    3. Einsteigerfragen
    4. Installation
    5. Adapter aktualisieren
      lamo1966 @Thomas Braun last edited by
      @thomas-braun said in Adapter aktualisieren:
      Dann lass die halt am Computer und log dich nur per puTTY ein. Da braucht es weder Bildschirm noch Maus und Tastatur am Raspberry.
      ja, hab ich jetzt wieder so gemacht (ging ja erst mit Putty)
      al@192.168.178.86's password:
      Linux Raspberry 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sat Jun 22 14:55:53 2024
      al@Raspberry:~ $ iob update
      iob upgrade
      iob stop
      iob upgrade self
      iob start
      Used repository: stable
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.3.1    , installed 6.1.4  [Updatable]
      Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
      Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.24", required ">=5.0.0
      Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.24", required ">=5.0.19
      Update js-controller from @4.0.24 to @5.0.19
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.7.0
      Installing iobroker.js-controller@5.0.19... (System call)
      added 4 packages, removed 14 packages, and changed 38 packages in 2m
      84 packages are looking for funding
        run `npm fund` for details
      al@Raspberry:~ $
      iob upgrade
      iob stop
      iob upgrade self
      iob start
      Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.24al@Raspberry:~ $ for detailsfundinges, and changed 38 packages in 2mlled "4.0.24
        Thomas Braun Most Active @lamo1966 last edited by
        @lamo1966
        Die Befehle einzeln eingeben.
        iob stop
        iob upgrade self
        iob start
          lamo1966 @Thomas Braun last edited by lamo1966
          al@Raspberry:~ $ iob stop
          al@Raspberry:~ $ iob upgrade self
          Host    "Raspberry"      is up to date.
          al@Raspberry:~ $ iob start
          al@Raspberry:~ $
          nochmal iob diag ?
            @lamo1966
            Komische Rückmeldung. Da solllte eigentlich was anderes kommen.
            iob update
            iob upgrade
              @lamo1966
              iob update
              iob upgrade
              einzeln ?
                @lamo1966
                Ja, immer zeilenweise einzeln.
                  @lamo1966
                  iob update
                  al@Raspberry:~ $ al@Raspberry:~ $ iob update
                  iob upgrade
                  This upgrade of "trashschedule" will introduce the following changes:
                  -> 3.3.0:
                  NodeJS >= 18.x and js-controller >= 5 is required
                  * Improved error reporting / log messages
                  * Fixed translations
                  * Added Abfall+ as Webservice
                  Would you like to upgrade trashschedule from @3.2.0 to @3.3.0 now? [(y)es, (n)o]:
                  Y oder?
                  und die nächsten auch
                    @lamo1966
                    Ja, alles aktualisieren.
                      @lamo1966
                      da gehts nicht weiter, nachdem ich y eingegeben hab
                      Would you like to upgrade trashschedule from @3.2.0 to @3.3.0 now? [(y)es, (n)o]: ^Cy
                      Update trashschedule from @3.2.0 to @3.3.0
                      NPM version: 10.7.0
                      Installing iobroker.trashschedule@3.3.0... (System call)
                      al@Raspberry:~ $
                      • DJMarc75
                        DJMarc75 @lamo1966 last edited by
                        @lamo1966 sagte in Adapter aktualisieren:
                        hast Du ja auch nicht
                        ^Cy
                          lamo1966 @DJMarc75 last edited by
                          @djmarc75 said in Adapter aktualisieren:
                          ^Cy
                          danke für den Hinweis, das kommt immer, wenn ich eine Copy vom Text machen will
                          Thomas Braun L Homoran 3 Replies Last reply Reply Quote 0
                            @lamo1966
                            iob stop
                            sudo reboot
                            Und wenn die Kiste wieder oben ist mal ein
                            iob diag
                            zum Besten geben.
                              lamo1966 @lamo1966 last edited by
                              @Thomas-Braun
                              jetzt heisst es
                              This upgrade of "shelly" will introduce the following changes:
                              -> 7.0.0:
                              * Added Shelly 1 Mini (Gen3)
                              * Added Shelly 1 PM Mini (Gen3)
                              * Added Shelly PM Mini (Gen3)
                              * Added Shelly Pro Dimmer 1 PM and Pro Dimmer 2 PM
                              * Fixed Shelly Wall Display integration
                              * Added device list of ble events (receivedBy) - removed rssi state
                              * Added Switch Addon for Shelly Pro 3 EM
                              BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                              Would you like to upgrade shelly from @6.9.0 to @7.0.0 now? [(y)es, (n)o]:
                              Machen ?
                                @lamo1966
                                Ja, natürlich.
