    3. Einsteigerfragen
    4. Installation
    5. Adapter aktualisieren
      lamo1966 @Thomas Braun last edited by lamo1966
      @thomas-braun said in Adapter aktualisieren:
      Wie schaut es beim Rest vom Fest aus?
      Copy to Clipboardiob diag
      anschauen.
      Ich hoffe das passt so, war ne ellenlange Liste.
      Die anderen updateble Adapter kann ich nicht updaten, weil der JS zu alt war.
      Bis vor 2 Stunden wusste ich noch gar nicht, was die kleine Zahl bei Adapter bedeutet :_), nur dass du weist, wie weit weg ich bin
      UNd unten steht dann was von Fehlermeldung
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.13.16 , installed 6.13.16
      Adapter "alias-manager": 1.2.6 , installed 1.2.6
      Adapter "backitup" : 2.11.0 , installed 2.11.0
      Adapter "device-watcher": 2.12.1 , installed 2.12.1
      Adapter "discovery" : 4.5.0 , installed 4.5.0
      Adapter "echarts" : 1.7.2 , installed 1.7.2
      Adapter "energiefluss" : 3.6.0 , installed 3.6.0
      Adapter "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter "history" : 3.0.1 , installed 3.0.1
      Adapter "influxdb" : 4.0.2 , installed 4.0.2
      Adapter "iqontrol" : 2.3.0 , installed 2.3.0
      Adapter "javascript" : 8.3.1 , installed 6.1.4 [Updatable]
      Controller "js-controller": 5.0.19 , installed 4.0.24 [Updatable]
      Adapter "modbus" : 6.1.0 , installed 6.1.0
      Adapter "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
      Adapter "shelly" : 7.0.0 , installed 6.9.0 [Updatable]
      Adapter "simple-api" : 2.8.0 , installed 2.8.0
      Adapter "socketio" : 6.7.0 , installed 6.7.0
      Adapter "sonoff" : 3.1.0 , installed 3.0.3 [Updatable]
      Adapter "trashschedule": 3.3.0 , installed 3.2.0 [Updatable]
      Adapter "web" : 6.2.5 , installed 6.2.5
      Adapter "ws" : 2.6.1 , installed 2.6.1
      Objects and States
      Objects: 1504
      States: 1245
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Hit:3 http://deb.debian.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
      Get:6 https://packages.grafana.com/oss/deb stable InRelease [7661 B]
      Hit:7 https://repos.influxdata.com/debian stable InRelease
        Homoran Global Moderator Administrators @lamo1966 last edited by
        @lamo1966 sagte in Adapter aktualisieren:
        nein!
        umso wichtiger alles zu zeigen
          Thomas Braun Most Active @lamo1966 last edited by
          @lamo1966
          Bitte die 'ellenlange Liste' auch vollständig bekannt geben. Mit so Schnipseln kann man sich kein Bild machen.
          Aber das Grafana-Repo kannst du schon mal richtig einstellen:
          https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
            lamo1966 @Homoran last edited by
            @homoran said in Adapter aktualisieren:
            Skript v.2024-05-22
            *** BASE SYSTEM ***
               Static hostname: Raspberry
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model		: Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             11:36:34 up 12 days, 19:28,  2 users,  load average: 0.04, 0.26, 0.28
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sat 2024-06-22 11:36:34 CEST
                       Universal time: Sat 2024-06-22 09:36:34 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            al
            XDG_CONFIG_HOME=/home/al/.config
            HOME=/home/al
            GROUPS=al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
            *** Display-Server-Setup ***
            Display-Server: true
            Desktop: 	LXDE-pi
            Terminal: 	x11
            Boot Target: 	graphical.target
            *** MEMORY ***
            Mem:            3.8G        2.5G        292M         77M        1.0G        1.3G
            Swap:            99M        2.0M         97M
            Total:          3.9G        2.5G        390M
            Active iob-Instances: 	16
                     3794 M total memory
                     2475 M used memory
                      531 M active memory
                     2746 M inactive memory
                      291 M free memory
                       81 M buffer memory
                      945 M swap cache
                       99 M total swap
                        2 M used swap
                       97 M free swap
            top - 11:36:34 up 12 days, 19:28,  2 users,  load average: 0.04, 0.26, 0.28
            Tasks: 208 total,   1 running, 207 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 12.5 us,  4.2 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3794.3 total,    291.3 free,   2476.0 used,   1027.1 buff/cache
            MiB Swap:    100.0 total,     98.0 free,      2.0 used.   1298.9 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G   11G   18G  37% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.3M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
            [Sun Jun  9 16:07:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Sun Jun  9 16:07:57 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Jun  9 16:07:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Jun  9 16:08:00 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET                       SOURCE         FSTYPE          OPTIONS
            /                            /dev/mmcblk0p2 ext4            rw,noatime
            |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
            | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
            | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
            |-/proc                      proc           proc            rw,relatime
            | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
            |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
            | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
            | `-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
            |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
            | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
            | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
            |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            3.5G	/var/
            2.9G	/var/log/journal/20caf098a3be48108459316835c16c60
            2.9G	/var/log
            305M	/var/cache
            Archived and active journals take up 2.8G in the file system.
