    3. Einsteigerfragen
    4. Installation
    5. Adapter aktualisieren
      @homoran sagte in Adapter aktualisieren:
      warum abgebrochen mit CTRL-C??
      Vermutlich sollte das zum kopieren dienen. Wird aber im Ternminal anders verwendet... 🙂
        lamo1966 @Thomas Braun last edited by
        @thomas-braun said in Adapter aktualisieren:
        Also ausschalten.
        da kam eine Fehlermeldung
        hab dann aber weiter gemacht
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: Raspberry
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model		: Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         14:04:30 up 12 days, 21:56,  2 users,  load average: 0.99, 0.94, 0.55
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-06-22 14:04:30 CEST
                   Universal time: Sat 2024-06-22 12:04:30 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        al
        XDG_CONFIG_HOME=/home/al/.config
        HOME=/home/al
        GROUPS=al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop: 	LXDE-pi
        Terminal: 	x11
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.8G        2.5G        338M         96M        958M        1.2G
        Swap:            99M        1.0M         98M
        Total:          3.9G        2.5G        436M
        Active iob-Instances: 	16
                 3794 M total memory
                 2497 M used memory
                  876 M active memory
                 2315 M inactive memory
                  338 M free memory
                   41 M buffer memory
                  916 M swap cache
                   99 M total swap
                    1 M used swap
                   98 M free swap
        top - 14:04:31 up 12 days, 21:56,  2 users,  load average: 0.99, 0.94, 0.55
        Tasks: 212 total,   2 running, 210 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 31.5 us,  5.5 sy,  0.0 ni, 61.6 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
        MiB Mem :   3794.3 total,    337.4 free,   2498.0 used,    958.9 buff/cache
        MiB Swap:    100.0 total,     98.2 free,      1.8 used.   1202.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   11G   18G  37% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.3M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Sun Jun  9 16:07:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Jun  9 16:07:57 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Jun  9 16:07:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Jun  9 16:08:00 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                       SOURCE         FSTYPE          OPTIONS
        /                            /dev/mmcblk0p2 ext4            rw,noatime
        |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
        | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
        | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc           proc            rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
        | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
        |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.5G	/var/
        2.9G	/var/log/journal/20caf098a3be48108459316835c16c60
        2.9G	/var/log
        305M	/var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        70M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        566M	/opt/iobroker/iobroker-data/
        321M	/opt/iobroker/iobroker-data/files
        136M	/opt/iobroker/iobroker-data/history
        89M	/opt/iobroker/iobroker-data/files/echarts.admin
        80M	/opt/iobroker/iobroker-data/backup-objects
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M	/opt/iobroker/iobroker-data/objects.jsonl
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.16.0
        /usr/bin/node 		v18.16.0
        /usr/bin/npm 		9.5.1
        /usr/bin/npx 		9.5.1
        /usr/bin/corepack 	0.17.0
        E: can not open /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease - fopen (13: Permission denied)
        E: The package lists or status file could not be parsed or opened.
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.13.16
        javascript: 	6.1.4
        nodejs modules from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : Raspberry                                -  enabled
        + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
        + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
        + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberry                                -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : Raspberry                                -  enabled
        + system.adapter.history.0                : history               : Raspberry                                -  enabled
          system.adapter.influxdb.0               : influxdb              : Raspberry                                - disabled, port: 8086
        + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
        + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
        + system.adapter.modbus.0                 : modbus                : Raspberry                                -  enabled
          system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                - disabled
        + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : Raspberry                                -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberry                                -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
        + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 8.3.1    , installed 6.1.4  [Updatable]
        Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
        Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
        Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Objects and States
        Objects: 	1504
        States: 	1244
        Hit:1 https://repos.influxdata.com/debian stable InRelease
        Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 https://apt.grafana.com stable InRelease
        Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
        Fetched 4586 B in 2s (2302 B/s)
        Reading package lists...
        Pending Updates: 223
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      591/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13879      555/influxd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1906279    196511/cupsd
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19873      2032/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19897      2082/io.sonoff.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16970      736/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16962      736/iobroker.js-con
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15468      567/vncserver-x11-c
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      591/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1906278    196511/cupsd
        tcp6       0      0 :::3000                 :::*                    LISTEN      117        16897      543/grafana
        tcp6       0      0 :::8086                 :::*                    LISTEN      116        16428      555/influxd
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19942      2135/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20553      1505/io.admin.0
        tcp6       0      0 :::5900                 :::*                    LISTEN      0          15467      567/vncserver-x11-c
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13265      406/avahi-daemon: r
        udp        0      0 0.0.0.0:38387           0.0.0.0:*                           108        13267      406/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14877      489/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1907418    196513/cups-browsed
        udp6       0      0 :::5353                 :::*                                108        13266      406/avahi-daemon: r
        udp6       0      0 :::47038                :::*                                108        13268      406/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14892      489/dhcpcd
        2024-06-22 13:40:36.263  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
        2024-06-22 13:44:42.537  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
        2024-06-22 13:44:46.385  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
        2024-06-22 13:45:36.043  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
        2024-06-22 13:45:39.445  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
        2024-06-22 13:49:13.096  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcec444" connected!
