    3. Einsteigerfragen
    4. Installation
    5. Adapter aktualisieren
      Thomas Braun Most Active @lamo1966 last edited by
      @lamo1966
      Die Befehle einzeln eingeben.
      iob stop
      iob upgrade self
      iob start
        lamo1966 @Thomas Braun last edited by lamo1966
        al@Raspberry:~ $ iob stop
        al@Raspberry:~ $ iob upgrade self
        Host    "Raspberry"      is up to date.
        al@Raspberry:~ $ iob start
        al@Raspberry:~ $
        nochmal iob diag ?
          @lamo1966
          Komische Rückmeldung. Da solllte eigentlich was anderes kommen.
          iob update
          iob upgrade
            @thomas-braun said in Adapter aktualisieren:
            @lamo1966
            iob update
            iob upgrade
            einzeln ?
              @lamo1966
              Ja, immer zeilenweise einzeln.
                @lamo1966
                iob update
                al@Raspberry:~ $ al@Raspberry:~ $ iob update
                Used repository: stable
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                Adapter    "javascript"   : 8.3.1    , installed 6.1.4  [Updatable]
                Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
                Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
                Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                iob upgrade
                This upgrade of "trashschedule" will introduce the following changes:
                -> 3.3.0:
                NodeJS >= 18.x and js-controller >= 5 is required
                * Improved error reporting / log messages
                * Fixed translations
                * Added Abfall+ as Webservice
                Would you like to upgrade trashschedule from @3.2.0 to @3.3.0 now? [(y)es, (n)o]:
                Y oder?
                und die nächsten auch
                  @lamo1966
                  Ja, alles aktualisieren.
                    @lamo1966
                    da gehts nicht weiter, nachdem ich y eingegeben hab
                    Would you like to upgrade trashschedule from @3.2.0 to @3.3.0 now? [(y)es, (n)o]: ^Cy
                    Update trashschedule from @3.2.0 to @3.3.0
                    NPM version: 10.7.0
                    Installing iobroker.trashschedule@3.3.0... (System call)
                    al@Raspberry:~ $
                    • DJMarc75
                      DJMarc75 @lamo1966 last edited by
                      @lamo1966 sagte in Adapter aktualisieren:
                      hast Du ja auch nicht
                      ^Cy
                        lamo1966 @DJMarc75 last edited by
                        @djmarc75 said in Adapter aktualisieren:
                        ^Cy
                        danke für den Hinweis, das kommt immer, wenn ich eine Copy vom Text machen will
                        Thomas Braun L Homoran 3 Replies Last reply Reply Quote 0
                          @lamo1966
                          iob stop
                          sudo reboot
                          Und wenn die Kiste wieder oben ist mal ein
                          iob diag
                          zum Besten geben.
                            lamo1966 @lamo1966 last edited by
                            @Thomas-Braun
                            jetzt heisst es
                            This upgrade of "shelly" will introduce the following changes:
                            -> 7.0.0:
                            * Added Shelly 1 Mini (Gen3)
                            * Added Shelly 1 PM Mini (Gen3)
                            * Added Shelly PM Mini (Gen3)
                            * Added Shelly Pro Dimmer 1 PM and Pro Dimmer 2 PM
                            * Fixed Shelly Wall Display integration
                            * Added device list of ble events (receivedBy) - removed rssi state
                            * Added Switch Addon for Shelly Pro 3 EM
                            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                            Would you like to upgrade shelly from @6.9.0 to @7.0.0 now? [(y)es, (n)o]:
                            Machen ?
                              @lamo1966
                              Ja, natürlich.
                                                        v.2024-05-22
                                   Static hostname: Raspberry
                                         Icon name: computer
                                  Operating System: Debian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v8+
                                      Architecture: arm64
                                Installation:           native
                                Kernel:                 aarch64
                                Userland:               64 bit
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000
                                Display-Server:         false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/nodejs         v20.15.0
                                /usr/bin/node           v20.15.0
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                /usr/bin/corepack       0.28.1
                                Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                MEMORY:
                                Mem:            3.8G        976M        2.1G        1.0M        765M        2.8G
                                Swap:            99M          0B         99M
                                Total:          3.9G        976M        2.2G
                                Active iob-Instances:   16
                                Active repo(s): stable
                                ioBroker Core:          js-controller           5.0.19
                                                        admin                   6.13.16
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                1506
                                States:                 1248
                                Size of iob-Database:
                                25M     /opt/iobroker/iobroker-data/objects.jsonl
                                5.3M    /opt/iobroker/iobroker-data/states.jsonl
                                === Mark text until here for copying ===
                                  @lamo1966
                                  Die Zusammenfassung schaut gut aus.