            /opt/iobroker/backups:
            70M	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            550M	/opt/iobroker/iobroker-data/
            321M	/opt/iobroker/iobroker-data/files
            136M	/opt/iobroker/iobroker-data/history
            89M	/opt/iobroker/iobroker-data/files/echarts.admin
            80M	/opt/iobroker/iobroker-data/backup-objects
            24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
            24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
            23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
            22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/nodejs 	v18.16.0
            /usr/bin/node 		v18.16.0
            /usr/bin/npm 		9.5.1
            /usr/bin/npx 		9.5.1
            /usr/bin/corepack 	0.17.0
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
                 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
             *** 18.16.0-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller: 	4.0.24
            admin: 		6.13.16
            javascript: 	6.1.4
            nodejs modules from github: 	0
            Adapter State
            + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : Raspberry                                -  enabled
            + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
            + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
            + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberry                                -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : Raspberry                                -  enabled
            + system.adapter.history.0                : history               : Raspberry                                -  enabled
              system.adapter.influxdb.0               : influxdb              : Raspberry                                - disabled, port: 8086
            + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
            + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
            + system.adapter.modbus.0                 : modbus                : Raspberry                                -  enabled
              system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                - disabled
            + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.sonoff.0                 : sonoff                : Raspberry                                -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberry                                -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
            + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Objects and States
            Objects: 	1504
            States: 	1245
            ^C
            al@Raspberry:~ $ ^C
              Punkt 1:
              Desktop: LXDE-pi
              Auf einem Server wird kein Desktop betrieben.
              Also ausschalten.
              sudo systemctl set-default multihost.target
              Dann wie schon geschrieben das Grafana-Repo aktualisieren. Siehe oben.
              Danach die vollständige Ausgabe von iob diag nochmal.
                @lamo1966 warum abgebrochen mit CTRL-C??
                  @homoran sagte in Adapter aktualisieren:
                  Vermutlich sollte das zum kopieren dienen. Wird aber im Ternminal anders verwendet... 🙂
                    Also ausschalten.
                    da kam eine Fehlermeldung
                    hab dann aber weiter gemacht
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     14:04:30 up 12 days, 21:56,  2 users,  load average: 0.99, 0.94, 0.55
                    CPU threads: 4
                    Current issues:
                                   Local time: Sat 2024-06-22 14:04:30 CEST
                               Universal time: Sat 2024-06-22 12:04:30 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    al
                    HOME=/home/al
                    iobroker
                    HOME=/home/iobroker
                    Desktop: 	LXDE-pi
                    Terminal: 	x11
                    *** MEMORY ***
                    Mem:            3.8G        2.5G        338M         96M        958M        1.2G
                    Swap:            99M        1.0M         98M
                    Total:          3.9G        2.5G        436M
                             3794 M total memory
                             2497 M used memory
                              876 M active memory
                             2315 M inactive memory
                              338 M free memory
                               41 M buffer memory
                              916 M swap cache
                               99 M total swap
                                1 M used swap
                               98 M free swap
                    top - 14:04:31 up 12 days, 21:56,  2 users,  load average: 0.99, 0.94, 0.55
                    Tasks: 212 total,   2 running, 210 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 31.5 us,  5.5 sy,  0.0 ni, 61.6 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
                    MiB Mem :   3794.3 total,    337.4 free,   2498.0 used,    958.9 buff/cache
                    MiB Swap:    100.0 total,     98.2 free,      1.8 used.   1202.2 avail Mem
                    *** FILESYSTEM ***
                    /var:
                    3.5G	/var/
                    2.9G	/var/log
                    305M	/var/cache
                    566M	/opt/iobroker/iobroker-data/
                    23M	/opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm 		9.5.1
                    /usr/bin/npx 		9.5.1
                    E: can not open /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease - fopen (13: Permission denied)
                    E: The package lists or status file could not be parsed or opened.
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.13.16
                    javascript: 	6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects: 	1504
                    States: 	1244
                    Hit:1 https://repos.influxdata.com/debian stable InRelease
                    Hit:4 https://apt.grafana.com stable InRelease
                    Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
                    Fetched 4586 B in 2s (2302 B/s)
                    Reading package lists...