                                                          v.2024-05-22
                                     Static hostname: Raspberry
                                           Icon name: computer
                                    Operating System: Debian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  Installation:           native
                                  Kernel:                 aarch64
                                  Userland:               64 bit
                                  Timezone:               Europe/Berlin (CEST, +0200)
                                  User-ID:                1000
                                  Display-Server:         false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:
                                  /usr/bin/nodejs         v20.15.0
                                  /usr/bin/node           v20.15.0
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  /usr/bin/corepack       0.28.1
                                  Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                  MEMORY:
                                  Mem:            3.8G        976M        2.1G        1.0M        765M        2.8G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        976M        2.2G
                                  Active iob-Instances:   16
                                  Active repo(s): stable
                                  ioBroker Core:          js-controller           5.0.19
                                                          admin                   6.13.16
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                1506
                                  States:                 1248
                                  Size of iob-Database:
                                  25M     /opt/iobroker/iobroker-data/objects.jsonl
                                  5.3M    /opt/iobroker/iobroker-data/states.jsonl
                                  === Mark text until here for copying ===
                                    @lamo1966
                                    Die Zusammenfassung schaut gut aus.
                                      das war der Anfang
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Model           : Raspberry Pi 4 Model B Rev 1.5
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       16:47:48 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** Time and Time Zones ***
                                                     Local time: Sat 2024-06-22 16:47:49 CEST
                                                 Universal time: Sat 2024-06-22 14:47:49 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      al
                                      HOME=/home/al
                                      GROUPS=al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                      *** Display-Server-Setup ***
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        977M        2.0G        1.0M        766M        2.8G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        977M        2.2G
                                               3794 M total memory
                                                977 M used memory
                                               1171 M active memory
                                                432 M inactive memory
                                               2050 M free memory
                                                 62 M buffer memory
                                                703 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      top - 16:47:49 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                                      Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3794.3 total,   2049.8 free,    978.2 used,    766.4 buff/cache
                                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2756.8 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       29G   11G   17G  40% /
                                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                      tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                      [Sat Jun 22 16:40:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      [Sat Jun 22 16:40:06 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Sat Jun 22 16:40:06 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Sat Jun 22 16:40:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET                       SOURCE         FSTYPE     OPTIONS
                                      /                            /dev/mmcblk0p2 ext4       rw,noatime
                                      |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                                      | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
                                      | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
                                      |-/proc                      proc           proc       rw,relatime
                                      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                      |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                      | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
                                      |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                                      | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                                      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
                                      | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                                      `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      3.9G    /var/
                                      2.9G    /var/log/journal/20caf098a3be48108459316835c16c60
                                      2.9G    /var/log
                                      692M    /var/cache
                                      Archived and active journals take up 2.8G in the file system.
                                      /opt/iobroker/backups:
                                      70M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      654M    /opt/iobroker/iobroker-data/
                                      408M    /opt/iobroker/iobroker-data/files
                                      138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      136M    /opt/iobroker/iobroker-data/history
                                      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      nodejs:
                                        Installed: 20.15.0-1nodesource1
                                        Candidate: 20.15.0-1nodesource1
                                        Version table:
                                       *** 20.15.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                              100 /var/lib/dpkg/status
                                           20.14.0-1nodesource1 1001
                                           20.13.1-1nodesource1 1001
                                           20.13.0-1nodesource1 1001
                                           20.12.2-1nodesource1 1001
                                           20.12.1-1nodesource1 1001
                                           20.12.0-1nodesource1 1001
                                           20.11.1-1nodesource1 1001
                                           20.11.0-1nodesource1 1001
                                           20.10.0-1nodesource1 1001
                                           20.9.0-1nodesource1 1001
                                           20.8.1-1nodesource1 1001
                                           20.8.0-1nodesource1 1001
                                           20.7.0-1nodesource1 1001
                                           20.6.1-1nodesource1 1001
                                           20.6.0-1nodesource1 1001
                                           20.5.1-1nodesource1 1001
                                           20.5.0-1nodesource1 1001
                                           20.4.0-1nodesource1 1001
                                           20.3.1-1nodesource1 1001
                                           20.3.0-1nodesource1 1001
                                           20.2.0-1nodesource1 1001
                                           20.1.0-1nodesource1 1001
                                           20.0.0-1nodesource1 1001
                                           12.22.12~dfsg-1~deb11u4 500
                                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  5.0.19
                                      admin:          6.13.16
                                      javascript:     8.3.1
                                      nodejs modules from github:     0
                                      Adapter State
                                        system.adapter.alias-manager.0          : alias-manager         : Raspberry                                -  enabled