        2024-06-22 13:49:16.708  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.76 (shellyplusht / shellyplusht-08b61fcec444 / shellyplusht#08b61fcec444#1)
        2024-06-22 13:49:45.965  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
        2024-06-22 13:49:49.750  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
        2024-06-22 13:50:39.572  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
        2024-06-22 13:50:42.986  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
        2024-06-22 13:54:49.468  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
        2024-06-22 13:54:53.277  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
        2024-06-22 13:55:24.912  - info: admin.0 (1505) ==> Connected system.user.admin from ::ffff:192.168.178.28
        2024-06-22 13:55:24.917  - info: web.0 (2135) ==> Connected system.user.admin from ::ffff:192.168.178.28
        2024-06-22 13:55:26.574  - info: web.0 (2135) ==> Connected system.user.admin from ::ffff:192.168.178.28
        2024-06-22 13:55:43.216  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
        2024-06-22 13:55:46.805  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
        2024-06-22 13:57:55.384  - info: web.0 (2135) <== Disconnect system.user.admin from ::ffff:192.168.178.28 energiefluss.0
        2024-06-22 13:59:53.580  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
        2024-06-22 13:59:57.356  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
        2024-06-22 14:00:46.632  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
        2024-06-22 14:00:50.190  - info: shelly.0 (2032) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
        2024-06-22 14:04:57.095  - info: shelly.0 (2032) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
        2024-06-22 14:05:01.361  - info: shelly.0 (2032) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
          Thomas Braun Most Active @lamo1966 last edited by
          @lamo1966 sagte in Adapter aktualisieren:
          Hatte aus dem Gedächtnis geschrieben. Muss
          sudo systemctl set-default multi-host.target
          lauten. Und bitte keine Screenshots von Konsolentext...
            Was haste denn da gemacht?
            ls -la /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease
              selbe Fehlermeldung
              al@Raspberry:~ $ sudo systemctl set-default multi-host.target
              Failed to set default target: Unit file multi-host.target does not exist.
                Sorry, jetzt aber...
                sudo systemctl set-default multi-user.target
                  ich hab bis jetzt nichts gemacht.
                  das ist das Ergebnis nach deinem Befehl
                  al@Raspberry:~ $ ls -la /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease
                  -rw-r--r-- 1 root root 4586 9. Aug 2023 /var/lib/apt/lists/deb.nodesource.com_node%5f18.x_dists_bullseye_InRelease
                  al@Raspberry:~ $
                    @lamo1966
                    sudo apt update
                      @lamo1966
                      sudo apt update
                      al@Raspberry:~ $ sudo apt update
                      OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                      OK:2 http://deb.debian.org/debian bullseye InRelease
                      OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                      OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:5 https://repos.influxdata.com/debian stable InRelease
                      OK:6 https://apt.grafana.com stable InRelease
                      Holen:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
                      Es wurden 4.586 B in 2 s geholt (1.939 B/s).
                      Abhängigkeitsbaum wird aufgebaut... Fertig
                      Statusinformationen werden eingelesen... Fertig
                      Aktualisierung für 224 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      al@Raspberry:~ $
                      Solll ich das noch machen, was am Ende gefragt wird?
                      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                      • DJMarc75
                        DJMarc75 @lamo1966 last edited by
                          Noch nicht. Zunächst:
                          iob stop
                          iob fix
                          iob nodejs-update
                          iob stop
                          sudo reboot
                            iob stop
                            iob fix
                            iob nodejs-update
                            iob stop
                            sudo reboot
                            ioBroker nodejs fixer 2024-05-23
                            Recommended nodejs-version is: 18.20.3
                            Checking your installation now. Please be patient!
                            Your current setup is:
                            /usr/bin/npm 9.5.1
                            /usr/bin/npx 9.5.1
                            We found these nodejs versions available for installation:
                            nodejs:
                            Installed: 18.16.0-deb-1nodesource1
                            Candidate: 18.17.1-deb-1nodesource1
                            Version table:
                            18.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                            *** 18.16.0-deb-1nodesource1 100
                            100 /var/lib/dpkg/status
                            12.22.12~dfsg-1~deb11u4 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                            Nothing to do - Your installation is using the correct paths.
                            You are running nodejs v18.16.0. Do you want to install recommended version 18.20.3?
                            Press <y> to continue or any other key to quit
                            Soll ich das Y drücken?
                              @lamo1966
                              Ja, das ist das Ziel der Aktion.
                                @lamo1966
                                hab keine Ahnung, was ich da mache. Hoffe es zerreißt den Raspi nicht 😀
                                  Der hängt schon schief...
                                    lamo1966 @Thomas Braun last edited by lamo1966
                                    jetzt heisst es
                                    und ich kann nichts mehr machen...aber den hast du/ich ja ausgeschaltet
                                      @lamo1966
                                      Man verwendet ja auch kein VNC sondern eine SSH-Verbindung zu seinem Server.
                                        sagt mir nichts.
                                        Ich hab jetzt auf den Raspy umgestöpselt, dort heisst es jetzt
                                        Sorry, musst da erst ein Foto machen, weil ich dort keine Befehle kenne
                                          sagt mir nichts.
                                          Dann lies dich ein.
                                          https://www.elektronik-kompendium.de/sites/raspberry-pi/2206121.htm
                                            sagt mir nichts.
                                            Dann lies dich ein.
                                            ja, das mach ich, danke für den Link.
                                            Sind wir auf der Raspi-Oberfläche fertig, oder muss ich da noch was machen?
                                            5356