                                    das war der Anfang
                                    Skript v.2024-05-22
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Model           : Raspberry Pi 4 Model B Rev 1.5
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    Systemuptime and Load:
                                     16:47:48 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** Time and Time Zones ***
                                                   Local time: Sat 2024-06-22 16:47:49 CEST
                                               Universal time: Sat 2024-06-22 14:47:49 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    al
                                    HOME=/home/al
                                    GROUPS=al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                    *** Display-Server-Setup ***
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        977M        2.0G        1.0M        766M        2.8G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        977M        2.2G
                                             3794 M total memory
                                              977 M used memory
                                             1171 M active memory
                                              432 M inactive memory
                                             2050 M free memory
                                               62 M buffer memory
                                              703 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    top - 16:47:49 up 7 min,  2 users,  load average: 0.68, 1.04, 0.61
                                    Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   3794.3 total,   2049.8 free,    978.2 used,    766.4 buff/cache
                                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2756.8 avail Mem
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G   11G   17G  40% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                    tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                    [Sat Jun 22 16:40:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Sat Jun 22 16:40:06 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sat Jun 22 16:40:06 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Sat Jun 22 16:40:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    Show mounted filesystems:
                                    TARGET                       SOURCE         FSTYPE     OPTIONS
                                    /                            /dev/mmcblk0p2 ext4       rw,noatime
                                    |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                                    | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
                                    | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                    | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
                                    |-/proc                      proc           proc       rw,relatime
                                    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                    |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                                    | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                                    | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                    | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
                                    | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                    | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
                                    | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
                                    | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
                                    | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
                                    |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                                    | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                                    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
                                    | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                                    `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    3.9G    /var/
                                    2.9G    /var/log/journal/20caf098a3be48108459316835c16c60
                                    2.9G    /var/log
                                    692M    /var/cache
                                    Archived and active journals take up 2.8G in the file system.
                                    /opt/iobroker/backups:
                                    70M     /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    654M    /opt/iobroker/iobroker-data/
                                    408M    /opt/iobroker/iobroker-data/files
                                    138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                    136M    /opt/iobroker/iobroker-data/history
                                    118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                    USB-Devices by-id:
                                    No Devices found 'by-id'
                                    *** NodeJS-Installation ***
                                    /usr/bin/npm            10.7.0
                                    /usr/bin/npx            10.7.0
                                    nodejs:
                                      Installed: 20.15.0-1nodesource1
                                      Candidate: 20.15.0-1nodesource1
                                      Version table:
                                     *** 20.15.0-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  5.0.19
                                    admin:          6.13.16
                                    javascript:     8.3.1
                                    nodejs modules from github:     0
                                    Adapter State
                                      system.adapter.alias-manager.0          : alias-manager         : Raspberry                                -  enabled
                                    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
                                    + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                                    + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberry                                -  enabled
                                    + system.adapter.energiefluss.0           : energiefluss          : Raspberry                                -  enabled
                                    + system.adapter.history.0                : history               : Raspberry                                -  enabled
                                      system.adapter.influxdb.0               : influxdb              : Raspberry                                - disabled, port: 8086
                                    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
                                    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                                    + system.adapter.modbus.0                 : modbus                : Raspberry                                -  enabled
                                      system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                - disabled
                                    + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.sonoff.0                 : sonoff                : Raspberry                                -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberry                                -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
                                    + instance is alive
                                    ioBroker-Repositories
                                    Installed ioBroker-Instances
                                    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                    Objects and States
                                    Objects:        1506
                                    States:         1248
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 https://apt.grafana.com stable InRelease
                                    Hit:3 https://repos.influxdata.com/debian stable InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye InRelease
                                    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15643      570/vncserver-x11-c
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17019      1674/io.shelly.0
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16249      1706/io.sonoff.0
                                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13811      546/influxd
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16119      932/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14061      932/iobroker.js-con
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11258      529/cupsd
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15620      580/sshd: /usr/sbin
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16171      1525/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15005      1751/io.web.0
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      116        15940      546/influxd
                                    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15642      570/vncserver-x11-c
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11257      529/cupsd
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        14810      540/grafana
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15622      580/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14519      497/dhcpcd
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16400      602/cups-browsed
                                    udp        0      0 0.0.0.0:54466           0.0.0.0:*                           108        13722      390/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13720      390/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          14547      497/dhcpcd
                                    udp6       0      0 :::37421                :::*                                108        13723      390/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        13721      390/avahi-daemon: r
                                    2024-06-22 16:41:29.325  - error: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.Zaehler.DVES_88D1F8 DWS7420  energy.DWS7420_energy failed, check warn messages !