                    Pending Updates: 223
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      591/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13879      555/influxd
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1906279    196511/cupsd
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19873      2032/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19897      2082/io.sonoff.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16970      736/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16962      736/iobroker.js-con
                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15468      567/vncserver-x11-c
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      591/sshd: /usr/sbin
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1906278    196511/cupsd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        16897      543/grafana
                    tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      555/influxd
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19942      2135/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20553      1505/io.admin.0
                    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15467      567/vncserver-x11-c
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13265      406/avahi-daemon: r
                    udp        0      0 0.0.0.0:38387           0.0.0.0:*                           108        13267      406/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14877      489/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1907418    196513/cups-browsed
                    udp6       0      0 :::5353                 :::*                                108        13266      406/avahi-daemon: r
                    udp6       0      0 :::47038                :::*                                108        13268      406/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          14892      489/dhcpcd
                    2024-06-22 13:40:36.263  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                    2024-06-22 13:44:42.537  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 13:44:46.385  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                    2024-06-22 13:45:36.043  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                    2024-06-22 13:45:39.445  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                    2024-06-22 13:49:13.096  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcec444" connected!
                    2024-06-22 13:49:16.708  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.76 (shellyplusht / shellyplusht-08b61fcec444 / shellyplusht#08b61fcec444#1)
                    2024-06-22 13:49:45.965  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 13:49:49.750  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                    2024-06-22 13:50:39.572  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                    2024-06-22 13:50:42.986  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                    2024-06-22 13:54:49.468  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 13:54:53.277  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                    2024-06-22 13:55:24.912  - info: admin.0 (1505) ==> Connected system.user.admin from ::ffff:192.168.178.28
                    2024-06-22 13:55:24.917  - info: web.0 (2135) ==> Connected system.user.admin from ::ffff:192.168.178.28
                    2024-06-22 13:55:26.574  - info: web.0 (2135) ==> Connected system.user.admin from ::ffff:192.168.178.28
                    2024-06-22 13:55:43.216  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                    2024-06-22 13:55:46.805  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                    2024-06-22 13:57:55.384  - info: web.0 (2135) <== Disconnect system.user.admin from ::ffff:192.168.178.28 energiefluss.0
                    2024-06-22 13:59:53.580  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 13:59:57.356  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                    2024-06-22 14:00:46.632  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                    2024-06-22 14:00:50.190  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                    2024-06-22 14:04:57.095  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                    2024-06-22 14:05:01.361  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                      Hatte aus dem Gedächtnis geschrieben. Muss
                      sudo systemctl set-default multi-host.target
                      lauten. Und bitte keine Screenshots von Konsolentext...
                        Was haste denn da gemacht?
                        ls -la /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease
                          selbe Fehlermeldung
                          al@Raspberry:~ $ sudo systemctl set-default multi-host.target
                          Failed to set default target: Unit file multi-host.target does not exist.
                            Sorry, jetzt aber...
                            sudo systemctl set-default multi-user.target
                              ich hab bis jetzt nichts gemacht.
                              das ist das Ergebnis nach deinem Befehl
                              al@Raspberry:~ $ ls -la /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease
                              -rw-r--r-- 1 root root 4586 9. Aug 2023 /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease
                              al@Raspberry:~ $
                                @lamo1966
                                sudo apt update
                                  @lamo1966
                                  sudo apt update
                                  al@Raspberry:~ $ sudo apt update
                                  OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  OK:2 http://deb.debian.org/debian bullseye InRelease
                                  OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                                  OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:5 https://repos.influxdata.com/debian stable InRelease
                                  OK:6 https://apt.grafana.com stable InRelease
                                  Holen:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
                                  Es wurden 4.586 B in 2 s geholt (1.939 B/s).
                                  Abhängigkeitsbaum wird aufgebaut... Fertig
                                  Statusinformationen werden eingelesen... Fertig
                                  Aktualisierung für 224 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                  al@Raspberry:~ $
                                  Solll ich das noch machen, was am Ende gefragt wird?
                                  DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • DJMarc75
                                    DJMarc75 @lamo1966 last edited by
                                      Noch nicht. Zunächst:
                                      iob stop
                                      iob fix
                                      iob nodejs-update
                                      iob stop
                                      sudo reboot
                                        iob stop
                                        iob fix
                                        iob nodejs-update
                                        iob stop
                                        sudo reboot
                                        ioBroker nodejs fixer 2024-05-23
                                        Recommended nodejs-version is: 18.20.3
                                        Checking your installation now. Please be patient!
                                        Your current setup is:
                                        /usr/bin/npm 9.5.1
                                        /usr/bin/npx 9.5.1
                                        We found these nodejs versions available for installation:
                                        nodejs:
                                        Version table:
                                        Nothing to do - Your installation is using the correct paths.
                                        You are running nodejs v18.16.0. Do you want to install recommended version 18.20.3?
                                        Press <y> to continue or any other key to quit
                                        Soll ich das Y drücken?
                                          @lamo1966
                                          Ja, das ist das Ziel der Aktion.
                                            @lamo1966
                                            hab keine Ahnung, was ich da mache. Hoffe es zerreißt den Raspi nicht 😀
                                            5369
