:* LISTEN 1001 19320 1591/io.nuki.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 11990 552/iobroker.js-con tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 110 9161 558/mariadbd tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 118 11945 460/redis-server 12 tcp6 0 0 :::8081 :::* LISTEN 1001 17436 1406/io.admin.1 tcp6 0 0 :::8082 :::* LISTEN 1001 15015 1571/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 9987 486/sshd: /usr/sbin tcp6 0 0 :::8087 :::* LISTEN 1001 20027 1819/io.simple-api. tcp6 0 0 ::1:631 :::* LISTEN 0 10066 450/cupsd tcp6 0 0 ::1:6379 :::* LISTEN 118 11946 460/redis-server 12 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13636 910/dhcpcd udp 0 0 0.0.0.0:45658 0.0.0.0:* 108 13407 358/avahi-daemon: r udp 0 0 0.0.0.0:631 0.0.0.0:* 0 10092 582/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 14788 1413/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 13405 358/avahi-daemon: r udp6 0 0 :::546 :::* 0 13715 910/dhcpcd udp6 0 0 :::5353 :::* 108 13406 358/avahi-daemon: r udp6 0 0 :::38265 :::* 108 13408 358/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-06-21 21:48:01.208 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.BM_Garage_Haustür_Radar: test 2024-06-21 21:48:01.208 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.BM_Garage_Haustür_Radar: test2 2024-06-21 21:48:01.208 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.BM_Garage_Haustür_Radar: test4 2024-06-21 21:48:01.209 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.BM_Garage_Haustür_Radar: test5 2024-06-21 21:48:02.759 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.Flur_BM: test 2024-06-21 21:48:06.490 - warn: sql.0 (1493) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found 2024-06-21 21:48:06.490 - info: sql.0 (1493) No Data 2024-06-21 21:48:09.136 - warn: sql.0 (1493) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found 2024-06-21 21:48:09.136 - info: sql.0 (1493) No Data 2024-06-21 21:48:10.636 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.Flur_BM: test 2024-06-21 21:48:10.636 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.Flur_BM: Licht Flur: an (BM) 2024-06-21 21:48:13.539 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.Flur_BM: test 2024-06-21 21:48:16.488 - warn: sql.0 (1493) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found 2024-06-21 21:48:16.489 - info: sql.0 (1493) No Data 2024-06-21 21:48:17.216 - warn: sql.0 (1493) getOneCachedData: got null states 1 times for zigbee.0.0015bc0031015219.temperature 2024-06-21 21:48:17.227 - warn: sql.0 (1493) getOneCachedData: got null states 1 times for zigbee.0.54ef4410000345bd.illuminance 2024-06-21 21:48:19.116 - warn: sql.0 (1493) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found 2024-06-21 21:48:19.116 - info: sql.0 (1493) No Data 2024-06-21 21:48:22.971 - info: zigbee.0 (1391) Device '0xec1bbdfffea186d2' announced itself 2024-06-21 21:48:25.456 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.BM_Garage_Haustür_Radar: test 2024-06-21 21:48:25.457 - info: javascript.0 (1432) script.js.common.Bewegungsmelder.BM_Garage_Haustür_Radar: test2 2024-06-21 21:48:26.501 - warn: sql.0 (1493) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found 2024-06-21 21:48:26.501 - info: sql.0 (1493) No Data 2024-06-21 21:48:29.303 - warn: sql.0 (1493) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found 2024-06-21 21:48:29.314 - info: sql.0 (1493) No Data
Bring das bald auf Debian 12 'Bookworm' in der 64Bit-Lite-Version.
Geht nur per NEUINSTALLATION. Dann halt direkt ohne Desktop-Zeuch.Updates für das OS und die ioB-Adapter noch einspielen, nodejs auf die Version 20 bringen.
iob nodejs-update 20
Geht nur per NEUINSTALLATION. Dann halt direkt ohne Desktop-Zeuch.Ja, das hattes du schon mal erwähnt. Ich scheue mich etwas davor...
Das heißt komplette Neuinstallation und iob über ein backup restoren???
Gibt es da ein workaroud?
Zudem muss ich mich mal ranmachen an die sql Fehlermeldungen. Die beziehen sich scheinbar auf verwaiste Objekte (siehe logs...) -
@brokeling sagte in Backitup und FritzNAS - bekomme ich nicht hin!:
Ja.
Was soll ein Workaround sein? Einen Wechsel der Architektur bekommst du nur per Neuinstallation hin. Davon abgesehen ist auch bei gleicher Architektur ein Upgrade von Raspberry OS 11 auf 12 nicht möglich. Dazu sind die Änderungen von der einen zur anderen Version zu groß.
Debian 11 'Bullseye' erreicht im nächsten Monat sein 'End of Life'.
Das ging aber schnell.
Komplett neu - ich glaube da hast du doch was im Werkzeugkasten.
Nicht schneller als üblich. Halt wie im Release Plan die vorgesehenen 3 Jahre ab Veröffentlichung.
Nö.
Bin grad da dran, aber es kommen viele Fehlermeldungen:
find: /backup/raspi/raspi-rsync-backup-20231002-050001/home/iobroker/.npm/_cacache/ content-v2/sha512/b9/56': Input/output error
raspi-rsync-backup
Keine Ahnung was das da genau macht.
Ist eine Nicht-Standard-Einstellung auf deinem System. -
Versuch mal die Version wie hier:
Ist das überhaupt noch wichtig, wenn ich eh bald umsteige auf bookworm? -
Nö.
Aber du könntest damit zu einer Verbesserung voniob nodejs-update
beitragen. -
Mit
Strg-C