                                    2024-06-22 16:41:29.326  - info: sourceanalytix.0 (1798) Initialising (8 of 8) "alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern"
                                    2024-06-22 16:41:30.200  - info: energiefluss.0 (1813) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.15.0, js-controller: 5.0.19
                                    2024-06-22 16:41:30.236  - info: energiefluss.0 (1813) Starting Energiefluss Adapter
                                    2024-06-22 16:41:30.394  - info: energiefluss.0 (1813) Adapter started and listening to 6 States
                                    2024-06-22 16:41:30.729  - info: sourceanalytix.0 (1798) Initialization of alias.0.Photovoltaik.SMAx.Gesamtertrag in kWh.30531_total_eingespeiste_AC-Energie_auf_allen_Außenleitern successfully
                                    2024-06-22 16:41:30.738  - warn: sourceanalytix.0 (1798) Cannot handle calculations for 5 of 8 enabled states, check error messages
                                    2024-06-22 16:41:30.739  - info: sourceanalytix.0 (1798) Successfully activated SourceAnalytix for 3 of 8 states, will do my Job until you stop me!
                                    2024-06-22 16:41:32.020  - info: host.Raspberry instance system.adapter.energiefluss-erweitert.0 started with pid 1828
                                    2024-06-22 16:41:32.529  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplug-s-4022D889A3CA" connected!
                                    2024-06-22 16:41:34.165  - info: energiefluss-erweitert.0 (1828) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.15.0, js-controller: 5.0.19
                                    2024-06-22 16:41:34.256  - info: energiefluss-erweitert.0 (1828) Adapter started. Loading config!
                                    2024-06-22 16:41:34.363  - info: energiefluss-erweitert.0 (1828) Configuration loaded!
                                    2024-06-22 16:41:34.364  - info: energiefluss-erweitert.0 (1828) Requesting the following states: energiefluss-erweitert.0.configuration
                                    2024-06-22 16:41:41.305  - info: shelly.0 (1674) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                                    2024-06-22 16:41:41.989  - info: sourceanalytix.0 (1798) Updating SourceAnalytix configuration for : shelly.0.SHEM#244CAB418C05#1.Emeter0.Power
                                    2024-06-22 16:41:55.580  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                                    2024-06-22 16:42:36.432  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                                    2024-06-22 16:42:41.050  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                                    2024-06-22 16:43:14.183  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                                    2024-06-22 16:43:18.204  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                                    2024-06-22 16:47:40.742  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-08b61fcd5c24" connected!
                                    2024-06-22 16:47:44.478  - info: shelly.0 (1674) [MQTT] Client Close: 192.168.178.77 (shellyplusht / shellyplusht-08b61fcd5c24 / shellyplusht#08b61fcd5c24#1) (false)
                                    2024-06-22 16:48:18.230  - info: shelly.0 (1674) [MQTT] Device with client id "shellyplusht-c049ef8e1bdc" connected!
                                    2024-06-22 16:48:21.958  - info: shelly.0 (1674) [MQTT] Client Disconnect: 192.168.178.71 (shellyplusht / shellyplusht-c049ef8e1bdc / shellyplusht#c049ef8e1bdc#1)
                                      @lamo1966
                                      Ja, passt.
                                      Künftig das System regelmäßig updaten.
                                      Sowohl Betriebssystem wie auch den ioBroker mit allen Bestandteilen.
                                        herzlichen Dank, du bist der Wahnsinn.
                                        Die letzte Stunde hat mich Tage meines Lebens gekostet.👍
                                          Homoran Global Moderator Administrators @lamo1966 last edited by
                                          warum?
                                          machst du STRG-c?
                                          nur markieren! Das reicht, dann ist es in der Zwischenablage. STRG-C bricht die Ausführung des laufenden Befehls ab.
                                          Frag mal Thomas! 😁
                                          • DJMarc75
                                            Die letzte Stunde hat Dir Tage Deines Lebens gerettet !
                                            5348