                                      + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
                                      + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                                      + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberry                                -  enabled
                                      + system.adapter.energiefluss.0           : energiefluss          : Raspberry                                -  enabled
                                      + system.adapter.history.0                : history               : Raspberry                                -  enabled
                                        system.adapter.influxdb.0               : influxdb              : Raspberry                                - disabled, port: 8086
                                      + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
                                      + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                                      + system.adapter.modbus.0                 : modbus                : Raspberry                                -  enabled
                                        system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                - disabled
                                      + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.sonoff.0                 : sonoff                : Raspberry                                -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberry                                -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      Installed ioBroker-Instances
                                      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Objects and States
                                      Objects:        1506
                                      States:         1248
                                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                      Hit:2 https://apt.grafana.com stable InRelease
                                      Hit:3 https://repos.influxdata.com/debian stable InRelease
                                      Hit:4 http://deb.debian.org/debian bullseye InRelease
                                      Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                      Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15643      570/vncserver-x11-c
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17019      1674/io.shelly.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16249      1706/io.sonoff.0
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13811      546/influxd
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16119      932/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14061      932/iobroker.js-con
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11258      529/cupsd
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15620      580/sshd: /usr/sbin
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16171      1525/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15005      1751/io.web.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      116        15940      546/influxd
                                      tcp6       0      0 :::5900                 :::*                    LISTEN      0          15642      570/vncserver-x11-c
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11257      529/cupsd
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      117        14810      540/grafana
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15622      580/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14519      497/dhcpcd
                                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16400      602/cups-browsed
                                      udp        0      0 0.0.0.0:54466           0.0.0.0:*                           108        13722      390/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13720      390/avahi-daemon: r
                                      udp6       0      0 :::546                  :::*                                0          14547      497/dhcpcd
                                      udp6       0      0 :::37421                :::*                                108        13723      390/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        13721      390/avahi-daemon: r
                                      2024-06-22 16:41:29.325  - error: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.Zaehler.DVES_88D1F8 DWS7420  energy.DWS7420_energy failed, check warn messages !
                                      2024-06-22 16:41:29.326  - info: sourceanalytix.0 (1798) Initialising (8 of 8) "alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern"
                                      2024-06-22 16:41:30.200  - info: energiefluss.0 (1813) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.15.0, js-controller: 5.0.19
                                      2024-06-22 16:41:30.236  - info: energiefluss.0 (1813) Starting Energiefluss Adapter
                                      2024-06-22 16:41:30.394  - info: energiefluss.0 (1813) Adapter started and listening to 6 States
                                      2024-06-22 16:41:30.729  - info: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern successfully
                                      2024-06-22 16:41:30.738  - warn: sourceanalytix.0 (1798) Cannot handle calculations for 5 of 8 enabled states, check error messages
                                      2024-06-22 16:41:30.739  - info: sourceanalytix.0 (1798) Successfully activated SourceAnalytix for 3 of 8 states, will do my Job until you stop me!
                                      2024-06-22 16:41:32.020  - info: host.Raspberry instance system.adapter.energiefluss-erweitert.0 started with pid 1828
                                      2024-06-22 16:41:32.529  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplug-s-4022D889A3CA" connected!
                                      2024-06-22 16:41:34.165  - info: energiefluss-erweitert.0 (1828) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.15.0, js-controller: 5.0.19
                                      2024-06-22 16:41:34.256  - info: energiefluss-erweitert.0 (1828) Adapter started. Loading config!
                                      2024-06-22 16:41:34.363  - info: energiefluss-erweitert.0 (1828) Configuration loaded!
                                      2024-06-22 16:41:34.364  - info: energiefluss-erweitert.0 (1828) Requesting the following states: energiefluss-erweitert.0.configuration
                                      2024-06-22 16:41:41.305  - info: shelly.0 (1674) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                                      2024-06-22 16:41:41.989  - info: sourceanalytix.0 (1798) Updating SourceAnalytix configuration for : shelly.0.SHEM#244CAB418C05#1.Emeter0.Power
                                      2024-06-22 16:41:55.580  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                                      2024-06-22 16:42:36.432  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                                      2024-06-22 16:42:41.050  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                                      2024-06-22 16:43:14.183  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                                      2024-06-22 16:43:18.204  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                                      2024-06-22 16:47:40.742  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                                      2024-06-22 16:47:44.478  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                                      2024-06-22 16:48:18.230  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                                      2024-06-22 16:48:21.958  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                                        @lamo1966
                                        Ja, passt.
                                        Künftig das System regelmäßig updaten.
                                        Sowohl Betriebssystem wie auch den ioBroker mit allen Bestandteilen.
                                          herzlichen Dank, du bist der Wahnsinn.
                                          Die letzte Stunde hat mich Tage meines Lebens gekostet.👍
                                            Homoran Global Moderator Administrators @lamo1966 last edited by
                                            warum?
                                            machst du STRG-c?
                                            nur markieren! Das reicht, dann ist es in der Zwischenablage. STRG-C bricht die Ausführung des laufenden Befehls ab.
                                            Frag mal Thomas! 😁
                                            5348
